Figures 421-427: Doorsteps. You will note that when assembled the two steps are not parallel to each other. It is very easy to confuse the parts as they are very similar, I keep the technical sheet handy as reference.
Current :
HMS Sphinx by Vanguard
Completed:
Orient Express Sleeping Car by Amati
Bluenose II (Artesania Latina)
Istanbul Tram - Occre
Bluenose II - Artesania Latina
Bosphorus Sandal Fishing Boat
Riva Aquarama - Amati
Titanic - Mantua
Bosphorus Fishing Boat - Tersane Model
San Juan Nepomuceno - Artesania Latina
Bluenose - Billing Boats
Figure 428: All parts ready for paint. I labelled the color not to make a mistake. I will start with white and proceed with blue and finally black, so that I won't need to clean the airbrush in too detail between the color changes.
Current :
Completed:
Titanic - Mantua
Figures 429-432: Several photos showing today's output. Handles, doorsteps, side roofs.
That's all for now.
Thanks for watching!
Current :
Completed:
Titanic - Mantua
Do you think that glueing the handle bars will provide a sufficiently strong bond ? Not that anyone would hang onto them, but glues may fail over time. Perhaps (hard)soldering would have been a more durable and (almost) invisible option.
The coach continues to come on nicely!
If they drop some day, then I think I will just glue them back. When it comes to soldering, although I am familiar with soldering electronic parts, I still don't dare to do it in this model. For the purpose of the handles, it would also create other challenges such as isolating the handle while painting the bar in blue, since any soldering should be done before paint.
Current :
Completed:
Titanic - Mantua
Sometimes glue is just easier....
Beautiful work Aydin...
Quote:
4 hours ago, thibaultron said:
You might want to hit all that exposed brass with some type of clear coat, to keep it from tarnishing in the future.
Good point! 👍. Would it work if I brushed matt varnish?
Current :
Completed:
Titanic - Mantua
Traditionally, a varnish called zapon-lacquer is used to prevent tarnishing on silver or brass objects. Easy to in Germany, but I don't know about Finland. Another option is Minwax, a commercial product, a solution of micro-cristalline wax in alcohol, I believe. The latter is used also by museums to protect metal objects. Both varnishes can be removed, if needed. And both varnishes are almost invisible.
I wouldn't use matt varnish, as the matting agent probably will leave some sort of veil on the parts.
I can check Amazon Germany
Current :
Completed:
Titanic - Mantua
Complete agreement...
Quote:
I found this one and ordered it.
Current :
Completed:
Titanic - Mantua
Proper ventilation for sure when dealing with all types of chemicals and also keep our hands at 10 and 2 on the steering wheel while driving.🙃
I can comment more when I have received it and read the warnings on the back label 😉.
Current :
Completed:
Titanic - Mantua
Hasn't almost everything, apart from a few 'organically grown' veggies, that reputation :)   By that standard I should be dead already - in the lab we rinsed our glassware with acetone p.a. to dry it faster and that over the sink ... the lab technician was always very concerned about H&S, but in the early 1980s it may not have been on the black list yet. Anyway, I always have the bottle of acetone on my bench for all sorts of cleaning and degreasing purposes. But the quantities used are really small, I had this 500 ml bottle going for almost 15 years now.
Edited by wefalck
27 minutes ago, druxey said:
Acetone has a bad reputation for one's health, does it not?
Yep, the health of fingernail polish... It's not something you want to drink for sure, or sit around sniffing for any length of time... it's one of those everyday chemicals that are harmless when used properly...
There are two types of paint thinner for models, spirit based and acetone based... Mr Color Leveling thinner and Testors Enamel thinner are Alcohol/Mineral Spirit based, True North Enamel thinner on the other hand is Acetone/Alcohol based...
Normal modeling usage shouldn't be any health risk at all
Quote:
More of an issue as to how much the Admiral is annoyed by the odors. But they all should be vented away from the painter.
Ken
Started: MS Bounty Longboat,
BUILD DAY 42 / 2 hrs / (TOTAL: 106 hrs)
Figures 433-438: Rails for sitting the roof on.
There are 3 rails: 2 on the sides and one going over the compartment doorline. The latter is to be painted in brown while the two on the sides will be white.
The rails are composed of two pieces each. The lower part has grooves to fit the structure while the upper part is flat to accomodate the roof structure.
Edited by aydingocer
Current :
Completed:
Titanic - Mantua
Figure 439: Overhead luggage/hat shelves. One for each compartment. The shelves for the 1st and 10th compartments are slightly different shape. The thin shelves are to be placed over the windows.
Figures 440-441: The overhead shelves are bent around 30 degress on the compartment side, in order to prevent the stuff from sliding and falling.
Figures 442-443: Some photos showing the shelves in place.
Current :
Completed:
Titanic - Mantua
BUILD DAY 43 / 0.5 hrs / (TOTAL 106.5 hrs)
Figures 444-446: Dry fitting the roof structure on the rails, which I installed in the previous step. After ensuring the positions, I will glue the roof structure on its own rails. These rails then will sit on top of those on the wagon.
Current :
Completed:
Titanic - Mantua
Figures 447-449: Roof sheets from etched brass. There are 33 of them. I was going to stop for today but then got tempted and started installing a few of them.
Current :
Completed:
Titanic - Mantua
Figures 450-451: By the way for this task I use this etch bender I bought from Occre.
That's all for now.
Current :
Completed:
Titanic - Mantua
Impressive building and details. It is nice seeing one of these finally come together. Obviously not an easy model to do.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
This is going to be a magnificent model when you are finished...such fine details! Great job!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
