Elijah, John, Augie, Joe, Don, thanks very much for the kind words and thanks for all the ‘likes’.
Hi All,
The way I see it, is that given this is Sal's second build, he is mere steps away from Danny V., Remco, EdT and some of the other great builders on this site!
Best,
John
John, I want to thank you for your confidence in my abilities but I’m still far from having the skills of Dan V., Chuck, Dirk, Thomas, Bob, Augie and many more too numerous to name.  I do try my best and with the help of all those on this forum I think someday I might be in their league.  As of now I see their ships as showroom new, mine, more like certified pre-owned, its been around the block a few times with a few dents from a 12 pounder.   I’ll be sure to bring it to the next meeting.
Nice work ---- getting a little crowded back there, isn't it.  Love the compass.
Augie, first I hope you’re feeling better and yes getting crowded. I’m glad you like the compass.
Edited by _SalD_
Sal
Current
Nordkap 476 - Billing Boats
Complete
USCG Harriet Lane - Model Shipways
U.S. Brig Syren - Model Shipways
New York Pilot Boat 'Phantom' 1868 - Model Shipways
Beautiful work, Sal! And amazing progress! I change my prediction for you having finished your Syren from Christmas to Thanksgiving  :)
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Thomas
Thanks Thomas. I'm making good progress now but I have the longboat looming and all those dreaded rat lines!
Sal
Current
Complete
Chapter thirteen started off easy enough by making the two raised deck sections at the fore and main masts. I just added some small strips to finish off the edges.  I’ll enlarge the mast holes later.
Then I moved onto the main fife rail.  You know, Chuck seems like a really nice guy but then he goes and tells you to take these flimsy, 1/32” thick laser cut pieces of basswood, with holes in them no less, and round off their edges!!!  Well all I can say is thank God for scotch.  Maybe I just didn’t have a good method for doing this but these pieces are a true test of your patience.  I walked away from these parts three or four times after breaking and gluing them back together the same amount of times.  For those that are working on this model take your time and use very soft hands as you work on these parts.  I finally finished both rail pieces and glued them together. They’re not the best but I ran out of scotch, only kidding, I have plenty.
For the legs I chucked a 1/16” dowel into my drill press and turned them to resemble the draw as close as possible.  After cutting them to length I inserted pins into each end to help secure them in place.  The parts were then stained and assembled.  Belaying pins were added prior to mounting on the model.
Sal
Current
Complete
I can only hope I come anywhere close to doing this good of a job when I get to these steps in the build. I'm studying this for when I get there.
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
That looks fantastic! I love those tiny legs!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Bitts, bitts and more bitts. The gallow bitts were straight forward and made per the instructions.  The posts were pinned at both ends to help position them on the deck and to provide additional strength.
Riding bitts and fore bitts
The galley stack was made from 1/8” diameter brass pipe. I still need to work on my soldering technique as I ended up filling off more solder than what’s needed.  The handles are made from 26 gauge wire and were glued (CA) into holes drilled on each side.  It was then given three coats of black paint.
post-11922-0-15776600-1447081432_thumb.jpgpost-11922-0-18218300-1447081433_thumb.jpgpost-11922-0-95478700-1447081433_thumb.jpg
The bowsprit bitts were made per the manual except for the cross piece.  I believe there is a typo for its size.  The manual shows it to be 1/16” x 1/16” but on the drawing it scales off as 3/32” x 1/8”.  I used the drawing dimensions.  I didn’t glue this piece to the deck yet and I left out the packing pieces between the posts for now.  I'm waiting until I get to the bowsprit mast to make sure everything fits before I secure it to the deck.
The last thing done was to set all the eye bolts and split rings for the carronade in-hauls. The in-hauls were positioned directly behind the carronades with the extra rings placed mid way between the in-hauls.
Sal
Current
Complete
That looks great! She is really coming together beautifully! :)
-Elijah
Current build(s):
Completed build(s):
Member of:
Absolutely beautiful Sal. Way to go!
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Bob, Robzorba, Elijah, John and Eric thank you all for the kind words.
John, I'll see you this Saturday.
Eric, glad to be of any help with your build.
Sal
Current
Complete
Chapter 14.  The timberheads were made pretty much as outlined in the manual except for the pins added to help position them on the cap rail.
I also added the two ladders amidships.  I needed to rearrange some of the rope coils that interfered with the ladder side rails.
The transom was notched for the stern davits very carefully.  Prior to installing them the faux sheaves were cut into the outboard ends. Some wood filler was required to fill the gaps between the davits and transom and then everything was painted.  The cleat was added after the davit was glued in placed.
The boarding panels were carved to simulate a raised panel; it’s hard to see with them painted black.  They were then installed on the cap rail along with the hammock cranes.  After installing these I noticed a mistake that I made with the cap rail that wasn’t that obvious until the cranes were installed.  The cap rail is not level and angles inboard a bit.  This angle is more apparent now with the boarding panels and cranes in place, but at least both sides are angled equally so they match. Nothing I can do about it now.
Sal
Current
Complete
What Tom said Sal!  She looks splendid!  :)
GEORGE
I think it looks great!
-Elijah
Current build(s):
Completed build(s):
Member of:
I am always amazed how full the Syren deck gets once you put in all the details! Beautifully done!
Thomas
Thanks Thomas.  The more I put on the more nervous I get that I'm going to start bumping into thing and breaking them off.
Sal
Current
Complete
Brilliant work, Sal! I can watch all day! :)
Thanks ZyXuz,  I wish I had all day to work on it. I hate it when work gets in the way of my hobbies.
Sal
Current
Complete
