Blue Ensign
  1. Post Sixty-four Bits and pieces. Time to make up the ladders leading down from the Upper deck. There are two laser cut sets in Pearwood, nicely formed with added decoration down the stiles and shaped treads, a cut above the standard fayre in many kits. 2195 The only point that struck me was that the Main ladderway midships is quite wide and I wondered if a central stile was appropriate to support the treads. 2178 Still need a little cleaning up at this point, and a finish with w-o-p. 2209 Ladders are tricky little beggars to fit, and I always attach a length of cotton to the top tread so it may be recovered if it slips onto the lower deck, or even deeper into the hull. I wasn’t happy with the Aft hatch grating and Chris was kind enough to sell me replacement bespoke gratings both for the Upper deck and the Quarter deck, which I thought also may present me with similar issues later on. 2176 The gratings are cut, soaked and bent around a large circumference tube to impart the necessary curve. 2188 It took two of the basic aft hatch gratings to make one split version, which is more historically accurate, and satisfies the detail devil that lives within me. 2190 Now satisfied, I can move on. The kit contains simple Mast rings to glue on the deck over the mast holes. With open beams I thought a minor enhancement to better represent the mast partners was in order. 2217 Not entirely authentic but sufficient for the purpose.. I believe the rings are supposed to be a representation of the wedges used to secure the mast against the partners. 2222 Fore mast partners. When doing this sort of modification it is worth checking how it will affect the surrounding fittings. 2226 The Fore riding Bitts and supports needed the mortices tweaking a little to fit, but with the surrounding fixtures very little will be seen of the partners. 2231 Looks like a major char removal exercise is looming. B.E. 15/01/22
  2. Fine work Grant, a beautiful little model. B.E.
  3. Well done Glenn that looks a fair base to apply the seconds layer. 👍 If you feel better about it, you will progress better with it. If you need to take a step backwards, take it. B.E.
  4. I much appreciate your comments guys, and those who look in and 'like' Post Sixty-three Sorting out the deck fittings A couple of hours work to clean up the fittings holes on the Upper deck and trial fit the pieces. 2159 Surprising how long it took to identify all the relevant parts, and group together in their respective sets. All were labelled and secured in six separate plastic bags. I don’t want any falling within the sphere of my yard assistant, whose first rule of operation is:- ‘if it’s on the floor it’s mine’ There’s a lot of char to clean up but that can wait for the present, a job for a day when watching paint dry isn’t an option. 2163 The deck is taped and the coaming/hatchways are repainted using Vallejo matt black. 2171 I decided to represent treenail covers using 0.35mm drill holes filled with tinted filler. They are barely visible, as should be, and are only applied to the butt joints. A final scraping, followed by a sealing coat of Vallejo matt varnish. 2170(2) 2164 I think I will make up the ladder sets next and fit those whilst the decks are clear. B.E. 13/01/22
  5. Nice job on the wheel Bug, one of those is currently winging its way across the pond for use on my Sphinx. I hope I make as nice a job of it as you have. Great progress on Pegasus. B.E.
  6. I found this of help when I was working on the headworks of Pegasus, It has been many years since I tackled one of these and the thought of it gives me the yips. I recall getting that smooth transition between the Upper cheek and hair bracket, and the Eking Rail and the Lower rail a very testy exercise. Wishing you a trouble free passage in completion of one of the most critical areas of a build. 🤞 Regards, B.E.
  7. Post Sixty- two . A five month photo review. With the planking completed I was keen to see how the hatches and gratings looked. 2148(2) 2140(2) 2137(2) 2136(2) With the decking in place it all looks so much better and things are proceeding to plan. 2152 2146 My eye keeps catching the slight difference between the Aft hatch grating and the others. I am otherwise happy with the modified coamings and curved gratings. 2141 2144(2) I will now spend some time ensuring that all the deck fittings slot into their allotted holes before moving on. B.E. 11/01/22
  8. Post Sixty-one ... and more deck planking. The second bite at the planking cherry went better with fairly rapid planking along the deck using 3.4mm strips. At the bow end I merely butted the planks against the margin, back to the Bridle port, but this part of the construction will be obscured. When it’s straightforward I find deck planking quite relaxing, as with most things it’s the fiddly bits that take the time, and tend to frustrate. As the planking line approaches the Margins, Hooded planks become a requirement. I am not using joggling into the margins on this build. Wider planks as necessary are needed to make hooded planks; it’s not that difficult, the tricky part is getting the tail to match the standard 3.4mm wide planks that extend from the hooded strakes. At this point I also considered using Top and Butt planking for the outboard four strakes as indicated in the Tffm Swan books. On contemporary models of the period there is not any evidence that I can see to support a general use of this planking form. This is what Peter Goodwin has to say on the subject. (The construction and fitting of the English Man of War 1650-1850) In most vessels all the planking was of parallel strakes, with the butts square. Some builders fitted two strakes of either top and butt or anchor stock 4 ft from each side of the ship. This practice was probably adopted towards the end of the eighteenth century. Much as I find Top and Butt visually appealing, I have decided to forgo the pleasure; I did trial a mock-up but the t&b planks would extend some 26mm from the margin with a high point of 5.5mm. They covered over half of the broadest deck width, and seemed to my eye to overwhelm the overall look. Well that’s my excuse. A further three days work and the planking is complete. 2107 The process of deck scraping begins. 2116 2114(2) Once I’m satisfied with the scraping I will apply a coat of flat matt varnish to help protect the surface. I will then need to re-vist the finish on the coamings which has suffered somewhat during the planking. B.E. 10/01/22
  9. Hi Allan, The kit supplied Pearwood gratings are very nice; the ledges are 1mm and the battens 0.70mm. The after market equivalent from Vanguard are still good but slightly less fine than the kit specific ones. I had originally intended using Syren curved Boxwood grating kits but having made up a sample, on this particular model I thought the Pearwood looked better. The kit coamings etc were designed to sit atop the supplied etched decks, so I added the thickness of the deck to the bottom to represent the depth down to the beams (represented by the false deck) The Boxwood planking is now at the same level as would have been using the kit set -up. The Head ledges were added as a 'round-up' wasn't represented on the kit set-up, and it's something I like to see. Thank you for looking in. B.E.
  10. Post Sixty Planking continues. The tricky business of laying down the binding strakes is next. These incorporate the tabs that fit around the coamings and are cut from wider 6mm strip. 2086 I had a few goes at getting the cutting right particularly along the section that encompassed the Main and aft hatchways, but got there at the end of a long day. The next tedious stage was re-cutting all the holes for the deck fittings and masts. Drilling, cutting with a scalpel blade, and finishing with files. 2079 The deck will look much better once it has been cleaned up. This will involve scraping using an old small plane blade, I never sand decks. The cut-out holes for the fittings will be fully cleaned up once the decking is complete. This work needs to be done with soft hands using needle files, as the merest hint of harsh filing has a tendency to rip the thin Boxwood planking. As he who needs no introduction would say: You are not carving a bear with a chain saw here folks. I love that saying which has stuck in my mind from my Royal Barge build instructions. 2088(2) From this point I moved to using the 3.4mm planks and I start to apply tapering towards the bow and stern having marked the decreasing widths on the false deck. After a days work I decided it wasn’t good enough, and I didn’t like the look, so at close of play most of the planking beyond the binding strakes was ripped up. 2094ps Fortunately, the planks came away mostly intact simply by slipping a thin blade beneath one end and sliding it along. Frustrating, but it had to be done, and it’s back into the fray today. B.E. 08/01/22
  11. Thanks for looking in Tom, and for your kind appreciation. These two kits do make attractive little models. B.E.
  12. Sorry to confuse, The cut of the recess of the crutches should be angled slightly inboard so that the boom rests in them when moved across from the central line of the mast. B.E
  13. Great start to the deck planking. 👍 I can't quite tell from the photos did you check the angles for the boom crutches atop the counter timbers? B.E
  14. The Rudder coat is a tricky thing to make and not a particularly pretty thing as it does need an element of bagginess to allow movement of the rudder. I make mine using fine cotton sheet cut to shape and stuffed with cotton wool to provide the bagginess. Details of the making and fitting process are shown in my Cutter Alert build log, I will follow the same procedure for the Sphinx build. ps. I like your Snatch block enhancement Ron, and the Capping rail is spot on. 👍 B.E.
  15. Thank you Theo and Ron. 👍 Post Fifty-nine Planking begins. The centre line coamings are at last glued into place and the gratings are temporarily replaced by the fret cut-outs to prevent stuff falling down the hatches. 2028 2029 Always worth keeping these pieces which also make good templates. One final check, the Quarter deck sub deck is tried in place to confirm that the Capstan link between the two decks aligns, along with the Mizzen Mast, I don’t want any nasty surprises down the line. 2019 2023 The hatched areas are part of the reduction in planking area, but until the deck beams are in place this can’t be progressed. As we all know there is no need for butt shifts between the hatches etc; the shorter plank lengths preclude such requirements. My primary planking strips will be of 3.4mm and 4.5mm. I trialled different approaches to the initial planking layout; a plank along the middle line of the deck, or planks each side of the middle line. I settled on planks either side of the middle line. 2066 2064 The kit plan butt joints and shifts are marked on the false deck, but in practice there will almost certainly be variations as planking progresses. 2067 These are a combination of 3.4mm and 4.5mm wide planks to give the best result between the hatches. The binding strakes will have tabs to meet the coamings and avoid the otherwise narrow planking strips. 2053 2048 2052(2) Work will now continue on the planking. B.E. 04/01/22
  16. She looks very nice Andy, and I like the blue ground to the Topsides . Good to see you progressing the build. B.E.
  17. Nice one Glenn, rest assured I will be coaming thro’ all my options to resolve the issue. @ Derek – there’s a great British tradition of blaming it on the dog, and I’m sure Hector is simply lulling you into a false sense of security, dogs are great at playing the long game. Cheers, B.E.
  18. Post Fifty-eight Back to gratings. The replacement gratings (separate sets of 1.1mm square holes) have arrived (thanks Chris) so I return to creating gratings with a ‘round’. Somewhat disappointed as these sets have a subtly different look to the kit provided ones, not quite as fine, and they are less accepting of messing with than the originals. Chris did tell me that the gratings are made using the same timber and process but that The Sphinx ones were specifically made for the kit, as with much of his stuff. 1997(2) The ones in the frame are originals the others the after market grating squares. So far I am happy with the originals for the Fore Hatch, and the two sections for the Main Hatch. 1995(2) My meddling with the Aft Hatch resulted in an acceptable result as above, being destroyed when I decided to split it into two sections. The replacement had to be made using the newly arrived gratings. Even there I destroyed one square cutting the grating the wrong way; those who know will know that the longitudinal strips run fore/ aft on a grating. With careful cutting I eventually managed to create the size and round, but I’m back to square one as far as having two sections. 2004 The difference in look is clearly apparent here between the Fore Hatch (original) and the Aft Hatch (aftermarket) 2014 I am unable to split the aft hatch into two sections due to the hole spacing. 2013(2) The one saving grace is that if I have to use the Aft hatch as is, it is below the Qtr deck, but then there will be very little planking on the Qtr deck. Not sure my eye will accept the difference. I may have to approach Chris cap in hand, to sell me replacement kit specific gratings for the Sphinx, or live with the consequences. 5095 A last resort may be to plead with Chris that the Dog ate my gratings. (he does have form) Anyway, Happy New Year to everyone from me and my shipyard liability assistant. B.E. 01/01/22
  19. That's a great shot of your 'Swan', looks as if it should be on a book cover, I'd buy it. B.E.
  20. Those gratings over the scuttles made no sense to me, they are shown solid and flush on Victory and are depicted as such by David Antscherl in his ffm Swan books. They are designated Top rope scuttles to give access when raising the Topmasts, but otherwise not used. The same issue re-appears on my current Sphinx build, which will be given the same treatment. B.E.
  21. Good progress Ron, Those rudder pendants were also used to steer the ship were the wheel or steering lines lost or damaged. The pendant was usually secured in the Mizzen channels, and if required tackles were attached to help steer the ship. I used thin Evergreen styrene strip for the stern Capping rails on my Pegasus build. It easily follows the curves of the Tafferal, and as it was to be painted the material type wasn’t critical. As your Camilla is to be sea-set do you intend to fit a Rudder coat? That’s a big hole for a following sea to enter.🤔 B.E.
  22. Looks nicely done to my eye Paul, your planking looks excellent. 👍 B.E.
  23. Thank you Ron, a very generous comment, I think we both enjoy 'tweaking ' kits to hopefully add interest to our builds. B.E. Post Fifty-seven Great Cabin The parquet flooring is glued into place, it is reduced in size due to the cabin modifications, and w-o-p was applied before fitting. I did experiment with various wood dyes on the offcuts to see if the pattern could be enhanced, but none were successful. 1986 Still not convinced whether I like it or not, but there’s always the fallback use of the b/w chequer. I rather thought that a degree of panelling was appropriate to the Great Cabin but at this scale and with the available views, I considered a printed version would suffice. 1990 I used the simple expediency of printing off the kit panelling and scaling it to fit with a little bit of tweaking here and there. Thinking about deck planking. The Upper deck will be planked using 0.6mm x various widths of Boxwood strip, mostly 3.4mm and 4.5mm. Wider strips will be used to work around the hatches. The first task will be to plank between the centre line fittings. 1995 I have the idea of using a photo copy of the kit deck plan to mark the butt joints on the false deck as a guide to work to. This will save me the job of working out a schematic and an appropriate butt shift. The kit arrangement is a four butt shift which looks fine to my eye. 1982 The overlay will also be used to mark and cut those awkward fittings cut-outs, particularly around the Mainmast. Here’s a mock up of how things will look. 1974(2) 1975(2) Before all this happens I need to invert the hull for the last time to apply one more coat of w-o-p and complete the fettlin’ of the finishing pieces of the Quarter Galleries. B.E 29/12/21
  24. Thank you, Bob, Kirby, and Jean-Paul. I think the black coamings will be enhanced once the Boxwood deck planking is down, while I wait for the new gratings to arrive I am looking at panelling for the Great cabin. B.E.
