I too like that muted blue color, Ronald. Despite your hiccups (we all have them!), she is coming along so very well.
18 hours ago, Ronald-V said:
Update:
I actually wanted to post an update only after I finished the entire bow...but I had so little time to actually work on the ship, so I thought...might as well post a small interim update. Otherwise, it'll be a very long update.
First, I had to fit the gammoning knee. I noticed it didn't quite fit the curve of the prow. I probably sanded away the char a bit too enthusiastically. So I glued some scrap wood to the knee and then sanded it into shape.
Supervisor 🥸
Next, I glued the V-brackets to the gammoning knee, but discovered that the middle one wasn't completely straight/level, which would cause problems. So, I loosened it with some alcohol and re-glued it.
Dryfitting as much as possible, nothing glued here
Okay...this part wasn't so good, haha. I was too hasty here. I had everything nicely taped off before painting, but I didn't do a good prep (sanding), and with the WOP already in the wood, removing the tape didn't go well. That was just stupid of me and way too hasty. Prepping is very important, especially if the wood has already been treated.
I pulled off a nice chunk of paint while removing the tape ;)
But with a sharpened screwdriver I was able to remove the paint again and this time I did it properly with the right pre-treatment
The bow hair brackets were relatively easy to paint because I could scrape off the excess blue paint with a knife. This gave me a nice, clean decorative line in the center, as the laser-etched decorative lines are slightly deeper than the rest. I did, however, paint the "raised areas" that weren't going to be blue with WOP first. This made the blue paint adhere even less, which was an advantage.
Glued the bow hair brackets onto the now painted prow.
It looks like this now :)
I painted the black line at an angle, this seemed to be the case with almost all the contemporary models I've seen.
From the side it then appears that the wales continues at the same angle towards the prow.
I've already finished the bow grating, etc., but I'm still unsure whether I should do anything about the bow lower rails that will be attached to the sides.
Blue Ensign indicated in his log that the slots in the V-brackets could be smaller. But perhaps I'm too far along in the build to do anything with this. It doesn't seem very visible in other build logs, so I might leave it as is.
Later I will continue with sanding and attaching the bow cheeks :)
That's it for now...I hope I can make some more progress in the near future :)
Hi Ronald! Your work is an example of how to do things neatly and beautifully! What kind of paint did you use? Was it ready-made, or did you choose the color?
Thanks Mark! 🙏
Thank you! They're pre-mixed colors (thankfully), so it's just much more convenient to have a large quantity on hand. I'm very happy I found these colors. Incidentally, I don't mind mixing them myself, but for these larger projects, it's more convenient to have some pre-mixed colors. :)
Colors I use for the black are "matt metal black" or "Ironwork black" is it called now from Jotika/Admiralty colors.
And the blue is "Tamiya Medium blue XF-18". I had seen them on the HMS Diana built by Beef Wellington here on the forum (worth a look)
Beautiful work Ronald! Your pear planking is not only near perfect, but also very warm and beautiful to the eye!
I'm curious if you're going to paint the freezes or use the etched metal?
I'm thinking of painting my freezes on Winchelsea too, but haven't got the nerves to do so till now...
Ofcourse I could use the printed papers as a template and glue them on later when they're allright, but then I'll have two layers of paper, or I will have to remove the existing freezes.
You could paint the freeze white over blue, spray or paint the bleu again using the etched metal as a template and then fill in the left behind white 'negative' forms with darkened (with brown?) yellow ochre, yellow ochre and lightened yellow ochre (with white?)?
Frank.
Edited by FrankWouts
Current builds on MSW:
HMS Winchelsea 1:48
Prior builds on MSW:
None
Ofcourse I could use the printed papers as a template and glue them on later when they're allright, but then I'll have two layers of paper, or I will have to remove theexisting freezes.
Frank.
Thanks for the compliment Frank!
My intention was to just use etched decoration because I didn't quite trust myself to paint it freehand (plus the enormous amount of time that would take). But I never came up with it the way you suggest. I have to say, that sounds more plausible to try it that way than freehand. Besides, it would still be incredibly time-consuming, haha. I've also already installed the channels, which would be a huge obstacle to laying the ship on its side for comfortable painting... I don't know, but it's definitely something to consider! Thanks. :)
Update:
I've been quite ill for the past two weeks, flu, fever, etc., but I'm feeling a bit better now. I haven't had much motivation to work on the Sphinx, but I've already done some small things. So, just a quick update. I actually wanted to update when the whole bow thing was finished, but that's taking too long. :)
So I just do small pieces and update them.
First, let's move on to the "bow cheeks." After I had cleared them of char, I wanted to paint a nice blue stripe on them, like those seen in other build logs from members like Blue Ensign and Brunnels.
Just painting a straight line wasn't going to work for me; I can't paint that neatly, so I wanted to create a groove in them, just like the laser-etched "bow hair brackets." This would ensure a reasonably clean line.
Now, I do have some nice "scribe plates" from Artesania Latina. I'm not sure if that's the correct name, but I had to make some adjustments. The cheeks are made of 2mm thick material, and when I look at the pattern for the 2mm thick scribing plate, I found the groove in the center looked too narrow (compared to the line in the hair brackets).
But the 3mm pattern one seemed to have the perfect width. But that one is obviously too wide.
So I made a very basic jig to put the cheeks in (this one only lasted 2 tries and then I had to replace the wood because I didn't have any good quality wood available)
But otherwise, it worked fine, and I was happy with the final result. The grooves weren't as clean as the laser-etched ones from the kit, of course, but they were much better than I could paint. I approached the painting the same way as the bow hair brackets, which I showed in the previous update.
Before gluing the cheeks, I first glued a test piece of wood to a thick piece of painted wood. This was to test whether I could glue PVA to painted wood without sanding the paint away for adhesion. I was very satisfied with the adhesive strength, so I glued the cheeks without sanding.
After they were glued, the blue line didn't quite match up with the "bow hair brackets" so they still had to be connected
I still had to drill the "hawse holes" from 2mm to 4mm. I did this by first drilling 2.5mm, then 3mm, then 3.5mm, etc.
Next up were the "hawse bolsters." The order of work was... first, adjust the height to the hawse holes, then glue them to two pieces of scrap wood for a better grip, then file the rough shape with a file, and finally, smooth it out with sandpaper. Finally, sand in the curve at the rear to make it flat against the hull.
The photos below show this order.
The last thing I worked on were the two wash cants. I saw in some build logs that other forum members had omitted them. Perhaps for aesthetic reasons? I thought it would be a shame not to use them, so I started working on them. Initially, I thought they had to be black so they wouldn't distract too much from the lines of the bow cheeks. But once I had sanded them into shape, I was quite impressed with their beautiful rounded shape and thought it would be a shame to hide them in black. So I decided to leave them natural, and I think they really add something to the bow. Their rounded shape and color make them work well with the hawse bolsters.
First, I filed/sanded the correct curves in them to make them sit flat against the wales
Then I sanded in the nice round shape and finished it with 2 layers of WOP (also covered the hawse bolsters and holes at the same time)
I removed the hair ;)
This is what everything looks like now:
The next and final step is the "lower bow rails" that will go between the hawse holes and the gammoning knee...that seems like a really fiddly job and I'll have to see how I can manage that...to get it looking a bit nice.
Edited by Ronald-V
Have to agree with Russ and Javelin - the planking is very impressive - after 15 models I still cannot achieve these results....clearly something is eluding me that is more intuitive for you Ronald - patience, perhaps! In any event, this build is a real treat to follow
hamilton
Beautiful work there Ronald on the head 'foundations', also really highlight your fantastic clean planking.  Great stuff.
Cheers,
Jason
In the shipyard:
3 hours ago, Javelin said:
That planking job really is amazkng. Each time I see it, I'm mezmerized by its perfection.
It would fit right in a manual or even a book from a museum.
It's good to see you keep that same level of perfection in the bow details.
:dancetl6:
Thank you so much Roel!
1 hour ago, Russ2025 said:
I completely agree! It’s mesmerizing! I am currently on my first build so seeing this level of skill is intimidating and inspirational at the same time. I will continue to follow and use as a benchmark for my progress.
Russ
Thank you for your kind words Russ! You will learn so much from your first build, that will be a great springboard to new skills :)
hamilton
Thank you so much Hamilton! 🙏 I must really give Chuck Passaro credits for his planking video's...that made good planking a lot more accessible....at least for me :)
Otherwise I think I would still be in the dark about how and what.
34 minutes ago, Der Alte Rentner said:
I love a perfectionist.  Simply magnificent.
Thank you! Luckily these days I can also be happy with something less perfect sometimes ;)
Thanks Jason! 👏
And thanks everyone else for the likes! Really appreciate it! :)
Edited by Ronald-V
12 hours ago, Nearshore said:
Hi Ronald,
You are truely a master!!! You are doing an amazing job. I quite enjoy watching your progress and your explanations on your techniques are second to none.
Cheers
Nearshore
Thanks Nearshore! 🙏
2 hours ago, KurtH said:
Immaculate work as always!!
Thank you Kurt!👏
Hello, Ronald!
I join in all the enthusiastic compliments!This level of skill is something worth striving for!) You write that you glue the PVA directly onto the painted surface. I tried it too, but I couldn't get a solid connection (Maybe it's the paint... Now I leave unpainted the part of the surface on which I'm going to glue something.
Yours sincerely, Frecap
28 minutes ago, Frecap said:
Hello, Ronald!
Thank you Frecap! Yes, I also had my reservations about gluing PVA to a painted surface. Perhaps it's also because of this specific glue that it grips well. I do try to avoid gluing to a painted part, but in some cases, it would save a lot of prep work if it were possible.
Very clever approach to using the scrappers.
The fit and finish on the bow, including the planking is exceptional work.  Well done.
Regards,
Glenn
Current Build: HM Flirt
I am glad to hear you are better, Ronald. Never a good thing when you are off your game. Your progress and the standard of the workmanship is truly impressive!
Thanks Mark! Yeah this was a spicy one, long time ago feeling this sick, but now much better :) . And thank you for your compliment! Also everyone else thanks for the likes!
Edited by Ronald-V
This chapter is finally finished! Of course, not all the parts that will be added are in place yet, but the manual now continues with other sections of the ship. A more detailed update with photos will follow tomorrow. :)
 Maybe not entirely clear...below is a reel/film, you can press play ;)
Edited by Ronald-V
1 hour ago, Some Idea said:
What a fantastic build so far Ronald - your planking and attention to details is as good as it gets - congratulations on finishing this chapter
Thanks Mark! Really enjoying your work with the "Le Rochefort", such an inspirational build log 👍
Ronald, hello! Great job! High-quality materials plus skilled hands and attention to detail work wonders! Thank you for your publications, they help me see the work of a true master and learn from him!)
Ronald, is the ornament on the slats that cover the head timbers just painted, or is it embossed? Did you use a brush or a stencil? How wide are the slats?
10 hours ago, Der Alte Rentner said:
Geez, comparing your head supports to mine, I bow my head in shame.  What exceptional workmanship.  Nice touch with the video.  I've been experimenting with a feature called Imagine, which is included with Grok 4, and may post the results of one of those attempts.
Your comment shows that we really are our own worst critics...because your head supports etc. look really, really good! But ofcourse thanks for your generous compliment, I really appreciate it! Not exactly sure what Imagine and Grok 4 is, but I asume it has something to do with filming?
I made this with my phone...saw a friend of mine post nice little reels of her creative stuff and she did everything on her phone. And just recently I bought a better phone then I had with all the editing stuff on it (music and such). It's all very basic stuff, but fun to add and a bit different than a photo :)
So much thanks for your compliment Frecap! I really wouldn't call myself a master (that are some others here on the forum are in my eyes) But I'm glad you can get something out of it. :)
Everyone else thank you so much for the likes 🙏
