Eberhard, Merry Christmas and Happy New Year to you and yours.
I hope everyone here had a good start into the New Year 2025!
Continuing with the bulkheads
Progress over December was slow, due to a couple of travels and a visitor over Christmas, but quite steady. All parts of the backbone have now been cut out and sanded/filed to shape. Dimensional accuracy was checked by placing the parts over a drawing on a LED-backlit board. The cant-frames, however, can only be finished, when the bulkheads have been glued in place.
Collection of finished bulkheads
I was happy to see that the Plexiglas-sheet is dimensionally very accurate and fitting tightly into the milled slots in the base. This means no particular arrangements need to be made to ensure that they sit perfectly perpendicular on the base.
Milling a chamfer on the inside of the stanchions on micro-milling machine set-up as router
The bulkheads still required a bit of work. I thought it would be a nice detail to give the future bulwark stanchions a light chamfer over part of their length. This kind of edge-treatment was very common on many ship parts for both, aesthetic reason and to reduce the risk of splintering in case of an impact. It is not seen very often on models though. To this end I had made the router table last autumn. A 0.5 mm drill in a collet served as guiding pin and a small conical burr was used as router. The length of the chamfer was marked on the stanchions before milling it freehand. The result is difficult to photograph on the clear Plexiglas, but will become visible, once the model is being painted.
Filing notches for the wales on the shop-made filing-machine
Another operation was to cut shallow notches for the wale. The top-edge of the wale is marked in the original drawings and its width was taking from a table of scantlings of a similar ship. Having the wale fixed in that way will give a guidance for the later planking.
The shop-made filing-machine in action on the bulkheads
The notches were cut with a 1 mm x 1 mm fine machine file on the shop-made filing machine (https://www.maritima-et-mechanika.org/tools/diefiler/diefiler.html). I was lucky to have been able to find on ebay some years ago whole boxes of unused machine files in various shapes, dimensions and cuts. A life-time supply of a tool that is not made anymore.
To be continued
Edited by wefalck
Very precise work, the plexiglass construction method is very visually striking as well. Having never worked with any sort of glass, I'm very curious to see how you fair the hull. I may have missed it elsewhere, but will you be planking it in wood or some other material?
There won't be any wood on this model. On the prototype only part of the wale, the deck, mast and spars would not have been covered in paint. At this scale, even the grain of box-wood would difficult to handle and Plexiglas keeps much crisper edges.
More details on the planking etc. at its time 😉
Recently found your new project log and have read through it in its entirety.  Excellent research and an interesting read.  Question - did you choose acrylic glass over polystyrene because you had a readily available cache of it, or does it machine and hold edges better?  As you know styrene is a favorite of many model makers for its available thicknesses, workability and solvent welding.  Not questioning your decision of course - simply curious.
Looking forward to following this project and watching you perform your tiny scale magic!
Gary
Completed Scratch Builds
Plexiglas (acrylic glass) is much harder and stiffer than polystyrene. It machines very well in comparison and keeps a keen edge. It can also be polished, unlike styrene, which comes handy when building skylights etc.
I am kind of partial to Plexiglas, as I sort of grew up with it. My father worked for the pharmaceutical subsidiary to the parent company Röhm GmbH, the original manufacturer of Plexiglas. So we had easy and cheap access to it. In fact most of my supplies were acquired before my father retired in 1986, so the material above is probably more than 40 years old.
A problem is that Plexiglas is not available in thicknesses of less than 0.8 mm. So, the 'structural' parts of the model will be made from Plexiglas, while the planking will be styrene - not ideal, because I would have preferred something stiffer. I could use bakelite-paper, which works very well for the purpose, but I want to engrave some of the planks (as one will see later on in the building-log) and that does not work very well with the brittle bakelite. Also, I would have to glue everything with CA, which I don't like too much.
Hi Eberhard, this may be excuse you need to get that 3D printer you have hinted at :)
cheers
Pat
If there wasn't the messing around with the monomer resin. Hopefully, in couple of years or so I may have a dedicated workshop-room, but in the corner of the study in our apartment that is not such a good proposition 😞
The is also a steep learning curve to get to master the CAD modelling programmes, so I had some basic training in Auto-CAD a few years ago and regularly use my 2D CAD program.
On another forum I am following a couple of guys, who model and print whole ships in 1/100 scale. Wonderful stuff they do. I am envious. On the other hand I would loathe to replace my 'historical' lathes and milling machines because they have become obsolete by this new technology. It took me years to build it up and now that it is in full working order it has become kind of obsolete in a way 😲 Well, at least for building 'realistic' shipmodels, perhaps not for 'artisanal' style models.
Edited by wefalck
Filling the spaces between the bulkheads
After careful checking, the bulkheads were now cemented in place with Acrifix 192®, which is essentially liquid, unpolimerised Plexiglas®. This basically unifies two pieces with the same material, resulting in a virtually indestructible bond. Together with the tight fit in the milled slots, a very rigid framework resulted.
In order to facilitate fairing the bulkheads and prevent the very thin and flexible planking with styrene strips from sagging in, the space between them was filled with Rohacell® foam-board (https://history.evonik.com/en/inventions/rohacell), which is an acrylic equivalent to Styrofoam, but much harder and finer grained. I actually used material left over from the first project I built this way back in the early 1980s. It is sufficient to glue the pieces in place with general purpose glue.
Spaces between the bulkhead filled with Rohacell® foam-board
The bulwark stanchions are actually very fragile and to support them during fairing and being able to turn over the hull, the spaces between them were also filled with Rohacell™, but this unit was not glued down to the rest. Unfortunately, I still managed to snap one stanchion … Grrr.
The fillers were ground back to the bulkheads, the edges of which were blackened with a permanent marker to indicate when I touched them. I then progressed to fair the bulkheads.
In the meantime, also pieces for the gill and the transom were drawn and laser-cut from Canson-paper and then soaked in zapon-varnish. At time when this ship was built, transoms often had carved elements and false windows, low-relief pilasters etc. as indicated in the original drawing. These were built up in two layers on a backing layer. Carved profiles were imitated with thin wire glued into place. The gill was also built up in three layers.
Looking up through the Plexiglas bottom-plate
When I offered up the gill piece to the ‘counter timbers’ and checked, how the hull planking would run up against it, I realised that something was wrong. The last bulkhead was too full in the lower part, but completely conformed with the line in the original drawings. After some head-scratching and careful analysis of all the lines in the original drawings, it dawned on me that, while the rearmost frame was projected into the same plane as the other frames, it was in fact the profile of a cant-frame the trace of which was drawn onto the waterline-drawing. Some rough lofting confirmed that suspicion.
Extract from the original drawings with the misconceived cant-frames marked
There was no way of breaking off the faulty bulkhead due to the strong bond mentioned above. I had to shape the counter as is done in bread-and-butter construction. In fact, it might have been better to build up this area of complex curves from layers of Plexiglas right away. This kind of ships’ counters are not so easy to deduct from the lines drawings and to understand in its complex geometry – at least not, if you are not a trained naval architect.
The correctly shaped counter and ornate transom
With the help of diamond burrs and files I managed to arrive at reasonable ‘free-form’ representation of the stern and trust that eventually the construction mistake will not be visible. After these corrections the gill-piece and the transom were glued into place.
Bow view of the hull ready for the planking layout
Admittedly this looks rather rough at this stage …
To be continued
Good catch on the stern! It's fascinating to see the different construction methods used here. I really shouldn't be, but I'm surprised by how well the varnished paper mimics wood.
Yes, I noticed this as well and was contemplating in my previous project to use this effect, perhaps by staining the paper a bit to mimic mahagony. However, it is difficult to clean-up sufficiently the scorched edges on small complex parts, so I opted for painting with acrylics in the end.
No chance in this project, as on these working boats everything, except the spars, was painted. No fancy varnished woodwork.
Thanks ! Even better would be the ability to avoid such mistakes in the first place 😁
Ah, but this is how we learn. Especially useful for those wise enough to learn from the mistakes of others.
That body plan was a trap! Normally projected cant frames are not included. It's a bit small to see, but is there a number designation on that profile? I assume it does not have a number like the other station line contours. That would have been the clue! Anyway, good recovery, wefalck.
You are right @druxey, that last one does not have a number, neither in the longitudinal section nor in the body-plan. I wasn't aware that this could be an indication of a cant-frame. What also tricked me, was that in the longitudinal section there is a station without number equidistant from the other stations that appears in the body-plan as well.
Slow Progress (as usual)
The run of the planking and their layout will be determined by three structural members, namely the rail on the bulwark as upper edge, the covering board, which marks the lower edge of the bulwark and the upper edge of which is marked in the original drawings, and the wales, the upper edge of which are also marked in the original drawings.
In order to physically define the top edge of the covering board, the waterways have to be installed first. The consist of a 1 mm x 1 mm styrene strip running along the inside of the bulwark stanchions. This is thicker than the actual water ways would be, but the thickness includes that of the covering board inside the bulwark stanchions. The space between the stanchions was filled with small pieces of 1 mm x 1.5 mm styrene strip. This is a tad wider than needed, but allows me to sand them down to the actual profile outside of the stanchions. While in theory the stanchions are spaced equidistant, the filling pieces still required a bit of sanding to fit them snuggly.
There are actually many different designs for the waterway/covering board arrangement and not any particular construction method is being followed here. The idea is to give the right visual impression after painting, not to follow prototype construction method. In fact, it would have been rather difficult to cut out the notches for the stanchions from the styrene strip representing the covering board at these dimensions, as would have been the prototype method.
The arrangement will be completed by a 0.5 mm x 0.75 styrene strip that will be shaped to a half-round profile using a scraper fashioned from a piece of razor-blade and that will be cemented along the upper edge of the covering board.
To be continued
Thanks for the 'Likes' !
Quick update
In between travels I managed to attach the outboard part of the covering boards:
I also scraped all the pieces to the same level, but some of the joints will need a bit of filling with putty to give a uniform appearance of a single board.
To be continued
Just like sox in the wash - never [know] where they disappear to :(  Nice work Eberhard.  It is just too easy to forget the scale you are working at here sometimes.
cheers
Pat
Edited by BANYAN
Always a joy to see how you bring these tiny masterpieces together and I'm pleased to know I'm not the only one with a black hole around my work table, I've got a tiled floor and small pieces still disappear!
Thank you very much for the kind comments and the 'likes' !
Digression 3
As the start of the planking is imminent, I had to think about a way to shape thin, narrow and long strips of styrene. A clamp is needed that can hold strips down to 1 mm width, 0.25 mm thickness and 150 mm length securely. In addition, the strips have to be held in a way that allows to slightly bevel the edges, if needed. The idea was to clamp the material between to flat metal bars of sufficient stiffness.
image.png.a8050330ed7961a1e5e27af874581846.png I happened to have to matching aluminium bars of 20 mm width and 3 mm thickness that once formed part of a jig and could be repurposed.
The two bars were tightly clamped together and milled flat on the top so that they abut with sharp edges. Then, one edge was bevelled to 45° to give clearance for bevelling the styrene (or wood for that matter) strips. Unfortunately, the table travel of my mill is not long enough to do the milling in one set-up and I could not clamp the whole length of the bars in the vice, which resulted in some chatter marks. Not beautiful, but still functional.
image.png.18916bee928e1193ff6c2b88aa5b968d.png The clamping action is exerted by three thumb-screws for which holes were drilled and tapped.
I stuck a strip of Tamiya masking-tape at about 0.5 mm distance from the top edge in order provide a stop for very thin and narrow material.
image.png.265ea4d85bf9edc6fe6d74a3b2c35ab8.png Now the clamp has to be tested in anger, to see, whether it really proves useful – not all of my home-made tools that felt like a good idea, really turned out to be that practical 🫢
Building log to be resumed soon …
Thanks for the 'thumbs up' !
Installing the wales
It was fortunate that the upper edge of the wale was marked in the original drawings. I had transferred this to the bulkheads and cut appropriate notches. Somehow, however, these notches turned out to be not very useful as I would have to score the whole core of the hull accordingly, which would have been messy. In the end, I ignored them, though used their upper edge as guidance for placing the wales. I have no information on their dimension, but thought that a width of 240 mm = 1.5 mm looked about right on the hull. They would have been probably composed of two thick planks. For the thickness I choose 0.75 mm, as the hull-planking will be 0.5 mm thick. Contemporary pictures and naval construction books show both options, smooth hulls, where the thicker wales are not visible and step-changes in thickness. I think smooth hulls became fashionable around the middle of the 19th century, but in the Baltic they were always lagging a bit behind, so I went for the stepped design.
Perhaps this is a problem of building up the planking around a solid core, but the way how the wales run against the gilling at the stern caused me some head-scratching. The point where the upper edge of the wale touches the gilling is marked in the original drawings, but it is not clear, where the lower edge touches it. While the wales have an easy run all along the ship, at this point some twisting is needed.
I had not done any planking with styrene before. It turned out to be quite simple: unlike wood, it does not have grain of course and strips can be easily bent and twisted even across the long sides. Pulling the strips around a round piece of e.g. steel causes the strips to curl and one can thus achieve a nice pre-bending without the need of much clamping force, when cementing them on.
Nevertheless, the wales were attached with the recently discovered artificial nail cement, that is a mixture of light-curing acrylic cement and cyanoacrylate. It sets fast, but not so fast that no adjustment would be possible. I let it seep under the wales attached to the hull with Sellotape. Hereby I worked from the more complicated stern forward in more or less long sections, depending on the curvature.
Final clean-up will be done, once the rest of the planking has gone onto the full, with the view to blend everything nicely together.
To be continued ...
Looks great! I'm very curious to see how it goes planking with styrene.
Interesting updates, Wefalck.
Hmm, a little adjustment time would be useful.
Me too.
Gary
So, here it is ...
Planking the hull
In principle planking this hull with styrene strips is not very different from planking with strips of wood. The styrene strips have the advantage that they can be more easily bent across the breadth. One can also shape them like metal by stretching and compressing until they conform to the shape of the solid hull. A disadvantage is that they are less stiff than wood and easily ‘sag’ in, say in thicknesses of les than 0.5 mm, but it also depends on the distance between the frames.
Planking proceeded up and down from the wales and down from the covering board. The Evergreen styrene strips are sawn from sheets as is evidenced by saw-marks on the narrow sides. This results in slight variations of their width, typically up to 0.1 mm wider for a 1 mm wide strip. This has to be considered, when planning the plank layout.
In the end, I didn’t actually use my new plank-clamp much. It was easier to hold the strips short with the edges upright and to scrape the edge with a scalpel to reduce the width in a controlled fashion. There was not much need to bevel the edges. The styrene cement, of course, softens or dissolves the material, which allows it to be pushed together closely, obviating the need for bevelling at least for material of 0.5 mm thickness or less.
Unlike for woodworking, not many specialised tools are needed. I use a scalpel, the tools that in the old days was used to rub-on lettering comes handy to press on the strips, a large diamond nail-file for thinning down strips, and cutting-tweezers as watchmakers use them for shortening strips to length. The latter have the cutting edge bevelled only on one side, allowing for clean cuts without squashing the material. I also made small scrapers from a piece of razor-blade, held in a pin-vise. Steel-wool of various grades helps to blend-in parts or lightly round edges.
The pictures show the planking after cleaning up by sanding and scraping, but before puttying any gaps that may have occurred. I went for some slight irregularity of the surface, as may be observed in a well-used older wooden ship. This livens up an otherwise somewhat sterile styrene surface.
To be continued …
Edited by wefalck
