Hello All, Thanks for the comments and Likes, as always very much appreciated.
I Come across a learning curve (Mistake)  Chain plate's I miss understood but as the picture shows the step req.
Rich.
Builds in Progress:   HMS Victory
Completed Builds:   Constucto Enterprise
Future Builds 2021/2022 USS Constitution
For a change i stared on the Jip Boom.. took a bit of time but the help of The Anatomy of Nelson's Ships Book, The Beed and Sheaves and the plans only showed one side.. hope its right if not .. Well Not Changinging it now LOL
Cheers
Rich.
I I have made a small advancement with the bow sprint. as per pictures,
sorry not much to say, I think the pictures said it all,
Work wil now come to a hult yeat again as the wife want to ( sorry me ) to tile the concevatory floor going to take a few weeks the the hollidays time comes ..
Ill try and get some done or some somesmall bits cleaned up.
cheers
Rich.
Hi Rich
OMG thats beautifully done, hey its big too, very big. Time has flown... I remember you getting that but didn't think it was so long ago. Salivating over the kit mate its the RR of the Victory kits and looking at this I see why...
Great job
  • 2 months later...
Hey My friends, I just thought i would drop a few words, just so you know i have not sank to the bottom of the sea..
Work had ground to a stop of late, this is due to a large number of staffing issues, and my HUB,  and been turned to to a playroom for the granddaughter..
Work has started, and now working on the Fore Mast. But need to do a bit of reading first.. so look out new updates coming soon.
Cheers
Rich.
Hello Rich,
Just ran across your log and quite impressive it is. I have just started my Victory by Panart. for the third time; being unhappy with the results of the first 2 trials.
I had the fantastic experience of spending 2 days aboard HMS Victory several years ago with 2 friends who were also building the model. It was a 4-day boys' night out trip to Portsmouth and the NMU in Greenwich where we actually held MR Steele's plans in our hands that the staff had pulled out for us. Those who like history always speak of a profound moment when observing something of significance. Mine came on the Victory when I realized that the serving vessel on which I stood was older then my country! Awesome!
Good luck with the continuation of your build.
Regards
Well,  few days back on the build has been a good one.
The Fore mast, not been that bad, still tweaking things.so this is not the final.. I have left the boarding pikes of till painting is finished.
Rich.
Welcome Django, I am no where "master builder"  this is my second build. I'm in no rush to finish. All I would like it it to look great and to the best I possibly could get. Sometimes redoing  more than twice! ask question were you need to, Some time look a few steps beyond where you are, in case you need to do something different.
Rich.
Wonder if anyone can help. I thinking ahead of the rigging... Now I have read people using serving machines. To bind rope together etc. I cant afford to buy one are the postage from the US is high, and cant find any in the UK.
Does anyone know a way round or even to i need to do this?
Rich.
Rich, you dont NEED to serve, but it does add a textural element to the rigging that is nice. Check Alexi Domanof in the list of dealers on the NRG page. I believe he is in Europe and I have heard good things about his ropewalk, I think it will serve also?
EDIT I just looked, he offers a serving machine.
Sam
Current Build Constructo Enterprise
On ‎26‎/‎05‎/‎2014 at 5:13 PM, Archicar said:
HI All, The following pictures are of my attempt of a 4 butt system for the decking, I will use this of the other deck, I'm not sure if i will use tree nails(unless someone has any ideas of the best way to do)).
I think I do this right!
post-123-0-79557800-1401120433_thumb.jpgTHis is a 5 butt system Which on lower decks was often correct
Note this missing  plank at No 1.
Planks where laid on the DFEck Beam and some times wernt exactly the same distance apart
Although the butts on the same number where exact
Well the masts are almost complete, (mainley overall hight ) hmmm!
The Main and Mezz Mast Seem to be leaning back a little (mezz the most) any recomdations to fix or are they ment to lean back slightly
Cheers
Rich.
with the advice given i have made and added jerr blocks for both fore and main masts, as it makes it easier later on.
unnamed.jpg.66ba819dfcf2cd86e1db40cb4be3ab4c.jpg(credit for this picture @Shipyard sid
the following is my jeer blocks and at time before any touch ups.
Rich.
Your build looks fantastic. Great work on the masts. I do like your nest rigging. Good work.
Regards, Scott
Completed builds:
Awaiting construction:
Just A small update, I  have now the Rat lines sorted on the fore mast, port side so far. (Happy ? Yes, I think so .. Far to much to change if im not)
Im Doinging to coat the as it rat lines ( both completed sides ) in PA/water, before next stage, this sould give it a less bounce!!
Rich.
:default_wallbash::default_wallbash::default_wallbash:     Dissapointed Update       :default_wallbash::default_wallbash::default_wallbash:
Well Small update...   Well more of a a BIG Mistake.
Rat Lines . Drawing Sheet 12,  Shows Mizzen Mast of the left side with lines @ .075mm --- So previous Post Complete lines  ( although finished)   Took it as all ratlines are the same.
Rate lines Fore and Main Masts,  should be @1.3mm  .......... So guess what...
Its all being ripped out and started again!!!!!
Diffrance to far to much to ignore....... bugger!!
Cheers!
Rich.
