Thank you Dave, Syren do a 1.4mm and 1.6mm ø line, and I see that Ropes of scale do a cable laid line in 1.3. 1.45, and 1.6mm diameters. I often find that the calculated line size doesn’t sit quite right with my eye on the model, so I always let my eye be the final arbiter, and I tweak the size to suit. I usually buy a couple of sizes around the indicated size, and pick the one I like best. B.E.
Just knew you would say that Bug, 👍 what else should I expect from a guy who knits his own netting. 😉 B.E.
- 419 replies
- Victory Models
- Pegasus
I don't think so Alan, circumference meant circumference, and line dimensions were always given in inches circumference. We model makers tend to work in mm diameter or fractions of inches diameter in relation to model line as that is how it is supplied. All we need to remember when using contemporary records is to divide the given circumference by 3.142 before doing the scale calculation. B.E.
Nice looking bees Moon, and I admire your persistence and result with the rope netting for the waist rails.👍 On the question of the Bowsprit cap did you allow for the Jack staff, I can't quite tell from the pics? B.E.
- 419 replies
- Victory Models
- Pegasus
Thank you Ron, what you see is only a temporary building board. I favour displaying the model on keel blocks which will be fitted within the case that I already have for her, but that’s a while away. Regards, B.E.
- 855 replies
- Sphinx
- Vanguard Models
That is quite some project Chris, and looks so good even in macro. Must require a lot of concentration working on such fine parts, very nice work. B.E.
Post One Hundred and Six Foc’sle deck cont’d. 6396 6403 The sub- deck is glued into position. The first consideration is the Margin plank, Sphinx has a tight turn at the bow which makes fitting more difficult. There are two options, cut it out of suitable sheet stock or edge bend it using heat. Edge bending 6mm wide x 0.6mm strip is an almost impossible option, even with repeat soakings, bendings, and the application of a hot iron, the result is not pretty. Where is a piece of 0.6mm Boxwood sheet when you need one to cut the margins, not in my workshop. An order is submitted and the item delivered in 24hrs, great service from Original Marquetry. 6399 When I ordered this ‘sheet’ I hadn’t quite realised how long it was, I was primarily concerned with width and depth. 6400 Still, I now have more than enough to satisfy any future needs. 6405(2) A template for the margins is taken from the sub deck and glued to the Boxwood sheet. 6407 This is thin enough to cut with a scalpel; needs tidying up and adjusting for the inner bulwarks yet to be fitted. The plan is to fit the inner bulwark patterns directly on the engraved deck pattern, now my sub -deck, fit the margins to them. and add the thinner inner patterns atop the margins. B.E. 07/04/22
- 855 replies
- Sphinx
- Vanguard Models
On my Pegasus build I secured the trunnions thro the brass barrels before blackening. I use a spot of ca. Once blackened any ca overspill is clearly shown. This was scraped off and the blackening process repeated until satisfactory. I also used a spot of ca to secure the monograms and vent, again clean up was required using a fine point scalpel blade before re- blackening. If you’re using brush applied varnish a light touch is required to avoid marking the blackening. I have never glued the barrels to the quoins, why would you. With Pegasus and the guns fully rigged I pinned the guns to the deck, the most secure approach. This is easier if the carriages can be temporarily positioned before the barrels are fitted, and the pin holes pre-drilled. This is the arrangement I used. With my current build the guns are simply secured using pva, but the built- in capping squares which means the barrels have to be fitted during the carriage assembly, makes the pinning approach more difficult. B.E.
Post One Hundred and Five. Foc’sle deck cont’d A representation of the Cat Tail (beam) is attended to next. Part of this will be visible thro’ the unplanked deck so needs to be in place. Because of the design of the kit I can only display the aft end of the tail as it fixes beneath the deck beam forward of the Bowsprit stop. 6374 The forward end is abruptly terminated against the kit bulkhead beneath the extra beam I fitted at the very forward end. The Cathead position is marked on the bulwark and it is suggested that this be enlarged by filing out to suit once all the decking and inner bulwark patterns are fitted, and the Cathead inserted thro’ from the outside. This seems to be an awkward approach to the job, I cut a slot in the outer bulwark to facilitate a trial fit. 6392 I need to ensure that the Cathead aligns with the Cat Tail. 6388 The ‘false’ deck is temporarily pinned into place with a deck piece to facilitate alignment and fitting. 6387 Not fully adjusted at this stage but the stive looks pretty steep. A small adjustment to the cross beams of the Bitts; I filled in the belay pin holes. 6380 There is evidence that such items were not in use at least in the early years of ships of this era, and many contemporary models do not show them. 6373 The Foc’sle steam grating/ Flue assembly is modified to reflect its fixture to the deck beam/carlings, and is given a slight round-up to the head ledges/gratings. The provided veneer deck pattern deck piece is modified to suit my arrangement, and will be planked over using Boxwood strip. 6371 I have already fitted the breast beam decking strip with slots to take the rails and Belfry which will sit directly on the carlings. Before I glue this in place I will check out how the planking strips actually relate to the pattern. B.E. 04/04/22
- 855 replies
- Sphinx
- Vanguard Models
Post One Hundred and Four. Fore deck considerations. Before I can do anything further with the Foc’sle the four guns have to be put into place. 6292 A production line approach is taken for painting and assembly, a repetitive job, but I do like those resin guns. 6342(2) The last thing to fit are the Quoins, the handles are represented by a pva blob. 6349(2) Once cleaned, coated with spray matt varnish, and weathering powder applied, they do look the part and I doubt I would return to brass versions. 6350 I will have to go with the kit set-up in relation to beams, but I added an additional beam against the existing bulkhead at the bow. This will provide a ledge to fix the Cat beam against its underside, and further mask the solid bulkhead. With the guns glued into place the deck beams are added. 6353 6354 I’m not sure why the two half beams either side of the mast extend beyond the carlings, perhaps it is just to provide additional support for the deck around the Foremast. I adjusted beams 460T to be flush with the inner edges of the carlings and prepared mast partners to fit in the space. 6362 A card template is used to form the partners. Once again Chuck’s ‘Winnie’ build has given me a lead, this time for planking the Fore deck. 6365 Tweaked to suit Sphinx I think I can make it work. 6367 6368 Additional planking will be required at the bow, but otherwise I will leave the deck un-planked. The next tricky little job is to work out the Cat beam position but for that I need to assemble the Catheads. B.E. 02/04/22
- 855 replies
- Sphinx
- Vanguard Models
Post One Hundred and three. Fettlin’ the Foc’sle Beams. 6271 With a fresh set of sanding sticks prepared I am ready to get stuck into the char removal from the deck beams. Fortunately the last major exercise of this type. 6273 The beams are quite delicate and it’s worth repeating that it’s best to support them in a vice for sanding to eliminate the risk of snapping at the mortises. In trying to more authentically represent the deck beams of the Foc’sle I am faced with a trickier situation than with the Quarterdeck. 6274 The two carling parts (459) are not an authentic fitting. Together with the foremost and aftermost deck beams ’S’ and ‘Z’ they form a box structure to support the deck beams, with the consequence that the fitting of deck ledges is inhibited. This is not a criticism of the kit which was not designed for this level of detailing, but it means that the deck planking will need to extend beyond this point. I have decided to fit the Galley doors; the decision had to be made before the aft deck beam was fitted. Having painted the remaining beams they are trialled for fit to make sure that no nasty surprises are lurking. 6280 6284 6285 6286 It all slots together very cleanly. I have a lot of things to think about in relation to the Foc’sle. Fitting of hanging knees in conjunction with the beams, there are sufficient kit provided parts to do this. I like the look of the exposed beams and fancy leaving it more open than the Qtr deck. It will need planking along the bulwarks inboard to the outer carlings and on the solid bulkhead section at the bow. Other than that I am inclined to leave it completely un-planked but I will fit the coamings and gratings above the galley stove. There is the tricky question of the Cat beam running beneath the deck beams and the connection to the Cathead, it is not clear in my mind how to approach this yet. Still for the next week I will be enjoying the magnificent scenery of the Menai Straits. 5032 There has barely been a day over the past few months that I haven’t worked on Sphinx and I’m not sure I won’t get withdrawal symptoms, but Anglesey has its compensations, not least the wonderful photo opportunities. Cheers, B.E. 25/03/22
- 855 replies
- Sphinx
- Vanguard Models
Well done Tim, she's a fine looking 'Swan', you've every right to feel proud of your achievement. B.E.
- 164 replies
- fly
- Victory Models
(and 4 more)
Thanks for looking in Gary, there is a lot of evidence for the ‘solid’ galley doors either in isolation or as part of a Foc’sle Bulkhead. The Adm plan for Sphinx does appear to show this feature. It is an interesting idea that canvas screen may have been used instead, but many contemporary models show solid doors. These were not fixed but held in place by cants across the deck in much the same way as the bulkheads across the Great cabin. I can imagine the use of canvas screens within in the foc’sle, it was a popular spot for a temporary sick room, and the Hanging cabins are recognised as a feature on the lower decks, altho’ I never been motivated to model them. Regards, B.E.
- 855 replies
- Sphinx
- Vanguard Models
Post One Hundred and Two Bitts and pieces. 6261 This is a convenient point to fit the Main Ladderway, but the stanchions I will leave until later. 6263 I’m glad I took the trouble to shape and paint the support columns on the lower deck. A significant feature of the fore part of the Upper deck are the Riding Bitts. 6245 There are two sets of these; the aft Bitts which have a substantial cross piece, and the fore Bitts which sit beneath the Foc’sle deck either side of the Fore Mast. 6244 Shoe-horned between the aft Riding Bitts and the stove is the Galley door frame and doors. There is no doubt that these were a feature of ships of this period, but the position seems awkward and on a practical level one wonders why they are there. I suppose that when closed they do provide an element of weather protection, but little else to my 21st century eye. From a modelling display aspect the more immediate question is how much fitting this feature will further hide the pretty little stove a good few hours spent in the making of. The only way is to trial fit it. 6255(2) The view of the Stove end is not unduly obstructed. 6256 6258 … but the doors do impinge on the Riding Bitts. I’m not sure at this point if I will keep the doors but If I do I will varnish them rather than paint them red. The Marshall painting does show them fitted and painted red, but I think there is already an excess of red paint in that area. The Bowsprit step is also now glued into place. The step and the support legs of the Topsail sheet bitts are one unit in my build as the manger boards butt against the unit at the Upper deck level. 6265 I made the Manger boards back in posts 79/80, they now have to be put into position before the Foc’sle deck beams are fitted. 6268 6270 I can now move onto prepping the Foc’sle deck beams. B.E. 23/03/22
- 855 replies
- Sphinx
- Vanguard Models
Thank you Bug, and Allan. @ Allan – In his book The Arming and Fitting of English ships of War, Brian Lavery includes a sectional drawing of a 1775 stove and conveniently gives the dimensions for each rate of ship from 14 – 100 guns. The dimensions for a 64 are given as 5’ 9½”(B) x 5’ 9”(L), and for a 20 gun 4’ 1”(B) x 4’ 0”(L) The Sphinx model Stove scales to 4’ 2”(B) x 4’ 10” (L) These measurements are for the carcase only. The inference of the table is that the stove was of the same style but scaled to fit the vessel size. Out of curiosity I looked at the scale drawings of the stove in the AotS Pandora. This scales to 4’ 5” (B) x 5’ 2” (L) The corresponding size in the Lavery table for a 24 is 4’ 2” (B) x 4’ 0½” (L) Make of this what you will, but the stove looks right on the Sphinx model and all importantly fits between the standards of the Riding Bitts. Regards, B.E.
- 855 replies
- Sphinx
- Vanguard Models
Thank you Christian and Thomas, and for all the 'likes'. Post One hundred and One A few more thoughts on the Galley stove. Sphinx would certainly have had an iron stove, but one that pre-dated the introduction of the Brodie Stove. Up to the time of standardisation following the introduction of the Brodie stove I understand there were several manufacturers of iron stoves, all broadly similar. What we have in the kit is a sort of Hybrid, having some features common to the Brodie, the chain drive being the most noticeable. I was puzzled by the two holes in the back panel of the Sphinx stove, so I scoured thro’ all my reference books on the subject. The closest I could find is the stove used on the Dorsetshire of 1757. The Arming & fitting of English Ships of War - Brian Lavery. The position of the ‘Crocks’ (I think it should read Cocks) is close to the position indicated on the Sphinx stove. I decided to add the cocks to give a little more interest to the aft end rather than just two holes. 6238 6239 6240 I think that’s enough for a stove of this scale given the views that will be available even for the more open aspect of my build. Time to move on. B.E. 21/03/22
- 855 replies
- Sphinx
- Vanguard Models
Post One Hundred The ships stove I have been relishing making up this little beauty and decided to do it at this point as I will soon be moving onto the Foc’sle. 6186(2) The basic carcase is of Pearwood and it slots together perfectly, taking barely any time at all to assemble. Most of the carcase is encased with brass etched panels which I have chemically blackened, but I can see potential problems in avoiding marring the finish during the fitting process using ca. There are also separate Brass fittings which may prove an easier option for chemical blackening. Either way if it fails, the blackening will provide a key for painting. As always the treatment of brass etch starts with a thoro’ cleaning, washing, a rub with fine wire wool, acid bath, neutralising fluid, an acetone dip and onto the blackening agent. 6182 Initially the recesses that form the rivets stubbornly refused to blacken, but a clearing with a micro drill eventually cured the issue. The top of the stove is unplated apart from the lids and the Flue. 6193(3) These areas were painted black before applying the plate, and were treated with a weathering powder. The blackened plate is then glued into place using a smear of ca. 6197(2) The brass etch Flue is a fold and meet assembly and I took the precaution to silver solder the join before blackening. The Chain Pulley The blurb indicates that 1mm rod be used to connect the pulley wheels and chain pulley but I think this is incorrect. The holes in the spit support crane would need drilling out to take a 1mm rod, as would the small pulley and chain wheels, a far more tricky task. 6199 The provided 0.8mm rod fits perfectly, and you won’t risk distorting the delicate drive chain. The 0.8mm rod also looks better for scale. The completed stove. 6206 I don’t know what the two holes are for in the back plate. I did wonder if the plate is the wrong way up and they were intended to be the drain cocks for the boiler, but even that wouldn’t look right. One omission that I think could be provided with the kit are the fire grating bars that sit across the open front of the stove behind the spit support cranes. The supports for these are perfect for the brass etch treatment. However, the Stove is already finely detailed much of which won’t ultimately be seen in the standard build of the kit. 6215(2) Even so I decided to add the fire grate bars knocked up from some 0.6mm wire and bits of etch left over from earlier builds. 6220 The grate bars in place with the spit drip tray that I also decided to add. 6221 The connector for the still was added to the aft top plate. 6227 The assembly in place onboard. 6226 The stove certainly looks the part sitting on the deck. 6232 There are a couple of other minor enhancements that I could make to the stove, lifting ring bolts, and a rail along the top, but for the present my enthusiasm is expended. B.E. 20/03/22
- 855 replies
- Sphinx
- Vanguard Models
Nicely cleaned up deck beams Glenn. 👍 B.E.
- 476 replies
- sphinx
- vanguard models
Post Ninety-nine Quarterdeck planking completed From the outset of this build my intention was to show as much of the Upper deck detail as is practical and with the completion of the minimal Quarterdeck planking, bar the fettlin' I think I have achieved this. 6176(2) 6173 I have followed the line of the False deck that I had cut away which means that the two inner strakes of necessity have to be fayed into the inner plank. 6180 Altho’ not entirely authentic, this is a cut-away and I like the impression of curvature that the effect gives. This would also have applied with full planks but with a much reduced opening over the Great Cabin. 6172 The alternatives would be to step the two inner planks, more authentic, but perhaps not so pleasing on the eye, or remove them altogether. I will ponder on that awhile, I suppose it goes against the grain in terms of deck planking to bring anything to a point. In the meantime I have to make up a few more guns, and take a look at the Foc’sle. B.E. 18/03/22
- 855 replies
- Sphinx
- Vanguard Models
Post Ninety-eight Quarter-deck planking continued. The completed ladderway/coaming set is glued to the false deck prior to planking. 6158 I start to planking down the centre line and for the shaped planks around the ladderway/gratings a pattern is made using 18mm Tamiya tape. 6160(2) The shaped deck plank. 6163 It took a couple of goes to get a pattern to correctly fit on the model. 6165 The completed centre line planking, but without any fettlin’. It will need scraping and a coat of flat varnish. 6170 6171 The coamings require re- painting, got a little marred during planking, but I think the ‘round-up’ modification gives a more authentic look. 6168 I now need to figure out the planking along the margins. B.E. 17/03/22
- 855 replies
- Sphinx
- Vanguard Models
A sweet build James, very nicely done, love the finish you've achieved on the Windlass. B.E.
- 29 replies
- well smack
- Vanguard Models
For continuity of planking material as used on the Upper deck, it is far too flimsy to stand alone. Cheers, B.E.
- 855 replies
- Sphinx
- Vanguard Models
