Red Baron by pwog - FINISHED - BlueJacket Shipcrafters - 3/8" - Lobster Boat
The painting is going slowly, as I wait 24 hours between coats. I finished the well deck and moved on to the main deck, cabin roof and pilot house roof. I decided to stray from the original color scheme and not mix the flat white paint with the Jade green. I did mix both for my first coat. Also, the difference is very subtle. The Jade Green paint is thinner and goes on so much nicer than the primer and flat white.
While waiting between coats I built the lobster traps, stained them and scratched some lobster buoys, to scale, from a dowel and bass wood.
Paul
On the Ways: Mighty Mite, Harbor Tugboat by pwog - NautiCurso - 1:64
__________________________________________________________________
Completed Builds:
Lobster Boat Red Baron (Bluejacket)
Sardine Carrier Pauline (Bluejacket)
Swampscott Dory (BlueJacket)
Link to comment
Share on other sites
Just a quick update...
I'm still in the painting process. I finally got the deck to look (probably) as good as I'm going to get it. The image shows seven coats of jade green. As I previously mentioned, the jade green was so much thinner than the other paints I've used on this boat, so far. I'm not sure if that is something that is normal across model paint manufacturers or not. I started to paint the hull a flat red and that paint is very thick compared to the jade green (all from the same manufacturer).
Paul
Completed Builds:
Link to comment
Thanks VTHoklEE! The brand is True North Precision Enamels, they came with the kit.
Paul
Completed Builds:
Link to comment
I don’t have significant experience with painting but the Humbrol paints that I’m currently trying have variation in thickness between colors. I have heard Admiralty paints may have better coverage though (?).
Link to comment
@VTHokiEE I’ve started researching acrylics for my next build.
Paul
Completed Builds:
Link to comment
James, I'm not sure what primer you are using but I've always had good luck using Krylon spray primer (grey or white) from the hardware store. It goes on pretty evenly, dries quick, sands well and forms a good base for the paint.
Tim
Current build: Continental Navy Frigate ALFRED (build log)
Past builds:     Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
Link to comment
@schooner
Hi Tim,
I think you meant to post the above to this build log:
https://modelshipworld.com/topic/25401-lobster-boat-red-baron-by-ctyankee-bluejacket-38-scale/?tab=comments#comment-757261
James is having problems with primer.
Paul
Completed Builds:
Link to comment
Your right, sorry.
BTW, is your "avatar"  photo your boat?
Tim
Link to comment
1 hour ago, schooner said:
Your right, sorry.
@schooner
No reason to apologize.
Yes, my avatar is my boat. It’s a Monk 36 trawler. They only made 254 of them. Mine is hull #077.
Paul
Completed Builds:
Link to comment
Nice looking boat! I thought it might be a Grand Banks.
There is an interesting build log of Amati's Grand Banks kit, "Grand Banks by Mindi" https://modelshipworld.com/topic/24208-grand-banks-46-by-mindi-amati-models-120/
I've been thinking of doing an RC build but I don't want to mess around laying fiberglass on a wood hull. This kit has a fiberglass hull but some very nice looking wood detailing inside and out. You could probably bash it into a good facsimile of your boat.
Tim
Link to comment
@schooner
I’ve been watching that build. I never thought of bashing it, but now you have me thinking. I probably need more experience before taking on something like that, but that would be cool having a model of my boat.
A lot of people think the Monk is a Grand Banks. They look very similar, especially the older ones. Personally, I like our layout much better than the GBs of the the same era and size. The Monk being a lot more comfortable and sensible layout.
Paul
Completed Builds:
Link to comment
I thought I would update my log, as I am still a bit mystified about the painting. I am now in the process of painting the hull. Those that have been following along will know that My painting process has been taking a while. The flat red for the hull is pretty thick, but I really like the way it is going on. The following image is after just three coats. I think one more will do it for this color.
Paul
Completed Builds:
Link to comment
Just read your log from the beginning Paul, and you're progressing nicely on this model.  Bluejacket makes a great kit, but it still requires dedication and effort (just as you are doing) to produce a really fine model.  First time builds are difficult, but going forward you will build confidence and I'm sure the end result will be beautiful.  Keep at it and watch out for rolling knives.
Gary
Completed Scratch Builds
Link to comment
Another quick update. I have completed the hull painting including marking my waterline. I strayed from the instructions, as I used Tamiya masking tape instead of the supplied pin striping tape. The instructions called for using the pin striping tape (which will also be used to make the boat topping) to mask off the waterline by rubbing the adhesive side between your fingers to decrease the holding power to minimize the tape lifting paint when removed. I didn't trust myself that I would prepare the adhesive surface adequately, so I used the Tamiya.
The image was taken as I'm waiting for the final coat of bottom paint to dry. I was so nervous about the waterline tape lifting the red paint on the hull that I couldn't wait to remove it. I'm very pleased with my result.
As much as I complained about the other paint coverage and application (see above log), the flat red and Green or Grun, as it is named, went on and covered beautifully! I am still baffled by the difference in paints across the supplied bottles. In the end I am pleased with the end result, so far. I have just a bit more painting to do.
Paul
Completed Builds:
Link to comment
49 minutes ago, VTHokiEE said:
The waterline looks sharp! Nice painting!
@VTHokiEE Thank you! I appreciate your support.
Paul
Completed Builds:
Link to comment
Almost finished with the majority of the painting. I am currently working on painting the sheer guards and toe rails.
As I’m waiting between coats I am prepping some of the other details required for fitting out the boat to complete the build.
 I framed the cabin door and scratched the hinges and door pull. I cut two small pieces of 30G .010 brass sheetIng and then cut two pieces of brass rod to make the hinges. For the door pull, I cut a piece of brass wire and bent it to shape.
Paul
Completed Builds:
Link to comment
@VTHokiEE Thanks! I got the idea from @schooner
Paul
Completed Builds:
Link to comment
Got my windows cut, mounted and framed. I’m not really happy with my job on this one. I was pondering taking it all off and trying again, but I am afraid of ruining the paint job and making an overall mess of everything. So, I decided to use it as a learning lesson. Isn’t that what first builds are for?
I would definitely use a different method when cutting plexiglass. Also, I think I need better tweezers. I don’t have any with serrated blades, so everything seems to slip a lot.
Paul
Completed Builds:
Link to comment
Really liking that paint job.
Not to push you in either direction, but first builds can also be a good time to try the repair 😉. Nice tweezer and nice files are really good tools to have. I’d consider at least filing down the frames that extend to far on the left window when you are facing them.
Link to comment
IMHO
If you are not happy now, think of how it will eat at you for the next 20 years.
If it is truly a learning lesson what is to be lost by taking it off and trying again.
Only lesson learnt is by doing it over until you're  satisfied.  If something gets damaged, do that over too.  You will be glad you did... eventually.
I was so reluctant to remove items... now I don't  think twice about it...but it did hurt the first few times.
Alan O'Neill
Link to comment
On 10/27/2020 at 8:48 AM, MrBlueJacket said:
But if you're not happy, I think it's necessary. Go for it and make yourself proud!
Ditto, Ditto, Ditto
Your model is looking very good Paul.
Gary
Link to comment
IMHO
 Many of us say that if it's worth doing, it's worth being happy about it. Welcome to the world of adjusting everything regardless of how much experience you have.   Overcoming the little problems is an extra source of joy over that provided by the kit manufactures, if that makes sense.This hobby is one of craftsmanship, making every model a unique work of art...as yours now is. I hope you get as much satisfaction from your build as we all do from ours.
Current build: Great Harry, restoration
On hold: Soliel Royale, Mantua
Completed:
Bluenose ll, Artesania Latina
San Francisco llArtesania Latina
Chris Craft barrel back triple cockpit, Dumas
Chris Craft 1940 double cockpit, Dumas
Santa Maria, Artesania Latina
1901 Scow Schooner, scratch built
Hannah, Continental Navy, scratch built
Candelaria bomb ship, OcCre
Pride of Baltimore, Model Shipways
17 foot Chesapeake kayak (2, one scratch), Midwest
USN Picket Boat #1, Model Shipways
Kobuksan, Turtle Korean ironclad, YoungModeler
HMS Revenge, scratch
NY Pilot Boat, kit bashed, Model Shipways
USS Monitor, scratch
Nuestra Senora de Afortunado, 1926 Popular Science plan, Resoration
Martha, CBMM,
Puddle Jumper, scratch stern wheeler
Lady Sarah, kit bashed Constructo Victorian launch
Link to comment
Another quick update. I painted the propeller bronze and I’m in the process of painting the rudder. Once that is done I’m going to do some tweets and touch ups and finish with adding the dry transfers for boat name, hailing port.
Happy Halloween!
Paul
Completed Builds:
Link to comment
Okay, I believe I am finished my first build. After all is said and done, I am very happy with my result. Looking closely, I can see many imperfections, some I may touch up or try to correct. It's not perfect. After all, it would be unrealistic of me to think I could be perfect my first time out. I might also say that if you've ever seen a working lobster boat, they can look very rough and sometimes scratch built. :) That being said, I have learned a lot from this build. I have started using skills that I have never tried before, especially when it came to working with wood, scratching out some details and figuring out how to do some of the tasks involved.
I would like to thank everyone following for their support. In particular, I would like to thank schooner (Tim) for his insight, ideas and guidance.
I enjoyed building this boat so much. I am looking forward to starting my next one.
Your thoughts and/or suggestions are always welcome.
IMG_2224.thumb.jpg.906cd327c74a9e9f626ecd46b26e68b7.jpgIMG_2225.thumb.jpg.8f7c9d83a5f070c69439c8290289816d.jpg
Paul
Completed Builds:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
