MEDDO
Everything posted by MEDDO
  1. That framing looks really nice. I am sorry if you said before but what are you using to cut all those mortise out with? Are you getting those incredibly tight joints with a chisel/file/blade or are you one of the power people with a fancy mill?
  2. This looks like a great start. The hull and coppering look very clean and gun deck is coming along nicely
  3. It really is helpful to have others build logs to reference. The new tag system makes finding them much easier than before. I especially used the great log by @JpR62. Also the middle of @Chuck 45 page thread was very nice here
  4. I know @kurtvd19 had made one of those "cut outside the blade" jigs and showed it at one of the recent NRG conferences. Seemed like it would work well.
  5. Those look really nice I can’t wait to see how they work out
  6. Many of us have built on dining room tables and it sounds like you have a good plan going forward. Looking forward to the build
  7. Welcome aboard! You can search for your ship with the search function to see if anyone else has built this before. If you start. A build log for yourself You can show off your work ask questions etc.
  8. Thank you Derek. You certainly should pick up one of these “most excellent” kits. You will to regret it
  9. I also had this problem. One of my first attempts basically glued the flag to a paint brush handle and as I was trying to free it it ripped. With more experience I was able to shape them without it getting too sticky.
  10. First thing I would do is to practice a few times with some tissue and some scrap poles. You don't even have to print the pattern for the practice runs. A few attempts and they really started to look better. I used regular tissue paper that the wife had for wrapping presents. I cut a piece out and then just used scotch tape to tape all the edges to a piece of regular printer paper. I then printed the design with a normal ink jet printer. After cutting it out (11 blade scalpel) I used some thread to attach it to a pole. I used Krylon matte fixative in the big spray can. My first few attempts ended up using too much and apparently was doing it in too high humidity. Too much spray resulted in a whitish frosting on the tissue when it dried. It also wetted it so much that it became very fragile and tore. I did do it in my office/workshop (very smelly not recommended) as it was in the 90's today with really high humidity. After spraying both sides lightly I gently shaped it with my fingers as well as the roundish tips of a pair of hemostats and the end of a round paint brush. The spray has about 10-15 minute wet time so there was plenty of time to shape it. I was able to spray again if it did not dry in a nice enough shape. After a few tries I then proceeded to make the final ones which I think came out pretty well. Here is a picture of the white frosting on the practice runs
  11. Thanks Jean-Paul My thoughts exactly Maybe soon although the wife really likes the Echo cross section
  12. Do it!!! After this kit I am giving the big ol side eye to the other kits in my stash. They simply cannot compete
  13. Getting there. Need to decide on final mounting. Still leaving the rudder off until finished with the carvings. Carvings are still being practiced. I do want to try one with a rotary tool as so far have only been using the 11 blade scalpel and carving knife. These are the first flags I attached to the poles. I had an epic fail when trying to shape them. Turns out you can use too much of a good thing (krylon fixative). So after printing out a few more on some tissue paper I was able to practice enough and get 2 to come out looking fairly decent. Now just on to the carvings... Deo Volente
  14. Welcome Chris! Plenty of people here to help you out if you have any questions. A build log is a great way to show what your re working on and to connect to the community.
  15. I was surprised how much I started to use this once I had one.
  16. Dios mio! Cant complain about the amount of carving I have to do after seeing those ones. Marvelous!
  17. Another reason to not model while tired. I put this post here so maybe will help someone else not be like me.... While putting the sweeps together I ran into this problem as you can see the square part has notches in the end for the handle and the shaft. I wasn't quite paying attention and when putting them together last night ended up with a few like the one pictured at the top. The one in the middle is correct. I didn't even realize this until I came down today and saw something funny on a couple of them. Obviously the plans have them right (another reason to always go back to the plans). The notches are not the same size. Here are a few more close ups Haha had to take them apart and use some of my precious precious isopropyl. Them came apart easily and 'correctly' glued together. Always learning...
