Looking good!! Looks like your having fun. How do you plan to paint
the photo etch? Are you going to tape the deck off and spray or are you going to use a brush? Keep the pics. coming. Really like seeing your progress.
Rick
Tape it off and spray, I'm actually using Wal-Mart brand primer as the paint then I'm going with a liquid wash for the gray surfaces and a powder to weather the deck
What's your painting technique to keep the minute detail crisp? It looks great in the pictures.
D'Brat
Current Build - Bluenose II - AL
In the wings - HMS Supply - AL
Id'e like to know this aswel,  as i am painting a 1/700 scale british modern warship and its so hard to keep the detail and avoid over paint thickness even with tamiya acrylics...
C.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
I am actually using Wal-Mart brand primer gray. I just shake the can for about 3-4 minutes and do several very light coats. Takes a lol longer but it's worth it. I'll usually put 4 coats of paint, and I always make sure the paint is completely dry. I have been using flory models was after that. I have always built scale radio control aircraft and I used a trick from putting panel lines on the aircraft. I take a dark gray colored pencil and sharpen to as small a tip as I can get and trace back over the very small details and giving them shadows.
On the wooden decks I used the same wash, almost a dry brush technique, and then used my finger to take away anything that looked to dark
Do you have to warm the paint can to get the finest spray or does just the shaking prevent any splatters. You must have a verrrry steady hand to draw lines around the tiny bits. Do0 you have any before and after close ups of the detailiing effect?
D'Brat
One of the advantages of spraying or using an airbrush is the abilty to put on several super light coats so as to not hide the details.
David B
have you tried clicking on the photo, to enlarge it?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Even after all those months lurking I never knew about clicking on the photo. Thank you.
Now I'm even more impressed with the details of the PE on this build.
D'Brat
I just make sure the temperature outside is warmish and humidity is low. I build in my house but do all spraying in garage of course. I keep all of my spray paints in my house so they are at a good temperature and it seems to work pretty good. If I need touchups on the photo etch instead of spraying everything again I spray the paint into a small plastic epoxy cup and use a very small brush. Thank you all so much doe the positive comments and trust me I am open to any and all suggestions.
Very impressive. Everywhere you look there is more detail. Did you have many "Oh, Drat" moments attaching the wood veneer to the deck? It looks totally smooth.
D'Brat
I wish the deck would have been smaller pieces because there were a couple of those moments I hoped it would lift up and thankfully it did. My first time doing it and I think Idid a decent job, ddefinitely worth the cost though.
You dig a great job with it for a first time. The veneer looks so fragile. I would probably have had a very costly wad of wood at the end.
D'Brat
