Absolutely amazing. It's great to see a model with all that spread canvas. It makes me think about the (usually pretty small) crew having to manage all of that sail so that the ships could make top speeds.
The finish line must be visible now...
George K
Thanks, George.
Yes the work being done now all seems to make a difference to how the final model will look, which is spurring me on.
It's startling how much sail these vessels can spread. Stefano must have been an amazing sight, even though she was a humble working vessel.
A small update today. I spent my day off yesterday beginning the ratlines for the mainmast shrouds. I was pleased to complete the starboard side. I use 6mm lines placed behind the shrouds as a guide, and begin by adding spaced out lines, then filling in the gaps, gluing each row as I complete it. The ratlines are #20 DMC Cordonnet Crochet thread... The same stuff I use to make ropes. I'm pleased with how it looks, and how easy it was to tie. As a natural thread, it takes the watered down PVA really well, and is easy to clip to length once dried.
That's it for today. Happy building, all :)
Rob
Rattling down continues... Work has just begun on the ratlines for the Starboard Mizzen shrouds. Port Mizzen shrouds are done, now.  In retrospect I didn't tighten the shrouds enough, and it's caused them to become slightly wavy on the mizzen mast. This was my nervousness at making sure they didn't pull out the deadeyes from the rail. Not a disaster, but not quite as neat as I would have wanted... Oh well 🙄 This is all part of learning about this homemade rope... it doesn't behave quite the same was as the caldercraft rope I used on Ethalion. It's much softer and more easily stretched out of shape.
Hi all,
Thanks for the likes. I've completed the main shrouds, and added the mainmast stay. This one had to go on first, as it attached to a pin inserted into the jib boom. (That was my kludge fix for gluing the foredeck down too early!). Having said that it all went together okay, and looks fine. I've finally added the deadeye strops (Caldercraft) and fixed the tops to the masts, now as well.
20230623152136-26070206-la.jpg.f900d62ff5a578e021133fa558ed9858.jpg20230623152135-762d4615-la.jpg.6226dc78479857a2f4553668a6ed4d1e.jpg
I've also done some tidying up, gluing down the anchors, fixing the anchor chains, and removing the excess, which was just sat on the deck up till now. I've also added the eyelets underneath the pin rails round the fore and main masts. Not a lot to show, but it is progress :) These parts are very fragile, and I can see trouble ahead when it comes to tying things off... time will tell how much of a headache this proves to be.
Happy building to you all :)
Rob
Okay - time for a short update... I've added the futtock bars - it took me a lot of head-scratching to work out how to do this neatly, but I ended up using 0.5mm brass wire, with a loop at one end, that was tied to an eyelet in the mast, having hooked the other end through the eye in the bottom of the deadeye strop... They were tested for size, then blackened before final fit.
The parts...
And the fitting...
And then I went on to put on the topmast shrouds, and I've begun the ratlines...
Progress is being made :)
As before, the ratlines are DMC Cordonnet #20 Ecru thread. The same stuff I use for rope-making. It's lovely stuff to use for tying ratlines - very forgiving, and once brushed with watered down PVA, I've had no problems with knots coming undone. Once the topmast shrouds have their ratlines, I'll need to add the futtock bars for the crosstrees on the fore and main masts.
Thanks for looking in and taking an interest.
Happy building :)
Rob
Super work Rob....she is looking so good.  I'm not so sure I would have used white line for the ratlines...myself...but to every builder, his own desire.
She's just wonderful.
Rob
Current build:
Finished build:
Current build(On hold):
9 minutes ago, robdurant said:
Thank you @rwiederrich - yes, it's definitely a personal choice, and not one that's historically accurate, perhaps. I just like the look :)
*I just Like the look*, is a powerful phrase. A personal one too.  Your interpretation is very pleasing, magnified by your skill.  I've enjoyed every stage of her construction.
Rob
Current build:
Finished build:
Topmast shrouds and ratlines are complete. I've been doing a little work on the bowsprit, adding the inner and outer bobstays using the kit supplied chain, which was chemically blackened. The chains were attached using black thread, which will be trimmed one I've put some glue on it to stop the knots coming undone.
Over the past few days, I've made good progress on the bowsprit rigging, including making the "whiskers" on the catheads, which were soldered from 1mm and 0.5mm brass rod, and then sprayed with white primer. The topgallant shrouds were also set up.
I wanted to use black card for the strapping on the cathead whiskers, but also wanted them to be strong enough to withstand knocks and bumps, so rather than simply stopping them at their inboard extent, I have them bending 90 degrees, and fitting into a hole drilled into the cathead itself. This provides lots of strength, and I'm confident they'll withstand gentle knocks... Hopefully I'll avoid anything more dramatic.
Adding the "hooks" for the rigging first...
Then bending them to fit... and trial fitting them in the holes drilled in the cathead.
They were fitted before I bent them vertically up, so that I could ensure they both bent up the same amount... and black card was added to simulate the metal straps...
The finished article, once rigged... (rigging required that I make some 0.5mm rope, and then stained it... For those interested (and as an aide memoire for myself, it was made with #100 DMC Cordonnet crochetting thread, 1x thread per strand, 3x strands). The rigging was fastened using #50 DMC Cordonnet thread, and fixed in place with watered down PVA.
And as mentioned at the beginning, I've also rigged the top gallant shrouds... Rather than adding deadeyes, I've copied the way these were rigged on my Ethalion...
It's nice to feel that progress is being made.
It's been a while since I posted an update, but today I managed to get the remaining forestays, and some of the main stays set up.  Here are a couple of photos of progress, since the weather was playing ball...
20230926174631-42f84f30-la.jpg.abe6c5e4ebc9133459556dee576cd646.jpg 20230926174630-32bfa1c4-la.jpg.e1fdc101e0386e31e4a170b91d5da3ca.jpg
Rob
Edited by robdurant
cropping edges of photos to remove clutter...
Rob...she's looking amazing.  Clean and precise.
Rob
Current build:
Finished build:
Rob
Agreed that is a very fine model.
Andrew
Completed (Kits):-
She is a lovely ship Rob  and an beautifully built model
David
David
Previous Builds
HM Cutter Hunter Mamoli 1:74
Baltic Ketch Scotland - Corel 1:64
HMS Fly - Swan Class ship sloop - Victory models 1:64
HMS Diana - Artois Class Heavy Frigate - Caldercraft - 1:64
HM Cutter Trial 1790 - Vanguard Models - 1:64
18th Century Merchantman Half Hull - NRG-1:48
HMS Speedy 1782 2023 Edition - Vanguard Models - 1:64
Current Build
HMS Harpy 1796 - Vanguard Models - 1:64
I'm sure this has been asked.....are you building a case for her yourself?
Rob
Current build:
Finished build:
Rob
Sadly, the cost of cases is prohibitive for such a model - last time I looked it would cost over £500, and the companies I talked to were unwilling to take on the work - it being of too large a scale for them to want to try delivering the case once it was made... Time will tell, but I do have a willing recipient, so I suspect Stefano will end up on display out of a case... I haven't got Ethalion into a final case - she's behind a perspex screen so that I can see her, at the end of my boat building desk. The enjoyment is absolutely in the building for me, so if someone comes along, admires her, and wants to put her in a case, I'd probably be tempted to pass her on :)
Rob, I had the same dilemma over a  case for Diana. I was going to make one myself from acrylic sheet but at the time, my daughter was looking for a larger aquarium for her fish and since a case is just an inverted aquarium, I asked if they could make one for me and they agreed. The price was not much more than the price of the acrylic sheet. I'm waiting for delivery but if I'm happy with it, I will log the details.
David
David
Previous Builds
Current Build
Yeah, the case for my Niagara cost more than the kit. It was a little over $500 for the wood pieces (Bluejacket) plus the cost of the glass/plex and the poly. That said, there is a lot of work out into these things, it's nice cherry wood and it seems safer and more secure...
After a very enjoyable day off, more progress has been made. I've been attaching the stay sails... These are attached with tiny rings which are opened up one by one, and threaded between the bolt rope and the sail... The sail is then lifted into position and the rings closed one by one. I've found that a pair of tweezers is essential for holding and opening the rings, then a pair of pliers with grooves helps to grasp the ring to close it (a smooth pair of pliers won't stop the ring pinging round flat, and that led to considerable frustration at the beginning of the process. I've got quite good at it now.
There are two staysails waiting to be attached. I wanted these in place before I added the backstays, so that I still had easy access to the centreline of the model, where all this takes place. I think that's proven to be the right approach.
Thanks for all your comments, and for showing an interest :)
Rob
