clearway
Everything posted by clearway
  1. Thanks for the link Craig, anyways there is an Azimuth compass going on the post 😁. As regards the bridge will stick with the plans and add iron supports either side of the centreline made from brass rod blackened and most likely on the bridge wings leading to the outer bulwarks or capping rail. Keith
  2. as a guide for the plating i used the kit supplied veneer and ran it diagonally downwards towards the bows (there is a pic somewhere early in the logs) which as you needed to shape them to fit the bows it gave a guide for trimming the plates but start at the top and you will get a feel of the run Keith
  3. No problem Keith we all been there😜. if you look at photos of shackletons endurance the bridge was between the main and foremast while the wheel was still at the stern, They set up 3 or four foot long pointer on a post which was basically telling the helmsman which way to steer to avoid the growlers and bergs. Back with terror and i have now got Azimuth compass mark 2. Take care all Keith
  4. That is why i think the navigator on the bridge will get his bearing on the Azimuth and when the helmsman is on course the navigator will shout "mark" and he can use that bearing as a guide with the azimuth being consulted on a regular basis. Found this online regards Polar steering:- 3321. Magnetic Compass The magnetic compass directive force depends upon the horizontal intensity of the magnetic field of the earth. As the magnetic poles are approached, the opposing force on the compass card becomes progressively weaker until at some point the magnetic compass becomes useless as a direction-measuring device. In a marginal area it is good practice to keep the magnetic compass under almost constant scrutiny, as it will be somewhat erratic in dependability and its errors may change rapidly. Frequent compass checks by celestial observation or any other method available are wise precautions. A log of compass comparisons and observations is useful in predicting future reliability. Keith
  5. Thanks Craig, i have heard they would set the azimuth using a celestial body / geographical feature and keep her true using that bearing. Keith
  6. Don't forget Keith the Azimuth compass on the post came into play when they got towards the pole and normal compasses were as much use as a chocolate fireguard! So the azimuth would be used to set the course with the navigator correcting the helmsman till he was steering true. As for the "normal" compasses i think one like what keith S and i were talking about a year or so ago would have been mounted either on a binnacle in front of the helmsman or more likely on top of the skylight. Craig i think you could be on the right lines as on the Owen drawings there is no obvious sign of it sticking that far out. Keith
  7. Hi Richard , hows it going with the plating? I was thinking regards the hull colour you could go with Keith S idea and use ebony stain for the black which when varnished will give a nice finish? Keith
  8. thanks for the likes and comments everyone. Now i have the compass post in place i thought i would try making an impression of the Azimuth steering compass (best i can do in 1/75) measures 4mm square and still need to sort a lid and a stand. Also trial fitted the bridge on the lowered supports.... to carry on my original dilemma before we sorted the compass post i still cant decide whether to go with the full width bridge off the plans or shorten it slightly (as we now know some unrecorded changes were made on the final refit)? psssst Keith notice i now have camber on the skid beam 😁. Take care all Keith
  9. Yey we both have it at last Keith! Jeez nearly two years we were waiting m8.... woooosh! Keith
  10. Ahh ice bumper joy! But yes Hake - i wondered the same thing myself but it is needed (think i was sneezing sawdust for a month after final shaping)! Keith
  11. To be honest Hake you dont have to go as in depth as Keith S and myself to create a better model, even just reorganising the fife rails around the foremast, moving the massey pump supports and replacing the mizzen mast fife rail with a spider band + of course adding the deck houses will bring her into a league of her own. Whichever way you steer as always just ask us fellow Terrorites😁. Keith
  12. Thanks again guys, couple of shots showing the new navigating table/post and lower skid beams (when viewed from astern and compared tothe stern elevation in Matthews book the old height mistake stood out like a sore thumb)! Take care everyone, and if you have a bank holiday today enjoy. Keith
  13. Coming along Daniel, yep can get a bit daunting when you see exactly how many fittings are on a yard (at least the topgallant doesnt have any battens in the middle and less blocks)! If following Keith S and myself with the azimuth compass post through the table and the confounded bridge i would get the base for the post sorted but still leave the bridge supports off once made to ease access to the mainmast pin rails (main reason you see the funnel and capstan missing from when i was rigging there). Keith
  14. Coming along nicely Phil..... feel myself twitching at thoughts of making bridges😁. Keith
  15. Thanks for likes, comments/ hints /tips / suggestions, measurements everyone, have re made the table and re used the old legs, while in redux mode i removed the port side stern deckhouse so i could panel the doors to match the starboard side (was thinking should i remove the forward facing door and move it to beside the other door but thought na i like it)! While doing that i tackled another job that needed remedial work which is the skid beams were around 5 mm too high, so removed the posts and skid beams and moved the knees to their new height.... i was going to move the post back but thought best not as i super glued the brackets in and will probably rip the capping rail off😱 (sometimes best not to push your luck). In the pic you will see the new table beside the old table top for comparison. Take care all Keith
  16. I can vouch Keith it is repaired as i was on the 10.58 train from Carlisle (diesel unit though unfortunately) which crossed it before pulling into the station, it is still single track though (in fact every time i go to the steam railway at Keighley {actually pronounced Keithlee} you have to go over it😁.... bloody fantastic)! Keith
  17. yeah, problem with Cutty Sark is she was altered in one way or another with rig changed and deck house alterations etc. Back to terror and i am thinking that navigation table is too big on the model so will salvage my carved walnut legs and rebuild it slightly smaller. Today i had a day off work so took my son down to Ribblehead to see the Yorkshire three peaks and the magnificent hand built Victorian viaduct (been over it loads of times but never got off at the station to have a look from below.. till today😁). the pics really dont do it justice! 20220826_125715[1].mp4 Take care all Keith
  18. Yeah Craig.... Keith S and myself have been saying for two years if only they had panned this way or that way! some of the Juicy detail we need is soooooooooooo close (hey Keith have you organised a dive down to the engine room yet)! It was interesting in my last update when reading the stuff about Cutty Sarks compasses in the link about compasses from Keith B how her Azimuth compass was also between the skid beams. was not 100% about the post but in the end i got my (wait for it).........bearings! Keith
  19. OK chaps i am taking the plunge...................😱 introducing footing for the infamous column and as an encore we have a square hole in the table (had to move it forward because some idiot put the skid beam too far forward🤪. Also trialed the rope handrail, and yes i know there should be a gap tween the column and the bridge☺️ Thank you Craig (AKA Keith) for the invaluable input ,....... now to figure out a brass or wooden stand for the azimuth compass! also while reading about the binnacles on the link supplied by Keith B i noticed this about the cutty sark " The Tea Clipper, Cutty Sark, built in 1870, was an iron-framed and iron-clad ship. This is now a museum ship located in Greenwich, UK. According to the original specifications of the Cutty Sark, there were 3 compasses on board as well as spares: Compasses: Three binnacles to be found, viz. Steering Binnacle and Compass, Standard in front of Poop with Board of Trade Compass, Azimuth on Skids between Boats, one suspended Cabin Compass, two spare cards, two spare Agates and two spare pivots to each compass with deviation card to be found, and two spare brass compasses all to be properly adjusted by swinging the vessel Take care all Keith
  20. Hey up a lot of posts about posts during my shuteye😁. When you get your book Keith (and well done getting out of the airport) there is a drawing of an 1845 royal navy binnacle/ compass. Not sure if you seen the post a couple of days ago regarding the wavertree which had a compass forward and both sides of the wheel - don't forget the helmsman would have been standing on the starboard side with the wheel off to his left side so the compass and binnacle in the book would look o.k. beside the skylight- but once they reached the arctic the "normal" steering compasses would have been removed and stored and navigation would have used the azzimuth steering compass (which is why i think the drawing shows the post only and the azzimuth compass would have been on a binnacle on top of that so the navigator could get his heading and keep an eye on the needle). The idea of having to climb on the table every time you wanted a bearing/ course plotted seems like hard work. Also when/ if the bridge was dismantled they could ship the post and still mount the compass on the table?... oh and guys don't forget the average height in 1845 was around 5'6" or there abouts maybe even a couple of inches shorter! Keith
  21. your not the only one Keith B! still swinging between the azimuth compass on the table or the pillar? Craigs argument does make sense, but so does Matthew Betts. I am now wondering if the pillar was actually two, one for the port and one for starboard steering compasses which could be observed from the bridge hence why on posts? The other thing on my mind is that is a long unsupported 12" pillar (except for the table). Will stick with the bridge but might revert back to my original idea and place the azimuth compass on the navigation table which was my inkling from day one?!?! This ship is going to drive Keith S and myself completely nuts😵 Keith
  22. that is about the size of the one i was depicting in its box, now thinking hmmmm lets have the lid open and a bit of detail added! As it stands i have not fastened the post in place or cut a hole in my table yet😁 as i cannot 100% make my mind up!!!!!!! Keith
  23. Have also seen them look like this, problem with deciding on the compass is our victorian friends invented/ improved designs at a very impressive pace. Keith
