Hi all,
After finishing VM's Lady Eleanor Fifie the other day I wanted some downtime. But by the next day the Flirt box had somehow found it's way into the shipyard, opened itself and started assembling parts...strange!
Truthfully, I just couldn't stop myself. I haven't even read through the manual once or even looked at the plans. So that needs to be rectified over the next few days before further building continues (he says). I have  read through the excellent Flirt builds on MSW and will take notes from them to supplement VM's instructions.
Having built VM's Lady Eleanor I'm now a bit more familiar with the excellent layout style of the manual, the plans and how they relate to each other. I don't expect the Flirt instructions to be any different.  Having experience of a company's way of conveying instructions shortens the learning curve.
So here's a couple of pics to get started....
Below - manual, box cover and cradle. I think I actually prefer the wooden cradle to the plastic version. It's stronger and more rigid - I might try to paint/varnish the wooden version when all is done and use it as Flirt's permanent display cradle - we'll see.
And some parts have already been dry fitted together....
The build should gather momentum once I've spent time reading the instructions and cribbing from MSW Flirt builds.
And that's all for now, catch you soon,
Richard
I hate when that happens, but it seems to happen a lot to me too...🤣
Regards,
Glenn
Current Build: HM Flirt
Hi all,
HMS Flirt continues her construction, in spite of some minor distractions.
Below, The lower decks have been glued in position and weighed down overnight. Everything seemed to fit fine.
Bow patterns etc glued in to position, and now preparing to fit the Deck Beams.
Upper deck longitudinal supports, Stern Frame Parrerns etc all glued.  One of the Bow Patterns had slipped down a few mm during clamping but I don't think it will affect any later fittings.  And Main Sub Deck ready for fitting.
The Main Sub Deck, although accurately made, does take a fair bit of manoeuvring to get it to slot into all the bulkheads etc. As the instructions say, curving the deck longitudinally helps squeeze it into position. Even after I was convinced the deck was snugly in position I twice went round each bulkhead slot location pressing firmly down on the deck and on the secound round heard a couple of clicks as the deck found an even snugger fit....to the naked eye all had looked fine but there was obviously the odd 0.5mm here and there to still be taken up. And just to make sure the deck didn't try to free itself the heavy squad was called in for overnight duty.
The (slightly curved) Stern Counter was soaked in hot water and clamped to a chisel handle for an hour or so. I really need to sit down and figure out better clamping methods - appropriate clamping is a subject that keeps raising it's head with me. 4x tie wraps isn't ideal but did the job.
Bulldog clips clamping the stern Board.
About to check the beveling of the parts that the planks etc will run over. Correct beveling is still an area of 'great mystery' to me. The plank showed good contact in all the places it should up and down the depth of the bulkheads, but the Bulwarks...ah, that's a different story.
Bulwarks soaked in hot water and then clamped (rubber bands) overnight to achieve the desired curvature before gluing. It's fairly easy to get the curvature correct in one plane, but as the bulwark approaches the bow there are at least two directions of curvature. I still haven't figured out how to clamp in two planes.
Bulwarks now glued in position. There are some small gaps between the bulwarks' lower edges and the bulkheads, near the bow and to some extent near the stern. The gaps are maybe approaching 1mm (worst case) - I've driven in some nails to push the bulwarks towards the bulkheads but I still see some 0.25mm - 0.5mm gaps. Probably nothing I can't fudge a solution to, but the gaps are the result of less than perfect beveling and not being aware of appropriate clamping methods....two areas I need to brush up on.
OK, well the planking is next 🙂
My study, which not so long ago was a radio shack/electronics learning area has now been usurped by a shipyard. And boy, do shipyard tools, materials etc quickly spread to all corners of the room in a matter of hours.  Fortunately, I have workshop training so at close of play the last thing done is a full tidy up. I'm not a fan of the 'clean desk' policy that some companies force on their employees but am in full agreement with tidying up the workshop at the end of the day....it pays dividends.
All for now,
Richard
PS: There is a door to be fitted below decks...it was...but fell out... I need to figure a way to glue it back in position before planking commences... that is tomorrow's first challenge.
Edited by Rik Thistle
Hi Spyglass,
Thanks for the info.
My first planking layer will be 1.5mm x 5 mm limewood, so that thickness gives me plenty scope for sanding the planks to the same level as the bulwarks.
I used PVA glue.  I did pin the bottom edges, but would ideally like to aim for a solution where pins mostly aren't necessary.
And that sure is a lot of rubber bands ;-)  But maybe that's what I need to plan for before gluing.
As I gain more experience I should be better able to look at a part to be glued and know what clamping is required beforehand to get the desired result.
I did realise afterwards that a rod pushed though facing gunports would give me a couple of sturdy attachment points for rubber bands to hook on to and therefore put loads (in the necessary directions) onto the glued part.
So it is a case of me building up a database in my head of 'best practice' clamping methods.
Thanks again,
Richard
i use strips along the bottom and elswhere
Ah, good idea....thanks. I hadn't spotted the strips being used prior to gluing.  Noted.
Yes, I intend to take my pins out after the glue has set.
Thanks and regards,
Richard
Hi all,
Here's my weekly (or so) update on Flirt.
Planking the hull with the first planking has been the main activity.
But let's get the important stuff on first. The below-decks door that had fallen out has been glued back in position. Schrodie, the ship's cat, would probably be the only one that knew it was back but it's the thought that counts.
Below, the door stuck back where it should be. A bit excess glue showing, but the door is ajar enough for the cat to wander about.
Below. I've been using a 6" rule to cut planks etc but never felt comfortable with it for two reasons ...
1) my finger tips were dangerously close to the blade, and ...
2) the narrow width of the ruler caused it to tend to coggle over under pressure. Adding a scrap of wood on the opposite side stopped the coggling but reduced the clamping load on the part being cut.
So I dug out my old 12" rule which has a nice finger-safe groove in the middle. Also, it's greater width reduces the coggling effect. So far it seems to be doing the trick.
So, on with the hull planking. Below is my 'bending jig' - 1/4" ply. Ideally it needs to be a couple of inches longer since the Flirt planks hang over the ends, but it's good enough for now.
And here is how I make the bends permanent. I use the same method for as for putting a sharp crease in trousers ie hot iron plus a wetted hankerchief.  I'm still puzzling as to how to simply make bends in two planes, which is sometimes desirable on hulls.
Below. I've also been looking at how the planks are pinned to the hulls. A comparison below shows some pin diameters (in mm....my schooling was at a time when the UK was switching from Imperial to Metric so I tend to switch between the two systems without thinking). 1.2mm is way too fat and splits wood too easily; 0.7mm is also just too fat; 0.5mm nails (as supplied with Flirt) are a perfect diameter but really need to be positioned with needle pliers, to be pushed in or tapped with a hammer.  So I've ended up using 'Map Tack Push Pins 1/8"' (from Amazon), and am quite happy with them.
The Map Pins can take a fair bit of hammering, and are also 'grippable' enough to be finger pushed into the (in this case) 1.5mm Lime planks.
Below. Map Pins finger pushed into the plank and the plank glued onto the hull. Next is to tap the pins with a hammer into the bulkheads.
The Map Pins can be easily reused by extracting with needle pliers (or if the red head comes off then gingerly use side cutters on the 2mm wire protrusion). Another benefit of the Map Pins is that if dropped on the floor they can't be missed!
Anyway, back to the chase.  The final hull planks held in position with the poppy field of pins.
And below, two views of the hull before any cleaning up. It's a bit of an ugly duckling at the moment but hopefully it should brush up good enough.
Bow view.
Stern view.
I now need to read up on what planks and where, there needs to be feathering before adding the second planking layer to the stern area and the hull.
I feel I haven't progressed much since the last update but hull planking does take time. Fifie has a smaller hull so didn't seem to take too long.
Ah well that's it for now. Hope everyone is fine, and that the 'vaccine competition' provides a worthy winner and soon.
Regards,
Richard
Looking nice!
Any chance you can still twist those stern planks in a little so they make more contact with the false keel?
Ongoing:
Thanks James.
Actually, now that you point it out the stern planks are most definitely not parallel with the false keel....hmm. Thanks for the heads-up.
I think I had been relying on the fact that those planks will be heavily feathered as they reach the edge of the false keel, but even then they are a bit too squint. I'll see what I can do 😉
Regards,
Richard
Ah Richard, Richard, it hasn't taken long, fresh from your success  with the Fifie I see you're a lost cause now fully seduced into the world of model ship building. 😀 There's no cure you know.
Following on from what James said, if you mark on the plank towards the stern where it starts not to lie flat, dampen it, put the strake in a vice, twist it using pliers whilst applying heat with a hair dryer and Robert's your Mothers brother, -  works for me.
ps Love that expression 'coggle over'  know what you mean about using a six inch metal rule, but sometimes it's the only thing that will do, annoyingly I've misplaced mine and I miss it.
B.E.
B.E.
Yes, no cure now ...I've joined the ranks of the unsaveable ...at least I've got company, lots of it 😉  And I doubt if BigPharma is working on a vaccine!
Brilliant. That's what I was missing...makes sense and will be employed in future.
I used to think planks were simple, straight things. Now I find they they are cut to profile, heated and curved in two planes, positioned and glued, pinned in position and then sanded smooth. And then painted.  Life used to be so much more simple in Spring 2020.
I've probably got about half a dozen 6" rules dotted around the premises, but only three or so are findable at any given time.
I think 'coggle' may be Scots or Irish but I suspect the whole of the UK uses it. It's one of those words that kinda sounds like what it means - onomatopoetic - I remembered that word from school days but did have to Google to confirm spelling.
Thanks again,
Richard
You can get that second plane with your iron. Clamp one end of the plank to your table and gently twist it while running the iron along the board, like “air ironing.”  I did this a lot on my Cheerful, it’s less precise but it gets the job done. Just be careful not to iron your plank holding hand ...he said from experience... I just wet the board with my finger dipped in water.
edit...what I said is essentially what BE described
Edited by glbarlow
Regards,
Glenn
Glenn,
Thanks. It has been a gap in my knowledge...how to bend planks in two planes. But you and B.E. are getting me up to speed. It's one of the many things this website is very good at ... sharing knowledge.
Yes, keep the fingers away from the iron 😉 ...even with my current bending method I'd had a few unplanned warm digits!
regards,
Richard
Never too late to adjust - here is a "late adjustment" as I put my Speedy garboards on a day or so ago !!
Spyglass,
Thanks for your suggestion. It has been added to my 'data bank'.
I've slackened off some of the worst offending planks, reglued and squidged them down hard with clamps. And then done a bit of light sanding on them. They're looking a bit more acceptable than they were.
All the best,
Richard
I recommend giving the rearmost inch or 2 a good soak with isopropl alcohol.  That will de-glue it and make it easier.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
    For second planking, I recommend tucking the forward end of the plank up under the rabbet of the stem before working it back towards the stern.  Soak it, twist is and let it dry in place before gluing.
Chuck Seiler
I've joined into following your build since I have the same model an the shelf waiting for it's time in shipyard.
I'm a big fan of working with each plank until it nearly sits exactly on the hull without any clamps by prebending the plank using dry heat while slightly moistening the plank. Clamping the plank to my work table and then bending and twisting it while heating it with a hair dryer to create those compound curves near the bow works very well also.
Edited by BobG
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Thanks Bob.
I think I've been guilty of trying to short cut the work needed to get planks to fit. I had set myself a target of getting the first planking done in about 1 week, even though I wasn't working on it every day. Less haste, more speed.
Thankfully my build log highlighted where I was cutting corners and the members have been great in advising me how to fix the issue and what to do in the future.
All the best,
Regards,
Richard
27 minutes ago, Rik Thistle said:
Thanks Bob.
All the best,
Regards,
Richard
Pretty much anything is fixable, especially at this stage.
Just take your time. Really liking watching you build this one.
Ongoing:
Spyglass,
use a scrap of strip as a buffer for easy removal and it also come in handy to overlap
I hadn't thought of that. It seems obvious when I read it but the good ideas always are.
Thanks,
Richard
Hi all,
Well it's been a couple of weeks since my last update, mostly concentrating on hull planking and playing with new toys.
Below - I eventually got the first layer of hull planking to a vaguely acceptable profile and then planked the stern area. A bit more sanding still required.
Test fitting a 2nd layer plank to see what final sanding was still required for the first layer.
Below-  4x second layer planks glued.
And a new toy making it's first appearance. I think I have managed to use the hot iron to create curves in two planes, plus a twist at the bow and stern ends of the plank...but don't quote me on that 😉
2nd layer planking all on. Now for the tidying up of it and sanding.
The final planking is starting to look a bit more shipshape...from a distance.
Cutting through the base of the bulkhead tabs prior to twisting them off. Even a 2mm deep cut is enough to encourage the tab to snap off at deck level rather than half way up.
I have a couple of Zona razor saws...one came with some extra blades which included a pseudo flush cutter. Make sure the knurled locknut is topside to let the saw lie as flat as possible.
I also used one of my small Veritas chisels to get the tabs flush with the deck.
Laser engraved deck fitted and glued in position. It pretty much dropped straight in to position with only some light persuasion at the stern end with a 1/8" screwdriver blade to find it's proper rest position.
Inner bulwark planks being fitted. I used continuous planks rather than two halves...it seemed to work fine. I had pre-painted the planks in the shed the evening before.
I've fitted two full length planks each side. For the 3rd layer I will use short lengths of plank (which will leave all the hole positions revealed) then revert back to a full length plank for the 4th and final plank. Then trim out the holes.
I've noticed at the bow and stern the bulwarks 'swoop' upwards which means that 4x plank widths will not be enough. Have I fitted the bulwarks incorrectly at the ship's ends?.... and how do I remedy this? ....I can always put in some 'stealers'...or sand down the bulwarks' height...hmm.
Ah well, that's it for this fortnight....most of the time has been spent on hull planking...glad it's finished. If only the rigging wasn't blocking the light at the end of the tunnel the outlook would be quite sunny 😉 But I chose Flirt to improve my skills so I can't complain.
See you all soon,
Richard
Ah, I've just noticed on the .pdf version of the manual (pg 18), if I zoom in, there is a short tapered length of (5th row) planking added at the bow, and a longer length added at the stern which is then sanded (or cut) to follow the line of the upwards swoop of the bulwark. All is good 🙂
Richard
Hi all,
Work continues on Flirt - two steps forward, one step back....due to someone not reading the instructions properly.
Below - Clearing out the holes in the bulwarks after the internal planking was fitted. The Banggood 'dremel' is really quite useful, and it's rechargeable battery lasts an acceptable amount of time. The internal planking needs a little bit of 'filling' plus a bit of touchup paint.
And hacking out the gunhole ports with a scalpel blade and then a needle file to smooth the sides off.
Yes, the stain (now difficult to see after major clean up) above the wales looks like someone has mistakenly glued the wales above the pencil marks rather than 'up to' the pencil marks. Also, I couldn't find the 3mm x 1 mm wood so used some walnut I had in the 'stores'.
Below - Keel being glued into position. The toothpicks are wedges to make sure the keel lies centrally. Yup, there is a handy gap (don't ask) between the keel and the garboard planks for the toothpicks to dig in to...filler later removed those gaps. Filler is great stuff  😉
The MDF Pegs for aligning the keel parts are necked at their ends... so I couldn't get them to slide on to the keel parts. Not sure what I was doing wrong here?
Wales painted black, and a bit of general tidying up done.
Below - Marking the waterline with my home made marker. Note the bulldog clip, bottom right on the keel to stop the hull sliding about in the base.
Hull painted white. Gaps showing between the planks. They look worse than they actually are, but I may add a touch of filler and repaint, or more likely hand paint in the gaps at a later date. I don't mind the planks showing since it indicates what the structure is but the gaps mustn't be too obvious.
Whilst the white paint dries, the rail and timber posts were painted black. There are a lot of small parts that need painting black, yellow etc.
Below- After getting fed up continually digging in to the Flirt box for wood/brass sheets I decided to lay them all out my home made drawing holder/work platform. A Banggood Christmas tree has been added because...well, it's that time of year. Nope, I'm not on a commission from Banggood 😉
I think that's all for this post.
Flirt seems to be progressing very slowly. The hull planking did take quite a bit of time and I lost a bit of momentum, but I guess it's not a race.
Catch you all soon,
Richard
Probably still plenty of thickness to fill, sand, and repaint the hull. Nice job on the Wales, remove and replace is a way of life for me...
Regards,
Glenn
Since posting, I've sanded the white paint back a bit and added some filler. And repainted - it's now looking not too bad.
🙂 Yes, 'fixing'  becomes part of the build process... ie realising I've messed up and, once I get over the 'doh!' moment, enjoying figuring out the least painful fix balanced with it looking acceptable.
Richard
21 hours ago, Rik Thistle said:
least painful fix
Where's the fun in that, sometimes I think I wind up doing the most painful rebuild possible 😄
Being willing to step back and improve something is the sign of a good modeler, its only the impossibly great ones that never have do-overs.
Regards,
Glenn
Hi Glenn,
I did say that the fix to be balanced with it looking 'acceptable' 😉  ... but you're right ... it can be a head scratcher sometimes trying to figure out how best to correct a mistake... but I enjoy solving puzzles, so it's another good aspect of modelling.
As I learn more about modelling I'm growing my list of ways to fix 'instructions misunderstandings'.  Happy days.
Cheers,
Richard
Hi all,
Another 10 days or so have gone by, mostly absorbed by small detail work. Although I'm more than half way through the instruction manual that doesn't mean the work is anywhere near half done...nope, the really testing stuff (rigging) is lurking just a few short pages away...gulp.
Anyway, the small pots of acrylic paint are now appearing on the workbench. I suspect they will be setting up home there for the next few weeks.
Below - The area above the upper rail is painted blue. This becomes an area of high assembly activity so the pristine blue finish is not going to last long!
Work also starts on the bow area. Again, the black paint will need re-touching in the days to come.
A bare stern 😉
Gun post timbers clamped in position. They kinda went on OK. For some reason I had anticipated, because of their spindleness, they might have been more problematic.
Back to the stern, now with a splash of blue and soon to be neatened up under the board rails.
Below - Yellow gun support timbers added. It was fiddly getting them centred, some better than others.
Black board rails added but the blue paint now has a dusting of ...well, I'd like to say dust, but it's probably excess glue. Nothing another swab of blue paint can't cure though ;-).
Below - Now the even more fiddly parts start to make their appearances. A lot of these thin parts require 0.5mm or 0.8mm holes drilled through them.
1) 0.8mm is a bit on the large side and can split the thin part in two if I'm not careful.
2) The 0.5mm drills I have are utter junk and break easily. Today I ordered 10 off better quality ones. (Edit: I later read that someone suggested Jewellers suppliers as a good source of quality drills etc....will investigate)
This black, stern side counter timber is a bit of a misfit, so remedial action will happen in due course. However, the rudder now sits happily glued in position.
Below - Side steps and depth markings etc fitted. The steps are reasonably parallel (mostly) ...I used a temporary 3mm spacer between them to try to keep them aligned.
Well, that's another few days slipped by without any large structure etc being added.
But there has been work going on...it's just that it is small stuff, time consuming and not that noticable. And it is Christmas.
Regards,
Richard
I spent a full day scratching two ladders and another half day on fabricating a tiller, the small stuff takes as much work as the big stuff. I enjoy it even if there isn’t much to show for it.
Your Flirt is coming together nicely!
Regards,
Glenn
