Very smart way of Fixing the carriages B.E.
thanks for sharing your experience
I have to remember that one....
I had finaly put a drop of CA on each of the four wheels. The metal wheel rims would prevent the CA from soaking into the Wood and rundown the outer rim to the lowest Point (contactpoint to deck). The tricky Point is to get the Tackling on and by untangling the threads with several tweesers at the same time I was straining my brain how this could be avoided. Sometimes the tiny 3 mm block slipped out of the stropping and I had to relax inbetween to Keep calm....
Nils
Current builds
-Lightship Elbe 1
Completed
...I catch myself every time on knees and elbows swaying / feeling the Hands over the carpet when one of
these parts has fallen down,bounced a few times on the carpet taking an undefinated direction ...
So familiar. We all from time to time have to fall on our knees to pray to the God Of Accident And Clumsiness
Edited by Nenad M
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Thank you Ben
Nils
Current builds
-Lightship Elbe 1
Completed
So familiar. We all from time to time have to fall on our knees to pray to the Good Of Accident
Thanks Nenad,
I think I I had the choise again to determine the floor decor in my hobbyroom it would be uni-Color...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils -- That gun rigging is impressive not only for its detail but for the sheer complexity.  YIKES!  I don't know how you can find your way, even with a list!
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Thank you Martin,
the most tricky sequence on the whole build to date is the fideling and sheaving of those tiny 3 mm blocks, with two tweezers, a scalpel and a very sharp Little scissors in Operation. I am looking out for a way to do that more professional, because in the Moment it is very much time consuming
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, have you tried tweezers used by jewels for working with pearls? I know some modelers who have them and they are the cats meow for holding blocks securely.
David B
Thanks for the tip David,
I never saw or heard of those Special jewelery tweezers before, but I`ll go on search after that....
Nils
Current builds
-Lightship Elbe 1
Completed
Check out jewelry supply house. I use Sante Fe Jewelry Supply. There is also Connentti.
David B
I have no doubt that you will resolve this, Nils
In progress:
Content of log :
Past build:
Nils -- I have a supply of 3 mm blocks that I got for the gun tackle, and I never even tried to use them because they're so tiny.  I'll be intrigued to see your resolution (your hands are obvsiously steadier than mine!).
Cheers,
Martin
David,
I found several different type "Pearl tweezers" by Ebay, Thanks again for your tip
Nenad,
probably I shall stick to the method I already practiced with success, but very weary to go indeed
Martin,
my Hands are still quite steady but my eyes are at the Limit when trying to get the thread into the sheave hole
Nils
Build log part 42
stropping the tiny blocks....
this is the way I do it, pending having knowledge of an easier way, of which I do not know yet...
I work with These medical grip tweezers. One hold the block firmly in place and allows Access to the notched groove for the strop (both sides)
tie a first Little Loop around a small sized drillshaft into the thread, this Loop goes to one end of the block
two strop Ends layed around the block
and fixed carefuly into the grooves, whereby the Loop must sit on Center Position aft of the block
here the second tweezer Comes into the game... and holds the positioned strops in place so that the second knot can be tied, capturing the block as tight as possible
then Looks like this....
double- and single sheave blocks
repeatable work.... to go
the thread (rope) I use is 0,3mm hemp Colored 100% Polyester, the Advantage of Polyester is that it can be heated thined down and stretched at the end. Otherwise I would never get those Ends through the mini sheave holes
ist just a very fast touching of the thread end into the flame, and then immediately stretching it out between thumb an pointer finger. Always have to do several attempts to get the right thined out end
Current builds
-Lightship Elbe 1
Completed
Nice work Nils, Nice to see how you got the blocks ready ,
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
the thined out end is only appr. half the original Diameter, and there is no fringing out of the end. By this means it is easier to fiddle the thread into (and through) the sheave hole
Build log part 43 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
very interesting method Nils.........something to remember ;)  haven't had the chance to work with blocks that small...........my days are numbered though.   my Half Moon has some 2 mm blocks........that should be fum  {that's fun,  with some degree of fumble in it}  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
2 mm blocks Popeye
must be something for watchmakers or so, where the the whole mothly production Output fit in a matchbox.
Would love to see if anyone has tackled those yet
Nils
Current builds
-Lightship Elbe 1
Completed
thank you Donny
Nils
Current builds
-Lightship Elbe 1
Completed
thank you Geoff
Nils
Current builds
-Lightship Elbe 1
Completed
That series of photos shows a fine technique, Nils.  Fascinating.  Two questions, though:  how often do you burn your fingers on that heated polyester?  and how do you keep the polyester thread knotted tightly?  Every time I've used anything but cotton, the knots all come loose.
Cheers,
Martin
I can confirm opening knots on Polyester Martin,
thats exactly what I also experienced. To avoid knots opening I put a very small dosis of CA on the knot (with toothpick) and also on the side grooves of the block only, so it ca`nt slip out of ist "harness" again. Be careful not to get CA into the sheave holes. I do two knots on top of each other before applying CA. The second knot already hinders the first from opening
surprizingly the molten Polyester cools down so fast that the heat is not even felt between the fingers. Of course Keep the fingers well away from the tourch-flame. Lucky to say no burnt fingers to date. The tourch is left burning because there is no time to Switch it off. It stands safe on the Gastank base. It takes a litte practice to be fast with the fingers when thinning out the end of the thread...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Hipexec,
those are stainless steel artery clamps ( like used in surgery operations), I would`nt want to miss them in my Toolbox any more.
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 43
still rigging the guns
The tackle jig is of great help to avoid tangling of the chords
The naval officer inspects the tackle maker`s 3 mm block tackles...
one by one the rigging of the guns process continues
wirtgh 25 mm figures there is no Problem with the deckbeam hights
the guns on the cutaway deckside are Standing on rails
the last gun on port side
the gundeck capstan will be rigged with the Messenger cable, when I get the anchor cable
this area of gundeck and beneath will be partly visible through the cutawy quarterdeck
Build log 44 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils
Although I've looked in now and again I never have said anything on your build. This is because it is the Scratch Forum while I mostly hang out in the Kit Forum .
Great work on your Pegasus - everything looks very authentic. You do have a lot of rope on the decks from the gun tackles. That is why I left the rear tackles off my Fly but that is just a choice...Anyway good stuff and keep it coming!
Cheers
Alistair
Current Build -
Hi Alistair,
thanks for dropping in. I also often look into yours (great looking) and the other Fly / Pegasus builds here on MSW.
Perhaps I would have left away the tackles beneath QD and forecastle deck if the were not those cutaway giving view from above. The rough coiled up gun shifting ropes on deck is probably how they were shortly before or after interaction, as all guns are pushed out. Tidy coiled ropes would probably go with all guns backed in and secured and ship alongside Pier
Nils
Current builds
-Lightship Elbe 1
Completed
Nils
Excellent work, excellent craftsmanship
Cheers
Geoff
Thanks for your words Geoff
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils, Beautiful work, excellent craftsmanship.
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
nice appreciative comment Pete,
Thank you very much
Nils
Current builds
-Lightship Elbe 1
Completed
