Looks great Geoff. I was tempted to make and install the stuns'l booms to help stabilize the support fittings (the aft one gets really banged up), but I wasn't sure they would be in the way of rigging. I see that they are.
Thanks for posting the photos!
Harvey
Well, I finished the fore and aft bumpkins. I used basswood for the bumpkins Square plastic for the iron band and wire for the rods. Just took everything off the plans.
The one Thing I noticed is that once the bowsprit is installed it is going to be a tight fit to install the chains around the bowsprit :o
Edited by Geoff Matson
Geoff
NRG member #2666
Current build : USS Constitution
Finished builds: Armed Virginia Sloop (in gallery)
Hello Geoff
Beautiful work. the details on the masts are amazing. Your bowsprit turned out excellent also.
I tend to spend way too much time thinking things over myself. I prefer to think of it as internal research rather then putting it off. The difference is the amazing detail that was produced by that stalling/thinking. I like the pace that model ship building forces us to take sometimes. Its a slow precise hobby and your mastering it. I can't wait to see your rigging, as I'm sure it will conform to the excellency of the rest of your conny build.
I second that !!
Edited by CaptainSteve
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
I just relooked over your log, to evaluate your use of styrene and on my previous post I guess I didn't pay attention to the fact that this is a 1:76 kit. I'm even more astounded with the details of the masts and their components then on my previous look. One often forgets to look at the scale before evaluating. Such detail at such scales is a definite mark of a true artist.
Looking forward to seeing those masts rise and standing ringging go on.
Looks like we are at the two ends of the state. I am right on the Ill. Wis. Border. Thanks for the comments. I wish the Conny was of a larger scale so you could show more details. But if it was You have have to keep it in a garage! :)  I am now working on the yards, A lot shaping and sanding to get them right.
Geoff
NRG member #2666
In looking over your last set of images, I took particular notice of the stern and have two questions.
First, how did you create the "Constitution" nameplate with such fine lettering detail. Is this self made decal, part of the kit, or what?
Second, what is the purpose of the rudder chain? Obviously it's not part of the steering mechanism. The only thing I've been able to hazard a guess is, it is some kind of fail safe to catch the rudder should it fall off during battle or storm. If that is the case why are there three chain loops. Are they decoration or do they serve some sort of purpose like a shock absorber to prevent breakage should the chain suddenly become taut due to a falling rudder?
Thanks for your interest
The lettering on the name plate is just dry tranfer lettering from woodland senics. Very east to use.
As for the chains on the rudder. I think you are right about it being a fail safe to keep the ruddr from breaking away. Not sure as why there are three loops. That is what is on the plans.  If I were to do it over I would blacken the chain and not have it brass.
Geoff
NRG member #2666
Making progress on the yardarms
Since I have no lathe here are the tools I use to make the yardarms.
I start with a square dowel and sand it down.
Here is the yard before painting.
Again I used styrene to simuliate the wood battens and iron fittings. Here it is painted
The studding sails dowels were colored with Burnt Sienna oil paint.
Geoff
NRG member #2666
Jeff:
I can never find good straight dowels. So I make my own. For the Conny they are a strip of poplar wood from Menards. I then cut them to proper size and then sand away.
themadchemist:
The sanding blocks are made by GreatPlanes and called easy-touch hand sander. They fit good in your hand and are easy to use. I have five of them with grits of 80,100,150,180 and 220. Makes sanding alot easier.
Geoff
NRG member #2666
Hi Geoff
Just caught up on your log. Beautiful work indeed. I always tip my hat to those who take on this model - it is epic and you doing it a great justice. Will follow from now on.
Cheers
Alistair
Cheers
Alistair
Current Build -
I finished the Fore, Main and Mizzen lower yards
One of the draw backs with using oil paint to simulate the bright colors is that it tends to rub off with ahndling and will nedd to be touched up. No big deal.
Geoff
NRG member #2666
Geoff, the alignment of those eyebolts and jackstays is perfect!!! Great job, my friend. I wish mine were that good.
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
Jay
Those jackstays took some time. I am now working on the top sail yards and want to make the jackstays one size smaller and do the same for the top gallant yards. The top gallant yards will be a challange to make. But I love a challange. :)
Geoff
NRG member #2666
Thanks for all the pictures I'll be using them with my Morgan to follow how you've done the yards and such. Looks great.
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
I finished with the top sail yards.
I did use smaller eyebolds and rods for the jackstays. I will folllow the same procedure the remaining yards. THe higher I go the smaller the eyebolds adn rods for the jack stays.
Now on to the top gallant and royals. The smalller the yards become it is more time consuming to shape the yards.
Geoff
NRG member #2666
Beautiful (and I imagine painstaking) work, Geoff! I love the detail and finishing on the spars!
hamilton
Well I finished the spritsail yard and the gaff boom and spanker boom
Now all have do is make line and then onto the rigging part
Geoff
NRG member #2666
Outstanding work, neat and clean (I am so drawn to that and dying to do that kind of work on my own... but living through people like yourself for now =) ).
And the colors just pop.
The masts are coming along really nicely and look solid.
Love it.
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Geoff, you are doing fantastic work on those spars. I like the way you added the studding spars. The fittings are perfect.
I am afraid I tend to go too quickly with mine and overlook the details. I just need to pay more attention to your work. Keep the pictures coming.
Jay
