I'll start by saying, I wasn't planning on doing a build log...
There are a 15 logs for the same model on MSW already. However, at last check, only one was to completion. The other logs offer a lot of help and information but only as far as they go!
So, even though I started the model 3 months ago, I did take pictures along the way and any details I may have left out can easily be found on the other logs. I pledge to keep this log running to the models completion, however long that takes.
This is my 4th model and I continue to learn new techniques and ideas. I think that will never stop. There are so many masters on this forum! I hope, someday, to be as capable as them.
I am attempting to keep this model as historically accurate as I can based on the plans and the book "The anatomy of a ship : The armed transport Bounty". Additionally, I will be aging or weathering the ship as I build it to give it that "realistic" look. This is the first time I've tried this method and as you'll see it has been challenging but also a lot of fun!
Before I start, I'd like to thank several builders that have inspired and unknowingly helped me to this point. Many are still on my favorites list and all have build logs that you may want to reference too:
Captain Al
Cobr
Grendel
Rcmdvr
Thomaslambo
Tim Moore
Trig
There are probably a couple more that I missed...
Okay, lets get started!
I didn't bother taking pictures of the box, unpacking and indexing the parts. I'm sure there are plenty of those out there! I found the contents to be of very good quality and I was not missing any parts or components. The scale drawings and picture book are very detailed. The instruction book is probably a bit sparse if you are new to modeling. The picture book helps fill in some of the gaps but frankly, without some of the build logs, it would be very difficult in places.
The first few steps are pretty straight forward:
1.  Cut out the keel and frames
2.  Sand the little tags off and remove the charred layer for better glue adhesion.
3.  I chose to stain the frames and keel with a walnut stain, taking care to keep stain away from the areas to be glues. It took two coats to get to the color I wanted. The picture below was taken with just one coat.
I purchased (prior to starting this model) a  model ship building slip:
It has been a great tool for holding the model and I expect to use it throughout the build. Look at the above log for more details... worth every penny!
It is extremely important that the keel is kept straight and that each frame is installed plumb and level to the keel. This CANNOT BE STRESSED ENOUGH!!
If any of these are off, you'll struggle with it throughout the build. A word of caution... Make sure the table or bench is level too... If it isn't, make note of the difference and ensure that the identical difference is transferred to your model as you build it.
As you can see in the pictures above the building slip has an attachment to help keep the frames at 90 degrees to the keel and the frames were leveled using a small level resting on the top of the frames before gluing and taping into place. Each frame was allowed to dry several hours before the next frames was added.
More to come later today or tomorrow.
Lyle
"The only thing that stays the same is the constant state of change"
Completed Builds:
Occre HMS Terror - https://modelshipworld.com/gallery/album/2065-hms-terror-occre/
NRG Half Hull Project - https://modelshipworld.com/topic/23546-half-hull-project-by-lylek1-nrg/
1:130 1847 Harvey - https://modelshipworld.com/gallery/album/2125-1847-baltimore-clipper-harvey-1130-scale/
Scott Miller's Sea of Galilee Boat https://modelshipworld.com/topic/29007-sea-of-galilee-boat-by-se-miller-120-scale-lylek1/
In progress:
Artesania Latina HMS Bounty - https://modelshipworld.com/topic/26817-hms-bounty-by-lylek1-artesania-latina-148-scale/
Waiting for dry-dock space:
Model Shipways - USS Constitution
Master Korbel - Cannon Jolle 1801
A Scratch build -TBD
3 hours ago, Matt D said:
I like this kit.  I’m going to pull up a chair and watch.  Good luck, Lyle!
Welcome aboard and thanks Matt!
Next update coming...
Lyle
Completed Builds:
In progress:
Moving along, a few things to mention regarding the frames and keel...
Using the ship building slip helps to keep things straight but it does require a few shims under the keel to ensure the frames fit completely onto the keel section. I dry fitted every frame piece to ensure that was the case. As I stated earlier, these steps are important for the future alignment of the model!
Frames going into place and the bow section pieced together:
Additionally, the first of three mast steps is in place... disregard the lower deck piece, for now! I didn't have any other pictures of just the frame work!
Once the frames are in place, the bow and stern frame work can be accomplished... pretty straight forward work. I had no problems but did have to sand and fit a few tight pieces. Nothing out of the ordinary.
The beams for the lower deck are next. Again, straight forward work. A few things to mention, first, in a few logs I noticed some modelers did not take the time to index and inventory the parts prior to work. This could cause confusion during the construction and this is one place for that to happen. The lower and middle deck beams are cut from walnut stock and are not part of the pre-cut pieces (the main deck beams are pre-cut). The beams will need to be cut and sanded to fit, care must be taken to have a good fit but not too tight as a tight fit will spread the frames apart and cause problems later in the build. Also, the mast steps should be finished and placed before doing the lower deck beams.
Nothing difficult about the mast steps just ensure that you place them correctly on the keel.
The lower deck beams are only installed at the bow section and the stern section per the instructions.
Next up is the lower deck sections.
Edited by LyleK1
Lyle
Completed Builds:
In progress:
The lower deck section are next!
Consistent with many models, there is a false deck that must be "planked" before installation.
There are more methods than I can begin to list for performing the planking of the deck. I think the final expected "look" can make a difference on which method is chosen. As I noted earlier in the log, I plan to "age" or "weather" the model throughout the build. This area is my first trip into that realm!
I painted the false deck black and spaced my planks approximately .5mm apart to simulate the caulking between planks. I also cut my planks to matched the beams below the deck. Trimming and treenail markings next:
I did a some experimenting with how I wanted the treenail pattern to be throughout the ship. Because this deck is hidden enough to be unnoticeable, you can see my experimentation! Obviously, I settled on the side-by-side pattern and the decking on a three butt pattern... not as noticeable on these smaller deck sections.
Aging and weather was a completely new concept to me and I did a ton of reading and looking at other work.
I experimented with some leftover plank pieces trying for the right "look".
IMG_4109.thumb.jpg.4bc6922349f27984f9dad7d71366af06.jpgIMG_4115.thumb.jpg.b2caa32686a7fdea040910f9fdd4371c.jpg
Not quite right and I didn't like the "scarring" effect.
After much head scratching and wasting a lot of planking material...! I settled on a system that I used on both the lower deck and the middle deck. The main deck will be different since it is exposed to the sun and weather. Here is the system I used and the supporting pictures:
I used a Golden Oak gel stain and coated the entire deck with a medium coat and I immediately wiped it off with a clean rag:
The wipe down helped reduce the depth of the color but also helped highlight the grain of the wood. After this dried, I added highlights and random "wear" with a black wash:
This was allowed to dry and then I coated it with polyurethane.
The stern section was handled the same way and I think I got pretty equal results:
Once both sections had dried, they were installed on the frames and beams, ensuring proper alignment with the mast steps and the deck mast clamps. I glued the mast clamps with a very small amount of glue in case I need to adjust later.
Now for some kit bashing! That's in my next post!
Edited by LyleK1
Lyle
Completed Builds:
In progress:
Although the kit comes with some extras, I just thought there wasn't enough and the model looks empty. So, I decided on a few things:
1.  Lighting will be added throughout the lower decks and the two stern lanterns, and
2.  Detailing will be added to make the model look "lived" in.
Let's start with the lighting... Again, something I had not attempted on previous builds. Lots of research and perusing other attempts by other modelers. Technology has advanced to the point that small LED's are ridiculously small! I purchased "Z" size LED's. These are less than a millimeter across, are already wired and very easy to hide.
But how to hide them and make the model look realistic...?
I decided to make lamps!
This is a proto-type of the lamps to be used. I made the lanterns from a piece of very small PVC, brown thread and brass rod. Eventually, I reduced the size of the handle and cleaned up the thread work. This one is done except for some black paint:
Hiding the wiring would be the challenge! For the lower deck, I decided to have three lamps. One forward one aft and one on the bilge well (more on this one later). Staging them so that wires wouldn't show was the next challenge. For realism, I made some crates and I used a barrel.
First, the crates:
62502536102__214BBF55-3F40-4484-BE12-83778F693794.thumb.JPG.5d2814199e4a238ca3c1d9b0ecd0fddf.JPG
Again, lots of experimentation! Aging the wood was a process. The above photos were taken while working through the process and the only shots I own. However, the process wasn't complicated as long as the end product looked like an old crate! infinite ways to achieve the look. I cut small cubes of Styrofoam and glued the wood to it.
In the case of the bow section, I ran the wiring for the light through the deck and up through a crate. The I glued the lantern to the crate!
The end result:
IMG_4336.JPG.9061c049fb6279caf4dc4360f6911fdb.JPGIMG_4337.JPG.8ef501225b6d70a0752c62c02be98488.JPGIMG_4339.JPG.906043e52762a32c059c87a6a0757c01.JPG In the aft section, I did a similar trick but I used one of the barrels that came with kit:
Ignore more poor painting job on the barrel!!
The last one was placed in the bilge well hanging on one of the walls. The bilge well was a simple task to assemble but I deviated from the instructions and made the walls more time period realistic. Of course, aging was done, the lamp was hung, some soot placed above the lamp and the hardware all aged too:
The shot box is on the right panel. I decided to open the shot box lid and during final staging, I plan to add cannon balls in the box! I made a shallow false bottom in the box. The panels were easy to install and glue into place.
Here is the results:
Before the barrel was installed but you gets the gist of it:
The final detail for the lower deck until later on - Hammocks!
Made from the remnants of past sails, a little thread and a few hooks.
IMG_4347.thumb.PNG.8ed25eb15db0a381f376553fa0e2d9e9.PNGIMG_4244.thumb.jpg.24b463b0cbc9a9c8b9deead59c94cd1c.jpgIMG_4245.thumb.jpg.62334a5885dbd560c7b7517cf370534f.jpg
I glued the edges with a gluestick... hoping it will keep them from unraveling!
Moving to the middle deck next! Almost caught up with my current work!
Edited by LyleK1
Lyle
Completed Builds:
In progress:
On to the middle deck. There will be bunch of kit bashing on this deck.
But first, I went through the same process as the lower deck to plank, age and detail the middle deck and the beams were installed just like the lower deck. Making sure that the fit was tight but not too tight. Also, as mentioned in several other logs, the bilge pump elm tree tubes pass through the decks and unfortunately, through the main deck beams and the middle deck beams. Don't forget to make these cuts now, later will not be fun I don't have a picture of that particular part but it is obvious during assembly if you're aware it! Below the deck is glued in place:
62692712730__5D4EF347-C881-41E8-8C6E-58F6322B4680.thumb.JPEG.803375677bedbc1404341699946a8514.JPEG
Be sure to check the alignment of the mast holes before gluing! The stairs to the lower deck were next for me. Straight forward assembly and aging was done with a black wash:
62810787890__F080E8DB-6BDF-44B9-BC22-63C92E09CBE5.thumb.JPEG.3fc4c44f697203f56cbad510379eb733.JPEG
The kit made no suggest to any type of railing and the plans and books didn't show anything either! So, it left it up to me to do what I thought was fitting for the time period; I could've gone with railings down the stairs but chose not to because the stairs would be too narrow for my taste. The banister set up feels right for this model:
Fitted but not stained:
Next the stern walls for the garden room was made very similar to the bilge well walls which I have been using throughout the model, seen above and here:
The next step was to build and install the middle deck gratings. The grating kit has been a topic of discussion with this kit. Some have complained of the quality... admittedly, it's not the best but I was able to make due with the pieces provided. Built and installed:
Above shows one aged and the other prior to the procedure.
62820385602__1D43BD48-AE81-4D51-953F-158586262CE7.thumb.JPEG.324d3662d2c968326d2133eb036280c7.JPEG
62820390155__CE2A7596-E042-406B-B433-21BBAFE36F26.thumb.JPEG.adb1726a0921397232c678ec66a4d0b3.JPEG
Above, everything from this post installed. And a hint of what's to come!
Next, work begins on the cabin walls, doors and windows...
Lyle
Completed Builds:
In progress:
The middle deck cabin walls, doors and windows took nearly two weeks of cutting sanding and fitting each little piece to the walls before final assembly. I didn't take a lot of pictures of the process and frankly, you probably don't want to see a bunch pictures as these walls went together. I have couple:
Nothing too drastic to pass along as this is part of the kit. However, the lay-out was funky! One door opened into a stairwell and another into the bilge pump tubes! So, I moved them to be more appropriately located.
Aging and installation, again no real issues:
IMG_4330b.thumb.jpeg.af0f71d9eb1d83d31e98d203baa5bffc.jpegIMG_4328.thumb.JPEG.bc6ed9bb7ffba537e79ec826714b7dce.JPEGIMG_4329.thumb.JPEG.3bce7d692523b89c484140b102c45e8d.JPEGIMG_4358.thumb.JPEG.1e71a69d4d770d322ad7a5fdeb4674d4.JPEG
I just noticed that I missed a window frame in the above picture! Easy to fix!
Painting buckets and preparing the racks for the great garden room:
As of today, this is where I am on the model! I have over 110 hours and about three months of work, so far.
I will be doing some more kit bashing... There is a "Captains dining cabin" that doubled as a clerks cabin on the port side just forward of the current cabin work. Additionally, there is a "parlor" for the galley that technically is located on the starboard side across from the dining cabin. Since the starboard side is open, I've decide to move it to the port side just forward of the dining cabin. Forward of that, I may make some canvas screened cabins... haven't decided. According to Captain Bligh's logs, many of the crews cabins leaked rainwater, etc. Due to the size of the crew (nearly triple the normal compliment), some temporary canvas screens were put up with hammocks for the crew. I'll do the dining cabin and the parlor, which are not part of the kit, and then decide!
The next update will come as progress is made!
Lyle
Completed Builds:
In progress:
Amazing start. Can't thank you enough for posting. I hope to build this kit one day. What sources have you used for referance?
Thanks and stay safe,
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Thanks Mort!
I have the book "Anatomy of a ship: Armored transport Bounty".
Additionally, I have collected several drawings from different sources online.
Lastly, the build logs (as mentioned in my first post) have been a huge help at times, can't say enough about them!
Lyle
Completed Builds:
In progress:
Just a quick update today:
I completed the racks and buckets for the Breadfruit plants and installed them in the Great Garden area. These are really way out of scale! I thought seriously about making new racks and buckets to scale but frankly, for the amount you'll actually be able to see, I decided to keep the kits version.
I purchased 1/48 scale Yucca plants to use for the Breadfruit plants. I plan to put a plant in every other bucket:
Working on the template for my dining cabin and Pantry. I'm using a piece of thin carboard as my template. I'll make all the necessary cut-outs and the transfer to a sheet of Basswood that I have leftover from a previous build. This (for me) is a slow process as I try to flush out all the details, placement of doors, windows, interior components, pattern for the walls and bracings. I am borrowing ideas from previous builders and their logs!
Cardboard being shaped and cut above.
That's it for now! More in a few days...
Edited by LyleK1
Lyle
Completed Builds:
In progress:
Hi Lyle,
Where did you buy the yucca plants? Were any included with the kit?
Thanks,
Mort
Edited by mort stoll
23 hours ago, mort stoll said:
Hi Lyle,
Thanks,
Mort
Hey Mort,
No plants with the kit. I did a little research on the Breadfruit plant and how it looks. The closest I could find was the Yucca plant.
I purchased it from a place called HobbyLinc. Inexpensive... about $12 for all that I needed.
I had to cut the flowering part out as it doesn't match a Breadfruit plant!
Edited by LyleK1
Lyle
Completed Builds:
In progress:
Any time I do any kit bashing or changes to a kit, it takes me a while to think through the process, source other build logs for ideas and direction and come up with a suitable plan.
As my last update showed, I was in the process of developing and executing a plan to add more interior cabins on the middle deck. Cutting out carboard pieces to use as templates is the first step. Once I'm happy with the template, I move it to wood:
There's not much point in adding walls and doors, etc. if you can't see what's going on inside! So, for this wall, I cut an oval shaped hole in it to give visual access. A simple process that can be seen in the pictures below and really doesn't need any explanation:
Additionally, I didn't want the hull planking to be the walls. I made small panels to go between the frames and then I planked all four pieces using the usual methods and marking the edges of the planks with a pencil:
IMG_4390.thumb.JPEG.2d0ef51113065257b1674356576a4162.JPEGIMG_4391.thumb.JPEG.ad62444f451c50cf2dd4f412669e9fdc.JPEG
And then I framed the pieces with 2mmX2mm walnut stock:
On the middle section, I added a map of Pitcairn Island and on the left section I added a shelf that I plan to add a lit lantern. I also made a table:
IMG_4400.thumb.JPEG.13921dc7c6a5d99877faac2bd0b9c8e0.JPEGIMG_4401.thumb.JPEG.5be1865d9f285b321801c98b0e9bb6e6.JPEG
The pieces were glued into place and the outer wall added:
IMG_4397.thumb.JPEG.050343860e4fe3693c35c9b72174a3ae.JPEGIMG_4398.thumb.JPEG.cae5d2d7ea0392660c8d1816c09d8cc9.JPEG
I also worked on some finishing work... One thing that was bugging me was the edges of the deck and walls that are open to the view. I decided to give them a better, finished look. Here is a before picture:
I took some 2x2mm walnut strips and glued them to the edges:
IMG_4403.thumb.JPEG.1a0cd878d0c82428f9e4b335107fd2c1.JPEGIMG_4404a.thumb.jpeg.dd075d0001937fd5aebb4bf35be97414.jpeg
A much better looking finish!
And the Breadfruit plants have been added:
IMG_4366.thumb.JPEG.73c2f74c27cf282be970d2a713b114be.JPEGIMG_4367.thumb.JPEG.15404c80f50bb519b9945576f672bda6.JPEG
On to the Pantry and adding lighting next:
Lyle
Completed Builds:
In progress:
Captain Al
Cobr
Grendel
Rcmdvr
Thomaslambo
Tim Moore
Trig
I really Like the look of this kit and just wondered if you could rotate this 180 degrees? I much prefer to have something to support the ship whilst planking.
I have made a jig for this but I have only just started on my second model and already I have had to modify it twice.
Completed     St Canute Billings            Dec 2020
Completed    HMS Bounty Amati          May 2021 Finished
Currently building HM Bark Endeavour
Hi Dave,
Yes, actually, if I set the model up correctly, I can rotate it 360 degrees!
Good luck with your latest model!
Lyle
Completed Builds:
In progress:
It's been a week since my last update and I've put in 18-20 hours this week!
The challenge has been to work through the ideas in my head and from other build logs and move them to the model. So,  a pantry (of sorts) and a couple more cabins, along with lighting were this weeks' projects.
Making the lanterns is a process:
I've outlined the process in an earlier log. Once the lanterns were done and ready for installation, I started on the pantry and cabin walls. Again, my process remained the same from previous installations:
IMG_4489.thumb.JPEG.b417b0335c43d0a03e7df5134091a623.JPEGIMG_4490.thumb.JPEG.ec1d8cc4135f9139cebc2904c925f31d.JPEGIMG_4491.thumb.JPEG.8ab0788b8269a9e6ac4d3a50a4d8e70d.JPEGIMG_4492.thumb.JPEG.3fd87b81fb86f33353381ca0c4195c0b.JPEGIMG_4493.thumb.JPEG.fcb9ebdf462875c339f313a41b5a4e65.JPEGIMG_4460.thumb.JPEG.fd807f95f45e233a74df6d346941b119.JPEGIMG_4494.thumb.JPEG.0aaedfe67041402ce43c725a72aed735.JPEG
The sections were aged and then installed.
Pictures of the installed sections and the lighting will be in the next post!
Lyle
Completed Builds:
In progress:
Sections in place:
Previously, I had installed three lanterns on the lower deck and I have six on the middle deck. The remaining two lights will be mounted in the stern lanterns.
The first concern after making the lanterns, is the placement of lanterns to conceal the wiring. The placement has to allow a wire to run behind a wall or on the port side of the lower deck (won't be visible once the model is complete).
The following pictures show some of the process:
The wires that will lead to the switch and battery and ask as the conduit for the lanterns to attach for power, are placed where I plane to have pedestals for the final mounting of the model. The false keel is drilled and then I predrilled the keel pieces to match up with the false keel. Need to make sure these are long enough to run throughout the entire ship (if needed).
Lantern placement from the backside:
The lantern wires are small and delicate. They are glued into the lantern from either the bottom or the side of lantern. Once the wire is run through the wall, I glue the wire down to prevent accident tugs from dislodging the lights. The wires are run strategically to locations hidden by walls.
I've only soldered one light, so far:
My soldering skills have not been tested in a while! But I think I'll improve with a little practice.
More in a few days!
Merry Christmas!!
Edited by LyleK1
Lyle
Completed Builds:
In progress:
All the wiring is now soldered and all the lights (except the stern lanterns) are now operational:
IMG_4535.thumb.JPEG.1e1f590d4526034da35d936844ae7be9.JPEGIMG_4536.thumb.JPEG.7b5f28a3dd83fe0e9ab9541b14b232e5.JPEGIMG_4537.thumb.JPEG.b596450f962504e0a0c3e298ad97eda3.JPEGIMG_4530.thumb.JPEG.e0cc67e1a0bba4d00f0d0f049b266c05.JPEGIMG_4533.thumb.JPEG.269bae8fd36c6da81e31714f9fceec6f.JPEGIMG_4534.thumb.JPEG.dd6b5e7bdf4d9287be2d5c5c825b23e9.JPEG
Hiding and tucking in the wires didn't pose too much of a challenge:
IMG_4538.thumb.JPEG.405dff3b7ea1c42956980108a9e10af7.JPEGIMG_4539.thumb.JPEG.042ad60fd2e0f9e05444acaa788537e4.JPEGIMG_4540.thumb.JPEG.6c69120829c50360401fb8f7638c5d72.JPEG
This last picture is showing the stern lighting wiring. I can't install the lights until the stern section is complete.
Moving on! The remaining upper deck beams are installed and I need to add a shim to the ports side of nearly every one of them... not sure why most of them are short by about 2mm. Nothing a shim can't fix.
I need to figure out whether I should do the planking on the upper deck before or after installation.
Decision time in the next post!
Edited by LyleK1
Lyle
Completed Builds:
In progress:
On 12/30/2020 at 7:37 PM, Duanelaker said:
Fantastic work! I love the details.
Thanks David.
Thanks for checking out the log! A long ways to go. But I am enjoying this build a lot.
Lyle
Completed Builds:
In progress:
Just a quick update...
Not much progress this week with the holidays and everything that goes with them!
I did start to fit the upper deck... including checking the masts and other items that fit through the deck and go into the lower decks.
Most everything seems to line up but I'm researching a couple of things before moving on:
1. The pinrack stanchions are not perpendicular to the deck, they have a slight lean to them. Is that normal? Or is the deck out of alignment?
2. The fore mast looks to be at 90 degrees to the deck. However the main mast seems to be swept aft a slight amount. Is that normal?
3. The mizzen mast is raked back (that is normal) but how many degrees?
After looking over some drawings, it looks like the main mast is not straight and does have a slight rake to the aft, similar to the mizzen mast. I don't remember where I got these drawings, hope its ok to share:
For the stanchions, I gotta believe they are correct in being raked to the aft too. In the picture above, it doesn't seem so but in this picture it does:
I'm still researching the degree of rake for the mizzen and main masts. Probably not that important to the model if its a degree or three off but I'm like a dog digging for a bone!
I gotta find it!
More soon!
Edited by LyleK1
Lyle
Completed Builds:
In progress:
I gotta find it!
This is what I get:
Do you have this drawing? https://commons.wikimedia.org/wiki/File:Admiralty_Sheer_Draught_Ship_Plans_-_HMS_Bounty_RMG_J2028.png
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
11 hours ago, iMustBeCrazy said:
I do have the drawing but not with the red lines and the info.
Thanks Craig!
Lyle
Completed Builds:
In progress:
Ah well, the lines are my work ;)
Thanks Craig!
No problem.
Craig.
Thanks to Craig, I have the masts fitted properly. Obviously, by removing the main deck, things move and change but I'm confident that I can get the masts perfect when the main deck gets glued into place.
However, the bow pinrack stanchions are another story!
The stanchions go through the main deck and down to the middle deck where they are supposed to fit into holes in the deck. When installed, they actually rake forward and not back as the plans suggest. Everything else on the main deck lines up pretty good, a few minor areas on the frames that don't match up perfectly but real close.
SO, why are the stanchions off?
The only thing I can do is fill the holes in the middle deck and move them forward about 1/2". This will give it the proper aft rake.
Fitting the main deck is a very time consuming part of this build and must be accurate! I'll keep working on it!
More soon...
Lyle
Completed Builds:
In progress:
Here are the final pictures of the details and lighting on the lower decks before I get started on the main deck and planking. Many of the details are glued down but not everything... Everything not glued down will be removed and not re-installed until she is done!
The wires in the foreground will be hidden in the mounting base along with the battery and switch.
Enjoy:
IMG_4535.thumb.JPEG.c6982b7b1e884daec7a248b3ec9a58f5.JPEGIMG_4533.thumb.JPEG.e62451a16ccae1228b037c3a5978fafe.JPEGIMG_4534.thumb.JPEG.4badfe6c13e93d2bca4e0f518366df5e.JPEGIMG_4598.thumb.JPEG.cca7f555f87c313d9cba42a3234239f4.JPEGIMG_4599.thumb.JPEG.75f6c3e7e8a68e14d79161d9920c79cc.JPEGIMG_4600.thumb.JPEG.29b41625705691556f52b355dd71dc49.JPEGIMG_4601.thumb.JPEG.561b6df4b8f79aef0b720ceb9a877ede.JPEGIMG_4587.thumb.JPEG.93ebf6ca7596dbe487631da9df1bc4fb.JPEGIMG_4588.thumb.JPEG.785c259f54c22c3c9f8a41d0083f2bb8.JPEGIMG_4589.thumb.JPEG.2232f392eff131d9107907dbf0c9d219.JPEGIMG_4590.thumb.JPEG.a17241b0b546db890cebc361cd653fc1.JPEGIMG_4591.thumb.JPEG.32b3c6c652a76b180b01a38a15e96beb.JPEGIMG_4592.thumb.JPEG.469f0255b09bb2454b181c5afa4409fb.JPEGIMG_4593.thumb.JPEG.40b6153a5c02d5ccb46dbc5e8e6b4952.JPEGIMG_4594.thumb.JPEG.2c6c3e6e266350b3d4adc2a70e3ac64d.JPEGIMG_4595.thumb.JPEG.77d55fd5af83926d5002f6f2c402edfc.JPEGIMG_4596.thumb.JPEG.a871053e7b1b7a2abae766659648ba27.JPEGIMG_4597.thumb.JPEG.140374ba892988a604bae7b0dcf0a727.JPEGIMG_4602.thumb.JPEG.0bb0fc08cf402e30ecc759e4c66ae173.JPEG
Lyle
Completed Builds:
In progress:
I neglected to mention that although my kit bashing is done on the lower decks, there is some details that I have not done yet. There are several barrels to be painted and added, a stove and its associated duct work and anchor lines. These will be done when I get frustrated with planking or the rigging! I always need a diversion of some sort when things aren't going well or you just need a break.
On to the Main deck!
As noted in a previous post, the foremast pinrack stanchions were not properly aligned. I kinda took the easy road for a fix. Even though the side is open, you really can't see where the stanchions were to be located on the middle deck. So, I just filled the holes with a small piece of planking material, gave it a little color and moved on:
Not a pretty match but this is the last time you'll ever see it from this angle!!
When the stanchions go in, I'll glue them to the middle deck, the upper deck beam that they pass right up against and the main deck. I'm sure it will have plenty of support.
With that problem solved, I started dry fitting the main deck. As part of that procedure, I also ran any pieces that passed through the decks to ensure alignment:
IMG_4626.thumb.JPEG.335d1670e7bb365ea4bf9ae7d2f7c2ca.JPEGIMG_4627.thumb.JPEG.9e4a403979913d2b705a090015dcb631.JPEG
The alignment worked out pretty good. However I did have to make minor adjustments on the mizzen mast and the foremast.
As has been mentioned in all the other logs about this particular model, the beams need to be drilled or reamed for the bilge pump piping. Don't forget to do it!
The mast were pushed into place (very tight fits, lots of sanding and a little file work) and just a hair above the mast foot. I marked the mast for cutting:
Used a miter saw and cut the mast base to the proper depth. I used an Exacto blade and chiseled out the excess wood. A final sanding and my masts are ready to be installed... much later on! Don't forget to mark the top of your mast with the direction to insert it and which mast it is!
IMG_4623.thumb.JPEG.8c4244ef4dca365b09bef447ad2017d4.JPEGIMG_4625.thumb.JPEG.e2bd12d6937e8763a56d63534bd19054.JPEG
It's also a great time to check if they are level (foremast), raked back 1 degree (main mast) and raked back 3 degrees (mizzen mast). Be sure to check alignment of the masts from the bow. They should be aligned.
I dry fitted everything on the Main deck 4 different times to ensure that I had everything aligned and fitting properly. This was a big step in the model.
I put the Bounty back in her building slip to ensure the keel is straight.
Carpenters glue was applied from bow to stern on every beam, wall and frame ends. I clamped it down on nearly every beam and checked from the underside of the deck for a tight fit.
Before the glue had a chance to dry, I re-insert the masts and all other pieces that passes through the decks and left them in place until the glue dries 24 hours.
Good adhesion is important to me on this step because this will solidify the frames and the ship overall to better withstand the beating it will take from the upcoming sanding for planking!
That's it for this week!
Edited by LyleK1
Lyle
Completed Builds:
In progress:
The interior is looking terrific Lyle. Meticulous and unique work, really well done. Going to be a great Bounty.
Tim Moore
Perfect is the enemy of good
In progress
DH.9a Ninak, 1/32, Wingnut Wings
Docked for Repairs
IJN Pre-Dreadnought Battleship Mikasa, 1:200, Hobby Boss
On Deck
The Blue Sky Company, 1:48, Sierra West Models
Completed
Triumph 3HW, 1/9, Italeri; Fiat 806 Grand Prix 1:12, Italeri; Fifie 1:32, Amati Victory Model; HMS Bounty 1:48, Artesania Latina; Endeavour 1:60; Corel; Miss Severn 1:8, Legend Model Boats; Calypso, Billing Boats; Carmen Fishing Trawler, A.L. ; Dallas Revenue Cutter, A.L., Bluenose, A.L.
Thanks for the kind words, Tim. Your build log has been an inspiration and a big help at times.
You work is beautiful. Thanks for dropping in!
Lyle
Completed Builds:
In progress:
