And now for something completely different!
I usually like warships.
However, this is an unusual subject that looks like a fairly quick and easy build.
The Sampang/Sampan is a traditional boat originally of Chinese origin that is still utilized throughout Asia.
I got an Amati Sampang kit off EBay that only had the rigging supplies and the plans.
I paid $7.99 for it with free shipping.
I decided to build it in card, because I like building in card.
I am making it out of a couple of Honeycomb boxes which are about .6mm thick, and a couple of Little Debbie boxes which are .5 mm thick.
Most of the pieces are 3mm thick so I copied the plans 5 times.
I think there are under a hundred pieces to the entire model.
This will be a fun quick build!
Here is the start:
Building:
All parts are rough cut:
Next up is to final trim them and laminate them in order, starting with the keel plate, so I can commence with assembly.
This looks like a lot, but it’s really not.
Edited by GrandpaPhil
Building:
All parts are cut out and laminated together now:
IMG_7429.thumb.jpeg.a011eb08b9a3791372659e53b612364f.jpegIMG_7430.thumb.jpeg.28d58e9f8309730014c85a7d4cd677ce.jpegIMG_7431.thumb.jpeg.b2de7a536bb414b3d59882e05169c09d.jpegIMG_7432.thumb.jpeg.5ab5d2b213bcda98b431134a27ea5904.jpeg
The main hull is test fitted together.
I made two planking patterns for the sides, which are supposed to have 4mm x .5mm planks edge bent to follow the curvature of the sides.
Thin card does not edge bend well, so I am going to cover the backs of those pieces in wood grain contact paper and draw out the individual planks and cut them out in shape.
The decks are not intended to be planked, if you bought this as a kit.
I am going to plank them with wood grain contact paper and then glue the decks into place when I glue the bulkheads together.
Then, after that dries, I’ll paint the visible areas inside, black.
Then I can finish assembling everything, plank the upper bulwarks, bow and stern and then seal and paint.
Building:
What a pile Phil. Hope you can find everything😬
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
LOL!  To be honest, I had to replace one hatchway, and I discovered I had an extra rudder piece.
The model is mostly assembled now.
IMG_7439.thumb.jpeg.5e77a473bbc7e3c93972afc64c7ad2c8.jpegIMG_7440.thumb.jpeg.10790ad20b914f21dfcc0b65148b9a35.jpegIMG_7441.thumb.jpeg.06cd64e3cb7eb88e7d56b443b7cbb2e6.jpeg
It is good and solid.
I admit that I used a couple of Honeycomb boxes and a couple of Little Debbie boxes to cut my pieces from, lol.
I am going to pause to seal and paint what I have to simplify matters later.
Then, I’ll put the rest of the sides on and plank them.
My last fittings are what look like the equivalent of fife rails.
Building:
Decks and deck fittings are on and painted:
Sides are on.IMG_7442.thumb.jpeg.bb4d1c6f432d5d15e9d8da0d5a26d868.jpegIMG_7444.thumb.jpeg.9871be61c7b797b2f481b5ce0a786f61.jpeg
Just have second planking to add and the hull will need painted, prior to the rudder being installed.
Then I will seal and highlight everything.
I bought a live edge slice of basswood for the base and an 1/8” sheet of basswood to make cradles from.
Next, I will make masts, spars and sails.
The rigging on this thing is very simple.
Building:
Excellent Phil.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith,
  Thank you very much!
Thank you to all who have hit the “Like” button, or just stopped by!
The second planking is on:
IMG_7453.thumb.jpeg.1a03e76462fdc31665bf44f0f1f1d0ff.jpegIMG_7454.thumb.jpeg.38bf808498e5929831c93c57eb42919c.jpegIMG_7455.thumb.jpeg.a3e0e349d4842468d11758effefb196c.jpegIMG_7456.thumb.jpeg.def14fbbffefdfbff7af5d1a73b2a271.jpegIMG_7457.thumb.jpeg.40077ea1f05f16e3decd1d9842b1b44d.jpeg
I’m waiting on the stern to dry so I can trim it properly:IMG_7458.thumb.jpeg.6991b1395146d9dcdd57d5c95c2d457e.jpeg
The rudder is mostly assembled too:
Next up is to finish trimming, sealing and painting.
Then it will be time to make the stand, mount the rudder, make and install the masts, make spars, make sails, install sails and rig the model.
This one is nearly done.
Building:
The hull is about done:
The rudder is about ready to be attached:
I need to finish touchups, add a railing, seal everything and then attach the rudder.
In Amati’s ad for the new version of this model, it shows barrels stowed atop the hatches.
That look appeals to me, so I bought a dowel rod at Hobby Lobby a couple days ago to make barrels from.
Here shortly it will be time to make a couple masts, some spars and some sails.
Building:
Beautiful and interesting boat Phil,
I like to see other nation`s boats here at MSW....
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you both very much!
This is an interesting subject to build.
This looks like someone’s workboat to me.
This would have been their equivalent of my truck.
So, I decided to name it “Good Fortune”.
That is a good name for it.
Speaking of being a workboat, here are the barrels on their way:
Building:
Wow I was going to follow along but your just about done. Lol. Very nice work, and so fast. Amazing work :cheers:
                   WASA
                   USRC Harriet Lane
One set of sails:
The last wood pieces are the spars.
In addition to the plans, in that model box were wood for the spars, the sail cloth seen above, the rigging line and the blocks.
I’m going to use the wood and all of the above rigging items for this model.
I love junkyard model boxes if there is something I can do with them.
There are 13 spars that need made and painted.
Then I will decide how I want to attach them to the sails.
Building:
And, done:
60 hours and $25 later.
This was a quick and fun build.
I embellished on the Amati plans a little bit.
I figured out my thicknesses finally for wood plans to card conversion.
The only real problem I ran into was trying to mark the waterline because this is a flat bottomed boat and it was so low.
But, I got creative and figured it out.
This is my third completed scratch build.
Thank you to all who dropped by.
Thank you all who either commented or hit the “like” button!
Happy New Year!
Building:
Nice job! It looks great, and seems like it was a fun build.
8 hours ago, Ferrus Manus said:
Pretty darn good! How did you get it done in only 7 days?
  I was able to finish so quickly because the plans were from one of Amati’s beginners kits.  There were fewer than 50 pieces if you bought this in kit format.  I spent close to 30 hours cutting out and layering pieces of card to get that point.  Once I did, I just assembled and painted.  Then, I added the rest of the planking and repeated.  One advantage to working with card is that bending it is a lot easier than bending wood.  The masts took a couple hours to carve.  But, the rigging was really simple compared to the models I’m used to.  Also, I took holiday vacation time for Christmas and New Year’s for model building time.
This was a fun build.  It came out really nicely.  I am happy with it.
My first finished model of 2024!
Building:
Nice little model Phil. It seems like the rule is "the older you get the quicker you get". I'm looking forward to my imminent speed increase!
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
