On 1/31/2025 at 4:37 AM, Javelin said:
Now that's dexterity and patience!
Great job so far Phil!
Roel,
  Thank you very much!
The railings and the support structure for the top decks are now in place and awaiting some paint work:
Building:
1:200 Russian Battleship Oryol (Orel card kit)
Wow, not only did you have to cut them out (a job well done there), then you had to take that fragile, fiddly wee thing and fit it correctly around those decks. Hat off to you, Phil, they look great!
It really is looking great Phil!  I admire your patience, but not surprised.  I remember you made like 200 belaying pins by hand one time (or something like that).  Truly a virtue you have sir.  Awesome work.
Steve
San Diego Ship Modelers Guild
Mark,
  Thank you very much!  I am going to adjust my methodology and try to use my basic printer card stock and make the next set of railings from that, and make them a little more durable.
14 hours ago, Glen McGuire said:
Those railings are incredible (along with the rest of the ship).  Well done, Phil.
Glen,
  Thank you very much!  I’m learning quickly on this one!
Steve,
  Thank you very much!  To tell the truth, this hobby is how I learned and developed patience over the years.  Hopefully those 200 belaying pins will become thousands as the years progress and I build more ships.
The top deck of the forward tower is on:
This one just has a ladder to the next deck down, a couple winches, a couple of what I assume are deck lockers and a bunch of railings.
That is except for the 47mm guns and search lights that I will make in mass once the rest of the superstructure is built up.
Building:
9 hours ago, Jsk said:
Wow! There must be a more sane method to make railings. I at least I hope so for my current project's sake!
I’m trying it with printer thickness card, the 110 lb sort from Walmart for the upper deck of the bow tower on the superstructure.
It worked well for the railings for the railings around the ladder well on the upper deck.
It gave them more rigidity and made the first railings easier to install.
I have used steel pins for railing posts, with string tied for the railings themselves.
1/200 railings in photo etch are available on EBay too for reasonable prices.
I just like to make parts myself.
That’s the fun part for me.
It’s why I tend to predominantly build card kits or build from plans.
Speaking of which, here is my progress for the day, with the next railing awaiting the second coat of sealant prior to shaping.
The forward tower is almost complete.
Building:
You have the patience of a saint, Phil, I will give you that :)
The upper railing is on!
I like the card railings better.
They are closer to traditional photoetch is terms of holding their shape better and workability.
The only downside is that they take a little longer to cut.
That one took about eight hours to cut out.
I broke about one in three of the rails and had to glue them back together.  They are less than 1/32” thick.
I’m sure that I will get better and therefore quicker as the model progresses.
This is valuable learning as I have several more of these in my stash, including the AAMM plans of the predreadnought battleship La Hoche and want to get Le Charlemagne too.
Edited by GrandpaPhil
Building:
 The upper deck railing turned out sweet, Phil.
Current Builds: Sternwheeler from the Susquehanna River's Hard Coal Navy
Very impressive detail Phil.  Patience is indeed a virtue.  Nicely executed and very convincing!
Steve
I agree with all of the above, nicely done, Phil!
On 3/31/2025 at 10:30 AM, Glen McGuire said:
Those railings look awesome!  Well done, Phil!
Thank you very much, Glen!  They helped me prepare for the ones for the aft tower!
Thank you very much, Keith!  I like the ones made from card much better!
Thank you very much, Steve!
Thank you very much, Mark!
The aft tower is coming together nicely now that the forward tower is mostly complete!
I made three more ladders, too!
I like railings made from card much better.
They work so much better when it comes time to install them.
Building:
She's really looking nice. My own experiments with making railings out of thread were not entirely successful. Seems to work OK for straight sections and gentle curves but they're really hard to form around tighter curves. I've giving your method a try now. Fingers crossed!
Jeff,
  Thank you very much!  I didn’t really care for the railings made from thread either.  I found out about making them from paper from the old Digital Navy website under their “How-To” section, a while back.  I have a whole section on the stern that will be essentially a latticework that would not look right if I tried making them from thread, to say nothing of trying to make all the different pieces for all the railing work on this ship, from thread.  There’s just too much and I think the card railings will look and work much better.
The next deck up is made and assembled now.  I just need to paint and seal, and then move up.
Building:
Building up the aft tower:
I just need to add the railings and the observation platform and then I can work on making the winches that hang from the lower deck of the tower.
Building:
Excellent work Phil
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
I agree, Phil, those railings really add to the overall look of your build. You are doing a fine job with this one.
On 4/7/2025 at 7:54 PM, king derelict said:
Super work Phil. The railings really make the model and are a tribute to your patience and neatness of work
alan
Alan,
  Thank you very much!  They have been a learning curve, but I am getting better at making them!
On 4/8/2025 at 9:57 PM, Old Collingwood said:
Excellent work Phil
OC.
OC,
Mark,
  Thank you very much!  I am very happy with how this model is turning out!
The upper deck has railings and an observation platform now!
I’ve working on the winches that hang from the bottom deck of the aft tower.  I know where three of them go, but haven’t been able to locate the other two on the drawings of the model.
Here’s a side shot of the model:
Building:
I made some progress!
The aft tower is complete except for the 47mm guns and the search lights:
I have the aft bulwarks installed:IMG_0756.thumb.jpeg.4ae64ad9cc240d9ee4764b3d72b79a44.jpeg
I am working on the port side bulwarks and the aft ladders:
The paperwork that came with the model would have you install the middle platforms first, but the middle platforms partially sit on top of the bulwarks so I figured that I’d follow my own experience and install the bulwarks first to save what I see as potential aggravation later.
Building:
She looks the business Phil.  And the black looks serious at that angle and lighting - very cool project!
Steve
Superb work Phil.
OC.
Current builds
Completed works.
Steve,
  Thank you very much!  Oryol is starting to look mean!  This has been a very neat project for me!
On 4/19/2025 at 1:49 PM, king derelict said:
It’s really looking good now Phil. Great work.
alan
Alan,
On 4/20/2025 at 10:04 AM, Jsk said:
Really looking good, Phil. Your paper railings came out much better than mine. I had to revert back to the thread technique.
Jeff,
  Thank you very much!  I greatly appreciate the compliment.  I used thread with steel pins on my Solferino and they worked well.  Your Baltimore looks amazing with all the 3D printed upgrades and the railings!  I can only cut these out because I have a special pair of glasses specially ordered for this hobby.
On 4/21/2025 at 5:29 PM, SaltyScot said:
Railing master!
Mark,
  Thank you very much!  I am learning and continually improving!
4 hours ago, Old Collingwood said:
Superb work Phil.
OC.
OC,
I have finished making the amidships bulwarks:
They still need edge painted and some touch up painting to cover repairs on mistakes made early in the build.
Building:
