US Brig Syren by _SalD_ – FINISHED - 3/16" scale
This will help me out also as I get to these steps. Thanks for sharing!
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Link to comment
Share on other sites
I can only add what Waco said in 614 post, but I also like the quality images. Bravo.
SOS
New Bedford Whaleboat build. Kit by Model Shipways
I've been making progress on my model and according to the instruction booklet I should be painting it, at least parts of it.
Are acrylic's ok ? I did apply a sanding sealer. but I want to stain the untreated floor boards which are walnut.
Thanks
S.O.S.
Link to comment
Started the yard construction and since all the yards basically follow the same 4 step construction procedure I decided to build all eight at the same time.  All yards were cut and tapered following the plans using the appropriate size dowel.
For the octagon shaped section of the yards I used some dimensional lumber from Midwest Products that I had purchased a while back.  Using a caliper I measured the diameter of the lower mast (0.156”) then determined the circumference (3.14 * 0.156”=0.49”) and divided that number by 8 (0.49/8=0.061”) which very closely equaled the width of the Midwest lumber.  The ends were rounded and glued in position.  These pieces were also very thin so the edges didn’t need to be beveled.  The gaps were filled with some Hobbylite filler and then sanded smooth.  The topsail and topgallant yards were done the same way but with a different size wood strip.
For the cleats I glued two rectangular pieces of 1/16" square wood stock to each yard.  After the glue set for a day I sanded the the blocks to the shape shown on the drawings.  For the lower notch I used a file that had teeth on its edges only.  The yards were then painted.
Foot ropes added.  The 28 gauge wire was used for the footropes as described.  Still need to add them to the topgallant and spritsail yard.
Sal
Current
USCG Harriet Lane - Model Shipways
Complete
U.S. Brig Syren - Model Shipways
New York Pilot Boat 'Phantom' 1868 - Model Shipways
Link to comment
Nice Sal! Using wire for the foot ropes is avoid idea. You just have to reduce shine.
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Link to comment
very nice Sal,
I like the way you did the foot ropes and the octagonal sides on the spars. Your setting a nice path for me to follow.
Richard
Richard
Member: The Nautical Research Guild
                Atlanta Model Shipwrights
Link to comment
Thanks Ken & Richard, appreciate the kind words.
Richard , I just followed Chuck's directions on make the foot ropes and it worked out rather nicely.
Sal
Current
Complete
Link to comment
Just  small update.  Finished all the yard arms and hopefully attached all the required blocks and pendants.  And then....
raised my first yard!!
I pinned the yard to the mast as described in the manual but only glued the pin to the mast so the yard is free to move, just not vertically.  Tying the truss around the mast was, lets say, an exercise in patience.  Should've of done this twenty years ago when the fingers could move a bit more without cramping up.
One lesson learned was that I made the sling on the mast a little too long so there's not much of a lanyard between it and the thimble on the yard.
Sal
Current
Complete
Link to comment
Thanks Lawrence and Thomas and for all the likes.
Well I've been busy, busy busy…  Lower, topsail and topgallant yards are all rigged.  I find rigging, as I mentioned before, to be a task I enjoy doing so once I start it’s hard to stop.  The yards were rigged following Chuck’s directions and so far no problems.
Well no real problems just one little glitch happened when I went to rig the starboard side topsail buntline which is supposed to be run through a block hanging from the aft most cross tree.  When I went to run it though low and behold there was already a line in there. :huh:  What had happened was when I rigged the topsail yard jeer which is run through the block below the cross tree right in front of the buntline’s block the holes in the two blocks must have lined up perfectly and I failed to notice that the jeer line went through both blocks. After a few WTF's and some deconstruction everything was put in order.
Parrel added to the top sail yards
Lower yards rigged and topsail yards added
Braces rigged and topgallant yards added.
As a side note, the more lines I add I start to understand why lions have a hard time hunting zebras.  Looking through all these black and white lines it’s hard to tell which is in front of which.
Sal
Current
Complete
Link to comment
Looking forward to seeing the model in New London Sal.  BTY beautiful work.
SOS
Thanks
S.O.S.
Link to comment
Thanks Dirk, Jack and Bob.
Dirk it's nice that you take the time to look at my log  and I appreciate your comments but I can't imagine you needing any help from me.
Sal
Current
Complete
Link to comment
The spars add a lot of life to the ship! Great job!
-Elijah
Current build(s):
Completed build(s):
Member of:
Link to comment
Thanks Elijah & Thomas.  Yes Thomas I think I can see the light at the end of the tunnel, just hope it's not an oncoming train.
Sal
Current
Complete
Link to comment
Sal, your rigging looks great. What are the odds that those two blocks would line up perfectly. If you had to rig them like that it would  probably have been nearly impossible, ha ha.
Link to comment
She's looking beautiful Sal!
Jesse
Link to comment
Finished placing all the fore and main mast yards and moved onto running the lower braces.  The instructions call for placing the lower braces in two pieces, one on the inboard side from the cleat to the pseudo sheave in the bulwark and the other on the outboard side from the pseudo sheave to the brace pendant.  For my lines I deviated a little from the instructions seeing that I had gone to the trouble in the beginning to install working sheaves in the bulwarks for them.  I did however follow Chuck’s advice to install these lines on the inboard side prior to starting the yard rigging.
Main and fore brace and sheet lines coiled outboard.
Block assembles for the lower course sheets, tacks and clew lines.
Main lower course braces and sheets, tacks and clew lines
Fore lower course sheets, tacks and clew lines
These are the primary tools I used for rigging.  The dowel has a sewing needle inserted into it with the eye cut in half.  This came in very handy tying off  the lines around the cleats and belaying pins.
The yards added another whole new dimension to the ship and for me, needing a magnifying visor to see the smaller parts, I found it hard at times to get close enough without banging into them.  Need miniature caution tape to hang from the yards. ^_^
Another part of running the rigging that’s not really described in the instructions but is probably understood by those who have done this before is when you bring the lines down through the lubber holes.  You need to pay close attention to how the lines run so they don’t wrap around and pull on the lines that are already there. I needed to rerun some lines three or four times to make them run without interfering with other lines.
Sal
Current
Complete
Link to comment
Hi Sal -
When I was rigging FAIR AMERICAN I found that when bringing lines down the lubber hole, it helped a lot to have the line attached to a longer heavier "yarn darner" needle.  I could lower the needle and line vertically down through the lubber hole (or aimed at a belay point) and get it to where I wanted without the lines tangling and snarling.  Ask the Admiral - she might have a yarn darner needle or will certainly know where you can buy one.
Your SYREN is looking very good.  You are doing a nice job on her.
<<Gary>>
p.s.  The yarn darner needle doubles as a marlinspike.
Edited by GaryKap
current build: SYREN
nearly done:  Fair American, Benjamin W. Latham
future builds:  Emma C. Berry
completed builds:  Rattlesnake, Newsboy, Sultana
Link to comment
As always thanks for the kind words Dirk.
Thanks for the advise Gary, the darner would definitely had helped, I should have asked sooner.
and thanks for all the likes, much appreciated.
Sal
Current
Complete
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
