Another great log Denis. Are you keeping track of the the hours spent on this build?
 I will be a regular visitor from now on.
I noted in your SOS log that you were not going to put that fantastic effort in a glass case.  Is that still the case?  Please excuse the pun.
regards
Malcolm
Completed builds; Caldercraft Mars; Vanguard Alert, Amati Revenge
On the shelf; Vanguard DOK & the Sphinx
HI Denis.... really nice work on the stairs..... just using  varnish was a good choice, they're beautiful. I really like the color of your decking too,
that last set of pictures really shows the color good . Nice!! work Denis.
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Hi Denis
Excellent job. Like the stairs.
Did you thought to paint the guns?
Wait for new pictures. All the best Cristi
Current build : Sovereign of the Seas - Mantua 1:78 scale
Finished:        San John the Baptist - Cross section
                    Santisima Trinidad - Cross section                  Galery Santisima
                    San John the Baptist ( San Juan Bautista)    Galery  San John
                    HMS Victory 1805 - Cross section - Corel 1:98 scale
                    Panart (Mantua) 740 Battle Station          Battle Station Panart 740 Galerry
On Hold:        HMS Bounty 1:64   Mamoli MV39
Hi all
I have done one cannon to see how it looks.
Washed it in Hydrochloric Acid 50% water 50% acid, washed in water for half an hour.
I then dried it off.
Got a cotton  bud and applied the Brass Black.
After 10 minute's I washed it in clean water.
Dried it off, then a second coat of brass black.
I am not that happy with what I have got,
I think I should have used fine wire wool before the first coat of brass black.
Will have to work on this one before I do more.
Denis.
very nice progress Denis........I noticed that you've removed all of the bulwark posts.   are you going to replace them all?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Denis, i like the "test" gun. It looks nie, and it is interesting that you explain all the process. I will remember this, when i will paint some guns.
Thank's for share
All the best Cristi
Hi all.
Had a bit of a disaster :( :( .
Two of the dummy cannon blocks under the forecastle decided they did not like the position they were glued in.
The little so and so's moved to the center of the deck, and they did not ask me :rolleyes: .
Now what do I do, after some thought I decided to take two hull planks off.
I have now re glued the blocks back.
Now putting the hull planks back.
So much fun :angry::huh::o .
Denis.
Denis, I experienced the same thing with the Euromodel  Friederich Wilhelm zu Pferde (FW for short !) and then made a vow that besides using instant glue, I would also pass a fine nail through each carriage into the deck before adding the cannon in any future builds. Maybe not totally authentic but hey, the use of glue isn't either.
Pete
