Folks  I brought this kit last year  and  although I used some of the parts  to make the interior  for  for my  Chally 2,   I still  have  enough in this kit to  make a decent  model  including  the engine/engine bay.
I thought I would  have a break from my  Hood  mini ship build  as I needed a break from  mini world.
Just a pic of the box  for now.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Good deal brother... is this the group build we were discussing a ways back? or are you doing a one off...
Either way brother I'm here... won't miss this....
Quote:
fancy doing
Happy  what ever  you  fancy doing brother  -  I could make a start and if  you fancy   starting   - that would be good.
OC.
Current builds
Completed works.
been looking at mine occasionally.  I'll follow along, too, OC. Kinda busy with other builds, so no spare time right now for this.
Ken
Started: MS Bounty Longboat,
Evening all,    so work  begins  on this  "bemoth"    I decided  to start in the engine  bay  (its going to be a bit of a hit or miss  as I used some of the parts  from this kit  to make the interior in my  Chally 2 kit  - but I should be able to  work around it and scratch  some  parts.
Some nice detail  that will weather nicely when I get to that stage.
OC.
Current builds
Completed works.
1 hour ago, king derelict said:
This is going to be a great build OC. I'm very tempted to follow along with its smaller brother; the 1/72 Flyhawk kit
It would be a relief from the intense catwalk activity on Wasp
Alan
Go for it Alan,   would  be ace to see you start  yours  too.
OC.
Current builds
Completed works.
This is a pic of the engine bay I am hoping to  model close to, I have the engine to build  also.
Internet  Pic.
OC.
Current builds
Completed works.
Evening all,   got some good progress  on this today,  to continue with  scratching  some of the bulkheads  - I had to  install the running gear, to fit these  I  had to drill through one of the  bulkeads,   then after careful  leaveling of all the legs,  I was then able to make a  bulkhead  out of  panels  - this was fitted  on the one side of the bay.
OC.
Current builds
Completed works.
great start OC........... :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you kindly Denis.
OC.
Current builds
Completed works.
couldn't keep my fingers out of that Patton tank........got a few pictures.  waiting to do some painting
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I'm putting  the hammock up now.
With your expertise, it's gonna be good.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thank you  kindly Edward, I aim to please.
OC.
Current builds
Completed works.
Evening all,   some more progress  -  I added a few more details  to the engine bay,  then I decided to have a go at the drivers compartment,  I wasn't too  sure how this would  turn out as I had  used  some of the parts  for my Chally  build,   one of the  main areas  was the  right hand bulkhead  - this I managed  to  manufacture  using  some other parts from the kit,    the rest of the parts  are mainly  there  - still needs an instument panel making up  from scratch.
OC.
Current builds
Completed works.
Looking good my friend....
Can't wait to see the paint effects...
Thank you kindly,    this time I will use my airbrush  for most of it  with plenty of masking  where required.
OC.
Current builds
Completed works.
13 minutes ago, king derelict said:
Very nice OC; I think I have the easier path😄
Alan
Think you might be right Alan.
OC.
Current builds
Completed works.
8 hours ago, Baker said:
i follow, great start.
Thank you  Patrick.
OC.
Current builds
Completed works.
Evening all  - "Engine Time"   - the power plant  in the kit is quite complex and is a kit in its self,  some nice sub assemblies  are built first.
Current builds
Completed works.
11 minutes ago, king derelict said:
The detail looks great. Its going to paint beautifully
Alan
Thank you kindly mate.
OC.
Current builds
Completed works.
nicely detailed kit.....look'in very nice :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you  Denis.
OC.
Current builds
Completed works.
Evening all,    more work on the power plant   - more sub assemblies  that were then  brought together   -  nearly  built  just a few more  fittings  - also a  dry fit in the  engine bay  (snug fit)
OC.
Current builds
Completed works.
45 minutes ago, king derelict said:
Not much spare room there
Alan
Indeed  mate.
OC.
Current builds
Completed works.
