As RGL well said above. Rust is always near hinges (gunport doors, deck hatches etc.) and chains. Anchor beds were always full of rust, just like hawse pipes. Rust dust can accumulate in the corners which was washed out by sea later, so drain holes are prominent points.
4 hours ago, Spooky spoon said:
A preview of what I'll be up to next.  I think Prinz Eugen will be first.  I buy too many kits.
Deffo.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Actually, that rust looks very good in the photo. But it might look different in real life, so you might be right in wanting to tone it down.
Maybe leave it for a few days and come back to it with new eyes - you might find you like it after all.
Steven
Rust exists in multiple shades. Fresh rust is almost orange and darkens as the iron continues to oxidize. This just looks fresh; like Greg said, rustier is better. Multiple shades. 😀
Ken
Started: MS Bounty Longboat,
Oven started painting up all the various bits that go on the deck, as well as some of the superstructure.  It went pretty well, although there are some visible gaps, as the parts did always fit on correctly.  My main concern now is the rear turret, there
doesn't seem to be room for it to fit on properly.  Maybe finding a way to boost it
up a couple millimetres would help.
Rather than raising the turret I think I would be more inclined to shorten the front face of the main cabin just behind. Should be able to do that without being able to see it after it's done. Even your close up shots are looking quite nice.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Perhaps you will end up with some spare railing when the build is done and can use that to try a fresh install.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
3 hours ago, Spooky spoon said:
So far my first attempt at doing a pe railing has not gone well at all.  It has been bent quite a lot, and I’m not sure how to deal with this.
I think this is still usable. Lot of tiny adjustments though. In general sense, fix the bent edge (i using a small vise for this) and carefully pull the other end with pliers. To bend the railing to shape you must use a roller. Hint video here, but i'd recommend to watch this out - many how-to can be seen there, however this Korean guy is a genius, and what seems so easy for him not so obvious for me :)
I’ve done a little more work on the masts, but some of the mast tips have become bent, as the plastic is extremely thin.  I’ve been looking for brass replacements but haven’t found any yet.  I’ll leave the masts off until the end, in the hopes that I can find suitable replacements.
On 7/21/2022 at 3:38 AM, RGL said:
Nah it’s stuffed. Get yourself a set of jewellers mandrels, they are cheap and will last for ever. I use them all the time and they are 90% cheaper than the PE Rollers
would this be suitable?
