On 1/22/2023 at 12:49 PM, CiscoH said:
planking looks great!
Thanks for the compliment  cisco
After sanding down I'm sure my planks will be uneven thickness.
Tim
Edited by oakheart
auto correct, garbage removal.
Current Builds :
Cutter "Speedy" 1828 from Plans by Bill Shoulders at 148
Bounty Launch - Scratch build - FINISHED
85 ft. Harbour Tug. scratch built  from plans by Francis Smith. ( FINISHED but no build log for this )
HMS Lightning. kit bashed from Deans Marine HMS Kelly kit ( FINISHED ) yes at last....
16 minutes ago, druxey said:
 bed that garboard down more.
Thanks for the tip Druxey, I think when I do the next version in Cedar, I do some pre bending as you suggest
it would mean less clamping needed
Tim
Current Builds :
Based on what Druxey advised I borrowed a heating tool from a model aircraft mate.
and bent the plank.
It really makes it easier to fit.
Tim
Current Builds :
On 1/21/2023 at 11:35 PM, oakheart said:
Next Time - ha ha, nice to see someone has faith in my new found skills ...
Tim
ps I have not been napping, but did not want to show plank by plank, more coming later today.
You got this.  And it's even more impressive since it's your first time.
12 hours ago, Montaigne said:
Kudos to everyone for sharing their research, ideas and suggestions, and to oakheart: well done so far, it's looking good!
Thanks for the compliments.
Allan and Craig are the experts here, There is a load of information on the their other logs as well.
I'm just here having a load of fun doing some research, trying new ideas and learning new skills.
Question Should all of the detailed information be collected together and put it in the "launch details" log.
Who started that log ?
was it Craig or Allan? my memory is not so good
Tim
Current Builds :
Allan, but it's a thread not a log.
It pretty much is, we don't know much. I'll add drawings (or a link to them after I finish my build and tidy the drawings up).
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
Tim
Thanks, I’ve been spending countless hours over the past days reading through MSW build logs on the Bounty launch. My head is going to start spinning in a day or two lol, especially considering that English is not my native language, requiring me to translate many nautical terms as I read. But it’s great fun.
I was thinking the same about the “launch details” thread, assuming you’re referring to the one linked below. I have a couple of questions regarding historical accuracy for my planned build, which will be a kit bash of the Model Shipways Bounty launch, and it feels as they might belong in that thread for posterity. But at the same time I don’t want to hijack someone else’s thread.
Edited by Montaigne
While Allan created that thread with a question about oars he later realised it was more a discussion about the Bounty's launch and he changed the title and purpose of the thread. Your questions would indeed be welcome.
Craig.
Thanks, much appreciated. I had missed the change of purpose for the thread.
I have now got to, as Craig said - the interesting bit.
Moving down the frame, now when I lay the plank on the frame, the plank is flat but the frame is curved !
In the photo, I have used a wider plank to exaggerate what happens, the problem is made worse when you can only clamp from one side of the plank.
Sorry - I could not get the phone to focus on the end of the plank, but you can see what's going on.
To overcome this I have just tried a test laying of a plank.
Firstly between the tick marks on the frame, I sanded that area flat.
It's glue up right now, we will see later if it worked.
How do others overcome this?
Is there a trick I am missing?
Tim
Current Builds :
Even native English speakers ( Me ) are having problems interpreting, understanding  and remembering the nautical terms used here.
It does sink in over time.
Tim
Current Builds :
16 minutes ago, oakheart said:
the interesting bit
There's a few things you can try.
First off, in a full size boat you can facet the frames as you have but this leaves a faceted interior, you can hollow out the inside of the planks to match the frames or you can use more skinnier planks.
In a model you have the additional option of bending the plank around the frame either dry or wet. Clamping with rubber bands helps and using hollowed out balsa blocks helps more. Only clamp on or close to the frames.
Craig.
Tim, try tapping the area on the screen you want focus on. A frame then appears and stays with the area even if you move your phone.
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
5 hours ago, iMustBeCrazy said:
1: Facet the frames as you have but this leaves a faceted interior
2: hollow out the inside of the planks
3: skinnier planks.
4: using hollowed out balsa blocks
5: Only clamp on the frames.
 so my take on those options are :
1: Could I live with the faceted inside - Yes, if it's not to noticeable it could be alright
2 : looks like it would be really difficult to do.
3 : Planks are only 0.8 mm ( 1/32 ") going even thinner may work, worth testing, may break.
4 : This would help but may need a lot of clamping pressure and crush the model.
5 : with the clamps I am using that's the only way they work, will try elastic bands
Thanks for all of those ideas, I will see how my faceted frame worked when I un-clamp it later
Tim
Current Builds :
I have now glued up the matching plank pre-bent and faceted the frames.
It looks good, so I think I will continue with this technique until I get round the bend, then up the straighter sides go back to normal.
I saw some one on this forum ( website )  who had planked straight from the Garboard right up to the gunwale in one run, so on this build that is what I am trying out.
As a programmer I was taught "only change one thing at a time" or you won't know what is causing the problem.
Here I have just jumped in with all feet first.
Tim
Current Builds :
Waiting for the 5th plank to dry, trawling through the incredible amount of build logs there are here on MSW.
I found this build log https://modelshipworld.com/topic/3741-queen-annes-revenge-1710-by-shipmodel-finished-136-scale/
Thanks  shipmodel  ( Dan ) your work on the QAR boats gives me a goal to work towards. It has re-inspired me, my planking was beginning to get to me.
I know this is only a tiny model but it is testing me.
Reading the QAR log I'm being tempted towards a larger project, like a pirate ship or a Bounty.
But I really do need to finish my launch first. I am too easily tempted into a new project, leaving a trail of part finished models in my wake
Tim
Current Builds :
The planking has been ongoing.
I am really not sure about it being correct. I need some advice.
The way the planks are tapered from the frame towards the stem looks odd, but I cant figure out what it is I've got wrong?
should it be more like the penciled in line ?
IMG_2844.JPG.98db9a92993d6119e0b355dfdcd43136.JPGIMG_2846.JPG.f4812fc1645fcbca0926be4bef16640e.JPGIMG_2845.JPG.26887c2f87ebc98fecfaf6f55cff114b.JPGIMG_2841.JPG.e708fe87dfe115c008ae734af98e1f47.JPG
With the photo above , I can also see that I missed the tick mark on the stem one plank up, that can't be helping.
Tim
Current Builds :
That looks exactly what I did on my first version of the Kågen hull.
While the planks themselves looks okay it is the buildup of tiny errors that get you to where you sit right now.
The culprit looks to be the second plank, the one above the garboard. It runs too high on the stem. I found out that a nice run of planks looks straight when eyeballed from stem to stern at specific angles.
See this post from my build log and the discussion that follows:
Don't let your heart sink though. It IS a learning experience!
Keep it up!
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Keep it up!
Thanks for that Håkan.
I do need to remember that this is going to be my 'dirty' boat so any errors will be hidden, the next version in cedar wood is the one that I want to look good.
I will read you build log.
Tim
Current Builds :
1 hour ago, allanyed said:
Cumulative error is the bane of many a ship modeler.
Allan -  thanks for reassurance
Note to self : must pay more attention, not just zoom off following my nose.
Tim
Current Builds :
I think that's a note to everyone.
Right or wrong, this is what I do.
First determine the maximum height up the stem of the garboard. This varies with the breadth of the plank. Cut a piece of plank the same breadth as the garboard short enough to sit in a straight section of the keel rabbet, use this as a spacer for a straight piece of balsa which reaches to the stem rabbet. That point is the maximum height up the stem of the garboard.
At this point you can take measurements to get the curve of the garboard in the stem rabbet (put tick marks on the balsa and note measurements) but I tend to 'wing it'.
Fit the garboard strakes.
Now some maths, working out the breadth of the 'normal' strakes. Measure the distance from the garboard to the top of the sheer strake and subtract any 'abnormal' strakes, in the case of this launch remember to measure the outside of the planks not just along the frames as the planks will be narrower on the inside of the curve. Divide by the number of 'normal' strakes. If the result at the stem (or transom) is less than half the maximum breadth (at station 0) consider adding another strake.
Note that at the stem the number is the length along the stem rather than the breadth of the plank.
Repeat the calculations for each frame. And you should re-check your calculations after each strake.
I then use the masking tape method to get the abutting shape of the next strake.
I then shape and test, shape and test, shape and test, shape and test, shape and test the next plank.
I then use the calculated widths to shape the other edge of the plank. (note the measurements noted on the plank in pic 3 above).
Rinse and repeat.
Edited by iMustBeCrazy
Craig.
Wow, thanks Craig.
I have only a couple of planks left to bodge on this build, ( the dirty boat ) but on the cedar version this is what I will do.
I have copied and pasted it into a word document and will print it out so I can refer to it.
Tim
Current Builds :
Tim, note that it's not perfect. I've fitted the next plank (that shown in pic 3) and it doesn't quite look right, That curve, I think I have to reduce that 5.8mm to 4mm. Maybe, I'll ponder it.
Edit: I left out that you should re-check your calculations after each strake.
Craig.
Well here we are, I finished the planking and let the glue set overnight.
Then with great trepidation I cut the frames away from the jig. With some wriggling and gentle pushing the hull popped off.
Now some detail shots
External
Inside from stern and stem
1634153079_insidefromstern.JPG.3ea515e2f4b974d7f02defe45906017b.JPG720609283_insidefromstem.JPG.c0d1432676d6b7e27f5547a012f2afad.JPG
close up
I am really pleased with my very first plank on frame.
It needs a fair bit of fettling, I have learned a lot by doing this
The frames need a lot of sanding, but I have learned to be careful when sanding....
I think I can fix this by gluing in a patch on the inside
so as a proof of concept it worked.
Comments please.
Tim
Current Builds :
I'm continuously impressed with you going almost straight into scratch building and the results. I have a scratch build planned myself, but only after completing two of my first ever model kits: the Bounty Launch and The Endurance (still in the "planning everything and saving up to buy kits and tools" stage).
I'm also happy to see you persevere when the construction don't quite add up. I think it's turning out quite well indeed.
A model ship builder friend of mine often jokes about his model possibly ending up as firewood when he encounters difficulties, and I keep telling him it would only keep him warm for twenty minutes. In your case, considering the size of the launch, it would only be a matter of a few minutes, so keep up the spirit. Every time we make a mistake, albeit at a price, we learn something new.
I have heard that "we learn nothing from success", can't remember who said  it.
Thank you for the encouraging words, they help to keep the fire going.
Thanks too to all the lurking likers 🙂
moving on, whats next?
Thwarts and gunwales I guess.
Tim
Edited by oakheart
fumbling fingers
Current Builds :
Comments please.
You have convinced me to try this method on my next go at a ship's boat. I can see how this can be used with the floors and futtocks being set up as separate pieces as well.  It will be interesting to see how it compares with traditional plug former methods at 1:48 or smaller.
Anxiously waiting for your next installment!!
Allan
