After the sanding i gave the hull a coating of oil.
I'm really happy with the result.
The treenails became darker with the oil. Much better now.
The planking is far from perfect. But it's better then it was before...
And for once i won't have to paint the hull to hide the planking job.
Chris
Current builds :
On hold :
IJN Yamato by DeAgostini - 1/250
Completed builds :
Bermuda boat Corsair (scratch)
President by Sergal - 1/60
She's a nice looking hull.  Well done.
Bob
Current build:  SS_ Mariefred
Hi, just found your build log I like all of your posts and especially the images. Will follow along for the rest of your build.
Phoenix, AZ
Current builds;
Previous builds, in rough order of execution;
Shipjack, Peterbrough Canoe, Flying Fish, Half Moon, Britannia racing sloop, Whale boat, Bluenose, Picket boat, Viking longboat, Atlantic, Fair American, Mary Taylor, half hull Enterprise, Hacchoro, HMS Fly, Khufu Solar Boat.
On the shelf; Royal Barge, Jefferson Davis.
Start of the planking the cabin floor using a paper template.
First i prepared the planks using a pencil to imitate the caulking.
Then using again a paper template i made the cabin sidewalls.
Afterwards i glued them in place and used some wooden blocks to put some pressure on certain points.
Cabin planking done.
And finished the cabin with some oil.
Chris
Current builds :
On hold :
Completed builds :
Now on to the margin plank.
I started with making a template out of paper by tracing the hull.
Onto which i drew the different parts for the margin planks.
I cut those out using caution.
And glued them on a piece of Cherry wood using a glue stick (Pritt).
After sawing them out, i needed a sander to get them to close to the line. My scroll saw skills are not so good  :)
The delicate parts i did with file.
The result before placing on the hull.
And finally glueing it in place.
Chris
Current builds :
On hold :
Completed builds :
Nice planking and a good looking deck.
Bob
I've continued working on the cabin.
I measured the place where the crossbeam must fit in the planks.
Afterwards after sawing i glued both planks in place and let try dry overnight.
I then made the tree pieces to cross the cabin.
And glued them in place.
Chris
Current builds :
On hold :
Completed builds :
Hi, very nice work
Referring to your first post and your pics hereabove: I like the hull lines too.
I can only guess - compared to a kit assembly- how appeasing this must be.
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
I progressed on the cabin.
I made the hatches. They were used to store the cooking gear and other stuff.
First i had to make some dummy beams to provide some support for the hatches. I made those from some scrap plywood on which i matched the curve of the cabin walls.
I glued them in place and let them dry overnight.
After marking the middle of the cabin with the laser i placed some cherry planks.
Then i filled the open spaces with the maple planks.  I had to to taper 5 planks on each side in order to fill it up nicely.
Then using a scraper, and sanding with different grits, I obtained a smooth result.
Chris
Current builds :
On hold :
Completed builds :
Chris,
What can I say but, Outstanding!!!!! Your attention, and care to details have made this little beauty a joy to look at. There are many aspects/procedures that you have used on your build that I wish to incorporate in future builds. Many thanks in advance to the assistance you've provided by simply posting your progress.
Ray
  • 8 months later...
Pfew... my little corsair has been gathering dust for quite a while now.
Next is the building of the "toe rail".
First I've drilled a whole on the place where i want the supports for the rail. Afterwards i squared them out using a square file.
Corsair-45-2.thumb.jpg.a503decf15434658f9f94a9de1df493f.jpgCorsair-45-3.thumb.jpg.4eda0ff19b2ec902bfb8853b3a8d1425.jpg
Then the glue goes into the wholes and the supports are put in place. I've used some walnut i had lying around.
Corsair-45-4.thumb.jpg.4a5182a43b6b2ce9d952375b188a44ee.jpgCorsair-45-5.thumb.jpg.1d07672383d5c0911e1dfd5398f9cb5e.jpgCorsair-45-6.thumb.jpg.afd862b60b26d5906d59a04d702b0457.jpg
After drying overnight, i put in the toe rail. To make that rail I've first drew a template from the profile of the hull.
After everything dried, i sawed of the extents of the supports and sanded everything smooth. Afterwards I treated the wood with oil.
Corsair-45-8.thumb.jpg.8195598ff7feb015e5da383077a01403.jpgCorsair-45-9.thumb.jpg.a3be92f995b3dd2968fa66c2f4fe7591.jpg
Chris
Current builds :
On hold :
Completed builds :
On 15.6.2016 at 7:30 AM, WBlakeny said:
Then i used a scraper on the deck to get it smooth.
beautiful and charming little boat Chris,
well done so far....:)
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Nils
@ Christian   I'm wondering myself :)
It has always been my problem, i want to start too much models.  I have a Deagostini SotS and a hms Victory here. I also started a Jacynthe of which i have all the bulkheads ready. And on top of that i have a Hachette Bismarck also ready to start.  I must confess,  I'm a shipmodel addict!
Chris
Current builds :
On hold :
Completed builds :
I made the pintles and gudgeons for her rudder.
I started with cutting off some strips of brass.
I plied the strip on which i applied some flux. On the flux i put the nail which i want to silver solder to the strip.
On top of it all i've put a tiny piece of silver solder.
The three pintles ready.
Chris
Current builds :
On hold :
Completed builds :
