Posts posted by SawdustDave
Beautiful job Ryland.....top notch clean.
Dave
Thanks Russ / Mark.... Really pleased with the bamboo in every way.
Did another experiment with regard to applying a stain to it after sanding. After testing a small section off ship, I found that it takes a stain beautifully. Seen in the last photo above, the bamboo planks were stained with Golden Oak, then a single coat of wipe on poly.
After tree nailing, I plan to apply another coat of stain which should make the tree nails pop. The poly coat will block the stain from the plank surface.
The bulwarks are planked with walnut to match the bulkheads.
Productive weekend....
First pic is for Popeye.....the re-shaping of the transom issue is resolved.
Next pic is a collogue of steps showing the method I used to create the short stansions seen in the mid-ship upper deck port.
This was necessary because I opted to plank the inward bulwarks, which is a another slight deviation from Chuck's plan sheets.
Finally, I was pleased to see the bamboo planking looking as nice on the side of the hull as it did on the stern area.
Tomorrow morning, I will tree nail the area seen here just to see how that is going to look.
- edmay, pete48, popeye the sailor and 8 others
11
Oh yes! She looks like a rocket ship. Are you super excited right now Pete?
Dave
Welcome to the forum sir. Very nice work on a beautiful ship. Thanks for sharing.
Dave
Also note that, as I began to develop an eye for using this material, you can see that the area above the gun ports is more consistent in terms of color and grain. I was able to be more selective in culling out a few of the visibly darker planks. I found, to my surprise, that 90% of the planks! thus far! seem to be very good shade matches.
Also....
Easy to see that I was able to correct numerous errors I had made in the layout of the stern.....tiller port was moved up almost an inch; gun ports moved up; corrected the transom plank pattern; and a few other alignment issues.
Simple fact is.....this whole thing was pretty much a complete train wreck and I was going to re-work it any way regardless of the bamboo experimentation.
Thanks Augie; Pops....
Mark....large 16" x 16" tray at Walmart....$15.00
Can't say enough about how sweet this stuff cuts. As for the possible issue with sanding as pointed out by Steve....no problem. The flat surface above the windows was my test case for that....sanded the heck out of that area just to see if it would be a problem....same beautiful grain. The four knees separating the window units were easily shaped and looks great even with exposed end grain surfaces.
I guess there is no end to the many different paint patterns found on Mayflower models huh, Klaus. That is not a criticism mate, I really like the looks of the one you are using....just haven't seen that one before.
Beautiful job on her rudder.
Dave
Whether the term was "Store High" or "Ship High" (In Transit).... I question whether this story of that being the original source of the crude word, we so often use, actually holds true.
Dave
Just looking at all the battle scars on you cutting table....Holy Cow! Sign of a real veteran.
Thanks for your input Steve....very interesting information regarding your experience with bamboo.
Hopefully, the amount of sanding required in this application and with this particular species of bamboo will not be an issue.
We will soon have answers to these questions as I am about to head back to the shop to begin putting the first planks in place.
Cheers mate.
Dave
Russ....so far, I am finding this stuff cuts so clean, really sharp hole drilling, easily shaped.....and nice color. Still playing with it.....will post more as it develops.
In past, the only application I have used bamboo has been for tree nails....never considered the beauty of the grain until finding these tray products.
Now surprised at how nice it cuts.
Dave
So here's the large bamboo tray I found.... 16" x 16" square. There's another 16" width counting the four side rails.
Another interesting discovery....after ripping the two surfaces on the table saw, I get some really neat scrap pieces which, after studying them for use, I determined they are a perfect thickness for deadeyes. Played around with making a jig to cut them into perfect triangles with a little holding jig....then drilling holes and a little bit of finish shaping. I think I am going to like them better than the results I've been getting from the walnut. Got to play with this some more before I decide.
So, the stern has now been sanded back down to a point I can begin applying the bamboo planks. Also did some re-shaping of the transom because Popey's sharp eyes pointed out a little cervature problem (thanks mate).....
- popeye the sailor, pete48, mtaylor and 3 others
6
Popeye.....Just returned from Walmart to purchase another of these bamboo trays....bad news - there was not another one to be found.
GREAT news, however, I found a.much larger tray of the exact same material....good to go!
Yes, the surface is completely sealed with a very fine finish.
As for the shape of the transom.....camera's really tell the tale huh.
Thanks for pointing that out....we can fix that whilst re-working the other. And for the record.....please do not hesitate to critique my work. In fact, I need all that I can get. Seems like I am more prone to mistakes as I am returning to the shop than I was just a few years ago. Takes a while to regain the required disciplines of measure / re- measure; check and double-check each detail.....But enjoying it more now than ever.
Hearing from friends like you really makes my day.
Cheers
Dave
Ed....Is this about the time "Store High In Transit" came into use?
Turning back to MF#2 this morning....
While browsing Walmart several days ago, I ran across this amazingly beautiful bamboo serving board....completely struck by the beauty of the grain, I could not help but invision it as the hull of a ship. So this morning, I experimented with ripping the outer surfaces from two edges and creating planks. I think I love it! The edges are so clean, and the bending quality could not be any better.
So, since the stern is the only hull surface I have used walnut planking thus far, I have decided to simply re-plank the stern with these bamboo planks. In fact, I was going to have to re-do that job any how after discovering (as usual) that I had made an obvious error in the original planking with regard to the location of the gun ports.
Update on both Mayflower builds....
MF#1 - 1:76 scale.... Finished tying all rat lines....installed preventor stay riggs for all masts. Installed bow sprit and rigged the fore top mast preverter stay. Looks like we are finally ready to add some yards and begin some serious rigging.
As for MF#2 - 1:60 scale.... Completed first planking of the hull. Will begin working on keel and beak assembly tomorrow. I have been spending most of my time on MF#1 the last several days. Plan to move over to MF#2 for a few days and develop the hull and bulwarks above the decks.... possibly begin outer skin planking of her hull.
Mark....happens to the best. As for me (not even close to being among the best) re-doing my mistakes seems to have become a way of life lately.
"That which does not kill us makes us stronger".....Friedrich Nietzsche....Must have been a very good modeler.
Dave
- Jack Panzeca, pete48, dgbot and 2 others
5
Thanks for clearing that up for me Ed....Makes perfect sense.
And thanks for the conversion chart.
Carry on Mate.
HMS VICTORY by Kevin - FINISHED - Caldercraft - 1/72
Hi Kevin....Just now joining your Vic build.....my favorite, having built her twice. I go to bed each night looking at her in her glass case beside my bed.
You are doing a beautiful job, and I have enjoyed browsing through your build log. Very nice photography as well.
Dave
