You van pinch that Caroline.
That's why I posted it.
There where a few more on the site http://www.picgifs.com.
That's the English version of the smileys I'm using…..
Edited by Sjors
Hi Caroline
Am I mistaken, or did your original build log on MSW1 include more details of your rigging process?  I remember photos with colourful arrows that showed how you adapted the rigging to suit the period better.  I got a copy of R.C Anderson's book, and although he explains everything in detail, your original build log was just a lot easier to follow!
If you ever find the time to upload some more photos and details, disciples like me following your original log will greatly appreciate it.
Edited by DesertWolf
Wolf
Current build : San Francisco II (AL)
Hello Wolf.
Yes, my log on mSW1 did have more detail on the rigging. I'm slowly trying to recreate the log, but have lost a lot of the photos I had, (though I've just recently found a whole bunch of ones I'd forgotten on our old PC, that our son is now using, and will have a look through them).
I will try to get the same level of detail, but you'll need to be patient, especially as I'm building Pegasus too! ;)
First Completed Build: San Francisco (Original Version)
Current build: Victory Models HMS Pegasus
Cross Stitch Project (Finished): Battle Of Agamemnon and Ca Ira
Cross Stitch Project : Victory & Temeraire
I've found some of my lost photos on our son's PC, so even though it's going back a bit in time, I still think they'll be useful.
I replaced the nasty metal grating with a wooden one made from the extra grating material left over.
The post in place at the tip of the beak and the trim and rings installed:
The bowsprit with blocks and yard attached;
In the next post I'll describe how I attached the blocks.
This is how I made the blocks that have a long strop and are attached to the bowsprit by an eye.
First I took a length of the wire provided in the kit, a single block and an eye:
Taking the eye, I wrapped the middle of the wire around it to make the loop at the top of the block:
Next I placed the block under the 'loop'
Take the ends of the wire and place one on each side of the block and twist the together once to lock the block in place;
Next take a second eye and thread one wire end through it:
Leave a short length and bend the end back up towards the block:
Keep this end up towards the block and bend the other wire end down towards the eye:
Now twist the eye around so the wires twist together:
Finally trim the ends and remove the eye from the loop:
Main mast, main top mast, bowsprit and their yards:
Main masts in place:
Main mast and yard:
Main mast crows nest and it's blocks:
Front
Rear
Bowsprit in place;
Next is how I  made the braces (the long bits at the ends of the yard, used to rotate the yard around the mast);
First I took a length of cord just under three times the length of the brace and a block:
I wanted the brace to twist so it held the block:
To do this I stretched out the cord between my hands and twisted the length, making sure to twist it the right way so it wouldn't unravel, then when I brought the two ends together the cord would twist around itself and hold the block in place when placed in the middle of the cord, a dab of cyano (superglue) ensures the block is secured to the cord:
Next I placed the yard on the plans and attached the brace to the end by slipping the yard through one of the twists, adjusting it until it was the length indicated on the plan:
Once happy again a dab of cyano held is securely onto the yard, once dry it was easy to trim;
Next is how I attached a block directly to a yard with the wire provided in the kit.
First I scored a slight grove into the yard where the block was to go, this would help keep it in the correct place.
Next i took a block (in this case a double) and a length of wire, wrapping the wire around the block, and twisting the ends together once, at the bottom of the block to secure it:
Next take the yard and place the block and wire in the grove:
Wrap one end of the wire clockwise around the yard and the other end anti-clockwise, bringing both end up alongside the block:
Now, take one end and pass it between the block and yard so it end up on the opposite side. do the same with the second end:
view on end so you can see the crossover just made:
Now taking the block and the two ends firmly, and very carefully (it breaks easily) twist the block around twice so it is locked onto the yard, then trim the ends.
The gammoning:
I'm repeating myself slightly here, but since I've found some of my missing pic's I can explain how I installed my shrouds in more detail. I first mentioned them and how I make the pendants and tackles here.
The pendants are placed first, they are spliced together:
To keep the mast straight, I temporarily fitted a stay. Next was fitting the shrouds, as mentioned earlier in this log, they are put on in pairs, one pair to the left, the next pair to the right and so on. The last shroud on the port was spliced to the last one to the starboard as they were both singles. On the main mast the first two pairs on both sides were put through the front hole in the crow's nest, the pendant and last shrouds through the back hole;
A lot of builders use a jig for getting the shroud's deadeyes all the same distance, it usually consists of a piece of wood with pins set at both ends, one end would fit into the deadeyes on the channels and the other end for the deadeye on the shrouds, it would be held in position while the shroud was attached to it. I found it got in the way and found it easier to do it without one. The first one was attached to the spliced shroud and the others were attached and leveled by eye;
First deadeye seized to a shroud;
Deadeyes in place on the foremast, all leveled by eye, they will get evened out more by the lanyards
Now to attach the lanyards.
These ones are on the foremast.
First, make sure the deadeyes are the correct way up! The holes are in a 'triangle', the top of the triangle should point down for the deadeyes on the channels and on the shrouds it should point up.
Next, take a length of thread and knot the end. Make sure it's big enough not to get pulled through the hole, but small enough not to be noticed.
From the back of the shroud (Top) deadeye, thread it through the bottom left hole (Note this pic is the BACK of the deadeye):
The thread now goes through the front of the top left hole in the channel (bottom) deadeye:
Now take it up and thread it through the back of the top hole in the shroud deadeye:
Now through the front of the bottom hole on the channel deadeye:
Next through the back of the bottom right hole in the shroud deadeye:
Lastly through the front of the top right hole in the channel deadeye:
Gently tension the lanyards so the deadeyes are all level:
Shrouds and lanyards on the main mast:
DO NOT TIE THEM OFF YET, they will still need tensioning when the standing rigging is complete.
Hi Caroline,
Early in the morning and all ready a question...
You are ending the lanyard at the bottom of the deadeye and not at the top?????
And how do you "closed" it then?
I know that the lanyard are at the top deadeye and then seizing on the shroud…...
Maybe you find another way?
Or is it still to early for me and I don't see it right….
Hi Sjors, that's correct the lanyard ends on the bottom deadeye and then is taken up to the shroud. I hitch it onto the shroud with a clove hitch to hold it in place and then seize it, but that shouldn't be done until all the standing rigging is completed.
Hi Arthur, I started in the bottom left hole in the top deadeye, the one attached to the shroud. )I called it the shroud deadeye, thinking it would be clearer, maybe using upper deadeye and lower deadeye would be better?) I made a typo, and said right hole, I've corrected it now.
The second pic is a bit misleading, I hadn't noticed that before, I'd moved the top deadeye out the way when I was threading the lanyard through the bottom deadeye in the second move.
That's a good pic, Arthur, and shows the order quite well. I agree with you on the second one, I would have thought the end should have passed over the others.
Thanks Arthur!
I think it happens to all of us, the times I've read something and then gone on auto pilot without reading the rest properly, then wonder why things haven't turned out as expected. :rolleyes:
I say let them wonder! They'll probably get the gist of it all by reading the posts. For those that don't: I made a typing error in my lanyard instructions, it was spotted by my trusty followers, who I'd confused slightly and they were trying to establish if I'd gone wrong, but when reading through it again, found it was a typing/reading error. I have now corrected it so it reads better.
Howz zat????!!! :D :D :D:P
Just checking in the ship looks great, The pictures of the attaching methods for the block were interesting, how will you colour the silver wire?
Michael
Thank you !!!!!!!
I have read it again and ok.
Was that the purpose of that miss understanding?
So everybody comes again????
No need to…..I'm still coming  :D  :D
