9 minutes ago, CDW said:
Gotta stay on top of carbon monoxide problems, and you did the right thing. Without an adequate warning, it can take your life before you ever know what hit you. Almost happened to me and my family a long time ago but we got lucky and realized what was happening before we were overcome in our sleep.
Thank gooodness  you spotted it in time Craig,    I checked out the official scale  and they say anything upto  6ppm  is  ok   so mine showing  1/16  of that  must just have been a trace  - possibly caused  due to us putting our  central heating rads on  first time in over 6 months  - might have detected a very fine amount of gas.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
CO is an odorless gas. Thankfully you have working monitors. Ours are wired into the house, but have battery backups. Those of us in northern climes need to pay attention to our protection devices as the heating season approaches.
Ken
Started: MS Bounty Longboat,
With all the processed materials going into building a home today, and as tight as they are making them, (no air infiltration) CO detectors are a must have....
Some parts of our environment must intercede on our behalf, it's why we put the things there....
Stay safe brother....
Quote:
Evening all,   thank you for the concerns about our gas meter  - all sorted now, batts re charged  meter re set  and now showing  zero on the display  - so its all good.
Anyway  back on with my build  - the faces  and hair  was completed  - and I have moved onto  the White belts  so far I  have  done Four  figures, will do the rest tomorrow  - I have to be honest I am slipping  again no pics, I will go and stand in the corner and  tell myself off  😊
OC.
Current builds
Completed works.
No need to stand in the corner, OC.  We've all done the same thing.
Thanks  Mark,   the photo taking should occure again later  if I remember   (what was we talking about)😁
OC.
Current builds
Completed works.
OC.
We were talking?  Oh.. hmm....  Oh well, it'll come back to me around 3 in the morning.
Evening all,  so Two evenings  (well One and a Half really)   painting the straps White  and creating a few painted on ones  on the backs  where the moulded on ones was missing.
The infill's  will be Red  and still have the bars to paint White on their  chests.
As promised  - here are a couple of pics  -
OC.
Current builds
Completed works.
Evening all,     firstly a belated  "Thank you"   for all the comments  and likes  my build is  getting  -  really means  A lot,  so  on with the build  -
I decided to work on the 5th KGL  centre company   captain,   I started by painting his single  belt for his  sword in White, then his haversack in Buff,   then I started building up his tunic Red colours  - this took a few layers  as Red ontop of a slight shiny Black primer - needs seeral layers to cover,  next was a few White details  - lots more to do to him yet.
OC.
Current builds
Completed works.
Evening all,   my 5th KGL  centre  captain  is  all finished  after giving it my normal  work flow.
Lighting is a bit harsh its not as bright as that.
OC.
Edited by Old Collingwood
Current builds
Completed works.
57 minutes ago, king derelict said:
Very nice indeed OC. Another great face
Alan
Thank you kindly Alan, on this one I was even able to pick out the White of his eyes.
OC.
Current builds
Completed works.
Evening all,   starting to paint the Red Jackets  - this needs several  light coats  as the primer has a slightly  smooth surface  and Red over Black doesn't sit all that well  - so these Four have had Two coats on so far  and still need more   - deffo not a fast production line  good  job  im not on piece work.
OC.
Current builds
Completed works.
But then, you are going for quality! and such quality it is!
Looking good😉
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Looking good😉
Thank you kindly edward.
OC.
Current builds
Completed works.
What Edward said.   Would white primer work better?  I gather you still have a herd of these guys to do.
Hi Mark,    what it is  - the Vallejo Surface Primer (even sprayed)  dries to a slightly  silky finish, and when I put my first paint layer on (again same make and base of paint - all Acrylics)  it goes on a bit like mixing oil and water,  then next layer covers better but can still  see some patchy areas then it covers normaly with the  Third or Forth coat  - it has to go on in thin layers  like watery milk  so as not to obscure the details.
The Black Primer is preferable as it is useful for creating a 3D effect on the edges of the details.
But I am searching for other Black Acrylic Primers.
OC.
Current builds
Completed works.
I found some Tamiya "Fine" primer at my local hobby shop.  It's acrylic and comes in three colors... white, gray, and black.  All they had was spray but you might check on line if they have it in bottles.    I wanted the "fine" for the brass on my model.
Thanks  Mark   worth a check out,      I know  the Vallejo Primer  is very  popular  and does work  - just takes more work with paint layers ontop of it.
OC.
Current builds
Completed works.
For anyone wanting to use Vallejo Surface Primer  - I found the following  review  quite useful   -
OC.
https://tangibleday.com/vallejo-surface-primer-for-miniatures-review-and-tips/
Current builds
Completed works.
Thinking about it - the problem might not even be with the Primer - as the White I have used was a brand new bottle  that was just diluted in my wet bowl  and that went on with no trouble  - I remember  I was having touble getting a flat finish with my Reds and Blues  before I started using a wet system - so I mixed in some  acrylic flat medium and flat coats  - I  think its the paint going on that causing the trouble  of needing several thin coats,   I thought it was funny  as  the mixed Red and Blue  when mixed with a bit of water to the right mixture, when loaded on the brush  I could not see the paint as if it was transparent.    It will  do the job  - just  taking a bit longer.
OC.
Current builds
Completed works.
Evening all,   more progress  applying the Red  coat layers  and cleaning up any over paints.
OC.
Current builds
Completed works.
Just now, king derelict said:
More great figures. Well deserved 40k views.
Alan
Thank you kindly Alan   - Wow that is some amount of views😍
OC.
Current builds
Completed works.
40K  Views   -   Thank You all  so much  for  getting it to so many views  - can't believe it  my friends.
:champagne-popping-smiley-emotic
OC.
Current builds
Completed works.
2 hours ago, Old Collingwood said:
4K  Views   -   Thank You all  so much  for  getting it to so many views  - can't believe it  my friends.
OC.
You mean 40K views right.... It's worth it my friend....
Quote:
Yes indeed brother  - still can't believe it.
Corrected it now.
OC.
Current builds
Completed works.
Evening all,  a bit more done this evening  -  Haversacks and water bottles painted,   Grey trousers  done  and  the facings done in Blue.
OC.
Current builds
Completed works.
Evening all,   another slight  update  on my 5th Line KGL   -  hands  now painted,  back packs with Grey Coats  and straps,   facings done  and details to the Shako's,   not far to go with these  than I will be back on some more 2nd KGL Light.
OC.
Current builds
Completed works.
