hello John
they come with the kit , there will be about 25 in total I think. I am not use the small hooks that come with them to hang them from the beams as the wiring accomplishes that
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
today I finished one of the bulkheads, adding the door and the two lanterns
Thanks John :)
me and the family have been on a road trip to Melbourne to catch some Australian  Open tennis and now I have 1 week before going back to work and I intend to catch up on the Pearl
Week 19 - 21
after finishing off the painting of all the tiny parts of week 16- 18 its now time to place them in the ship
I have also worked on fitting the lanterns (with LEDs) and only one remains to be done
all the parts of the lower deck are glued in place and I have checked to make sure they are sturdy as the ship will be on the side when planking starts and I don't want any bits falling off ;)
once the final lantern is in place I can glue the 4 parts of the next deck in place tomorrow.
I have modified two of those parts for the wiring so that all will be hidden
Edited by Adrieke
hello adrieke good to see that u are back in the ship yard . the ship looking real good so far keep up the great work
Great to see you back at it, Adrieke.
I really like the additional items ... in particular, the wine cellar and box of vegetables.
B)  B)  B)
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
WEEK 22
yet again I will not use the two provided sheets of cardboard that represents the deck planking, but instead use left over strips.
also provided are all columns for the beams. as I did with the ones on the lower deck I will adjust them a bit to make them look a bit more 3 dimensional ( I ll take a picture next time to show what I mean
WEEK 23
these are all the beams for this deck. 10 more lanterns will need to be fixed to these so I will need to adjust them so I can hide the wiring inside.
a groove about 2 mm will be cut on the top leading to the side that will be completely planked. there the wiring will be hidden between the inside and outside planking.
I shouldn't be surprised about instructions being wrong.
today I noticed that the little tabs on the ribs that will hold the parts with the gunports are on the wrong side.
they are on the side that is going to be open
thinking I made a mistake early on I went back to have a look and yup its the instructions that are wrong
in the picture on the right it shows the tabs on the right when facing the bow
in the one on the left it shows them on the left
this means I will need to cut them off and somehow add them on the other side
Adrieke,
Not sure I can see which tabs you are referring to ...
Do be careful, though. I created a whole lot of extra work for myself in a build because I thought the plans I was using were messed up. I only worked out after the rip-out/re-build that the photograph I believed wrong was taken from a completely different angle.
Not that I'm saying that is the case here ... I've not built this ship.
But could you not open up the other side instead ??
Or does that mess with all your internal work ??
CaptainSteve
here the adjustments I did to the columns
first picture is a shot before
second picture shows the two sliced of parts. I make 2 45 degree cuts at the top and bottom and then make a cut from one end to the other to remove it. then repeat on the other side
last picture the finished product all it needs is a bit of sanding and then staining
Hello Captain Steve I followed your advice and the tabs are where they supposed to be. I  incorrectly assumed they where to fit the parts on the closed side. what the purpose of the tabs then is on the open side I am not sure. maybe later on in the build it will become clear
for your suggestion to open up the other side , would be an option if all the parts including the wine rack weren't positioned to be viewed from the current open side.
everything is now finished up to week 23
the first picture shows with red lines where the wiring will go
a view of how she looks at the moment with the lights on
Looking good from here, Adriaan.   Wine rack?  Really? and not barrels of rum?   Gourmet pirates then. :)
WEEK 24 - 28
brings all parts for the in and outside walls of the gun deck
most of the work is done, just need to put them in place. but that will have to wait till I receive the next shipment of my lights
I have made some holes in the outside walls to tread the wiring around the bulkheads
the inside wall is actually 3 pieces but after checking I can still slide it in I put them all together and planked them.
I am almost out of those left over strips (7x0.6x500) but I should have enough to finish the 4 doors and 2 bulkheads
hopefully I wont need any more from then on
Ah yes, the sides with gun ports are going on.  Next will be the guns ??  Yes?
She's really taking shape Adriaan!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
thanks for looking in Piet. Yes I think the next delivery will include some cannons :)
thanks David :)
i received the lights sooner then i thought so i have been working on placing them inside
8 of the 10 or in place , the last two will come after i put the two bulkheads in place.
you can see how i placed the wiring all in side the double wall
you can also see that i broke several of the top bits off :(. lots of repairs to do after this deck is done
now i can add the outside wall and finish off week 24-28
WEEK 29 - 31
first week all the parts for the 4 doors
so far i have planked and stained them and added the metal grid . the hinges and door knob will finish these off
next week the parts for the bulkheads and 5 of the lanterns
bulkheads are planked and stained and i added supports at the back so i can easily fit in the doors
the last week brings some reinforcement for the stern. i have stained them but will not put them in place until they are needed as i know i will break off the top parts
after this weekend i am all caught up and the next shipment is not due til end of the month i think.
from then on this build will slow down again and i will be starting up again on the G|F
I finished all the lights so I thought I ll take a pictures with all 20 of them on
unfortunately you cant see the flickering in picture , I might have to do a video and post it
Hi Adriaan,
Ouch, that damage looked as though it hurt, hope it's not too difficult to fix.
Nice use of the lights mate, she's going to look special when she's finished.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
thanks Mobbsie. I don't think I ll have any issues repairing but we ll wait and see
thanks John. I ll give it a go recording and see where I get :)
It's a small world as they say and we appear to have the same taste in ships. Here are some pics of a 1:72 Revell kit called "Pirate Ship" that I'm trying to finish. In reality, it is the Black Pearl with a white swan if that makes any sense. I think there was some copyright/licensing issue with Disney such that Revell had to call it something else.
WEEK 32 - 34 all the parts for the gratings on the lower deck. I have them all assembled which wasn't easy. the edges are laser cut in mdf and when removing the burn stains I broke several of them. luckily I got them all back together without it showing. I haven't glued them on yet.
