Everything posted by TBlack
CA residue problem
TBlack replied to Doc James's topic in Painting, finishing and weathering products and techniques
I find that the white streaks will disappear with varnish or dull coat. Tom -
I've been working on the cockpit. And BTW, you'll notice that Michael Mott is building a Bristol Pilot Cutter. If you think mine is going to look like his, sorry to disappoint but I can't hold a candle to his ability. Anyway, my cockpit has a grating for a floor. Here's the first cut: I use the end grain which eliminates broken teeth. I also use a 1/32" end mill and a DRO that give me precise cuts. I needed to butt 2 of those to make the final product:
Michael, I don't think I've seen a picture of your new shop. I like the windows (I'm in the basement). I know we're supposed to write about the boat, but I'm intrigued with what looks like windows over the bench where the plaid box is located and the wye for a railroad? Tom
- 2,215 replies
I, too, am most impressed. Not only with the operation, but also your drawing of the davit is quite a work of art. The drill is hand operated, right? Tom
The plans arrived from England. They are of the Hilda and Marguerite. They have enabled me to lay out the cockpit and main hatch which then allows me to see where the deck planks don't go. Consequently, I've been able to lay the deck. The hull isn't quite symmetrical, but I've managed a passable presentation:
Your method is much better than mine, but I don't have a full sized lathe. I use a Unimat SL1000.
Don, I get it. Thanks. I use a drill press. Same idea just 90 degrees different. Tom
Ron, Hard to tell from the photo, but are the top and bottom sides parallel? If not then you've got to square the whole piece up, and then is there enough lumber to do what you want to do? The bigger question in my mind is: why do you want to use it in the first place? Won't the wale be painted black? I may be ignorant. Tom
Hello Don, Trying to make connections. Do you remember the Salmon Kings hockey team? My son-in-law used to play for them. Also, I'd love to know how you turn a lathe into a thickness sander; I'm having a hard time picturing the set-up. Tom
Hey John! I still use bees wax. Not only does it get rid of the fuzz, but also gives the line a little body which helps thread it through the block. Tom BTW, I think my wax dates back to 1975. A great bargain!
Peter, Thanks for the prompt reply. Picture not necessary. I get it. Last time around I tried super glue which didn't work so well. Tom
- 366 replies
- bellerophon
- victory models
I know it's a bit of a back track, but how do you get the footropes to hang so nicely? Tom
- 366 replies
- bellerophon
- victory models
Dave, If you tell us which model you are working on, there will be someone here who has built the same model and can give you specific advice. Tom
Having decided on the scale (1:32), and the type of boat (pilot cutter), I then discovered that the African Boxwood is brittle. On ripping the wood to make deck planks I found that small pieces would break off, making it impossible to get a straight edge. Putting the boxwood aside, I ordered up some yellow cedar from Chuck that has arrived. I found a couple of pilot cutter plans from Starik Hobbies in England, so I have a small hiatus while awaiting delivery. I can do some of the deck planking in the meantime. I have option: planks that follow the line of the hull, or straight planks. I prefer the curved option, I think it looks more elegant, but all the pilot cutter I have researched have straight planks So that's settled. Oh, and thanks Keith for the photos! Tom
HMS Sphynx by TBlack - 1:64
TBlack replied to TBlack's topic in - Build logs for subjects built 1751 - 1800
Druxey, I understand your concern. The final resting place for the model is presently occupied by a forest of nutcrackers. Post Christmas season, the model gets moved inboard. Thanks to all of you for the likes. It's always rewarding to see one's efforts inspected so closely. However, there are 3 tests for any model: the 10 foot test, the 3 foot test, and the 6 inch test. I hope I pass! Tom
