I finished all the foremast shrouds.
The shrouds are all I want to install on the foremast right now. I am figuring out the rest of the lines that will go on the Foremast and make them up ahead of time. That way when I begin installing the mast all the lines will be ready to go.
I will do the same for the Main mast and Mizzen mast.
Edited by Geoff Matson
Geoff
NRG member #2666
Current build : USS Constitution
Finished builds: Armed Virginia Sloop (in gallery)
I like the temporary mast stands and the protective "house" for the ship. Really good ideas!!  :)
GEORGE
Thanks George.
They work out great and make the rigging a whole lot easier. This way I can rig the masts while sitting in my chair instead of standing up and working over the model worrying about breaking something off. With the rigging there is a lot adjusting the lines to get them just right. If you look behind the masts you can see the other stands ready to go to work :)
Geoff
NRG member #2666
Some people have asked me post how I did the runner pendants.
In this picture the line has been made and served and attached to 1/8th bullseye.
The bulleyes have been adjusted and set with diluted white glue and trimmed.
The two lines have been seized and the tails left on for the final adjustments.
The lines have been placed on the mast. The tails aid in the final adjustments. This takes some time. I am so glad I do it off the model. Once I am happy with the position of everything I set the lines with diluted white glue. Once the glue is dry I trim off all those tails.
Here is the finished product
I will next install the swifter, which will be served the full length and move on the the lower shrouds. The small hole in the mast is where the yard will be installed. I try to pin all my attachments to make the rigging simpler.
Geoff
NRG member #2666
Hello Harvey
You got it! That is why I use Cotton Thread. You can set the line with a little diluted white glue.  I also apply it to the attachment point of the rigging if I need to take some slack out of a line.
Geoff
NRG member #2666
Looking good Geoff,  You can also use Testors Dullcote if white glue is not available.  Merry Christmas.
David B
I installed the lower shrouds on the main mast. I will attach them to the dead eyes once i set the mast. Here is a picture of the the shrouds laid around the mast
Geoff
NRG member #2666
Nice looking shrouds Geoff!
GEORGE
Hello lambsbk
Thanks for interest in my build. I also found your sight and you are doing a great job with your Conny.
At this smaller scale it is really hard to make the rigging look right. That is why I went with making my own rope using the Byrnes Ropewalk. The kit supplied rigging line just left a lot to be desired.
Geoff
NRG member #2666
Hello Dave.
Here is a sight I just came across for cotton thread.  http://www.discountembroiderysupply.com/It is called Discount Embroidery Supply. I ordered some 40 wt and 80 wt cotton thread from them to make more smaller sizes of rope. They have a lot of thread and different sizes. Just check it out and it may help you out.
If you use (Coats and Clark  30 wt  and 35 wt), (Guttermann 50 wt),(Maderia 80 wt), and( Floriani 40 wt) you will have five sizes of single black thread to use and no rope walk needed. You might want to check out the lighter colors for the running rigging.
Geoff
NRG member #2666
.Here is a sight I just came across for cotton thread.  http://www.discounte...derysupply.com/It is called Discount Embroidery Supply. I ordered some 40 wt and 80 wt cotton thread from them to make more smaller sizes of rope. They have a lot of thread and different sizes. Just check it out and it may help you out.
Here are a few shots of making three strand 40 wt cotton thread
Geoff
NRG member #2666
What method did you use to make the mouse?
Hey that Rattlesnake is looking pretty great. I remember when you started it.
Thanks for your interest in the mouse. It was pretty basic, I just followed Bob's idea of taking a square piece of wood proper for the line size, drill a hole in the center the size of the line and file it into a cone shape. Then just painted it black and slipped on the line.
Geoff
NRG member #2666
You must have a good memory, It's been a looooooong time since I started the Rattlesnake. Your Conny is looking real good. I hope to started mine before the millennium is up. 8-)
Jonathan
I spent the last few days making rope for the my Main Mast rigging. I will follow the same practice as I did on the foremast, rig as much as I can off the model. I also make up a lot of the other rigging line ahead of time so when I go to install everything I will be ready to go. The nice part about this is I will know ahead of time where all the lines will attach. This will hopefully prevent having to drill a eye bolt hole in the deck with everything installed and in the way.
Here is a quick shot of my main helper going over the rigging with me :)
Geoff
NRG member #2666
Looks like you must have worn him out, and he's going to take a nap now, after removing the optivisors.  :P
GEORGE
The level of detail is simply amazing.  Reviewing various galleries and current builds, I realize how much I have to learn.  Fabulous job!
“Here.  Hold my beer..." --- Common phrase uttered by Lord Admiral Nelson at any pub. 🍺
Geoff,
Thanks for your great work! I have just caught up with your log, and having just started a 'Connie' of my own this past summer, I am really going "back to school" after about 35 years totally away from modeling. Thanks for being a great instructor. Mine is a 1/96 Revell kit so the scale of everything is a bit different from yours, but the lessons are the same: "Measure twice, cut once." Even though it is plastic, the same principle applies.
Thanks again.
Pete
Thanks George.
I think you will still find time to break off things. I seem to anyway!
Bill
Chantilly, VA
Its not the size of the ship, but the bore of the cannon!
Current Build: Scratch Build Brig Eagle
Completed Build Log: USS Constitution - Mamoli
Completed Build Gallery: USS Constitution - Mamoli
Very nice build Geoff! I will follow with interest! Is the Connie too big to bring to meetings?
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Hi Geoff,
I'm enjoying your build log. I believe you have the LLS practicum as I do and I've been reading ahead in it a little bit. I have a question that maybe you've already come across as you're ahead of me in the build. It appears to me that Bob only addresses the mast measurements for the fore mast and skips over the main and mizzen and furthermore it appears to me that there's a discrepancy between his measurements for the fore mast and those in the plans. Specifically he says to measure up 4" from the top of the mast boot, whereas the plans say to measure up 4" from the deck (or bottom of the mast boot.) Did you find that to be the case, or am I misreading something. It appears that we must take the measurements for the main and mizzen from the plans and if that's the case then I'm inclined to take the measurements for the foremast directly from the plans too, rather than the practicum. I'm just curious as to how you handled this part of the build.
Thanks,
David
Current Build - St. Roch, Billing Boats; HMS Agamemnon, Caldercraft (on hold)
Previous Builds - Armed Virginia Sloop, Model Shipways; Constitution, Model Shipways; Rattlesnake, Mamoli; Virginia Privateer, Marine Model Co, restoration; Prince de Neufchatel, Model Shipways; Charles W. Morgan, Model Shipways; Pride of Baltimore II, Model Shipways, Bluenose, Model Shipways (x2); Niagara, Model Shipways; Mayfower, Model Shipways; Shamrock V, Amati; HMS Pegasus, Victory/Amati
