Venetian Carrack or Cocha by woodrat - FINISHED - 1/64
13 hours ago, Louie da fly said:
 is there a chance of a tutorial in the future for those of us who want to follow your lead?
Steven
I would not be so presumptuous. Compared to other methods on this site my sail is a little primitive. But the shape is close to what the contemporary illustrations show.
It is basically papier-mache using strips of calligraphy paper over the plaster-of-Paris mold shown earlier. White glue is the stiffener. Bolt-ropes are glued on.
Dick
Current build:
 Le Gros Ventre 1:48 POF   http://modelshipworld.com/index.php?/topic/564-le-gros-ventre-by-woodrat-scale-1-48-pof-1767-french-exploration-vessel/
Past builds:
Mycenaean War Galley by Woodrat - 1:48 - Shell first Plank on Frame:https://modelshipworld.com/topic/33384-mycenaean-war-galley-by-woodrat-148-shell-first-plank-on-frame
Venetian round ship 14th century by Woodrat fully framed - 1:40 scalCompleted
https://modelshipworld.com/index.php?/topic/17991-venetian-round-ship-14th-century-by-woodrat-fully-framed-140-scale
Venetian Carrack or Cocha 1/64 by woodrat   https://modelshipworld.com/index.php?/topic/4915-venetian-carrack-or-cocha-164-by-woodrat        completed
United States Frigate Essex 1:64 POF   http://modelshipworld.com/index.php?/topic/4496-usf-essex-by-woodrat-scale-1-64-fully-framed-from-takakjian-plans/ - completed
Yenikapi12 by Woodrat - 1/16 scale - a small Byzantine merchant vessel of the 9th century
https://modelshipworld.com/topic/23815-yenikapi12-by-woodrat-116-scale-a-small-byzantine-merchant-vessel-of-the-9th-century-finished/
The Incredible Hulc by Woodrat - an experimental reconstruction of a mediaeval transport
https://modelshipworld.com/topic/25641-the-elusive-hulc-by-woodrat-finished-a-speculative-reconstruction-of-a-mediaeval-merchantman-132-plank-on-frame/
Link to comment
Share on other sites
The bonnets were used to increase the area of the sail in this era They are unlaced from the mainsail as required. Reefing points are not seen in illustrations from this time although they are definitely seen in earlier mediaeval ships, particularly those from northern climes.The bonnets are now laced to the mainsail. I have applied a simple cross as in the Benincasa carrack shown previously. These need not be elaborate  and, indeed, need not be depicted at all.DSCN1359a.jpg.18872ad0b67d6af90f0c1c206276530a.jpg
Dick
Current build:
Past builds:
Link to comment
Wow, that turned out very good! I too am anxious to see how it looks on the yard.
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Link to comment
Thanks Jesse and Druxey. I have some deck level work to do first and also the Jacob's ladder before I can hoist the sail.
Dick
Current build:
Past builds:
Link to comment
This is the making of the Jacob's Ladder. I can understand why it became replaced by ratlines. They must have been a horror to climb on a pitching, rolling ship with the ladder twisting and slapping back and forth. question: were the ladders secured to the mast to make them more safe?
Dick
Current build:
Past builds:
Link to comment
I agree, Carl. But the parrels have to run freely up and down the mast. If the ladder is attached to the mast they could not do this.
Current build:
Past builds:
Link to comment
hoops or a sling round the mast ... no, that won't work either. Attached to the deck at least ... attached to a stay isn't very logical either ... was it fixed at the top, or pulled up with the sail ...
Carl
Link to comment
Dick,
I've seen some modern versions of that equipment from hell, but none of them is fixed between top and bottom. It seems when you were forced to use it, it was sheer determination, and strength of grip to get up, down would be easy ... just let go ;)
Carl
Link to comment
Hmm... Life was cheap in those days, I guess, but one could not replace mariners in mid-voyage! I've no firm evidence, but surely the lines must have been attached to bolts at deck level? In a gale, that length whipping around would endanger those on deck as well as gear aloft.
Link to comment
All the good contemporary illustrations, especially Carpaccio, agree that the ladder was fixed to the maintop and to the deck (presumably by eyebolts, Druxey). So, it must be concluded there was no other tethering
5967833cc8cfc_jacobsladder03.thumb.jpg.fe73ce453921bd03cd370bf9664d5a12.jpg596783434abe9_jacobsladder02.thumb.jpg.c5a7cc8df136d117128d767d870522c1.jpg
At least one illustration shows both Jacob's Ladder AND ratlines (or at least it looks like he's climbing ratlines, though you can't see them) Note the matelot perched on the mainyard.
Confusing, isn't it?
Dick
Current build:
Past builds:
Link to comment
I wanted to post this earlier, but I was also affected by the problems with the site.
I found another picture of the jabob's ladder, which seems to be fixed on the deck and the maintop.
Perhaps it helps on your decision.
Götz
Current build: Hanseatic ship 1:50   https://modelshipworld.com/index.php?/topic/16089-hanseatic-ship-c-1500-by-goetzi73-150-first-scratch-build/
Completed builds: Nina (Amati), HM Cutter Sherbourne (Caldercraft). Golden Hind (Mamoli)
Next on List: Fifie 1:32 (Amati Victory Models)
Link to comment
Götz
This seems to be a 19th century print of a small carrack. The ladder is well shown
On 14/07/2017 at 1:41 AM, bearegalleon said:
Free hanging ladders show up in a number of 16th c illustrations and on a number of 18th c models, usually hanging off a ship's stern.  Must have been interesting.
On 14/07/2017 at 9:15 AM, bearegalleon said:
  What were they doing back there?  Odd way to access a ship.
I presume they had stern ladders to access boats.
Current build:
Past builds:
Link to comment
Not odd. If you tied up in a ship's boat off the stern quarter (there was a swivel bolt under the aft part of the mizen chains), the boat would be towed aft of that. The ladders were a convenient way for sailors to come aboard. Only officers would come aboard via the entry steps on the side. Stern ladders (according to Steel) were of worn rope, with 'common treenail' treads.
Link to comment
the aft view of the mainsail with rigging attached for furling the sail
Dick
Current build:
Past builds:
Link to comment
thanks Carl and Druxey. Just wait till it's on the mastB).
Current build:
Past builds:
Link to comment
Looks real to me. I've never seen anyone do a sail like this before.
Jesse
Link to comment
19 hours ago, bearegalleon said:
   Would this be something documentable or suitable to the nave?
I cant recall seeing illustrations of navi from that time with stern ladders, plenty with side ladders. But I suppose anything is possible. With the very tall sterncastle it would be a long climb to the poop!dscn0002c.jpg.5738914809f21b3d9b436a27b8dbf54e.jpg
Dick
Current build:
Past builds:
Link to comment
Thanks, Steven. The dromon is looking great!
Here are some pics of the the parrels and the flagstaff. I have decided not to fit a topsail as they probably did not appear until about 1460. Also, no-one is sure how they were rigged.
DSCN1437a.jpg.cd084ed9853de0227f4f9f86a5b8e240.jpgdscn1435a.jpg.8923e222959b954831f4c63725942a7e.jpg
dscn1445a.thumb.jpg.bb0371b62a4df6583f53db34455cd218.jpgCheers
Dick
Edited by woodrat
Current build:
Past builds:
Link to comment
One of the more fiddly and interesting aspects of the rigging of this beast has been to work out how the parrels were applied to the mast. The excavated parrels from the Mary Rose were a great help in this regard. But I still had to work out a way of applying the parrels which I could understand and was consistent with the iconography. Firstly, in a large vessel such as this, three, four ar even more rows of parrels were needed. Secondly, any method of attaching them had to allow loosening and tightening of the parrels so that the position of the yard on the mast could be changed. In this regard, I recognise the wonderful work of Franco Gay ( The Ships of Christopher Columbus (Nuova Raccolta Colombiana, Vol. 7) by Franco Gay ) for his contributions . Thirdly, the parrel tightening needs to be done from deck level.
The concept is my own modification of Franco Gay's method and seems to work. Grommet is seized to the yard. Its purpose is to transmit the parrel ropes to the deck.
There are two ropes: one controls parrel rows 1 and 4 and the other  rows 2 and 3
Please note that the slots end up AGAINST the mast
The yard is now ready to be attached to the mast.
The starboard ropes are now passed around the yard. Note the parrels are loose.
All ropes are passed through the grommet
The parrels are tightened.
The time has come to hoist the mainsail.B)
Dick
Current build:
Past builds:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
