The channels, gun port lids, plus the oar ports and ventilation ports and the eye bolts have all now been fitted, plus the channel support brackets and the anchor lining boards I found the best way to work on her, was keel up, it gives much better access to the under sides of the channels, this would not be such a good idea if the deck fittings have been added.
One problem I found was that parts no 258 the channel support brackets there are only 22 supplied, and the plans shows 26 and if there are ones behind the anchors you need 28 I will get around this by making the extras from the brass strip around the etched parts.
This might be the last update for a bit as we are off on the QM2 for a holiday and Xmas is coming.
Working upside down
support brackets
All the parts fitted to both sides
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
Good stuff Ray. The extra brackets wont take a lot of making up, the brass sprue can make a lot of extra bits and pieces.
Enjoy your cruise mate.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Superb work Ray (as always)
One question : are you sure about the orientation of part 87 ?
(this thing that is to secure the anchor)
Enjoy your holiday, you have certainly earned it !
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
Ray,
Absolutely beautiful work my friend :). I've read through your log, didn't see a detail on how you fixed your cannons under deck so they swivel and stay in place. Turning her decks down is the real test for how well the cannon placements are set for sure!
Warm Regards,
Bill
Passion is Patience...and I am a carpenter in any scale.
Current build;  Endurance - 1:70 scale, Occre
Current build;    H.M.S. Surprise - 1796, 1:48 A L
Hi Guys
 Christian
 Thanks, I have had a look at the lining boards and I think you are right, they are probably the wrong way round, so I have removed them reworked them and refitted.
  Bill
To get the cannons to move up and down, when assembling them I glued the trunnion in the barrel and drilled down into the carriage and ten pinned the cap-square onto the carriage dry which allows the barrel to still move up and down. when I fitted the cannons to the deck I used very thick cyno and also rubbed the finished cannons on sand paper to give a small flat on the bottom of the wheels, to give a better contact-glueing area, plus I glued where the cannons touch on the inner bulwarks the last thing you want is one coming loose when the fore or quarter deck is on.
Mobbsie
The brackets under the mizzen channel are made from the brass/ sprue no problem to make, you would think that the price these kits are right number of parts would be included.
A carriage with holes for the trunnion
A cannon with trunninon and you can just see the sanded flats on the bottoms of the wheels
Ray
 Completed  HMS Diana
Such Excellent work! I will come back to this when I get to rigging my cannons.
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Enjoy your holiday.
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Just a small update not much progress as we before Xmas went on holiday, great cruise on the Queen Mary 2 what a superb ship, a 5 star floating hotel, so as it is a ship I have added a photo, and Xmas took over as well.
I have made a start on adding the dead eyes and links but first the alignment.
Dead-eye link alignment
When I was looking into positioning the channels, making sure they did not allow the links from the dead-eyes to the hull interfere with the gun ports, I also looked at the path from the mast the stays took through the dead-eye links to the hull fixing point. I wanted to get that path straight, so I made a jig using an old length of carbon rod  that fitted into all three mast holes and marked off the point where all the stays would come from on the rod with tape, and then ran a length of  rigging cord from the stays starting point, through the notch in the channel, to the termination point of the link on the hull (as shown in the photos)
so when the dead-eyes and when links are fitted they will flow in the right line from the mast.
Ray
 Completed  HMS Diana
It's always good to hear from you, Ray
Regarding the channels, it is wise to take the necessary precautions. Excellent work.
Starting from the channelplates, for uniformity sake, I let them go more perpendicular downwards as coming from the mizzen mast the channel assembly became a bit narrow due to the presence of the gunport lids.
And of course :  good health and lot of shipbuilding fun for 2014.
Kind regards
Christian
Hi Guys thanks for the comments and Best Wishes to all for 2014
I am working away, on fitting the dead eyes into the strops and the links onto the hull, and the covers over the chain plate edges, it is quite a long job and not the most enjoyable so far, but I am about half way through, and will give a full update when both side are done, with my way of doing this part of the build and solutions to the problems I came across.
Ray
 Completed  HMS Diana
Dead-Eyes and links
On dry fitting the 5mm dead eye into the strop it left a gap in the bottom of the strop, and I thought this will be tricky to connect the first link too, so I glued up the gap and made a metal link 13mm long ,to join the dead eye to the link that is pinned to the hull, I was not that pleased with the result but did find that when the dead eye in the strop is pushed into the slot in the channel it closes up the gap in the bottom of the strop,so I fitted the two links that are pinned to the hull, the preventor link and the toe link and then added the metal link, the middle link made from .5mm wire but the tension was not right so I tried joining the links with .5mm black thread which gives a nice tight linkage and with the knot tied in the channel notch it will not be seen when the covering timber goes on. One thing I would have done differently would have been to fit the 3mm dead eyes and links on the mizzen channel before the gun port lids the lids made it a real pain to fit the links and quite a few naughty words were uttered. The photos below show step by step my way of doing the linkage on this kit, I must say that I much preferred the strops and linkage in the Victory kits, also the kit comes with two toe links short but an email to Jotika quickley brought the parts in the post.
Linkage positions marked on hull side
Preventor and toe link added
.5mm thread through strop
Knott making middle link tied
Middle links ready for trimming
Fore mast --Main mast & mizzen linkage completed
Ray
 Completed  HMS Diana
Very nice. Very very nice.
Mort
Nicely done Ray,
I proceeded more or less the same way, but you were more wise than me as you  fixed  the 2*1 mm strip AFTER the job done, so your knots are entirely hidden and mine were partially as they went behind the dead eye strop.
Kind regards
Christian
Thanks for the comments guys
BE
I have given the thread one coat already and will give it another one.
Christian.
I might have been wiser in covering up the knots but not in other matters as below will demon strait
Major Quarter Deck gun port problem
When all the dead eye to hull linkage had been completed it showed up a major problem,I suppose I had seen it coming but like the ostrich had my head in the sand. The problem, some of the quarter deck gun ports did not line up with the gaps in-between the shrouds ( you cannot have the 9 pounders shooting through them) when I did the ports, I spaced them out neatly but did not look forward enough, to see this problem. I looked at ways of poking the guns through the rigging but in the end had to bite the bullet or in this case cannon ball ! Cut out part of the quarter bulwarks and reposition the gun ports, thats where I am now as photos show old bulwark cut out, a real pain as I expect when it remade will not be as good as when first done.
Cutting out the quarter deck bulwark and rails.
One side cut out  ready for re-work
Edited by Ray
Ray
 Completed  HMS Diana
That's got to hurt Ray, that's a major refit your tackling there.
I wish you the best of luck with it mate, I'm sure all will come good in the end given your high degree of skill and determination.
Be Good
mobbsie
mobbsie
Next Build :-
Hi Ray, as others already mentioned , I'm sure you will recover this.
It appears that shipbuilding is sometimes more related with real  life than one should expect.
More than once I experienced at my own expence to oversee the obvious by focusing too much on details.
Bon courage and take care !
Kind regards
Christian
Thanks guys I am now well on the way to rebuilding the bulwarks and rails, one good thing so far is the main beech wood top rail has remained in one peice. This has been one of those things you must do, for if you did not you would always regret it later.
Ray
 Completed  HMS Diana
Ray
 Completed  HMS Diana
Reworked quarter deck gun ports
I first cut out the bulwark as necessary and laminated some wood to the right thickness, and the glued and pinned it on to the cut out section, I then re-cut the gun ports and added the rails, and the trim and when all done repainted, I did one side first, and then the other, a real pain to do but it had to be done, I could not have left it as it was as it would have botherd me. Over all the repair is not to bad and when the cannons are fitted and rigged you will not see it, if you did not know it was there,and the one good thing was the beech top rail did not break so that looks as good as before and its the part that the eye catches.Also all the channels, dead eyes and links are now complete and painted. Next the fore and quarter deck fittings and guns.
Second side cut out
Laminated insert
New gun ports cut out
Rework completed
Reworked gun ports and finished channels and dead eye linkage
Edited by Ray
Ray
 Completed  HMS Diana
Great fix that no one but you and about 9,000 of us here MSW will ever know.   The last pics look great.
