Hard to believe you did all of this in a little over 3 months.   Fantastic job.
Had the same issue as Glen with the stern cleats, likely did not push edges down enough when gluing the deck.
Used this to elongate.
Then glue and filler
Then paint
IMG_7292.thumb.jpeg.d9a08d2b952cc191e8aa7d736ae6e928.jpegIMG_7293.thumb.jpg.32667fb974902db732d3efa1c9f62349.jpg
Did the faux woodIMG_7290.thumb.jpeg.ec6e176c352cd1f26a6e2f565b02fa91.jpegIMG_7291.thumb.jpeg.edb575d65565c8f33c7c70fdb18ecee9.jpeg
Final placement
IMG_7297.thumb.jpeg.5cbbae096aa91117fb18dbef93446ab4.jpegIMG_7295.thumb.jpeg.9f772ae29ec241daf586258c4d675005.jpegIMG_7294.thumb.jpeg.47c711fedafec34badf19eaf833a9b87.jpegIMG_7296.thumb.jpeg.fb244e61f43140ef2eea5af1569127d2.jpeg
Unfortunately the glare makesIMG_7289.thumb.jpeg.46cd7f813ce0877c2a2fcda340fd0eac.jpeg the stern look a bit off but not in real life.
Continuing onward, finished the deck fittings for the stern of the ship. Can see nicely through the skylight. You may notice I removed the stern lanterns as I was always catching and bending them. Will put back at the end.
IMG_7299.thumb.jpeg.0ecf79eb28caa8dff1a93599165eba58.jpegIMG_7301.thumb.jpeg.096345d075ae77ea581f95eaceda63f6.jpegIMG_7300.thumb.jpeg.7ef91b06fbcd60cae8331175bc82b35d.jpeg
Fitted the carronades
IMG_7309.thumb.jpeg.1b3f6a63245e9895d32ea8b83fd0dee9.jpegIMG_7308.thumb.jpg.8e03da13b4937a172a06ee4767f7d70d.jpgIMG_7302.thumb.jpeg.8882d62cf64b01bf9157ea38c05142f2.jpegIMG_7305.thumb.jpeg.f9374a0fc86e83f95a2eb369f30fa3e2.jpeg
IMG_7307.thumb.jpeg.da2664182e72a363c7227cb548ff0dc8.jpegIMG_7304.thumb.jpeg.db74217baddcc42454238b78eb7fa1fd.jpeg
You can see I wrapped the wheel with the steering tackle
The Capstan lines up nicely and inserted into the lower deck one.
Hopefully will finish by the end of the week. I will not install much of the railing as I usually bend it all out of shape when I am doing the rigging. Of course the anchors will also wait until the end. My debate is masts or the ships boats which are always a bugger to do.
Wow.  Looks fantastic.
Finished planking the buggers. There are 5 ships boats provided, duplicate 24 ft boats but I had to much battle damage on one of them to continue. Have 1 each 32,26,24 and 18 footers. Will take a lot of sanding, filler and paint to get them into shape.
IMG_7338.thumb.jpeg.35d6f9b61be66b4e30549d53897fc601.jpegIMG_7339.thumb.jpeg.3cd182a724ba741c2a2d715c46d164dd.jpeg
IMG_7349.thumb.jpeg.8fa619f2fd3cd0c48bdfd7cf4a7464e5.jpegIMG_7350.thumb.jpeg.a8e6214772ae5d452560dff44dc97551.jpegIMG_7351.thumb.jpeg.1c0d701548094adf7a6aca9da859c977.jpegIMG_7352.thumb.jpeg.949139f523cba044d90f7190184a1a62.jpegIMG_7353.thumb.jpeg.5d45896371c9eff91b3e0a861a671b11.jpeg
Well, back after a week of visiting my mother on the occasion of her 91st birthday.  Am building the mast lower sections first then upper. Previously I would build each entire mast but as these require painting and bindings I decided to do a bit more assembly line manner. I used tape instead of the black cardboard as I always mess the cardboard up and the tape sticks better. As the tape will be painted, color not an issue. I also added nail head as there are markings for bolts but the plan does not specify. I think it dresses the top up .
IMG_7449.thumb.jpeg.2e145a5dc84cb2e087736b209b9aec86.jpegIMG_7450.thumb.jpeg.baa666e603b219cb5ff1a32fc1bbd0f9.jpegIMG_7451.thumb.jpeg.ddbc194bf87b7c1c9eafd83f9f77e48f.jpegIMG_7453.thumb.jpeg.0dc9b7773d58b30311ad9dd1c453026d.jpegIMG_7454.thumb.jpeg.7d8cd984a24b37a3fc3dc43fcc725ac3.jpegIMG_7455.thumb.jpeg.f9de9d78e5e7feecf78e5f8eba0b4418.jpeg
she looks fantastic
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Last job of the day, also did the bowsprit, not as bad as I thought. The plans were well drawn making the angle cuts pretty straight forward. I opted for the extended jib. Stiker not on as it is one of the parts Itend to break so will add at the end. The bowsprit is not full engaged as I do not plan on putting it in until the masts have all their shrouds in at which point I will do the stays.
IMG_7471.thumb.jpeg.7b09cf9fdc0f1c016b593f101f8da779.jpegIMG_7470.thumb.jpeg.f61ca9d9e0a6b4978b4e37dbe501f0ec.jpegIMG_7469.thumb.jpeg.1da37cc2fcfaf6ac6a842d3948251353.jpeg
Spent the week making up all the yards. Not rigged yet as they have to be painted first. There are some differences from other yards I have done. In this the fore and main topsail yard have a different central configuration compared to the mains.
Pre spray painting. Note I use tape instead of the cardboard as I never get the cardboard correct. The tape sprays up nicely. Unfortunately I was short 2 8mm dowels in the kit but luckily I had spare dowels in the shipyard.
IMG_7500.thumb.jpeg.8c655cc1ce7493e578e269d40b953b8f.jpegIMG_7501.thumb.jpeg.8273073e38c36f0e9fbbe70594379bed.jpegIMG_7498.thumb.jpeg.ce3c5f74ada64257f24f96c5c7f8452f.jpegIMG_7497.thumb.jpeg.7a0b6bf4b28fbe0a5f677328291abfaf.jpeg
After Painting mizzen
Main
IMG_7504.thumb.jpeg.5493a4572086522584d3eacf3ceb6766.jpegIMG_7503.thumb.jpeg.ab781deecc37eacf0baf151bdd2c7168.jpeg
Fore and spritsail
IMG_7502.thumb.jpeg.6a17792fe7de617805eb972aeffbf5dd.jpegIMG_7505.thumb.jpeg.b7af3dbe99d1b53c1250122380cd4cc9.jpeg
Next week will be gigging the yards.
Edited by ECK
