Thank you for all the likes and encouraging comments, it is very motivating!
@mugje, thank you for your kind words! I don't fret about the prospect of many hours of work, but I have an analytical nature and can't help looking at the 'data' and extrapolating! 😁. Lack of perseverance has never been a problem for me - I may need a break at some point, but I will get through it in the end. And I am enjoying it! I did not start up this hobby to be fast!
@Thukydides, ahh that is interesting! I first thought that it would look weird at the bow until I realised that my lack of knowledge on ship construction and terminology may  make me misunderstand: is the bow not considered part of the keel? What I think you say is that the butts should always be vertical (perpendicular to the horizontal keel, as you say), but since the planks dont run horizontal except at midships, the angle is not generally square, especially at stern and bow where the plank deviates most from horizontal. Is that correctly understood?
@bigcreekdad, much appreciated!
TJM
Edited by TJM
Yes you have it. By keel I am referring to just the straight bit along the bottom. So if you took the ship of the cradle and laid it flat on the desk the angle for the butts should be square with your desk.
Great, thanks!
I agree for most ships, but the keels of the the Alert and Flirt are not flat.  It rises both fore and aft.  Not noticeable by most so not a big deal, just something a bit different.  ZAZ4631 at RMG Collections   https://www.rmg.co.uk/collections/objects/rmgc-object-84422       PDF below
Allan
Flirt keel line.PDF
Log entry 10
I am continuing with the second planking, and managed another 2 planks on either side.
I had a small bump where the plank did not run all evenly (slightly too much taper in one location over a few planks), but I think I have rectified it now, with a slightly unorthodox plank shape. Not very visible, so I am ok with it.
TJM
Log entry 11
I have managed to get another 4 planks on either side and I am now close to halfway in the second planking. I think I will now have to re-measure the remaining gap to ensure that I cut the planks to the right size to avoid weird shapes at the end.
This is what my Flirt looks like now:
TJM
Edited by TJM
Log entry 12
I have not had much time to work on my Flirt lately, both due to various Christmas obligations, and recently due to illness - it is estimated that 20-30 % of the Danish population is currently down with either flu, covid or other such, and I think I got a mild case of covid (third time now), so I have not been up to much!
Anyways, I did manage to remeasure and mark the hull and add a few planks.
I am reasonably happy with how it has turned out so far, though there is definitely room for improvement for future projects.
I am now missing 7 planks on either side to complete the second planking below the master plank. It should be another 5 hours of work or so, with my current speed.
TJM
Edited by TJM
Log entry 13
Phew, this feels like a bit of a milestone: second planking below the master plank is done! While not perfect I am satisfied with it as a first attempt. I will see how it looks when I sand it and decide if I want to keep it unpainted. I think I will.
I also removed the upper bulkheads with a small modelling saw and painted a bit, as per the manual. Now I am ready for gluing on the laser etched deck and do the planking on the inside bulwarks.
This marks the 38 h mark of the build. Time really flies when you are having fun, but 25 of those hours were spent planking and I am now looking forward to a more varied part af the build!
TJM
Edited by TJM
10 hours ago, Thukydides said:
Looking great. If you thought planking was unvaried, just wait till you get to the ratlines 😄.
Yes, I know 😬! Actually, the whole rigging business is what I dread the most! All those blocks and deadeyes! Not so much due to the time effort needed, but more because I am completely clueless! And the fact that my full size drawings are in German will not help either 🙄
I have somewhat compensated by buying Lennarth Petersson's book on rigging of model ships as well as Kerry Jang's book on model ship building, where Flirt's sister ship Speedy is heavily featured, especially in the rigging sections.
I hope this will help me along (I know there are rigging differences between Flirt and Speedy, but I am thinking more about the techniques used than where the lines actually run), but nothing but practice will fix my fumbling fingers - I am not normally good friends with thread, and there is a lot of it on a model line this... 🤭
Edited by TJM
13 hours ago, wmherbert said:
Remembering to drill out blocks before installing them and to run a little CA glue on ends of lines before trying to push them through blocks really helped me.
Bill
Thanks Bill, will do!
Log entry 14
I have now planked the inner bulwarks. The planking itself went easyly, but cutting out then gun ports took a while! The pear wood is not so easy to work with here!
I may sand them down a bit more and repaint, as the finish may be a bit too rough as it is.
Then, to repeat the exercise on the outer bulwarks and finish the second planking...
TJM
Edited by TJM
Do you draw in the ports then drill a series of holes just inside the line first?  Makes it much easier.  A key hole blade on an Xacto handle is also a big help at times.
Allan
Hi Allan,
I have tried a few things, but not drilling out most of the lines before cutting. I will give it a try now with the ports in the outer bulwark planking.
Looking great!
Nice to have someone else currently working on this kit to compare notes. Although now it feels like I’m cheating with my English manual and sheets. Happy to send some photos of the rigging sheets in English, if that would help.
Jeremy
Current build: HMS Flirt
3 hours ago, jereremy said:
Looking great!
Thanks! I do have the manual printed in english, so only my full size plans are left in German. But I will reach out if I run into trouble with them!
BR
TJM
Log entry 15
I have now added the last 5 planks on both sides. I first sanded with 120 grit and was very pleased with the result.
There were, as expected small gaps between planks here and there, and I had gathered the sanding dust, so I mixed it with pva and filled the gaps.
However, I discovered that the pva I use does not sand very well! It smears instead of being removed and it took quite an effort to remove the excess filler, even though I added very little and wiped it off the hull itself after application.
But after a few hours, I had a nice hull sanded with 240 grit.
While there are minor issues here and there, it turned out better than I had hoped! I think I will keep it unpainted - this looks good enough for me.
The only really bad issue is at the stern, where I had to use a bit of filler. It does not look that nice. But I think I will have to live with it as it is.
I will now open up the gun ports and then it is time for some varnish of some sort. I thought I had a satin polyurethane, but it is matte, and I think that will not be the best. I will find some satin polyurethane varnish and make som tests. But I found my airbrush, so I have the option to spray varnish, if I want to.
TJM
Log entry 16
Gun ports have now been opened. Thanks @allanyed for the tips, it worked well, though I am happy that I only had 22 openings this time around. Doing this on a 74 would have been a chore!
Now my lack of knowledge of ships shows itself: what is ther purpose of the small holes between the gun ports?
I also added the wales, which went easily and sanded everything (though a bit of touch up may still be needed here).
Oh, and as you can see, I couldn't resist lining up the 7 guns I have assembled while glue has dried in various steps of the build so far! I have the other 7 painted as well, just need the final glue up.
Now for trimming the wales at the stern and adding the keel!
BR
TJM
Edited by TJM
Log entry 17
Quite af few things have happened since the last update:
I attached the keel and filled the gap between the keel and garboard plank with scrap strips af planking:
Now that changes the profile!
I then masked off around and painted the wales. To avoid paint running under the masking tape, i primed with varnish to seal the edges of the masking. Then I primed black, but inspired by the brilliant Sphinx build by @Blue Ensign, I decided to paint in a slightly lighter shade than all black. I tried with Vallejo black gray, but found it a tad too light. It looked a bit too gray instead of 'light black', if that makes sense! So I mixed it with black in a 2:1 ratio and liked the result better. The edges are highlighted with the neat black gray, though the effect is very subtle. The masking worked great and I had very few touch ups to do when I removed the tape. I got some nice, crisp lines which I was very relieved to see!
Then a few details were added along with some paint touchup around the gunports and this is now the state of my Flirt:
It is slowly starting to look like something!
TJM
Edited by TJM
Log entry 18
A fair bit of progress. I have added the gunwales, painted the blue section and added the swivel gun post timbers. I also added the stern post and the rudder (not glued in yet).
With the painting, I am trying to not use all flat colours, by adding a bit of shadows with washes or adding som edge highlights. As a long time miniature painter, I have a bit of an aversion to flat colours, especially on areas with surface detail (like hard edges). I think I may go over the blue and clean up a few things, but overall I like the look. I also went for a much lighter and less saturated blue than the manual, as well as a darker, more muted yellow. It is Vallejo blue gray and yellow occre respectively for the base colours.
BR
TJM
I think the smaller holes are oar ports.  these ships apparently could be rowed, if you were desperate enough.
great planking and paint job
Edited by CiscoH
Really!? Wow, that must have been tough with a 200 ton boat!
Thanks for the compliment!
