HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
I am working on attaching the various blocks to the masts and tops. I stropped and fitted the block for the main topmast preventer stay. Fitted the blocks on the underside of the fore top.
Current Build: HMB Endeavour 1:51 (Eaglemoss part work)
Previous Builds: USS Constitution (Revell plastic) HMS Victory 1:96 (Corel) HMB Endeavour 1:60 (AL)
That is really nice work on those blocks. How are you serving the strops and what diameter thread are you using for the strop and serving thread? I am starting this phase of work on my bowsprit. So far I have adapted Chucks rope walk by adding hooks to the central gears and attaching the thread to those hooks. I then feed the thread to create the serve by hand whilst turning the gears, 1st the left side and then as the thread tightens, I turn the right side. This works okay :-/ but takes 30 minutes to produce a 30 cm length of thread...
Hi Mike
I am not serving the small blocks - too much detail that can't be seen, too difficult to do properly, I use black linen thread (see pic). I am serving the larger blocks and hearts, I have a serving machine that I bought off Alexey Domanoff, it works really good. I just use hemp coloured sewing cotton for serving.
Steve
Edited by shipaholic
Been busy this weekend made the rest of the futtock deadeyes, I used copper wire to make them then filled them in with solder and filed them flat and drilled the hole for the hook.
I finished off the foremast and top, added the block for the main topmast stay. Now to finish the main mast and top.
I was able to spend a bit of time on the ship this weekend.
I made the cat blocks and I was a bit disappointed that I couldn't figure out a way to simulate the wider centre of the iron band around the block where the sheave pin goes through.
I started making the second anchor as well.
The blocks look fantastic! What size are they please? I am going to build and rig my anchors shortly
Hi Greg,
Just found your log, a went through every page.
Very inspirational and fantastic photo diary.
Lots of top ideas for us beginners to learn from, my Endeavour being a first time build, need all the ideas and tips as I can get I reckon.
Keep the spirit(bundy ?) up. :D
Dave R
Measure twice, cut once.
Current Build: HMB Sirius 1786 - Flagship of the First Fleet to Australia (Scratch Build in the Shipyard)
Finished Build: HMB Endeavour 1768
Hi Dave,
Thanks for the compliment. It's a pity all the earlier posts were lost when this site crashed last year, so my log on here now starts when most of the hull work was done. I still have all the earlier pics on my PC so if you want to look at any of the earlier work let me know. This is my second Endeavour, I built the AL endeavour a while ago, and my third wooden ship. You will find plenty of help on this site, if you post a question on your log someone will give you the answer or helpful advice pretty quickly.
Actually I'm a beer man!
Cheers
Steve
OOPS! made a huge mistake, well not that huge - a couple of mm.
I spent a fair bit of time on the weekend making another one of the anchors. I bought a Caldercraft anchor that is 74mm long to use as the small bower anchor, the other anchor I had already made is the sheet or best bower anchor which is slightly larger at 76.5mm long. Then I looked at the drawing in Ray Parkin's book I have been using as a reference and noticed the diagram is of the small bower anchor. So the small bower anchor should be the one that is 76.5mm and the sheet anchor and best bower anchor should be 78.6mm long. So both anchors are a little bit smaller than they should be by a couple of millimetres. I am the only one who will notice so I will leave them as they are.
Today I spent a couple of hours making another anchor. I used 5/32" brass rod and some flat brass strip for the palms. Lots of filing to get the shape right and soldered together. When I finish this one I will have the sheet anchor, best bower and small bower. Two to go - the smaller stream anchor and kedge anchor.
Cheers
Steve
Hi Steve,
The Endeavour has been put into ordinary for the time being (i.e. packed away in a big plastic storage box  :) )
Because I don't have a permanent work area I didn't want to start the masting and rigging as it would be quite vulnerable and didn't want any dust on the rigging issues and would be a bit unsightly covered up in the living areas :D .
Once we get our new place sorted I can keep it out and covered when not working on it so no dust issues.  Hopefully around next April will have a dedicated modelling room.
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Superb job. The metalwork is very very good. I am working on my anchors too, i will post updates soon. it has been awhile.
Superb work on those anchors. That is dedication to craft and art of the highest order!
Cheers
Alistair
Current Build -
Spent a few hours today finishing off the best bower anchor. The hoops are made from copper wire that I flattened with a hammer then shaped and soldered. For the previous two anchors I used brass rod for the pins this time I used some brass nails. I thought the heads of the nails looked too big so I filed each one smaller.
Cheers
Steve
Thanks Greg. Okay lets post a few more pics just to show where I'm up to. Not trying to make it look like the Replica or like AOTS book, or Parkin's. My Endeavour is a combination of all the sources of info on her that I can find, my research project
