I have reached another milestone - the gun deck is more or less completed and it is time to start adding the quarterdeck beams.
I decided not to use the kit provided "handles for the chain pumps - something about square section material in place of round. So I fabbed new handles from .032 phosphor-bronze wire then painted it black. Since the plan is to have the two sets of handles on opposite sides (i.e the handle on one side up the other side down) it is harder to tell that they are not exactly alike
After taking these pictures I noticed that one of the boarding steps is missing (wonder where that went?), the decoration on the stem is missing on one side and the chess tree is missing on one side too.
I have been careful not to throw anything away that was not obviously debris so I need to sort through my "extras" bin and hope I find the errant pieces. I think I just forgot the stem decoration as I am pretty sure there are still some pieces left on that PE sheet.
So here is what she looking at the moment.
Q-Deck beams here we come!
Edited by cdrusn89
Thanks,
Gary
Current Build - Emma C. Berry
Prior Builds:   Rainbow 1934 America Cup defender
                       Lucia A. Simpson (Great Lakes Schooner 1875)
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Upon returning to the instructions i found I had neglected to add the stanchions and "railings" around the two gun deck ladders.
not being a big fan of the PE supplied stanchions I rooted around in the "parts drawer" and found some round, brass stanchions fitted for two rows of "rails". I had to enlarge the holes to get them mounted , blackened them with ATK Burnishing liquid and used some .005" natural line to form the railings.
I only had 10 of these stanchions so I better order another 10 (they come in packages of 10) so I can use them on the quarter deck too.
NOW on to the q-deck beams.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Q-deck beams in place.
I painted the sides and bottom of the beams forward of the enclosed spaces red to match the bulwarks - not that it is all that obvious in the picture or that they are likely to be visible but...
Carlings are next.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Thanks Brunnels - it will go slower now as i have decided to try and plank the forecastle and q-deck in boxwood.
Forecastle and q-deck beams and carlings in place.
I have decided to completely plank the forecastle and q-deck - no "inspection ports". I intend to full rig the model which will make seeing much through the openings very hard so I will (sadly) cover up all the details inside the cabin areas except what can be seen through the gun ports or stern windows. With the three ship's boats in the waist and the blizzard of rigging above there will be poor visibility of what is on the gun deck so I am not sure why I spent all that time rigging the cannon. Oh well, it is a "hobby" after all.
Anyway I am waiting for some boxwood strips and planks I ordered to plank the "upper" decks which will be much more visible than the gun deck. In the meantime I am trying to replicate the waterway on the forecastle using some boxwood planks I have "on hand".
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
How to approach planking the forecastle??
My experience with deck planking usually starts at the center with the "king" plank(s) and using constant width planks move outward until you hit the bulwark and then nibble the ends of the planks until you have filled all the area.
Looking at the maple deck and its planking scheme it appears that many of the planks were tapered as they neared the bow and ended at a wider, continuous "nibbing" plank at the bulwark.
I decided to try and replicate the maple planking scheme (less the trenails).
To affect this I carefully cut the nibbing strake from the maple deck - It was pretty easy to follow the engraved line, but not that easy since I had to do it twice to get an acceptable "sample".
That piece is also quite fragile so I decided to split it into two parts with my approximation of a scarf joint.
These are the starboard side pieces now in boxwood.
I had trimmed the plywood deck to fit but thought I should glue the nibbing starkes to the deck and then the deck to the hull (after installing the fore jeer bitts - I almost forgot).
Here is the ply deck with the port side nibbing strake glued and clamped. Starboard side next then the deck goes on the hull.
The one nagging worry is that now I will have a deck twice (maybe a bit more than twice) as thick as if I had just put the maple deck down. We are only talking about 1mm or so but....
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Ronald - I am pretty much committed to this approach, at least for now. I will look at the BE Sphinx build as I am not familiar with what he did but may use it on my Indy build coming "soon" after i finish Sphinx. I will have to "pay attention" to joints at the front of each plank where they meet the waterway or whatever the outboard plank is called in this case.
With the planking scheme established at the bulwarks it is time to figure out what to do at the back (stern end).
This is here I think the extra deck thickness is going to be an issue. If you just use the maple deck then the belfry and railing sit flush with the top of that deck (assuming you get the tabs on the supports into the slots in the deck.
My first thought was to cut a series of small pieces of boxwood to fit in between the areas where the railing/belfry will go. However doing that would put them about 1mm lower than would be the case with just the maple deck unless I fill in the holes in the ply deck first. Given that the railing is a belaying point I do not want to do anything to reduce the clearance between the deck and the railing as it will be hard enough to belay a line to the railing with the "standard" spacing.
So I cut a piece of boxwood as wide as the two sets of slots.
My first thought was to cut and fit this between the two waterways, mark where the railing/belfry go and "move on". I would have to file the tabs off the supports and probably pin the railing legs to the deck as I have little faith in just a glue joint for items under rigging tension.
Then I thought maybe I could cut pieces of the plank so the joint falls in the middle of each set of slots. That way no marking is required and it should be easier to locate the belfry/railing when the time comes.
That is how I think (subject to unforeseen "difficulties") I am going to proceed.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Having considered the "problem" again I changed tactics (slightly).
Instead of cutting pieces that would cover the entire area between the "tabs" I cut a narrow piece to fit across the very aft edge of the deck.
And then cut pieces to cover the area between the tabs so that the seam between each set of pieces would mark the center of the "tab" and thus where the railing/belfry supports should land give or take a small bit - since the railing sections are already made up with fixed distances between the posts I can't be too picky about where all three posts fall as long as it "looks good".
Here is the deck with the penultimate pieces glued in place. I am waiting until they are fixed in place before cutting the final piece. Trust me trying to keep more than 3 or 4 of those small pieces in place while you measure for the next one can be a challenge.
From here I am considering running pieces along the outside of the posts (after adding the other two) and then working towards the bulwark. Planking the inner section may require planks of varying width so as not to complicate things with "notched planks". I also need to keep track of where the markings for eyebolts are located.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
A big jigsaw puzzle indeed.
The forecastle planked over in box wood. Not the greatest job of color matching (although there is still a bit of clean-up water on the wood in places) but I find it difficult to discern the various shades of boxwood unless it is obvious to the casual observer.
I did not bother to plank around the hatches as they just sat on the maple deck - with the stove flue as I guide I can get the hatches located without the deck marking. There are a single piece after all.
A few coats of WOP and I can add the furniture, what there is of it.
I also need to figure out what to do about the very front - I apparently did not get the various parts together per the instructions. need a "filler" piece of some kind.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Thanks Ronald 😀
I would not recommend the approach I took unless you have the ability to generate planks of essentially any width.
I started planking from the bitt posts out to the edges where I had the "pre-cut" nibbling strake. That went okay until I got close to the edge where I needed to create planks with widths that would allow them to fit within what had become "per-determined" (by the planks already in place) dimensions. Without a miniature (4") table saw that would have meant a good deal of sanding and shaping. Plus I have to create some planks wider than what was my standard here (1/8").
Between the bitt posts was even more challenging because of having to plank around the stove flue opening and the bitt posts. Again wider than "standard" planks were necessary.
I have more boxwood coming tomorrow for the quarterdeck. Hopefully I can get a more consistent color match there.
I did notice that on the maple deck there is at least one plank (third one in on starboard side) that runs all the way from one end to the other without a joint. That would be a really long plank (approx 50')
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
17 hours ago, cdrusn89 said:
Thanks Ronald 😀
I had a lot of planks in the hull planking that had different dimensions than the standard supplied planks. And now between the hatches and gratings I use also a bit wider planks then the 4mm that I will use for the rest. But I shape all those planks with a small wood plane and sanding sticks. Now it just went wrong because I tried to sand 5 planks stacked at the same time. They all got different sizes, and that's why the deck laying went wrong...it started to be a bit wonky.
So I have to go back to doing 1 board at a time, which of course takes a lot longer :D
Edited by Ronald-V
Ronald -
I also noted the varying dimensions on the hull planking.
Next time (Indy) I am going to find the thinnest plank and use the thickness sander to get them all as close to that thickness as I can. Different widths are easier to deal with and many of the planks are not a constant width anyway. Thickness differences can really complicate trying to sand the hull smooth. Although by the appearance of your hull you overcame (and then some) whatever eccentricities the hull planking threw at you.
At least there is a "deck planking plan" on the maple decking although I think it used 3.5mm planks - at least on the forecastle.
brunnels - this is not my "first rodeo" planking decks. In fact this is the first time I had a "pre-planked" deck to use which I did on the gun deck - too many openings for my taste but the q-deck and forecastle are more my speed.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
My boxwood shipment arrived and a quick check of the dimensions look good 3/64 X 1/8" X 15".
Having learned my lesson on the forecastle I took the outboard planks which I had copied from the equivalent plank on the maple deck and modified them so that a 1/8" wide plank will fit.
The top plank is what I copied from the maple deck.
Below is the modified plank that a 1/8" wide plank will "fit" in the open "slot".
Have to modify the other outboard plank, pick some matching boxwood strips and get on with planking the q-deck.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
I have known this day was coming but it did not make any sense (to me) to address it before now.
I got the outer "skin" (the .08mm thick, engraved pear) on the starboard side a little too low, especially near the back of the forecastle.
It is pretty obvious as you can see below.
Port side:
Starboard side:
I wondered if it was just the outer skin or was there some underlying problem.
So I set out to measure the bulwark height at the bow.
I put the hull in the cradle and used my handy-dandy electronic level to at least attempt to get the hull level. I put the level as close to the center of the front of the q-deck and low and behold it came up level without me having to touch anything. So far so good.
Then I took the height measuring "device" and zeroed it resting on the aft end of the starboard bulwark just forward of the little "ear" that sticks up.
Then I moved it to the port side and found that at the aft end the port side is .073mm lower than the starboard.
Then I checked the bow
Port side is .1mm higher.
From this I conclude that there is no "underlying" problem, I just got the starboard side "skin" on too low. somehow (most likely inadequate attention to detail)
Now what to do about it?
I think I have four options:
   1. Ignore it, no one will notice, especially with the cap rail and blizzard of rigging above and shrouds/ratlines in front (mostly).
   2. Just paint the part of the inner bulwark that shows red.
   3. Remove the entire part of the skin currently showing and replace it with a new .8mm thick section that matches the height of the inner bulwark and paint red.
   4. Add a piece of .8mm pear above the existing to the height of the inner bulwark and paint red.
Anyone see another path?
I am going to plank the q-deck while I consider these options and any others that are provided.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Thanks Ronald - that was my choice as well. I seem to remember painting the joint between the inner and out planking with dilute PVA and getting the existing part off without doing more harm seems unlikely.
Still working the q-deck planking.
Here i have the all the edges completed and the "king plank" (actually two planks) down the centerline. is poised awaiting some detailed measurement to ensure it is actually on the centerline.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Quarterdeck planking completed.
Obviously some trimming, sanding and WOP yet to be accomplished.
Here is the forecastle after three coats of WOP
Getting close to adding the topside "details".
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
And I thought I had an "alignment" problem at the forecastle - much worse, approx 5mm too low at the extreme aft end if the external and internal bulwarks are supposed to line up - and everything I have says they should.
And back here it is not just the .8mm external layer that is too low, the entire side (approx 2mm thick) is too low.
Back to the drawing board to figure out how to "fix" this - clearly I have to add an additional piece (approx 2mm thick) on top of the existing bulwark.
Same problem on the other side just not quite so far off, 3mm or so at the extreme aft end.
I am going to put the WOP on the q-deck and go try and "fix" this problem on the bow (port side only) and hopefully learn something about how to tackle the stern.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Some research appears to be in order.
Plans (Sheet 10 in board profile) shows that the aft end of the q-deck bulwark should be 8.5mm above the deck.
And at the upper capstan (the easiest place to measure since that little blip in the bulwark is not shown on the inboard profile) the bulwark is 3mm above the deck.
Measurements on the model show the starboard side aft is currently at 7mm at the lower inner layer.
And forward the starboard side is maybe just a bit high (?) at 3.5mm but really only 3mm if the outer and inner bulwarks were trimmed to match (which they have to be to evenly support the cap rail).
And the port side aft is at 5mm.IMG_1528.thumb.jpeg.f1630205d1f5af88e39d606fee00aa39.jpeg
And port side forward is at 2.5mm or probably 2mm when bulwarks are evened.
So on the starboard side I need "addition" 1.5mm high at the aft end and tapering down to zero even with the upper capstan .
On the port side a similar addition 3.5mm high aft and 1mm even with the capstan the tapering to zero at the forward end.
Now on to creating the "piece that binds" so to speak.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Back at the bow I got a piece "scabbed in" to even out the two sides. I will add some filler and try and hide the seam.
I probably will not make more two attempts at filling in the seam. It is after all under the cap rail and mostly behind the fore shrouds.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Forward area with "scabbed in" piece filled and painted.
I checked the cross hull heights and they are all within .3mm of each other so I judge that to be "close enough".
Now to the aft "issues".
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Some progress.
I worked on getting the q-deck bulwarks up to the correct (at least for this model) height  I was not as successful in filling in the seam between the pieces but at least they are even side to side (I think). Here is what they look like now.
Sorry it is hard to tell one side from the other in this shot.
I still have to add a divider to the sheave port above the mizzen channel, some more touch up painting and the seam is too obvious but that is after two sets of filler so I will adhere to Adm Groshkov's (Head of Soviet Navy in the 80's) saying "better is the enemy of good enough".
I added the cleats to the transom  (I just noticed I broke one off already 🤐) and painted it red.
I planked the gangway decks and added the (previously assembled) ladders to the gun deck. I have the steps going from the q-deck to the gangway "in assembly" using boxwood for the step.IMG_1543.thumb.jpeg.a3f67bf48ceaf459ce5b2db0d3728492.jpeg
And now the next "problem".
It appears that now the entire stern is too low. I am not sure how these are all supposed  to fit together (I better make an exhaustive search of the supplemental drawings - the instruction manual is pretty light on this (IMHO)).
Here is the stern now.
The bulwarks stick up about 4mm (at least it is the same on both sides).
Considering my options at this point. It may come down to making a "transom extension" to fair in the bulwarks to the transom. Sounds like almost as much fun as fashioning the bulwark extension although at least everything there was flat and straight lines.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Before I forget - IMHO it is much easier to cut out the openings for the cat heads BEFORE the cap rail is installed.
I got so frustrated I took the cap rails off on both sides (and did some damage in the process) but deem it easier to fix that than spend several, hours trying to file away three layers of bulwark keeping it straight and square. Using a Xacto saw then a #11 blade took less than 10 minutes and made a much cleaner job.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
There is additional information in the manual regarding setting the height of the stern parts so they sit above the bulwarks.
Page 38
Ongoing:
Clearly (to me) I must have made another error somewhere, probably I did not get the sub deck or maple deck all the way down on the framing. That would seem to account for the inner bulwark pieces coming out higher than the existing bulwarks.
I probably should have trimmed down the interior bulwark pieces rather than adding more material to the existing bulwarks - live and learn.
Anyway I am working on a filler piece to bring the various pieces together at the stern.
It is not what should be there but I think it will not be all that terrible looking.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
While "messing around" with the transom I also decided to work the bow "to completion" rather than moving forward to aft and back again. Seems better (to me) to get one end "done" before working on the other end.
So here is the belfry and the forward pin rail in place and glued down. along with the hatch coamings and stove flue. I tried to get a picture lookung forwad from the waist but I can't seem to get the camera (iPhone) to cooperate. Have to save that for the next time i get my "big" camera out.
I used epoxy to glue down the pin rail as there are rigging lines that belay here. Don't ask me how I know but it is never good to have a belay point come unglued during rigging.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
