Everything posted by Jack12477
Glenn, absolutely magnificent workmanship. I love the interior shutters around the windows. Nice detail. I am in awe!
Very nice model, Tony. Well done ! And thanks for the excellent build log to reference. Great job all around.
- 269 replies
- Caldercraft
- First build
(and 3 more)
Nice, Keith. I like that dark wood contrast on the trim.
- 34 replies
- steamer
- sternwheeler
Airbrush
Jack12477 replied to Mike Dowling's topic in Painting, finishing and weathering products and techniques
Mike you might want to pick up a copy of this FineScale Modeler magazine how to book Airbrushing for Scale Modelers It has some pretty good "how to" on airbrushing. I subscribed to this magazine for years and found it had a lot of good information for modelers, even tho the magazine is skewed toward plastic model kits, a lot of the techniques apply to wood ships as well. I agree with Kurt, practice on pieces of scrap wood from the kit itself. -
Mobbsie, love the sail and mast. Looks great. Interesting way of bending the sail to the yard/mast - I have not seen it done that way before. Your boat is coming along nicely. I like the wood colors - nice combinations.
- 129 replies
- armed launch
- panart
Joining the peanut gallery also, Keith. Looks like a fun build
- 34 replies
- steamer
- sternwheeler
Denis (Popeye), Gerty, thanks for stopping by and your compliments. Gerty, I've been using your excellent model as a reference to help me decipher these cluttered plans. The shipyard will be a little slow the next couple of weeks as we have our youngest granddaughter visiting us for a few weeks. Lots of side trips planned.
- 250 replies
- willie l bennett
- model shipways
While browsing the digital edition of the Rochester NY Democrat and Chronicle newspaper this morning, I came across this very interesting article about the USS Rochester and one of our MSW members, Tim Igoe, and his model of the USS Rochester. I thought I would share it with the group. Congratulations Tim.
Rob, if you have some basic wood carving knifes or gouges or even some small [miniature] block planes (similar to the Veritas micro planes from Lee Valley or even the small ebony wood miniature planes) you can start shaving the clunker blocks down. Start as Thistle points out at the bow and work towards the stern. Set the plane to remove the smallest chip you can. Work slowly. You can also use a Dremel with one of their drum sander attachments - start at a low RPM speed and increase as you get comfortable. Start at the outer edge and work it inward, rough shaping as you go. If you aren't comfortable, take a scrap block of wood the same dimension and practice off model till you get the feel for it. Work slowly and take small increments of wood off. I didn't have to deal with the clunkers on mine because silly me forgot to read the booklet instructions and planked the entire hull bottom - had to finesse the bow a bit when I realized my mistake but it all came out okay. I use this Lee Valley block plane as well as this one (item A in the picture) Hope this helps.
- 45 replies
- model shipways
- willie l bennett
Marcus, welcome aboard and thanks for the compliment. Mark, Ken, Carl, thanks for the compliments.
- 250 replies
- willie l bennett
- model shipways
WOW, nice work on the sleeping platforms, Frank. I'm with Patrick's comment on milling the mortises - very impressive.
- 649 replies
- dunbrody
- famine ship
Best Paint Brush?
Jack12477 replied to mikiek's topic in Painting, finishing and weathering products and techniques
My son is an artist (Fine Art painter) and modeler and hobbyist as well. His recommendation is Grumbacher brand white nylon synthetic brushes seem to work best when applying acrylic coats to any wood, hold up the best, will have an even and consistent spread to them. He would go with a filbert cut; for large hull areas, use a #6, #8, #10 or #12 brush. When cleaning you can use soap and water, just water, or saddle soap/brush cleaner. The white nylons last the longest. Keep in mind when using water based paints, depending on the consistency of water to paint ratio, your first coat over a wood surface will suck right in. He prefers to use multiple thin layers of paint, but if you want a bolder, thicker coat use less water. My son has been using these brushes on multiple surfaces ranging from wood, latex, hard plastic polymers, vinyl, and porcelain on hobby projects for years with excellent results. As Bob Cleek points out above "synthetic bristles for water-based paint and natural bristles for oil-based paint". For oil base paints my son prefers Camel hair brushes; they last longer, shed the least of the non-synthetic hair brushes. Any other questions, feel free to post here and I will pass it along to him. Update: Here's a photo of the Saddle Soap my son uses to clean his brushes. -
Thanks, Ken. More work on the railings - now have the entire railing done. After marking and drilling the holes for the nails in both the railing and the ship's sheer. I insert the nails in the holes first, then place a 1/16" x 1/32" tube over each nail, then place a tiny drop of thin CA where the nail protrudes thru the tube. This keeps the tube from slipping off and winding up on the floor as I turn the rail over to align it with the pre-drilled holes. Then using a tweezer to align the nails with the hold, and using finger pressure I press them into the holes. To completely seat them into the deck I use a small hobby hammer (smaller and lighter than a standard tack hammer) to drive the nails all the way into the wood. Then another drop of thin CA to lock them in place. Then finished rails
- 250 replies
- willie l bennett
- model shipways
Rob, nice job on the sides. They came out a lot better than mine - I had to use filler to get them to mate completely at the transom. You've got a nice smooth curve to yours.
- 45 replies
- model shipways
- willie l bennett
Rob, thanks for the compliment and for looking in - also thanks to all those who hit the LIKE button Carl, I'm going to leave them as is - tried pounding them down further but they won't go in any further and I'm afraid I will break more than the railing if I hit them with anything heavier. The rail material is pretty thin and I'm afraid grinding the heads off will damage the rails.
- 250 replies
- willie l bennett
- model shipways
Another small update ( summer gets in the way of progress ) Got the forward railings installed on both sides. Used the 1/16" x 3/32" brass tubes I had cut earlier, drilled holes in the rails at 1/2" intervals, pushed the bras nails (which are magnetic by the way ) thru the rails, inserted the tubes over the nails, then pre-drilled holes into the sheer and with a little persuasion from my hobby hammer drove the nails home. After that I gave each nail a drop of thin CA using a cut-off sewing needle eye as the applicator. Of course the rails were pre-painted green to match the wales and cabin roofs. Also installed the pulley to raise and lower the "dagger board" in the keel. Photos follow: Nails and stanchion tubes for the rails: Rails installed Pulley for raising/lowering "dagger board" (aka center board - my Sailfish sailing lingo is coming out)
- 250 replies
- willie l bennett
- model shipways
Model Expo 1/2 money back if built in a year??
Jack12477 replied to WEHarlow's topic in Wood ship model kits
It is definitely an "in-store" credit - friend of mine did the same thing a few years back and it's a credit for another kit. They do honor the credit. -
Sean, nice work. Sorry about the hand; looks like you suffered the same fracture, same hand, my son (40) had about 2 months back, except he had to have surgery to fix his (4th and 5th metatarsal/metacarpal bones - ring and pinky fingers). I can sympathize with you. Oh and he was cold sober when he did it.
- 2,191 replies
- confederacy
- Model Shipways
Bob, great looking case and base. Thanks for the tutorial.
- 277 replies
- model shipways
- 18th century longboat
Rob, the cutting jig came from MicroMark see here. It works well. MicroMark is a good tool source, fast delivery to Northeast areas. The tubing fits in a V groove, the larger silver tube is where the slider moves in and out to set the cut length (see photos 2 <set for 3/32 cut> and 3 <set for longer cut> the material to be cut sits in the V groove, extends to the stop block <block with set screw on side>, the saw fits in a tiny saw slot visible in photo 3. The unsecured end (left side in photos) has to be held down with finger(s) or some other clamp. You can screw the jig to a larger surface as shown in the first photo (uses #6 screws). The cut off end just drops onto the work surface or in this case into the V groove because the stop block prevents it from falling out <hence the tweezers in photo> Another good miter box is this one along with the razor blade saw I get a lot of use out of both jigs/miter box. The razor blade saw is great. Check out MicroMark's online catalog. Also check out my post in the "What have you received today" forum for some additional tools. Also SRC's post a couple above mine.
- 250 replies
- willie l bennett
- model shipways
