Earlier (English) naval ships' treenail diameters were in proportion to the ship's length. I seem to recall the figure of  1" diameter for ever 100' 0" of keel. A sloop of 96' 0" had ⅞" diameter treenails, for example.
And Lloyd's went by tonnage to size everything per Wooden Ship Building, Charles Desmond, 1919
Alan O'Neill
Had a most enjoyable afternoon.
Started fairing the hull.
Just wanted to be the first person in history to ever write those words.  :blink:
Also, my #6-32 helicoil inserts came in today.  One problem, they were not stainless steel.
The supplier in Cambridge is overnighting them by courier to St. Catharines. I should pick them up Monday afternoon.
Alan O'Neill
Bad and good news for me.
The Bolt and Nut supplier in St. Catharines failed to fill my order for the #6-32 stainless steel helicoil inserts.
Amazon.com has the item and advertises they will ship it to Canada but try to place the order... sorry!
Amazon.ca does not offer it.
I have since found Ackland-Grainger has the item and at half the price.
Placed the order on line yesterday.
Now we wait to see if they follow through.
 Going to visit the local wood carving club this afternoon.
Alan O'Neill
Buyinbg on the internet can be really frustrating, Allen. It is very hard to find specific items at a reasonable price in the Netherlands, hence I order a lot in Germany, the UK, and even Canada, sometimes the US although their postal service sets you back a fair penny. Hope you get your items in a jiffy
Carl
Thank you Don,
At my last place of employment, they were my supplier of choice, and we would hold our orders until we had a substantial amount to reduce the overall delivery charge.
I could get the odd personal item free of charge that way.
As of late, I've been trying to support my countries economy.
I cannot say this any differently without getting political.
Alan O'Neill
I took advantage of some recovery time (pinched nerve in my lower back) to go through a bunch of the newspaper articles.
(I am much better today)
Over this time (my last push) I concentrated on the 1700's and (just now) completed that era.
Only 497 more pages to complete 1800's  (originally almost 1000 pages).
Attached is a PDF of the index of my transcriptions at this time for those interested.
This is far more info than any book I've read on this ship and her travels.
HMS Bellerophon - Part 2 - Newspaper Articles and Letters - INDEX.pdf
Edited by AON
Alan O'Neill
Also just received my helicoil inserts by courier from Acklands Grainger.
I'll be doing a trial in wood tomorrow, and then get them in my keel to clamp the build down to the table securely, and remove the pieces of wood from the table.
Alan O'Neill
TESTING the stainless steel #6-32 helicoil thread insert for mounting my build to the table and eventually the display mounting board.
FYI:  #6 refers to the screw thread diameter; 32 means 32 threads per inch.  I learnt long ago that the full strength of a thread is developed in the first fully engaged 5 threads, everything after that is safety factor.  When I ordered mine I made sure it was long enough to have at least 5 full threads... mine has 7.
I decided to drill and thread a hole in an attempt to assist the insert into feeding into the wood.
First I drilled a 9/64 inch (0.1406 inch) hole for a #8-32 tap.
Now a #8-32 thread is a slightly smaller diameter than the outside diameter (OD) of the insert but I thought as it was going into wood I might be able to ease it in so it followed the 8-32 and cut it's own threads a wee bit deeper.
That did not happen as the "wire" is very slim and so it deformed.  I then tried feeding it in with it on the threaded rod and that did not work.
If I had spent an extra $40 for the correct tap and proper holder for the insert I likely would have been successful, but I didn't think the extra expense was worth it for 4 holes.
Luckily I purchased 10 inserts and only need 4 for the job.
So next I decided to try by drilling a stepped hole.
First I used a #29 drill bit which is slightly larger than the rod OD  at 0.136 versus 0.132 inches and drilled through the wood.  So the rod slips thru easily.
Second I used a #15 drill bit and drilled down 1/4".  The #15 bit is 0.180 inch diameter and the insert is 0.1785 inch OD.  The next smaller bit would be too small (#16 at 0.177 inch).
This created a step or shelf that the insert rests on when placed in the hole.  Although advertised as 0.276 inches tall the insert is actually 0.232 inches tall so a 1/4" (0.25 inch) deep hole puts it just below the surface.  My keel assembly is almost 1/2" tall.
I then inserted the threaded rod and rub some good old petroleum jelly (Vaseline) on the OD of the rod threads.
Then I screwed the insert onto the end of the rod.
Then I cleaned up a bit of the petroleum jelly that got pushed out of the threads by the insert.
I applied a thick two part epoxy onto the OD of the insert.  The petroleum jelly is supposed to keep the epoxy from migrating through the coil of the wire and gluing the threaded rod to the insert.
I then pulled the rod back into the wood block to draw the insert in and up to the shelf or step.
I let that set for a while and eventually removed the threaded rod.
Now it is curing.
Later today or more likely tomorrow morning I will test that it is holding, does not spin.  I will apply reasonable torque (a wee bit over snug) for the small thread.
The end of the stainless steel threaded insert has a tang blocking the hole.  This is used with the proper insertion tool to help thread the coil into a threaded hole.  It is meant to be broken off after the item is installed.  If what I just did works, I think I will leave it on as a stopper for the threaded rod.
Below are some photos.
Edited by AON
Alan O'Neill
I must be thick, but why do you need to do all this? If I understand what you are trying to do, would not a threaded insert do the job? Or am I missing something?
Edited by druxey
Above is a threaded insert (aka helicoil threaded insert)
Below is a blind nut.
I think you are referring to the blind nut with the flange and spikes that have a much larger diameter cylinder (with the threads inside) than the OD of the threaded insert, requiring a larger hole and length removing more wood than I prefer.  The flange on the #6-32 blind nut is too large for the width of my keel and would require filing.  The thickness of the flange requires a spotface in the keel to get the top flush or buried. The spikes are just a pain in the behind.
I was looking for something cleaner than the flanged/spiked blind nut, and cleaner than a standard hex nut that would need to be filed across flats to fit in a pocket that would need to be chiselled out of the top of the keel.  I am attempting something different.  If this does not work I will resort to the hex nut, that is quite functional, but ugly (and, yes, I know it will be hidden).
And you, sir, are anything but thick.
Edited by AON
added "aka helicoil threaded insert"
Alan O'Neill
I started to use 6-32 brass inserts on Hayling, but felt that they were too wide for the 12" keel. The 6-32 insert measures about .218 dia. The pilot drill is between a #5-#8 which depends the the hardness of the wood. They work great and are quite easy to install. If you can pilot drill safely into your keel then it would be a great way to go.
Mike
Edited by Stuntflyer
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Thank you Mike.
I had looked at these and thought they were quite large a barrel diameter and then also to the OD of the cutting thread, and in some cases the length.
I was hoping to minimize the material (wood) removal.
My test worked, but I will need to remove the "tang" as if you continue to turn the rod after it contacts the tang the insert threads out of the hole.
Of course there will eventually be a frame covering the hole so the rod will only thread in so far and have to stop.
In my application, I used a somewhat backwards installation as I cannot cut the proper size thread in the wood (as I am a cheap ol' coote).
Normally they feed in the same side as the screw or rod, but mine in in the opposite side to create the retaining shelf for clamping.
Alan O'Neill
HMS Bellerophon - Part 2 - Newspaper Articles and Letters - INDEX.pdf 145.3 kB · 7 downloads
Alan, very impressive the list of articles you read. I hope you are planning on writing a book!
A book.
It would be the worst selling book ever!
I would think there are very few people willing to pay for such a thing.
Wouldn't you rather just get it for free?
Alan O'Neill
As a picture is worth a thousand words I thought I'd try to explain it another way.
In the photo below I show the Helicoil thread insert (in a stepped hole) versus a hex nut (set in a customized pocket).
I have also drawn in the rising wood (top), keel, and false keel (below) at the end of the block of wood.
The hex nut and helicoil are buried in the rising wood.
The hex nut is as thick as the rising wood so it necessitates the removal of a great deal more wood than the helicoil.
In my mind it is cleaner and simpler.
More rising wood is left in place.
The frames glue to the rising wood... so it would be nice if some wood were there.
The hex nut is entrapped and so cannot spin.
With the tang removed from the helicoil it does not move.
So both are equal in that sense.
The hex nut has 3.6 threads and the helicoil has 7.
Edited by AON
Alan O'Neill
Mounted the model on the travelling base.
Used a heavier clamp at one end as a counter balance as I made adjustments to align the drill bit with the mark then clamped it to the drill press base.
Drilled the holes.  #29 thru, #15 1/4" deep.
Set it on the build table and drilled thru the table.
Made up lengths of threaded rod, chased the threads after cutting the lengths (borrowed my son's tap and die set for this).
Installed the helicoil inserts as described earlier.
Now it sets up and cures.
I left one of the original wooden clamping bars on the table as I can set the keel to it/align to it, and it holds the plan in place on the table.
Alan O'Neill
Just had my 19th eye injection on Tuesday so I've not been in my shop since mid last week in a effort to keep fine dust out of my eye so it might not aggravate the recovery... and it seems to have worked.
So I spent the time at my computer researching where all the little things go on the bowsprit and jib boom I made earlier.
I have been frustrated to no end by all the contradictory information out there.
My go to books (in order of precedent) are Ree's, Steels, The Masting and Rigging of English Ships of War 1625-1860, The Anatomy of Nelson's Ships, and Rigging Period Ship Models.
I have saved a number of reference RMG model images ... having spent the morning going through about 170 of those on site as was recommended to me.
I also searched some paintings and sketches but they didn't seem to tell me much.   Possibly it is the recent needle trauma, or the cataracts... did I mention I have those too!
Geeze retirement is fun.
As I will be building her as I imagined she looked when launched there will be no dolphin striker, and I will have both the spritsail yard and the spritsail topsail yard as all is clear for the latter sail.
I've checked my drawing gammoning alignment with my gammoning holes and they align very well but my holes are too short to receive the nine to eleven turns of 2-1/2" diameter rope, so these need to be elongated in the correct direction at some point in the future.
Tomorrow I will start to mark all the lines on my drawing with references to the particular source and images so I do not have to re-learn it all again down the road... and all is in a binder to keep it together.
Monday I will start sanding frames again... and in the next month or so make some cleats, saddles, hoops, yards, and a fairlead for the bowsprit and jib boom that are stored away.
Here is the drawing I've made.
Edited by AON
Alan O'Neill
Quick update...
Still sanding off and on,  and having a wonderful time of it.  :default_wallbash:
I've chiselled what I can, and hasped and flexible filed a bit more, then #80 sand paper, followed by finer grades, but it is very slow going.
Finished my drawing of all the lines for the Bowsprit and Jib Boom, and created a MSWord doc for them all so I do not have to relearn it all in a few years when I get to this point, but for now, I have enough information to add my rope wooldings, rings, cleats and saddles to the bowsprit and jib boom I had made.
It has been good exercise for the brain, I learnt quite a bit.  I have posted a question in Masting and Rigging about the fairlead as it is the only item I am not 100% certain of.  Some of the running rigging passes through holes in the fairlead to keep them organized and from getting fouled up.  The problem is I have not found one source that states the number of holes or lines or what they all are.  So this is one small but important detail to allow me to wrap that up.
Bowsprit Rigging Layout.pdf
Alan O'Neill
Nice illustrations, Alan.The fairlead? Check contemporary model photos. I seem to recall seven or nine holes, but could be wrong. Now, keep sanding!
Thank you Druxey, but with the accompanying word document it is much more than a nice illustration, it is a map.
seven or nine holes?
funny it should be an odd number.
TFFM has seven, but others have even numbers up to twelve.
none have rigging as few install sails
Bowsprit + Jib Boom - Standing + Running rigging.pdf
Alan O'Neill
I spent a good part of the morning scouring the RMG site with model images zoomed in and then my screen zoomed in and my wife saw me with a magnifying glass...
that sight must have been hilarious.
I found one model that I could focus on and it seems to have nine (9) holes in the fairlead.
I wish there were more images and sources on this item.
With so few holes I imagine the outer most lines would be eliminated from passing through the fairlead.
So I suppose I should review my list of possibilities.
Edited by AON
Alan O'Neill
Thinking logically.... people need to walk out on the bowsprit, so lines through the fairlead cannot be a trip hazard, so maximum foot clearance space between them would be a plus.
At 9 holes the space would be about 8 inches  (203mm).
At 7 holes the space would be about 10 inches (254mm) which is better
What I was looking at was a 74gun 3rd rate MOW of 1760 and that model seemed to have nine (9) holes.
My ship has eight timberheads with lines secured to them.  These eight lines would be Nos. 1,2,3,4,7,8,9,10 on my list in my PDF word document above.  If I go by this list, it leaves one hole in the fairlead unused, a spare... and I would assume this is located at 12:00 leaving a 16 inches (406mm) open walkway.
I assume not all the holes would be used.
Possibly the outer timberhead lines might not pass through the fairlead leaving more spares... or to be used by a couple other lines.
Makes sense to me.
Nine holes it is then.
Yes Druxey, I am going down to the dungeon to start sanding again.
Edited by AON
Alan O'Neill
So ...
sanding is boring work.
thank goodness I have many diversions.
Having added all the features to my bowsprit I will add to my build log...
starting with an update to the drawing and document I posted earlier.   I found a few corrections were in order.
Here is the complete package
$ bowsprit rigging doc pkg- rev3.pdf
Edited by AON
updated dwg on pg 10 - thumb cleat locations
Alan O'Neill
Having determined the locations of the gammoning rope cleats on a drawing I needed to confirm the locations by fitting the bowsprit I had previously made and lining things up with a weighted string.
The forward face of my cleats must be aligned with the forward end of the slots.  Also, my cleats and woolding hoop locations at 3 and 9 o'clock needed to be forward of the knights head.  I discovered that the gammoning slots I had made per the Admiralty drawings were incorrect in length.  Luckily the aft most locations of the slots were okay.  They need to be elongated forward almost twice the amount of their present length.
I marked off the spots with a pencil, double and then triple checked it.
I fretted over how to accomplish this for a couple days, and finally decided to use my new long narrow nosed X-Acto saw blade to cut these slots longer, and then clean up with my flexible Japanese micro files u   Of course I had quadruple checked the locations just before starting... the feat was easier than I had imagined.
Alan O'Neill
