As soon as I solved this problem with bowsprit fixing I went to the mast tackles and made them tight + added imitation of ropes coils
Next stage was fore shrouds installation...as soon as it is my first model where I wanted to make more or less full style rigging,I men as much complicate as I can do...I was a little bit afraid to start...
One of the unsolved problem which is still remains - I use not proper ropes for rigging but ordinary polyester  threads...and appearance is not as it should be when You make Your own ropes...but OK...next model I will do with correct threads,just need to fabricate simplest rope makeing mashine
Thread which I used for shroud - hawser laid ,as said -ordinary rope...and same I saw was used on Duyfken replica
Above deadeye I didn't make end crossed standing part and didn't make "throat seizing" but just seized end rope to its standing part when rope went around deadeye -finaly have rope end lie forward on sbs and aft on ps ...classical arrangment on modern ship will looks different
Thread which I used was preliminary painted by acrylic paint (mix of brown+black+ochre light+raw umber+matt acrylic varnish) - proportion free, just maid it close to dark brown for standing rigging and brown -raw umber- yellow- for running rigging
Before start making shrouds I made hard carton pattern where marked pozition of the shrouds+position of upper deadeye+ratline position
upper deadeye secured with wire wich I purchased in some shop for sewing hobby and a drop of cyanoacrylate adhesive gel ...
The rest of procedure was much easy that I supposed :D -make shroud goes round of upper deadeye,adjust position ,make it tight as much as possible and hold by clip + secure end of the rope with couple of seizing...
forward shroud I made serviced
I guess this "technology" is very well known and isn't so interesting... ratlines will be installed at the final stage of the rigging...
Edited by kirill4
Next stage for me was just continue to attach shrouds without laniards and when all set was installed left them like this for a moment, than I fabricate fore stay with loop and mouse and install it and adjust nessry lenght ...and after that only it was possible  to remove carton and install and adjust laniards...adjusting laniards tighteness took me couple of days due to plastic masts very sensitive and load need to be distributed very smooth
As soon as it was done I secured them with drop of CA gel oposite and than made free end of laniard turn around and secured...details of location knob and passing those laniard ends well discribed in "The rigging of ships. In the days of the Spritsail topmast 1600-1720 - Anderson"
Mouse I've made from piece of liquid steel ,forming a ball shape(not pear shape like on modern vessel) and imitated stitch by knife + painted later on
Shrouds top Loops not served ///as I understood in this time they shouldn't  be(continent)
next stage for me was the fore mast top rope installation...actually it is not necessary to have it in normal sailing condition...but I wanted to have it just for fun :)
During top rope installation I've found that I need to replace mast bitt - this part from the kit was wrong construction and couldn't adopt my top rope...so I fabricated new one from telefon plastic cards...
than there was questn how and where to secure running end of this rope...I didn't find better solution but only to install additional cleat...it is funny, but I don't know how it should be arranged on galleon...I didn't find this arrangement on modern galleon sailing replica
From the books I only understood that mast bitt should have 4-th sheeve fo this rope :(
Edited by kirill4
Ok
futtock shrouds and catharpin next step ...
catharpins on my models will not be installed , I found that it is not "mandatory"  for galleon age ....the rest I tried to do as it is discribed in" The rigging of ships. In the days of the Spritsail topmast 1600-1720 - Anderson"
than I installed lower yard ties and halliards,ties clued to cap and tightened by halliards , lower yard will be installed later on together with fore sail
Hi all,
after completion foremast , I continue with fore topmast and topgallant shrouds and their futtock shrouds,and installed running backstays, as soon as it was done ,I started installation of fore topmast and topgallant stay
than there was a problem with guns...actually spanish galleon should have two wheel gun-carriage, kit version was 4 wheel, and I tried to modify it for two wheels carriage...let say I did it formal only due to wrong position of kit guns frame which positioned too low, and full size modification was not available ...so I did what I did :) , and removed previously installed gun tackles ...I don't know what kind of arrangements of this tackles need to be done for breech-loader guns and I left breeching only
Mary Roze armament pozition - just for example as it was very near to galleon age
Next stage,this month and last till my next vacation in september - spritsail making and installation
I used high quality percale for sails making - by my opinion- it is the best material even for scale 1:100 remains more or less acceptable...
For this scale I simplified procedure as much as possible, and use textile clue wherever posible - bolt ropes - clued to the sail edge,cloth connection imitated by pencil sharped to hair thick  and than all lines need to be light squeezed by awl ...
Fabric painted by wood stain in advance soaked in mix of water and white wooden clue and dried without ironing - after such treatment looks and feel like paper -very handle to work with :)
Edited by kirill4
and final pictures in this season :D installation the rest of spritsail rigging
next session should happend in september - october ... will try to fabricate and install rest of the fore mast sails and start to do smth with grotmast
Thanks everyone hwo spent time to look at my experiments
ALL THE BEST!
  • 6 months later...
Krill,
I know it has been awhile since your last post, but I just wanted to let you know that your rigging is phenomenal! I am blown away by how beautiful your rigging is looking, and that is on top of your scratch building. Hopefully, on your next vacation, you'll post more.
Thanks again,
Stveve
Current Build: Merit 1/48 Early Eco 80' PT Boat and Imai 1/50 Catalan Ship
Revell 1/196 USS Constitution (My oldest son's school project)
Revell 1/72 Hanse Kogge
Revell 1/50 Viking Ship
Revell 1/72 U-Boat
Zvezda 1/72 English Medieval Ship Thomas
Revell 1/90 The Nina
This is out of this world. You have done an excellent job. Keep the updates and pictures. Thank you for sharing this with us.
Wacko
Joe :D
Go MSW :) :)
Krill,
I did want to ask you if you used regular white glue to create the nail heads I saw on the bottom wale and the planking? How exactly did you do it? If not the white glue, could you let me know how you created them, they look awesome?
Thanks,
Steve
Revell 1/72 U-Boat
  • 1 year later...
Good day,
Dear Steve,WackoWolf
Thanks for Your warm comments,
I'm very sorry since long time I didn't refresh my building report,....for some reasons...but I didn't give it up, still have some progress...but everything goes very slowly...
Steve,
You asked abt imitation of nails head... afraid my reply is too late,...but anyway... I did it mixing acrylic Matt vanish with very fine "finish crack filler",which remains from that time when I did my flat repairing...actually such staff remained a lot,may be 500 gym. but for our purpose we need a few grams. only :)))... so this "finish fine chalk Crack filler" need to mix with acrylic Matt vanish, to reach some kind of cream consistency, and than you can use it for imitation nails/bolts head...I used some kind of dosage plastic tube to apply this staff on the surface...when you did micro drop ,wait couple of seconds,and than gently press it ,to make it flat...when it became dry,paint it to the color You need and finally You will have such nails head imitation...need to have a little bit practice ,but after couple of tries You will have good results...I'm very sorry for my English, but hope You did catch idea..
Some pctrs of the current stage of my building you can see here
http://karopka.ru/forum/forum190/topic10341/?PAGEN_1=84
And here
http://www.segelschiffsmodellbau.com/t2801f761-Spanish-galleon-the-Armada-campaign-in-just-one-more-version-3.html
Hope I will be able to return to my project at the end of December this year,or in the beginning of the next...
Wish all of you all the Best!!!
Kirill
Kirill,
It is great to see you back here. That is some outstanding rigging you are doing my friend! Thanks for the links, I checked me out, although Google Translate can be very amusing at time. Your English is far better than my Russian can ever be, so do not sweat it. And finally thanks for the explanation for the nail heads, I got the overall understanding and will give it a try on my next ship. As always, I am looking forward to your next installment.
Steve
Revell 1/72 U-Boat
Came across your log Krill nice work you have done the hull is splendid along with the rigging.
David B
  • 5 months later...
Good day,
Dear friends,
I did some some progress ,since last posts... unfortunately not so muchbas I planned to do during this my vacation...but at least Im very close now to start main mast running rigging !!! :)))
Im very glad that I finally passed that most monotonious phase of rattling main mast shrouds...to fitt yards with sails and add running rigging ,will be much easy...
also I completed jobs with F mast halliards...which remains uncompleted since last activities on my shipyard :)
with this halliard installation, actually with those crowfeet...was a problem,how to imitate theiir attachment to the stays and how to
show equal tension of each bridlеs- this I managed by apply liquid CA on each bridle while they were under extra load...when clue dried, all treads remains strait...
that effect wich I need...same time,in the middle of the process,when all bridles were movable,I adjusted stays in slightly curved position (up) as they looks at the real ship...almost same I saw on the picture of Kalmar Nykel replica...
there are some recent fotoes
11400493_m.jpg11400947_m.jpg11400955_m.jpg11455446_m.jpg11455451_m.jpg11471000_m.jpg11471086_m.jpg11471092_m.jpg11497847_m.jpg11497928_m.jpg
next portion of pictures -preparation of assosiated blocks of parrels and parrels itself
they are in very simplified version...:)... just imitation of real thing
11733927_m.jpg11733929_m.jpg11733930_m.jpg11733932_m.jpg11733933_m.jpg11755564_m.jpg11755566_m.jpg11755567_m.jpg11755570_m.jpg11844239_m.jpg11844240_m.jpg11844241_m.jpg11880776_m.jpg11880793_m.jpg11898596_m.jpg
Edited by kirill4
Thank You very much Robin for your warm comment... I try... but still too much black spots remains,how it must be ,looks like...the hull construction due to it is plastic modell...ommited complitelly...but actually ...seems to me ...it is one big mistake...so just I try to do...what can I do ...and what I could understand...from this rigging questions...lets say...in direction of spanish galleon... :)))
Edited by kirill4
some more pictures...relevant illustration abt ...how to fitt F mast halliards...
I have not too much pictrs of spanish galleon,where we could clearly see details...so it will be kind of mix of dutch,english,swedish and danish metods of halliards arrangements...+info from Anderson book
mostly Dutch :)))
Edited by kirill4
there is I did some mistake,with the places ,where attached halliard running ends...first choice was to securevthem on the aft reilings...suppose it is not correct...
next vacation I planned to make some rearrangements,and shift them closer to the Fmast base...
Edited by kirill4
those are the last for today... with wrong attachement... will be continued in September...I hope...
I wish All the Best of all of you and good progress with yours current projects!!!
fantastic looking ship......there is so much to this ship.......where to begin!   really like the rigging........easy to see why model manufacturers only give instruction for simplified rigging.   fantastic workmanship!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Good day,
Popeye the sailor and B.E.
Thanks a lot for your comments and attention for this project !
I'm very pleased and appreciated you like it :)))
Wish you all the best and good results in your current buildinds!
Kirill
  • 9 months later...
