22 minutes ago, mtaylor said:
The tank is looking good, OC.  As for posting on the phone, there's lots of members who do it that way.  I hope the power supply/charger gets to you soon as the laptop is easier on our eyes, not to mention a bigger keyboard.
Thank you kindly mate  little screen keys and big fingers  fun  lol
OC
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Evening all  more progress  I have closed up the turret and cleaned up the edges   Next will be all the fittings.
OC
Current builds
Completed works.
And I have added a wire antenna to the drivers radio I had to drill a small hole in the top of the radio.
OC.
Current builds
Completed works.
3 hours ago, Javlin said:
All looking Very good there OC I luv it when a black base comes through the right way and I wish I had your confidence when it comes to weathering.:imNotWorthy:
Thank you kindly  it’s a great kit for making my job easier.
OC
Edited by Old Collingwood
Current builds
Completed works.
ooooh kevin likes that, a lot, sorry i missed the start
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you kindly Kevin,  at least  you are here now.
OC
Current builds
Completed works.
really nice progress OC.........fun part is putt'in the bling on  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank uou Denis,    indeed  sir  - looking forward  to that bit.
OC.
Current builds
Completed works.
Evening all,   more work  after having a day off   -  I have been  populating the top of the turret,   I started  with the main sight  its comes as a unit with a few parts  including the clear styrene,  again to shade this I painted the rear of the clear  with a few coats of Red, then fitted the doors,   the top/doors  is just dry fitted  until I mask up the glass area.  I have also  been  adding  some other fittings  to it.
OC.
Current builds
Completed works.
Evening all,    some more progress  today   carrying on with the turret  details,   when I brought  it  I also got the Update  sets for it, so I have been diving into them  improving some of the details  - plenty of resin and PE  bits and pieces  going on.
OC.
Current builds
Completed works.
Evening all,   more progress  starting to fit the vision blocks  in the different areas on the  roof,   in the  super detail  set  are  self sticky  block  covers that are translucent  and look excellent  if a little fiddly  to fit.
OC.
Current builds
Completed works.
Yep they have that polarized look the real thing has and can't be replicated with paint...
Nice Work!
Quote:
Nice Work!
Thank you kindly brother.
OC.
Current builds
Completed works.
1 hour ago, FriedClams said:
Great progress and beautifully done OC.  Nice upgrade set too!
Gary
Thank you kindly Gary.
OC.
Current builds
Completed works.
1 hour ago, Canute said:
Those vision blocks really set it off. OC. Nicely done.
Thank you kindly  Ken.
OC.
Current builds
Completed works.
Eveing all,   some more progress  -  I  over fitted a few more vison blocks  with the stick on "thingys"   and  fitted the cupula  vision  blocks  and  fitted the stick on pieces, I also  fitted the top and hatch.
OC.
Current builds
Completed works.
EXACTLY the way they are supposed to look brother! a kaleidoscope of colors depending on the angle of light reflecting from the surface...
Beautiful well done, well worth it...
Quote:
Beacuse of the delicate nature of the self sticky  viewing block  pieces, I will not be masking them in case they pull the coloured  papers off, I will be  hand painting the  cupula  assembly/FLIR/CITV  and  drivers hatch  as they will be easier  to  hand paint  and  put on when the main turret  is sprayed.
OC.
Current builds
Completed works.
Thank you  so much,    they were/are  fiddly  but as you say  so worth it.
OC.
Current builds
Completed works.
very nice progress ........the windows look great :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you kindly Denis.
OC.
Current builds
Completed works.
I did a bit of research  regarding  the  European  temp colour  the  M1  now wears,   and my understanding is  the  single colour Green  colour is  called  Bronze Green,  its  painted  in Europe  then  pressure washed off  when back in the States.
This is a pic  of am M1  in Europe  with the Bronze Green  paint applied  and the  Vallejo  Acrylic paint.
Pics of the net.
OC.
Current builds
Completed works.
43 minutes ago, FriedClams said:
Good research OC. - that Vallejo looks spot on to me.
Gary
OC.
Current builds
Completed works.
Evening all,    I did a wee  bit more  on the turret today,   I made up the smoke grenade launchers  and fitted them  also the side bins.
OC.
Current builds
Completed works.
Morning all,  no work progress  as life  required my attention  (well  tv actually  lol)  but I  have been doing some research   into the visual differences  between the  base  M1  and the latest M1A1/ M1A2, and  apart from the  additional  fittings the Two main Turret  changes  are  - the front turret faces  received  some extra armour  of around 150mm  thick  - extending the physical length of the turret, and the rear edge of the turret was sloped in the M1  and  straight/flat in the  M1A1/M1A2.
Here are a few  diagrams  off the net  that show the difference  -
OC.
Current builds
Completed works.
Evening all,   so  I made up for lost time  today  and  got a bit more  done  adding more details to the turret  - side rails  rear  cover etc.
OC.
Current builds
Completed works.
