welcome back Daniel- feels good when you have all three masts stepped😀. Still plodding along with my Terror but getting distracted by 1/35 armour at the moment!
Keith
On 10/9/2020 at 11:33 PM, DanielD said:
illuminators” glued in, but I’ll think of something, maybe a clear polished dowel that slides in to make a lens..
HO model train suppliers have a window glazing material that will work here.  I forget what they call it. It looks like thin white glue and it dries clear. Just spread a drop on the openings with a toothpick.   In addition to glazing windows I have used it to make “water” in some  buckets on a model barge. It is quite effective
More work finished on the main mast rat lines. I think I’m all half hitched out and I know there are a thousand more to go.
Now to figure out the next step….hmmm…
Good evening everyone. I’ve been putting off starting the mast standing rigging…but no more. Started the fore mast…slow steady progress.
Edited by DanielD
Good evening all. As is the case with all good projects, one might learn more information information along the way. Dr. Betts book on the HMS Terror in hardback has not been and is still not available in the U.S.; however, I was able find a Kindle version. Looking through the book at the images and research I feel good about the “additions/ changes” I and others have made to the standard OcCre Terror kit. I did discover that there are differences in the standing rigging between Dr. Betts research and the OcCre plans I was following. Since I really just started the standing rigging, I chose to take a step backwards and fix a couple of lines, well, eight to be exact. Here is the updated model following Dr. Betts book.
Edited by DanielD
I started the rigging on my LN like you, standing rigging. I had the shrouds all done (no rat lines) and someone pointed out I missed some cleats. And then as I started looking at things, discovered there was no way I was going to get lines tied to the belaying pins. Are you concerned about this?
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
Good morning Dave and fellow Washingtonian,
I believe I have all the cleats and belaying pins installed based on Dr. Betts research of the Terror; however, attaching the rigging is always a challenge. I have a little experience with my Golden Hind I finished a couple of years ago, but it will still be a challenge. I have long hemostats for reaching across the deck to attached the lines to the belaying pins. Not easy, a delicate process, and very time consuming...
BTW, your LN is turning out wonderful. Keep up the great work.
Daniel
Good evening all, more bowsprit work with much of the fore mast standing rigging finished.
 Now back to rat lines…
Edited by DanielD
Thanks for a little of your time and the likes! More work going on in the shipyard today. Finally finished the standing rigging on the main mast. Here is the latest update.
