Everything posted by James H
Not a massive update, and there have been two prow reworks to get it spot on. That held me up a few days in total, plus my health hasn't been conducive to extended workshop sessions. Anyway, the hull is now fully first planked in 6mm wide strips of 1.5mm thick lime. For me, that's the king of my least favourite parts done, next to sanding it! I used a combination of palm sander and manual muscle/sweat to clean up the planks. After that was done, I opened up the gun ports so they are almost at right size. The inner, side bulwarks are left a little long so they can be trimmed exactly to your own build. To level up to the stern timbers, I use a rule and pencil to drawn an extended line from the stern timbers, then trim/sand to the correct length. The lower, curved area etc. are also trimmed back to the stern timbers. This little part sits across the inside of the stern timbers. It will later have a shelf sat on top which will help with its placement. Here it is fitted. To make things easier later on in the project, three poop deck beams are slotted into place (#1, 5, and 10) so I can temporarily fit the poop deck. This will help you sand the back edge to the same as the stern. Even though I show/include this, on my prototype it fit without needing any sanding at rear. The quarter gallery frames are now built up...well partially. These will soon be temporarily fitted to help with the vital positioning of the stern elements (stern face, middle and lower counters). Until next time...
- 488 replies
- Indefatigable
- Vanguard Models
A very quick update. I've just received the masting materials from Chris, along with some amended timber parts sheets etc. Also in the pack were the Pellew and Hornblower figures, plus the Indy figurehead. I thought I'd do some pics for you of the figures. Also, the Pellew and Hornblower figures are now available for sale on the VM site, in 1:48, 1:64, and 1:72 scales. Get them while they're fresh off the press! 🤪 https://vanguardmodels.co.uk/product-category/model-figures/ Hornblower: Pellew:
- 488 replies
- Indefatigable
- Vanguard Models
There'll be an update in the next days, but in the meantime, here are some pictures of the Indy figurehead and also 1:64 figures of both Pellew and Hornblower. Both of the figures will be on the website in the next days, but Pellew will also be included with HMS Indefatigable when the kit is released.
- 488 replies
- Indefatigable
- Vanguard Models
Subscribe to this topic. As soon as I have news, this is where I'll post it.
Hi all, When we post a review of a tool or kit at MSW, we do so objectively. We aren't obliged to write a glowing review as we have gotten a 'freebie' as some folk would assume (not on MSW I would hasten to add), but we are expected to be both critical and constructive. If we see limitations, then we mention them. We get some really good comments, questions and replies to these articles, which have taken time to create, and also at a cost to the vendor. What we would kindly ask, in the interests of forum etiquette, is that any talk is limited to the item reviewed and its availability, and not onto links to competitor items which is grossly unfair to the company that wishes to see their products honestly assessed/critiqued, including good/bad feedback about the item from someone who has made a purchase. Thanks, Jim
Not great photos, but I have been asked several times about the size of Indy compared to Amati's 1:64 Victory prototype, so here's a couple of photos for you. Remember that the angle of the first pic makes Indy look bigger than Vic. It isn't! That's why I did a photo of Indy sat on Vic's lower gun deck.
- 488 replies
- Indefatigable
- Vanguard Models
I find a good place to start is measuring the distance from bench top to keel underside, at both both and stern. Make sure they are the same so you know the hull is parallel to the worktop. Set your waterline tool at the stern waterline position shown on the plan and then touch this at the bow to confirm the plan position.
- 73 replies
- Sphinx
- Vanguard Models
At least I'm right-handed and don't need that to fret my guitar.
- 488 replies
- Indefatigable
- Vanguard Models
I have already sanded my fingertips off, twice. You never saw the bloodied sandpaper. Annoying as my Mac is fingerprint activated and I've had to scan my pinkie to make it work.
- 488 replies
- Indefatigable
- Vanguard Models
Do you know anyone just inside the US border who would receive for you, and you could pic up from them? Is that possible between the US and Canada? I know that feeling! 😆
- 536 replies
- Quadrireme
- radio
- 488 replies
- Indefatigable
- Vanguard Models
Those are now unfortunately out of production. If you do want some excellent razor saws, try ASK, but they aren't like the one I've shown. We have reviews of those tools here. Tell them I sent you
- 488 replies
- Indefatigable
- Vanguard Models
...and the top of the upper strip (directly below pear) sits along the top edge of gun port. Scrap material fills the gaps between. Works a treat.
- 488 replies
- Indefatigable
- Vanguard Models
Just for some info, Indy will be approx 880mm tall. Ok, onto business. The hull is now faired. This isn't really a task you can sit there with a piece of sandpaper and hope to achieve inner calm. Chris finally talked me into getting a palm sander (mouse), so I splashed out on a Black & Decker one. Even with this, fitted with an 80 grit pad, this job still took me a total of about 5 hours, along with the final task of wrapping some sandpaper around a 12 inch piece of thin ply to absolutely ensure the curves were right....plus the joyous task of blending those last bulkheads and fairing blocks into the keel. There is a lot of regular planking on Indy, but the inner core of the outer bulwarks are laser cut. So as not to stress out the forward bulwarks and those temporary gun port sections, these were first soaked and clamped in place. These were left for a full 24hrs to dry out and shrink back to their normal size. Pear has a hell of an expansion, even when soaked for 30 mins in hot water, so you really need to find a book to read, guitar to play, or TV to watch while this dries. Now that the parts are completely dry, I draw around the forward position of the bulwark so that I have my positions for the flow of the first plank that runs below the gun ports, and also the extent of the planks above this. It's important to know here that this pear part sits along the top of the gun ports on the main deck. The pear bulwark is now removed and the first 1.5mm thick lime strip laid along the bottom edge of the gun port sills, and along the lower line I've just drawn. On the prototype, each plank is 500mm long, and they meet up on the double thickness bulkhead #9. We're not yet sure if that will be the case on the final product. The back end of the same plank run is now installed. These planks are pinned until dry. If you pin all the way through, they will penetrate through the inner bulwarks, but that doesn't matter as any holes will be in the area covered by the spirketting. The pear bulwark sections are now temporarily clamped into position so the bottom edge runs along the top edge of the gun ports. You don't need top do this but I just considered that it was good insurance that the plank that runs directly underneath these pear parts, would be properly installed and a snug for in that area.It also gives you something to finally sit these parts onto later so you have a much better chance of both sides being exactly equal. Care is taken not to get any glue on those pear bulwarks. The spaces between the gun ports are now filled up with lime strip. This doesn't need to be neat at this stage. They'll be cleaned up later. A razor saw is now used to cut away the lime strip in the top row, that is partially obscuring the gun ports. The pear bulwarks can now be reinstated, but before this happens, you need to know a little bit about the side framing of the rear half of Indy. Not all of it will become a part of your finished project. When it comes to gluing the rear sections on first, the area in red here WILL NOT have any glue applied to it as that section will later be cut away. You can see the area with glue covers the the lower area just underneath the red area and for the rear section, it terminates at the point where the longitudinal strips were installed in sections. When you look at the model and my previous photos (without red marks), you can see that split in the strips, denoting the two areas. The rear bulwarks are now finally glued into position after some final measuring, ensuring both sides are in exactly the same position. This isn't too difficult now that this part sits upon that lime plank. Other factors also help too, such as the two rear gunport frames on the quarterdeck and the quarter gallery doorway. Just check at the back end to make sure things align with the stern timbers. Of course, you don't need to worry about gun port alignment on the rest of the quarterdeck gun ports as those frames will later be removed, as discussed. 2 inch clamps are very useful here to make sure the bulwark is squeezed into the hull curvature, as they can hook through the gun ports. The mid and fore pear bulkheads are now glued into place. And for the last part of this update, here's how she currently looks. Next job is to cover that lower real estate in lime planks. Remember, this is the same size as Agamemnon! Until next time....
- 488 replies
- Indefatigable
- Vanguard Models
Simply gorgeous and the colour of the finished timber is perfect. What do you use to varnish/oil your project?
- 216 replies
- masterkorabel
- ships
(and 3 more)
Welcome to MSW Great to have you with us. Let us know what your choices of project might be.
