This will be my first attempt at a full wooden ship build.  I have built several plastic model ships (Constitution, Cutty Sark and Charles Morgan, all by Revell) and R/C model airplanes but, this will definitely be a test of skill and patience.  I started by building the NRG half hull to get some experience with planking.  That went pretty well and I learned a lot!
I have always wanted to build a model of the Bluenose, as I am from Canada and have been fascinated by this ship for as long as I can remember.  I took the opportunity to dig in deeper to its history by reading Bluenose by Brian and Phil Blackman and A Race For Sailors by Keith McLaren.  This ship has a fascinating story and, unfortunately, a sad ending for such an icon of maritime history.
I purchased the Fair-A-Frame from Model Shipways, as it looked to be the best way to hold the keel while I worked on bulkheads and everything on the deck (and I was able to get it on sale!).  I modified it based on the changes that @Retired guy made prior to his Bluenose build.  This is definitely an improvement to the unit and really locks in the jigs that slide along the base.
I have been procrastinating since finishing the Half Hull, mostly because I am a bit intimidated with this build.  Reading through the forums, there are so many talented folks and high quality builds of this model.  Time to get under way and I hope that I can do it justice.
Edited by Fubarelf
Completed model. Add FINISHED to subject line.
Getting started on the build.  I suspect my assistant will be by my side, either sitting on the box, the manual or the plans throughout the build!
After checking through all of the parts (nothing missing) I got started on laying out the keel. I laid out all of the reference lines.  All of the pieces were straight but, I had to add several spacers at the joints to keep the reference line matched up and make sure everything was solid.
Once I had the three pieces together, I laid out all of the rabbet, bearding and bulkhead lines.  I then started to carve all of the rabbets.  This was one of the tasks that I feared the most.  I did get some practice on the NRG half hull, but that was only one side and it was a relatively simple cut.  With the varying widths and only 1/16 inch to spare at the deepest portion of the rabbet, I was concerned with cutting too deep.  I took my time and I have to say it was actually a very enjoyable process.
image.jpeg.36f68446e76c21b30cd85a4d7255c635.jpegimage.jpeg.3f7f4c709bf14dbc6912d6c9e1e65d17.jpegimage.jpeg.5745c8b2227a7b4863e55418f939220a.jpeg
image.jpeg.6e439533130504db537c5ddb4634e5fd.jpegimage.jpeg.778f340f17b6f563565ca85416bde693.jpeg
You're off to a great start and I'm sure you will enjoy building this model as much as I did.
This is a fun vessel to research; there are quite a few pictures and other resources on line. Based on all the old pictures I located I would say that the Model Shipways plans are very accurate. I didn't find any major discrepancies.
My favourite thing to discover were the two different versions of the stern lettering. I discovered these two different pictures:
The first picture shows the Masonic emblem and the second picture shows the Odd Fellows emblem. I understand that the Masonic emblem was the original decoration and that it was changed to the Odd Fellows emblem much later.
I'm looking forward to following your progress.
David
Current Build - St. Roch, Billing Boats; HMS Agamemnon, Caldercraft (on hold)
Previous Builds - Armed Virginia Sloop, Model Shipways; Constitution, Model Shipways; Rattlesnake, Mamoli; Virginia Privateer, Marine Model Co, restoration; Prince de Neufchatel, Model Shipways; Charles W. Morgan, Model Shipways; Pride of Baltimore II, Model Shipways, Bluenose, Model Shipways (x2); Niagara, Model Shipways; Mayfower, Model Shipways; Shamrock V, Amati; HMS Pegasus, Victory/Amati
Thank you David.  I enjoyed reading your build log of the Bluenose. I definitely appreciate any feedback or guidance as I work through this build.  I would like to be accurate to the original and will continue to research as I work through the build.
I think I prefer the original stern lettering with the Masonic symbol and will look to replicate that.  I have a long way to go…
Tim
Nice start Tim, and glad you found the modification to the fair a frame it was not going to work to well without it, I see you added a strengthener which makes perfect sense.
It was a sad ending to a beautiful ship.
Don't be to intimidated with this build it does turn out to be one nice looking model,  but I would say just follow the instruction manual .
Regards
Richard
Richard,
Thanks for the encouragement.  I have read your build log multiple times and it is a beautiful build!  I am in awe of your skill and definitely have shop envy!  I don't have the space, funds, or time to dedicate to building a shop like that but maybe someday...  In the mean time, I will take my time on this build and draw from all the great ideas and advice I have found on this site.
Tim
After I had all of the rabbets cut in, I glued reinforcement pieces over the keel joints at the keyways.  I waited until the rabbets were cut in to keep the keel laying flat on the workbench while I carved and sanded the rabbets.
01FAAD33-1C7A-41BE-9F8D-BF18061BC71B_4_5005_c.jpeg.daf451ea5461815f23f9e129ff416a46.jpeg0CAAA073-2429-4650-8F61-719BEE4DB52A_4_5005_c.jpeg.3c6f55374c07a91f3662751ef276499c.jpeg
 Next up, the bulkheads.  I cut out all of the bulkheads and then marked each with reference lines and bevel lines from the plans.  I then took the time to shape each one to the planned taper with a Dremel and sanding drum attachment.  This is definitely easier than trying to sand the bevels once attached to the keel and, as you can sand them individually without having to constantly handle and work around the full assembly.
10B92A69-5595-48FA-96A1-70EFD4005FCA_1_201_a.thumb.jpeg.96d1adb72f8594299d00e7bea77bd3ca.jpeg
I test fitted the bulkheads to the keel.  I sanded all of the bulkhead and keel slots to remove the laser char on the mating surfaces.  Some of the bulkheads were fairly tight or did not want to fit at all without extra sanding of either the bulkhead slot, the keel slot or both.  Once I had everything fitting nicely, I began to glue the bulkheads in.
The Fair-a-Frame was good to hold the keel and keep it aligned, but the bulkhead jig was of no use for this model.  It is designed to align the bulkheads at a right angle and perpendicular to the bottom of the keel, but none of the bulkheads on the Bluenose are aligned at right angles to the flat part of the keel.  I used the extended slot lines I transferred from the plans to make sure the bulkheads were seated properly and then used Lego bricks and clamps to hold everything square while the glue dried.  I worked from front to back, gluing every second bulkhead in, to allow space for the Lego and clamps and then came back and glued in the rest. (I forgot to take pictures of this step :()
Once all the glue had dried I added support pieces between the bulkheads on each side.
F0F0FD02-A34B-4DF9-9D5C-7775ECB54438_1_201_a.thumb.jpeg.11b6e3261450033546ef69f1c2464e12.jpeg
E385E5BE-FD7C-4157-9D21-A26F3B155111_1_201_a.thumb.jpeg.f1f3671c9f0d0f5e02d2be13e25e80cb.jpeg
BE5F82DE-2A06-413C-9299-9A9A3161A955_1_201_a.thumb.jpeg.361c4d52030c691bf5cd7b81f869c6f3.jpeg
You will probably notice that the stern bulkhead is missing in the pictures.  I took these after I had started working on shaping the stern blocks.  I had reinforced the fragile section of the keel with a couple of scrap pieces, sandwiching the keel with a clamp.  It worked well...until it didn't and I broke the stern section off.  Honestly, it was actually MUCH easier to work with one it was detached.
Most of the bulkheads lined up really well with the bearding line, with very little carving or sanding.  There were a few toward the stern that required some extra attention.
A12478EE-9198-47B3-B2F2-99ACF578D3DD_1_201_a.thumb.jpeg.3e21d64980b029bd687174c9807e8cfc.jpegD2C5E375-FBCA-44D5-9BF0-799B2853F400_1_201_a.thumb.jpeg.39a47549ef7cc4dd7a49a0ce1bd8450f.jpeg
I glued in pieces to fill the gaps and then sanded to align to the bearding line.
8647F6FA-BECE-4970-803A-79CC4B532B19_1_201_a.thumb.jpeg.5f7f94484031ad0494431d904890b3ef.jpegD83A8AF4-DB4B-459B-8830-9CC0E41BE4A9_1_201_a.thumb.jpeg.6d7dafa27b2f4f4bd84591a38e4afbac.jpeg
Wanted to make sure I was not missing something in the instructions or plan.  The plan and instructions show 2 pieces for the great beam and one for the deck beam at bulkhead H.  The single deck beam is on the same laser cut sheet as the keel.  On the other small laser cut sheet, it looks like there are two each of the great beam pieces.  Each piece measures to the plan dimensions. Are they just extra or am I just not seeing where they would be used?
If I remember right, for some reason there are two of each but you only need one of each.
D
As I mentioned earlier, the stern section broke off while working on the stern block.  I marked up the blocks and got them cut down a bit prior to gluing to the stern.  I had completed the rough shape of most of one side and "snap".  While I would not have purposely broken or cut the piece off, it certainly made it easier to work on.
I finished the shaping of the stern blocks and then added the quarter and transom frame pieces. I made several attempts to get the side "steep tumble home" pieces cut out and shaped.  I really had to think through the process to cut and shape the complex curves and angles from a square block but, finally got the two pieces to what I think is the right shape and both sides pretty closely matched.
9D92BFBD-79CC-4792-B053-E05E434CE728_1_201_a.jpeg.ac43a33bf2c13164d449a7d1c7128b25.jpeg40BBDE47-0E9B-4B6F-9B30-BFCD594583F7_1_201_a.jpeg.2827a042e2a95a10a85db8219ee88c66.jpeg05D3288A-99BB-48CA-9E61-5F9507436D28_1_201_a.jpeg.6d97956e176eeb9e9400e4722164cc27.jpeg
After completing, I reattached the stern section to the keel.  I added reinforcement braces and then installed the horn timbers.
04590B70-62A7-4CFE-95FA-AF3FC8361D99_1_201_a.thumb.jpeg.c88011dba88f8183e26e904499f101a3.jpeg
6603626B-32D2-49CB-A6B5-813EE55E6A9E_1_201_a.jpeg.b226f3f40e4511547e33c084c53275dd.jpeg6063B3CC-FAEB-4E52-9B5A-FC193CF2D293_1_201_a.jpeg.8f2330dddb6bde804c2d7a761193c716.jpeg
Last think before moving on to the waterways, I drilled and cut out mast blocks to slide into the slots in the keel.
67835862-6DE2-4506-9A5D-5E299A99ECD1_1_201_a.jpeg.4a2f6960ea3ec651d6ff4b332d7bd861.jpeg39E3D442-94DD-4B7A-8157-888234EDC52F_1_201_a.jpeg.b1e9af58eab807d59b5534b6eb3c9ef3.jpeg
Hoping to get started on the waterways this weekend.
Tim
Hi Tim, and Welcome to MSW.
I do have to say you have done amazing job so far. Specially the recovery of the broken stern piece.
Respectfully
D
Thank you David.
Thank you Nirvana!
Moving on to the next step in the manual, I worked on installing the waterways over the weekend.  Had to make a journey (40 miles) to the nearest hobby store to get 3/32 x 3/32 strips.  The kit was short 2 of 4 (which was the only thing missing) and I had thought at the time that I might be able to make due with only two, so I didn't bother to have MSW replace them.  Well, that was before I made the error of using them for the waterway planks that fit between the stanchions. Supposed to be 3/32 x 1/8.  I had the right size pulled out of the box and set aside, I just grabbed the wrong one and went to town.  Measure twice, cut once!!
To begin with, I added scrap "shelves" for the end of the planks that butt up against the bulkheads.  I probably could have held the planks in place long enough for the glue to set but, I had seen this done for other builds and thought it would be much more sturdy.
F012346E-0D12-415C-86D0-AA0CF7876C52_1_201_a.jpeg.b641afcefcbccdff57469d7fc70d27d0.jpegC305DD6E-24A0-40D7-B7F9-3B45F7E5EFDF_1_201_a.jpeg.68ca56c1752bbc72c900340f6bdb46aa.jpeg
After removing all the wrong size planks, I cut the 3/32 x 1/8 stock to fit in between the stanchions, test fit and adjusted to make sure everything was lined up, and then secured with a drop of thin CA at each end.  I cut and installed the second plank row of the waterway next.  Rather than just use one long plank, I cut the plank into sections.  The bulkheads are about 8' OC based on the scale of 3/16" = 1', so this means 8 or 16 foot planks.  I figured this was reasonable, and without adding something in-between the bulk heads to support the joints, there really was no other option.  I used wood glue along the edge, at the joints and where the planks sat on bulkheads to secure these.
                                      Wrong Size                                                     Correct size with second waterway plank installed
4FA586F7-7B57-47BD-9BF1-0678659044F4_1_201_a.jpeg.855beda39580b777b3a15b8f89b25ef4.jpegAB509B0D-41EE-4681-BF40-A7F8C04FFCE0_1_201_a.jpeg.61b47ed99db5cebfc80e721856d68896.jpeg
I finished up the fore deck waterway by installing the 3rd plank row in similar fashion and beveled so the inside edge was 1/16" to sit flush with the rest of the decking to be installed later.  I offset the joints so that I didn't have any side-by-side.
6A093A02-8446-4919-8D78-670BC0A37621_1_201_a.jpeg.527d5db7f3b98823676ce2ff8b9a0eeb.jpegAB509B0D-41EE-4681-BF40-A7F8C04FFCE0_1_201_a.jpeg.bf6b8efc1f791da01e12c4c2896e2331.jpeg
Next, I installed the quarter deck waterway between the stanchions.
4A122A58-2284-4E49-B224-5AC4AF6DD4F0_1_201_a.jpeg.57e136c59932a5c7564c4b7d0f9193d1.jpeg
That's it for now.  Although out of sequence based on the manual, I plan to add the nibbing strakes next .
Tim
Decided to wait on the nibbing strakes until later and worked on the hawse timbers, knights head per the instruction sequence.  I constructed the hawse timbers per the instructions as they were on the real ship.   First I cut 1/8 square pieces for each side to the proper angle and just a bit longer than the plan and glued together along a straight edge as a guide.  I then cut the fake stanchion and triangle piece and glued them in place.  Lastly, I made the knights head and glued in place.  Once the glue had dried, I measured and drew a line across the top of the finished piece to the match the plans and then cut along the line to get everything even across the top.  Last step was to bevel the knights head.
10F82AAD-F8E9-4475-8CB9-D23D0102A9FC_4_5005_c.jpeg.30805647cade56d549934281e70e3eca.jpeg
I built the whole piece as one to keep everything lined up appropriately and then cut out middle stanchion section and glued the two pieces in place
94829221-3329-49D0-89AF-3F41A4F9AA05_4_5005_c.jpeg.d2a44105194765a244be29629387b718.jpeg793898E1-D26F-4313-BFDD-EEDFC40FF09E_4_5005_c.jpeg.54ae7d695916e2d52eff35077d6b6912.jpeg
After gluing in place I notice that the bulkhead "A" stanchions were short by almost 1/8 of an inch, so I added 1/8 square stock to extend them to the top of the hawse timbers.  I checked the rest of the stanchions on the fore deck and they were all short to varying degrees, so I added stock and sanded them all to the correct height.  Looks like the quarter deck stanchion are short as well, so I will deal with those before moving on to the main rail.
2F9CEDFD-DAD3-4C8B-95FD-6929282FC4FF_4_5005_c.jpeg.698a527743926540297a3c7844192507.jpeg
After gluing both sides in place I worked on the hawse holes.  using a small drill bit in a pin vise, I drilled several holes through the hawse timber at an angle around the inside of the oval I drew from the plans.  Once I was able to open up the hole, I used a round file to finish shaping it out to the edges of the line, trying to maintain the offset angle.  When that was complete, I added the chafe blocks and shaped them to match the hole.
7EF8744A-B5BF-49B9-A29F-32D60F537483_4_5005_c.jpeg.22bf07009844dfab140e948499c52f75.jpeg46B13C4D-5E6B-4B2B-82F0-473812128C80_4_5005_c.jpeg.cb130249651b46201388ba55431b29a8.jpeg549E05B3-5006-4C65-B34B-51E5EBCD89B2_4_5005_c.jpeg.742c96e668f02913c76c49079b2e1ea0.jpeg
Next, I moved to the stern and finished out the inside.
CF89BE63-6C5B-4DCB-AE93-1812C0E5387D_4_5005_c.jpeg.ff5bdcafcf67418335929b5a40fa07a8.jpeg
I am going to work on the main rail next and have traced the pattern for the section between the bow and stern laser cut pieces.  I will likely cut this into 4 pieces per the instructions to keep each to about 6".
6F57E58C-E770-4FF0-8F84-4C52E85132AD_1_201_a.jpeg.099f2cb1c820ea7d9ae74e405d40ae61.jpeg
That's all for now!
Tim
20 hours ago, Retired guy said:
Hi Tim your Bluenose is coming along brilliantly, but I have one comment, your last picture looks as if the back end of the stern block is not faired totally to the bulkheads
Here is a picture to what I mean, hope I am wrong.
If this is the case your planking will not sit right.
Regards
Richard
Thank you Richard!  You are correct.  After measuring, it is about 1/8 of an inch out at the end of the block.  Great catch and I appreciate you pointing it out.  I started to pull everything off of the stern block to correct it and noticed a couple of other issues in the process.  The gap the picture below shows is actually because the width of bulkhead “O” is over 1/8 of an inch narrower than the Sheet 2 - Plank-On_Bulkhead Hull Construction plan shows.  Bulkhead “N” is also too narrow.  The odd thing is that they both match the measurements from Sheet 1 - Laser Cut Wood Patterns.
So, going to take it all off and start over.  Unfortunate, but a great learning experience.  I will post pictures of the repair work when completed.
Tim
5A285563-26DA-4EF2-8957-983358E600E0.thumb.jpeg.843b1bbe8c777ff5864539c70a5d1f02.jpeg.
I have been working to fix the stern issue that was pointed out by @Retired guy.  I truly appreciate the keen eye and willingness to offer constructive feedback!  As I started to assess the problem and develop a solution, I determined it was best to just remove everything and start from scratch.  I learned a valuable lesson to measure all the parts and compare to multiple points on the plans.  It turns out that the bulkhead outlines on the Laser Cut Wood Pattern Plan do not match the bulkheads on the Plank on Bulkhead Construction Plan.  I built the stern off of the ship, as I had broken off the tail piece of the keel earlier.  I used the Plank on Bulkhead Construction Plan for all of the dimensions and when I reattached the stern, it turned out to be wider than bulkhead N, causing the flair out toward the stern.
So, I ended up adding strips to bulkheads L, M and N to bring them to plan dimensions.
22609144-FB9E-4E82-A678-E84F0BE02BB9_1_201_a.jpeg.b79e59266933a932fcbd72afc7834f4d.jpeg578F3229-943B-48A4-B66B-11417F91A489_1_201_a.jpeg.3fbbe9469cdb27c73168b0462c75cf05.jpeg7D4CCC06-3708-4C0E-968B-6E5CE29A85DF_1_201_a.jpeg.99e8be6644d55ff2961d1020f6a650d6.jpegEADF0FE9-D15A-4110-A58C-F37806218B30_1_201_a.jpeg.8dd2791eb8079ea26db5929a6a31051d.jpeg
I cut a new tail piece and bulkhead O from a 3/16 thick sheet and then glued in the stern blocks.  After shaping to the plans and adding the transom pieces, I reattached the assembly to the ship with a little different reiforcement than I had originally used.  I had removed the waterways back to bulkhead L, so I recut and installed those.  Finally, I cutout and shaped new side pieces and added the stern fake stanchions.
78C3755D-8E3F-49F5-ACC9-CBDAF1E77A34_1_201_a.jpeg.ae3ca457b920c207fc3ea67b758faea9.jpeg3E6531D5-AF7A-4572-A9EA-02FE138BA687_1_201_a.jpeg.876b2ebac3a61c4c918b936b8290fd4d.jpegC653F5F7-6D2C-4A1E-A9CC-06EF07F2B8AA_1_201_a.jpeg.ac142f506cb7cd0a50ba6f602f99c6e3.jpeg3350F809-4841-4C84-9AB0-7BCBBF4A8101_1_201_a.jpeg.fe928e6603df47cdf97b42973dc92a77.jpeg
After all that was done I double check that the hull was faired from front to back and made some minor adjustments with sanding or adding strips where needed.  Had I done that earlier in the process I would have realized the mistake with the stern!  So many lessons learned and much happier with the results!  On to the the main rail...
Tim
Edited by Fubarelf
Absolutely lovely build Tim
I particularly liked seeing the use of Lego blocks.   I have a handful that my grandkids gave to me quite a few years ago and use them quite often.
Just curious, but is your screen name based on the military acronym?
Allan
Thank you Allan!  The Legos are quite a useful tool and, and cheap.
Yes, it has the same meaning as the military acronym.  I played softball on a team called the Fubar’s years ago.  I also worked for Keebler at the time, so I was known as Fubarelf.  It stuck and I’ve been using it ever since.
Tim
Completed assembling the main rail.  Needs a little more sanding, but trying to be careful not to over do it.
Added all of the fake stanchions to the fore deck and shaped to the hull.  I tried to cut them all to the same length with a kerf saw and mitre box, but there was some minor variation.  So, I sanded across the tops to make sure everything was even so the main rail will sit flush.
10565285-0BB0-4DDD-BBE1-2EE0B60798F2.jpeg.5055a393d69bf874b0b9e45e0204ccf2.jpeg9CD50414-B137-40BA-93CA-35E1B3999EBC.jpeg.f8a98372384edfb499e17f674580c883.jpegr
Tim
Hi Tim - Saw this build log in the list of "Recent Replies" on the MSW home page, and obviously caught my eye!  Hope you don't mind the follow and the encouragement.  As indicated in my signature section below, the Bluenose was a gift from my son some 16 years ago when I knew nothing about ship modeling.  Started it, but got frustrated and put it in the closet, where it became buried.  It's in my shipyard waiting for the next build, so I'm anxious to see how you do, and learn from all that you do.  Great start!
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
Thank you Gregg!  Happy to have you follow.  I have followed multiple builds of the Bluenose on this site and hope to do this kit justice.  I have received some great feedback and had to backup and redo a couple of steps in the build already.  Great learnings and hopefully a positive impact to the finished product.
It's been slow going the last several weeks.  Travel for work and great fall weather has left little time for working on the Bluenose.  I was able to get the first two rows of planking installed.   I installed the top row of 1/32 thick planking first.  I cut the planks into 5 sections, most spanning 4 bulkheads.  Next, I cut the cove into the top row of 1/16 thick planking with my table saw, ripped the aft section to the proper width and then cut in the scuppers.  I used roughly the same rule of thumb of 4 bulkheads to cut the plank into sections, making sure that the butts did not align with those on the plank above.  After install, I painted the stanchions and inside of the hull between stanchions white.  I had painted the waterways grey earlier per the clout on the plans.  I will need to go back and cut in the hawse holes through the planks and cut the planks at the bow to fit flush around the bowsprit.
41B208E1-1BBC-4145-AEB8-18D72F8A2AAD_1_201_a.jpeg.a52c30f83749b7e5df585d10b5712e73.jpegB9E0B9AF-1302-4DB8-9BAB-15BCDCD5C1C5_1_201_a.jpeg.2d182d9a20d18893f481edd2cbc079d0.jpegE736888A-2F9F-4D98-9F87-723C2952E816_1_201_a.jpeg.6bd8ac0baa0ad379ce19bb3326361392.jpeg3F414651-2E14-4AB6-9399-26AEE851B951_1_201_a.jpeg.8315af8b0f6a90bfe9691938e504a6b4.jpeg
Tim
Great start on your Bluenose, Tim!  I saw your "like" on my initial Bluenose build log post and had to acknowledge.  Your build log here is one that I flagged to follow in order to lean on hints and advice.  Look forward to watching your progress!
Gregg
I have started on the planking.  I shaped and installed the garboard strake on both sides.   I this marked the first belt, based on the plans and marked out the plank widths at the stern and each of the bulkheads, along with the end point along the keel, where the planks taper into the keel.   That was the easy part!
I had planned to work evenly on both sides as I installed the planking, but after installing the first plank on each side, I kept going up the port side.  What you see in the 2nd picture below is the second attempt.  I was up to 3 rows of planking above the garboard and didn't like how it was turning out.  So, I took all that off and started over.  Having only done the NRG half hull before this, I am still learning, so lots of trial and error.  Slow going , but in no rush...
240E6749-4750-4673-9CD7-70E95E531A18_1_201_a.jpeg.b2f925ede8e523112a461744f1b5756b.jpeg
79A74482-039B-498F-BFE2-DAE4E152AF96_1_201_a.jpeg.f55638e2249ae7e015e65af4d95da725.jpeg
Tim
Looks like your moving right along. I recall ripping out about 1/3 of my hull planking and starting over because I wasn't happy with it. So don't feel too bad, it's a process, not an event.
Dave
Previous build: NRG Half Hull
Previous build: MS Bluenose
