2 hours ago, Gregory said:
Just moving the pin into the cut-out should do it.
Thanks @Gregory  it will be the next job on the list.......
Edited by oakheart
Current Builds :
Cutter "Speedy" 1828 from Plans by Bill Shoulders at 148
Bounty Launch - Scratch build - FINISHED
85 ft. Harbour Tug. scratch built  from plans by Francis Smith. ( FINISHED but no build log for this )
HMS Lightning. kit bashed from Deans Marine HMS Kelly kit ( FINISHED ) yes at last....
17 minutes ago, allanyed said:
this gives the idea on their shape.
Hi Allan @allanyed, thanks for the compliment.
Those look a little complex to replicate at this scale, but I may amend the shape a bit
Current Builds :
Another interesting one, dated 1830.
Note that the forward edge of the pintle lines up roughly with the forward edge of the rudder and that the 'notch' is depicted dashed indicating a pocket which will look like a shallow notch from the side.
ZAZ6679-2.PNG.0561f4691f7c676a235a608346bda4eb.PNGZAZ6679.PNG.ac8cae4996ecf989cfddd6cca9f71091.PNG
Edited by iMustBeCrazy
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
The holes through the gudgeons should be aligned with the aft edge of the stern post as well. As mentioned, there should be a minimum gap between rudder and post.
11 hours ago, iMustBeCrazy said:
the 'notch'
Hi Craig @iMustBeCrazy talking of notch, it looks like the straps are rebated onto the wood of both the rudder and sternpost?
Don't think I will be doing that.
Tim
Current Builds :
Yep. Don't blame you, lots of things just don't scale well.
Craig.
Always ready to rush ahead.
I tapered the rudder top to bottom and fitted the top two pintles.
Then blacked them, I think they turned out pretty well. I am very pleased
closeup you can see there is a bit of bleed round the straps but it almost adds to the reality of the model?
they do look the part
Tim
Current Builds :
Gudgeons in place still to be bolted down and blacked.
The centre one I cut a bit short, If I can find the energy I may remake it, then again once the model is finished I may never notice it.
I need to trim the pins to a better length.
Tim
Current Builds :
Working up to the tiller.
My feeling about the original drawing is that it does not look right?
I have  a scale and figure ( @ 1:48 about 5' 9" tall )
which I have placed in bills drawing
I have this photo of BM45 Pilgrim built in 1895 ( much later I know ) but about the same size as speedy.
here is my rough cut based on Bills original drawing
does it need to be longer / higher to look right ?
Tim
and yet another rabbit hole, Alice here I come..............
may be of interest to others, here is Pilgrim BM45 in 2008 before her £1 million rebuild
Edited by oakheart
Current Builds :
Original?
Craig.
53 minutes ago, iMustBeCrazy said:
Original?
Thanks Craig, that is much more elegant, I will remake it to suit.
I forgot, your Lapwing is a sister to Speedy
Is that from zaz6425? I have a copy of that, should have checked it.
Tim
Current Builds :
14 minutes ago, oakheart said:
remake it to suit
the 'sheds' WC and pantry also look better in the orginal
Tim
Current Builds :
And some whittling later a much nicer tiller
now to tidy up round the base.
Tim
Current Builds :
It's the Danish version, G5757 .
2 hours ago, oakheart said:
a much nicer tiller
A much nicer tiller indeed.
Craig.
Yes now I look the RMG draught is different again to both that and Bills drawing.
I like the Danish shed better.
looks to be more leg room.
Tim
Current Builds :
First thanks for all the likes guys
The tiller is now finished, I just need to put some kind of lining around the post just to neaten it up
What's next?
I do have a list somewhere maybe I should look at it
Tim
Current Builds :
You might find THIS thread useful.
Craig.
Thanks Craig, that is indeed a very interesting discussion.
My solution is much simpler. A sort of skirting, it won't stop much water but it looks a bit neater than just a ragged hole.
Tim
Edited by oakheart
Current Builds :
9 hours ago, druxey said:
Usually rudderheads were boxed in, with a slot for the tiller.
Thanks @druxey I have just started reading the thread that Craig @iMustBeCrazy gave a link too above.
Was there any conclusion yet?
I can't see any details on the drawings I have, also the kit that @Thunder built did not give any details either.
Was it just a given. The shipwright just did what was always done.
I will be quite happy to make something suitable for this cutter model if I can find the shape and size.
It's all a voyage of discovery for me at this stage in my model ship building.
Tim
Edited by oakheart
Current Builds :
ZAZ6349 (Vigilant as fitted) I think is the only 'family member' drawing that shows anything. It's quite an elaborate structure with two wc's and a number of lockers and extends all the way to the stern.
I suspect they had a canvas cover over the slot and tiller.
Craig.
Thanks Craig @iMustBeCrazy I have done some more research and think I will leave it as it is.
Why
examples of Cutters from that period
@Chuck Cheerful looks like this, it's a simple hole
Pilgrim BM45 although built in 1895 she is a similar size and style of ship and still sailing.
other contemporary cutter models at RMG do indeed show the stern decked or boxed in, it looks like anything you wanted you could have.
It does beg the question, with these very simple designs, how did they stop a following sea from spurting up through the gaping hole ?
was it just canvas as Craig @iMustBeCrazy suggested?
Tim
Current Builds :
and just to confirm my decision, Vanguard @chris watton is bringing out a new kit for the cutter Sherbourne
looking at that, I realise that there is some woodwork missing from the transom on this model, I think I will add that.
What are they called, on the transom, those angled timbers.
after that - I really am going to line the gun ports
Tim
Edited by oakheart
Current Builds :
And it is your decision, you are owner and master.
However, many things are left off the drawings, none of the 'family portraits' show catheads, horses, backstays, ............. as far as I can remember.
Counter timbers. They usually stand on the wing transom and extend to the taffrail.
Craig.
 From what I've seen, the canvas cover was on the outside of the stern, wrapped around the rudder at the lower end of cover and then the top area was nailed to the transom.   I would think these vessels used something similar.
I was thinking the same later but couldn't find any evidence. But I think you're right.
Craig.
Counter timbers
Thanks Craig.
So as 'Master and Commander' I decree that counter timbers shall be fitted  🙂
Tim
Current Builds :
As you said earlier these details are not shown on the plans and any paintings tend to idealize the ship to look neat and tidy.
Maybe I could also add some of the barrels and other details as shown on the 'Kite' painting
Tim
Current Builds :
some of the barrels
You've said a few times "it's not Speedy", are you joining the other team?
Craig.
Now I am confused. I do not get the reference?
What I think is that Bill who designed this model in 1972  simplified it to make it easier to build.
I am learning to build a model ship from wood and having fun doing it, so adding detail that he left out is part of that.
here are two counter timbers made but not fixed yet, should I add two more in the corners, it would also hide that ugly gap.
Tim
Current Builds :
