Great job!! Looks nothing like my 1st build! You have given me a serious case of lobster pot envy - your pots and floats are very realistic. It's amazing how details like those can really bring a model to life.
As far as you next build goes you might want to consider a planked boat, particularly one with an open interior like a rowboat, wherry, crabbing skiff, etc. Something not too expensive because it will be your 1st planking build and should be treated as a learning experience, albeit one that you can put on the shelf.
Once again, nice job!
Edited by schooner
Tim
Current build:  Syren
Past builds:    Continental Navy Frigate ALFRED (build log & Gallery)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         Lobster boat RED BARON (Build log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
Will you be building a case for it to keep the dust off and prying little fingers away?
If you do I made my base and had the acrylic cover made locally.  Unfortunately I did not have the foresight to give them the base so their part did not fit snuggly so I needed to make adjustments to my base.
I also added a locking pin on each end through the acrylic into the wooden base so if someone picked up the display case by the "glass" it did not fall apart.
I used ornamental pins cut from kitchen cabinet hinges (bought for the purpose, not taken from the kitchen cabinet) for this task.
Alan O'Neill
Congratulations on finishing your first build.  You did a really nice job on your Lobster boat.  I am sure that you learned a lot that will help you on future builds.
Ryland
               - Nautical Research Guild
@AON
Alan, that is a great suggestion. However, I really don't have the room to display anything in large cases. There are no prying little fingers about.
I was wondering if I could spray an acrylic lacquer clear coat over the matte enamel paint to help protect it from scratches, etc. Can you or anyone else here shed some light on that?
Paul
On the Ways: Mighty Mite, Harbor Tugboat by pwog - NautiCurso - 1:64
__________________________________________________________________
Completed Builds:
Lobster Boat Red Baron (Bluejacket)
Sardine Carrier Pauline (Bluejacket)
Swampscott Dory (BlueJacket)
@schooner
Tim,
Are you talking about plank on bulkhead or plank on frame? Or does it matter?
Paul
Completed Builds:
Paul,
I guess open boat kits  could be called POB or POF.  They are usually built as POB (upside down over the tops of temporary bulkheads that are removed after the planking is finished - leaving the "frames" in place). You can look at build logs for Model Shipway's 18th century longboat to see what I mean.
From a strictly planking viewpoint there is no difference between POB and POF but POBs are usually easier to build because you don't have to build the frames too - which might require more shop tools than you have (certainly more than I have). I recommended a boat rather than a ship because the planks are bigger and fewer, and if it is"clinker" style like most of them the planking is a little easier too. Another plus is most boat kits are cheaper and smaller than ship kits, and don't need to be cased.
Spend some time looking around build logs here on the site and I'm sure you will find something. The catalogs from BlueJacket and ModelExpo are worth a look too.
Tim
Absolutely beautiful build. Thanx for all the photos and explanations...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
Sorry but I cannot comment on whether spraying with anything to protect from scratches is a good idea or not.
Alan O'Neill
Scratches and prying little fingers are to be considered but IMO the real enemy and reason for a case is dust accumulation. That being said my first two kits are not encased, but my current one will be.
10 hours ago, schooner said:
Paul,
@schooner
I’ve been thinking a lot about your suggestion and looked at Bluejacket, modelexpo and others, but I think I will stick to my plan of building Bluejacket’s Pauline next. I’ve admired the sardine carriers that I’ve seen up here including the Pauline, Jacob Pike and Grayling. However, I will take you up on your suggestion on building a pob  boat after the Pauline.. Thanks Tim, I appreciate you.
Paul
Completed Builds:
The Pauline looks like a great kit, I hope you do a build log since there hasn't been one for that kit yet. Good luck!
Edited by schooner
Tim
@schooner
I will be doing a build log. And I’m glad you gave me the suggestion of doing an open boat plank build. Knowing myself, I would have jumped into a plank build that would be way beyond my skills. 😂. Now I know where to start with planking.
Paul
Completed Builds:
41 minutes ago, MrBlueJacket said:
Good timing - We're carving Pauline hulls on Monday, will have kits a couple of days after that.
@MrBlueJacket
Nic,
can I call you in a bit to discuss picking one up?
Paul
Completed Builds:
Just catching up Paul and I want to congratulate you on your fine model.  It turned out excellent and in no way looks like a first build.  It’s cleanly made and nicely fitted together.  Good paint too.
Gary
Completed Scratch Builds
great job on your first model :)   I've never done a solid hull ...you did a good job getting the contours right.    I did the MidWest model.  your choice of colors are very nice as well {even though they were included in the kit}.   congratz!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
nice accessories
Current build: Great Harry, restoration
On hold: Soliel Royale, Mantua
Completed:
Bluenose ll, Artesania Latina
San Francisco llArtesania Latina
Chris Craft barrel back triple cockpit, Dumas
Chris Craft 1940 double cockpit, Dumas
Santa Maria, Artesania Latina
1901 Scow Schooner, scratch built
Hannah, Continental Navy, scratch built
Candelaria bomb ship, OcCre
Pride of Baltimore, Model Shipways
17 foot Chesapeake kayak (2, one scratch), Midwest
USN Picket Boat #1, Model Shipways
Kobuksan, Turtle Korean ironclad, YoungModeler
HMS Revenge, scratch
NY Pilot Boat, kit bashed, Model Shipways
USS Monitor, scratch
Nuestra Senora de Afortunado, 1926 Popular Science plan, Resoration
Martha, CBMM,
Puddle Jumper, scratch stern wheeler
Lady Sarah, kit bashed Constructo Victorian launch
