Moonbug
Everything posted by Moonbug
  1. I used quite a bit of extra wood on this kit. Because it seemed a little flimsy out of the box, I decided it would be to my benefit to overbuild it a little bit then put in some extra work on the sanding shaping end. In particular the planking strips were thinner than I would have liked. I cut out additional false deck solid pieces out of .5 mm plywood. I then planked these decks with aftermarket strips of wood. Not 100% sure what kind of wood this ended up being, I want to say basswood. It actually ended up being a little softer than I would have liked - so had I to do it again I would use walnut of the like. I stained the deck with a softer color. My treenails are made from sewing pins chopped and sanded. Once again, a lesson learned I would probably do a "drill and fill" method if I were to do it again. For the main hull, I once again cut out an additional false deck and measured and drew in exactly where my deck strips would go. This helped tremendously and allowed me to cut and place the deck planks efficiently and relatively quickly. This is a broken piece of the bulkheads and the head of the ship and it needed to be repaired after the bulkheads and deck were placed. After drawing in the main deck planking, I mounted the deck. This is where the false deck really came in handy - I was able to hold it in place and shape it exactly how I sanded all the bulwarks. The thicker strips I used for the deck allowed me to shape easily and gave me extra sanding room. I then stained my main deck a light oak stain.
  2. Hello all. In the interest of current Swift and Virginia Pilot boat type builds being conducted currently, I've decided to recreate my build log of the AL Swift kit that was lost in the great crash of MSW 1.0. Hopefully it'll help some of the folks along with their own builds. I'll do my best to provide the information I can based on memory, but in all fairness this may end up just being a bunch of photos. ;p~ To the moderators - hope this is ok since I already have some completed photos of the Swift in the gallery. Obviously if I'm stepping on some of the rules please let me know and act accordingly. :-) Here are the initial shots of the kit. Although this was a very enjoyable kit to build, I found that unlike my San Juan Nepomuceno this kit had quite a few warped and messed up parts. I had to straighten out the keel quite a bit. First I soaked and weighted the keel and bulkheads. Then I inserted balsa wood blocks at the front and rear and lined up all the bulwarks by inserted dowels that were cut to match the exact distance between each bulkhead. I measured that distance dead center at the keel to ensure accuracy.
  3. Nice work, much improved. That's going to pay big dividends when you start planking the hull! - Bug
  4. Hey Shawn, I edited with the pictures, did they come through?
  5. Hey Shawn, I totally believe how twisted it was before! When I got my Santa Maria kit, the bulwarks were so warped they had split in two. Back to the swift - my recommendation would be to try and get out as much of the warping as possible before you try and mount the deck. I think the extra work will pay off. Here are a couple of pictures of how I got some of the warp out of the front of my build. I used some extra dowels cut to the exact length of the keel and spread them out to the bulwarks. - Bug
  6. Impressive work. What did you use to age / patina the hinges? -Bug
  7. Shawn, Adding the blocks close to the keel helps a lot. It does add a bit more sanding and evening out if course. I also used balsa for mine to ease the process. You can usually pick up blocks of it pretty cheaply at most mainstream craft or hobby stores. -Bug
  8. Always good seeing another Swift! I straightened my Swift keel by soaking, then filling in blocks between the bulwarks. Have fun with the build! -Bug
  9. Doing a little bit of work and watching the NFL Playoffs. I'm a pretty crazy 49ers fan, so I'll be setting the SM aside when that came comes on... Like anything else with the Santa Maria there seems to be a variety of speculation regarding pinrails, cleats and the like. I've had to scan the rigging over and over to try and figure out where these fixtures would have been. I've also been trying to speculate whether or not the belaying pins are more traditional looking (as they are with more modern ships) or whether they may have been more primitive in nature like some of the cleats appear to be. So, like the rest of the model I've looked at many of the builds and references that are our there and then pressed on with what I think works best while maintaining a credible level of accuracy. I used a 4mm x 4mm piece of walnut and bevelled the top edges. I've stayed away from much ornamentation on this build because I truly believe the Santa Maria had very little. However, I wanted to include a little bit of craftsmanship that I think every vessel would have likely had. So, I used one of my mini pin-files (which sounds redundant) to notch out the top of the posts. I used a 1mm thick 5mm wide piece of walnut and sanded it at a curve for the rail portion of the piece. I then notched out both the posts and rail to give them a nice tight fit. After staining the entire thing in "Kona" colored stain (to match the weathering I've done on the rest of the ship) I put them all together with the belaying pins. Although it's not clearly seen here, I mounted the entire piece in the same method that I've done railings and stanchions - which is to drill and mount pins in the bottom of the posts, drill corresponding holes in the deck, then mount the piece with a touch of CVA glue. It's always a challenge come rigging time to get these pieces to hold well once the running rigging is attached and pulled tight.
  10. Sjors, I had to be quite careful on the second planking for my AL version of the Swift, as the second layer was at most a half mm thick and very coarse and brittle. I don't think I used anything more coarse than 400 grit paper the entire second layer so it wouldn't wear thin. - Bug
  11. Good idea with the sheaves. I've been procrastinating mine to determine exactly how I want to tackle them. - Bug
  12. Love it! I really like the tiny sandpaper method. Did you break any before you got a few done? Great work. -Bug
  13. Sjors, Are those little support legs at the keel your invention? -Bug
  14. Yikes! And yes, for a landlocked state CO is well represented. I'm a return visitor from before the MSW 1.0 crash and a 20 year Air Force guy trying to blend with sea fairing folk . ;-) Sorry we hijacked your thread Augie! -Bug
  15. My advice with sanding is - patience patience patience. :-) And don't give in to the temptation if using rougher sandpaper to go faster. The second layer is so thin that you really need to make sure you have what you want with the first layer because you won't be able to sand the second layer very much. When I think I'm done sanding, that's when I sand a little bit more with 600 or 1000. :-) - Bug
  16. I've been looking at some of the dollhouse porch lamps to see if I can bash or fashion something for my Santa Maria's aft. We shall see. - Bug
  17. Thanks Augie and Lawrence! Augie, I went back to look at the Syren. Hadn't seen it since the crash, and hadn't seen the ME case and cabinet. Pretty sweet. - Bug
  18. Gil, Always enjoy your builds. But I just wanted to tell you I appreciate your comments on 16 Dec (post #328) regarding why we build the ships and whom our limited audience is. Cheers. - Bug
  19. Augie - I can't even count the number of times my lovely wife has come out to my little shop, looked at me in my jeweler's specks pin filing something 6mm long and used the exact phrase "There's something wrong with you." LoL -Bug
