Hi all!
This is my very first build, and I decided to go with this maker as not only are all reports good, importantly for me, I think I'm more likely to finish it!
The kit arrived very well packed and quickly - always a plus. I'm going to include lots of piccies, and if I post too many please tell me. Building will begin tomorrow with the construction of the working cradle. I'm keen once I start to spe as much time on her as possible, but ill health may rear it's ugly head now and again.
D7B70817-FCF2-4637-A98A-D80DAE531DCA.thumb.jpeg.1fec41f9f09b682946c322edea5fb0d0.jpeg99765199-5F7F-40CD-9A22-81C74F206716.thumb.jpeg.66e7f681e57dbccc405d4ab3e3b3f9f2.jpeg21A012DE-03EE-4565-928A-09196B24DA4F.thumb.jpeg.c1284375225a4eb9c30067b1db6def5e.jpeg
A new toy I bought which was included in the box.
176FD5EE-3DA5-4640-B42D-8A3A7BDB214C.thumb.jpeg.8540fecd85cd6ec3b85ac3deb639be54.jpegA2891D8E-94C7-4D65-9A5A-477199D6D5EC.thumb.jpeg.1b5df944177ec4f6ad84bd0cb9faab37.jpeg51B9F956-E5BD-4AB1-96D4-5B53BA65B8C7.thumb.jpeg.e66335c88e137a202ccea7f8bb183e1a.jpegThe very excellent manual
561C3F4D-8307-4405-BB6B-0ABB8F84C340.thumb.jpeg.74854e9ad7694d376eca261ea4843896.jpegTomorrow should see a start
Max
Altogether elsewhere, vast herds of reindeer move across miles and miles of golden moss, silently and very fast.
1 hour ago, Mike Collier said:
It looks like a pretty good kit. I like the fact the sails are premade.
Yes Mike, it certainly is a good kit. I felt that as it's going to be my first build,  it would be worth spending a bit more than I'd originally intended to give me a decent chance of finishing it! Time will tell.
Max
As will having the kit's designer as an active member here.
Yes, without question that's another bonus Chris!
Looking forward to this.
BTW, I removed the text formatting from your original post which covered the text in a brown covering.
Ongoing:
Many thanks James, that's a lot better!
Max
On 10/21/2022 at 3:33 PM, robdurant said:
Looks like you're well set for an enjoyable build. Hope you don't mind my following along.
By all means, admirers always welcome, but bear in mind this is my first kit!
Thanks all! A few more piccies. The building cradle was glued up overnight and is ready to support it's precious cargo. Bulkheads have been removed and the four shown separately are now ready to be bevelled to their individually marked lines. I haven't finally decided how I'm going to do this yet, so watch this space .
Remember, those bevel lines are only approximated. They'll help you take off a chunk of material before assembly, but will later be faired in properly.
Ongoing:
Thanks James, I'll bear that in mind. I've actually already done #1 which is the biggest amount of removal, I'll hopefully do the rest tomorrow
Max
Hi Max,
I’ve just finished building Saucy Jack, she’s a super boat to build and the end model looks lovely.
My build log is below, hope it’s useful. I strongly recommend James H’s build log of the prototype as well.
Good luck, looking good so far. Dan
Dan
Current Build: Sherbourne (Vanguard Models, 1:64)
Previous Builds (All Vanguard Models 1:64):
Fishing Boats: Fifie, Nisha, ZuluSaucy JackErycinaRanger
Warships (and Yacht): HMS AlertGrecianHM Gun Brig Adder, Duchess of Kingston Yacht
Waiting to be Built: Speedy (Vanguard Models, 1:64)
6 minutes ago, DB789 said:
Hi Max,
Hi Dan!
Many thanks for that, I shall hopefully gain some tips from perusing your build log. You look as though you're as keen on British working boats as I am, or is it just Vanguard? Whatever, you're accumulating a nice little fleet there! I'll pop off now and have a look at your log.
Max
7 hours ago, MaxC said:
Hi Max, thanks. It’s mainly Vanguard - the kits are so high quality and a pleasure to build. They’ve been a fantastic introduction to building model boats for me.
I had no interest in British working boats before starting to build these… but it’s amazing how beautiful these old trawlers were. Erycina which is my current build has stunning lines and reminds me more of a racing yacht.
Dan
Hi all
Well a bit more progress to report with a couple more piccies. It was nice and warm here today, so I sat outside with a file, and bevelled off stern and prow support pieces. The previous lot I did with the Dremel and grinding stone, but the dust was horrendous even with a spraying mask on. Not as bad as sanding iroko but bad enough. Anyway, I'm really enjoying this little beauty so far, with further instalments to follow.
MaxC
Okay folks, removed clamps and moved on a couple more stages. The biggest job was painting glue around all the joints, this took a lot longer than I'd envisaged. The biggest problem was getting in between small gaps. If I was to make this again I'd consider checking for fit and then gluing all the stern members as I went. The problem though with doing that is that you really would need to wait then for the glue to dry before proceeding. But although my gluing up doesn't look very pretty, none of it will be seen when the hull is planked.
I'll now giv it at least a day to dry out sufficiently
Hi folks!
Today I fitted the sub-deck. Having made sure there were no little nibs or such i as quickly as I could brushed some PVA over the upper structures then the slightly nervous bit of springing in the deck. I did a dry run on one side before I started the fixing but it was still a slightly worrying operation. Once it was in and I'd checked proper seating all round, I again quickly brushed PVA along as many points as I could easily get to. Then a few cramps to help matters and now rest until tomorrow..
Max
The deck shouldn't spring at all as it slots into the notches at the bottom of each bulkhead ear.
That's important as you want the deck level to be even with the engraved lines on the inner bulwarks that you'll later fit.
She's looking real nice!
Ongoing:
Thanks James! I'm enjoying this a lot more than I thought I would. A great little kit, the emphasis being on 'little', she's a smaller than I expected, and if anything it makes it harder with the small pieces. But, I'm really looking forward to continuing, so watch this space!
Max
Max
That's what makes them lovely projects for the beginner and 'in-between' builds too. Easy to display. I have my Saucy Jack on my fireplace at the moment.
Ongoing:
As do I! She’s a beautiful boat when complete.
Dan
Yes, I suspect that this little beauty will be considerably more straightforward than the Billings FD10 Arnanes that I have in waiting 🤔.
Max
Okay folks, next stage stern framework supports fitted. I was tempted to carry on with the pieces that go beneath, but decided I'd be happier leaving this stage to dry. The whole structure is now feeling a lot more solid and the sub-deck certainly makes me feel as though I'm getting somewhere 😊.
Max
  • 10 months later...
Okay, here I am again! Nearly a year later and hoping to rekindle my interest in this little beauty. All came to a stop when I realised that the fairing lines printed on the forward bulkheads are wrong? It appears that by taking them back to these lines can't be right, or is it and I just can't see it? Perhaps I was just not too well at the time, or just couldn't be bothered to resolve the problem. But, I'm intending to have another go. Watch this space 😊.
