Posts posted by steamschooner
I thought I would show my method of making some handwheels for my project. I start by making some rings of 28 ga brass wire. OD of ring is the size needed for the handwheel I need. I had some P.E. handwheels from a watertight door set. I than drill a center hole for the wheel shaft. The rings and P.E. hw were tinned on one side. I used a jig to center both parts tinned sides facing each other. They were than soldered together in the jig. Once removed from jig they were trimmed up and cleaned up.Only needed a few of difference sizes. Ah the joys of sratchbuilding Steve
More outstanding metal work to inspire the rest of us. Great job Valeriy!
Steve
- Valeriy V, Mirabell61, Canute and 4 others
- 7
Eric, West Coast steamschooners used painted canvas as a deck covering. Many ships did I believe. Tar paper covered decks I would think would be a mess on hot days as the tar melts and is tracked all over the place. Course it may have been a different type of tar paper than we use today.
Just my 2 cents worth.
Steve
Thanks Nils, Happy to get some shipyard time in. Your recent build turned out real nice
Steve
- Mirabell61, Keith Black, Canute and 1 other
- 3
- 1
Wow, It's been a few months since I have posted anything. Well now that winter is here I can spend some time in the shipyard. Have spent some time making rigging for the boom. With no measurement drawings it is difficult to determine sizes. Using a number of photos isn't as helpful as one might think. But that is the nature of scatch building. So here are a few photos of what I have been doing. I like to leave pivot pins long so I have a way of removing them until final assembly.
Couple days ago I bought a small box with ship modeling wood and a few hulls. In the bottom of the box was a mixture of parts and tools. Well I didn't think 5 bucks was a bad deal. Included were some clamp like items. I do not know if they are for model building or not. I have never seen this type before. Any idea's ?
- bruce d, thibaultron, Ryland Craze and 2 others
- 5
Bob my Zipper build came from one of the Ideal Series books. I also will buy them when I find them.
- Bob Cleek, mtaylor and thibaultron
- 3
coming along very nice. Nils
- FriedClams, Mirabell61, Canute and 2 others
- 5
Gary, The derrick winch is 1 inch wide and 1&5/8's from gypsie drum to gypsie drum. It's a little over 1 inch tall. Levers, drums, gears are turned ( several times on some items). Styrene, brass, copper and aluminum are being used to make parts. Considering I did not have a lines drawing and I had a couple of limited photos. It has been a real bugger but I think I have the rest figured out.
I did not realize you had posted a reply so I am catching up.
Thanks everyone for stopping by to take a look.
Well it's about time I posted something to show the shipyard is still open. I have not had alot of time to spend working on my project. The following pictures are of the derrick winch that I have been working on. It is not finished yet as you can see in the second picture. All I have for a design is two very poor line drawings and three photos that only show some of the winch. still have much to do
- Keith Black, mtaylor, Ras Ambrioso and 9 others
- 10
- 2
Look'n real good, the number of fasteners gives it that special look.
- Greg Davis, Keith Black and mtaylor
- 2
- 1
If you go to the Alamy site and search N.N. floating steam winch it should bring up the pg I posted.
Steve
- Keith Black, Valeriy V and mtaylor
- 2
- 1
- Keith Black, mtaylor and Valeriy V
- 3
Thanks everyone for the likes and comments.
Motor whale boat started out as a shapeways printed boat but was a early version. It had a hinged rudder on the stern. The whale boat I needed was a later version where the stern has been filled out to a more rounded shape and had a canopy.
I built the canopy with glue soaked paper on a canopy shaped plug
- KeithAug, GrandpaPhil, FriedClams and 9 others
- 12
Ok, a little update on my project. I am getting closer to being able to fasten cabin to the deck. A few hoses to drape, couple of fittings to add.
Tring to get as much done on cabin while not on model.
- mtaylor, Canute, MAGIC's Craig and 12 others
- 15
I do not know if this was bought up or not on this site. So I will post this just in case it is useful for others.
I recently bought acrylic rod for making running lights, mast lights and who knows what else. My purchase was for 1/4" rod in red, green, and clear I than added amber, yellow, and solid black. With 1/4" rod you get 6 pieces that are 36" long for $11.50. They have rod up to 1" and you get fewer 36" pieces, cost goes up a little. I bought them from Delvies Plastics on esty site.
I now have several lifetimes of material for making running/mast lights.
- BobG, Keith Black, mtaylor and 1 other
- 4
SS Blagoev ex-Songa 1921 by Valeriy V - scale 1:100 - Soviet Union
Wheelhouse looks great I really like the color of the wood. Did you have to use your big match for decking strips?
Looking great Valeriy
