Everything posted by clearway
Welcome back Hake- somewhere in my log somewhere are details of the jib boom and dolphin striker- unfortunately i didn't realise til too late she needed the flying jib boom but it will be included in my Erebus- be careful as the design of the bees battens changed and would have been altered to the 1840s pattern when they rebuilt her bulwarks and altered the position/angle of the bowsprit. Ahhh takes me back to the fun we two keiths had 😁 Keith
I blackened my studlink brass chain for my terror build using "birchwood casey brass black" but it took a few goes - if you look at the pic Jorez added on bottom of page three you can see the conrods leading to the drive shaft from the cylinders. Keith
It was certainly that Keith and i was really glad of the Band of Keiths during the dark days of the lockdowns! Back in the now and suddenly summer has returned so its full steam ahead felting my mother in laws shed😁 Managed over previous couple of evenings to plank the bows diagonally downwards like the reinforcing planking on Erebus and Terror's bows (didn't see point of wasting walnut planking under the metal bow plating). Yet once more i am so glad i managed to correct the run of the bilges on Erebus. Take care all, and thanks as always for the likes and comments Keith
it certainly does explain the steam pipe you are talking about- if you google steam anchor windlass you will get plenty of pics - normally a couple of horizontal cylinders aft of the drum with a couple of con rods leading to a gear shaft driving a large central gear wheel- to be honest though the windlass is so far under the anchor deck (forward of the WC and lamp store) it most likely wont be missed by anyone looking at the finished kit. Keith
she is looking great Greg- i run a line of thread from the top to where the chainplates are going to determine the angle of the relevant chainplate (if that makes sense). Been distracted from my Pourquois by HMS Erebus! Keith
- 123 replies
- Le Pourquoi-Pas
- Constructo
The dark nights are really starting to close in now - twilight by 8.30pm now and still need to re-felt my mother in laws garden shed and fit the woodburning stove in my new outdoor messy jobs workshop (hopefully get some decent weather before winter sets in)! Back with Erebus and i have marked and scribed some extra detail on the keel at the base of the sternpost (not 100%accurate but close enough). Also started on the walnut 2nd planking from the bumpers up- on my Terror it took 4 planks, on Erebus there are 6- its interesting seeing how the 4mm x 1mm stock left over from the terror build has oxidised to a lighter shade. on the bows below the bumper i will most likely add slightly diagonal planking below where the iron sheathing will be like on my Terror build Take care all Keith
also in the pic is a insulated steam pipe so i think it is below the ritz in the old crews quarters regards railings it will be best to redo the aftermost ones as it will niggle at your sub conscience (been there)! Keith
Little more progress with the inside of the bulwarks planked- also looking at the admiralty plans the entry way and gunports should be more square so sanded about 1.5mm of the top of the bulwarks. Also looking at the plans the forward opening or gunport in the bows should have a door or lid closing it- looking at the opening midships the draughtsman included any items seen through it but not the one near the bows. Also any holes from heightening the bulwarks have been filled with scraps of wood along with half of the rearmost gunport. Openings will need planking filed back and tidied up. Take care all Keith
this is from the plans for Polaris showing the skylight, galley, pantry and staircase to below decks I suspect some of the crew shots might be from below decks as there are wooden pillars supp0rting the deck beams above which you cant see in the original photo of the ritz? Also in colder weather/ winter the Ritz was abandoned till the spring. Keith
looking good- i split the railings into sections with the ends of the rod hidden in the ball stanchions- something i missed from my Polaris plans is the railings angle inboard slightly aft of the bridge wing to make room for the ships boats. Keith
Well done- the base really sets her off Keith
- 45 replies
- Earnslaw
- Paper Shipwright
Thanks for the likes and looking in, I have sanded the forepeak a little shorter along with shaping the rudder/ sternpost and gluing it in place. The other thing i am doing on Erebus i didn't with Terror is painting the shroud protector white instead of just varnishing- i will still be cladding the rest of the hull with varnished walnut strip though. i feel the altered forepeak captures the look of Erebus better now. Keith
They also had cleats incorporated into blocks as well just to confuse matters even more! On the main mast apart from the tackle to use the boom and the halliards for the sail the braces for the foreyards would lead there- if you look carefully there are also pinrails on the shrouds just above the deadeyes. I have Harold Underhill's "rigging the clipper ship and deep sea carrier" as a source of reference but havn't delved too deeply into yet. Keith
Thanks for looking in- i now have the keel pieces and altered forepeak glued in place- as already mentioned i trimmed it back below the gammoning hole to look more like the admiralty plans while altering the angle slightly to align with the altered bowsprit (also had to take a little off the scarph joints). Sorry about the grainy finish but artificial light and my phone don't mix- OMG this means the long bright summer evenings are getting darker! take care all. Keith
