Jack12477
Everything posted by Jack12477
  1. It's been a few weeks, but progress has been slow. Working on cutting the tiny 1/16" diameter x 3/32" long brass tubes for the cap rail posts. Had to dig around in the ole toy box till I found a suitable jig to use to cut repetitive lengths of pipe. 24 pieces cut so far, about a dozen more to go. The jewelers saw was the only saw small enough to fit in the slot and tough enough to cut the brass tubing.
  2. Happy birthday, Mark :pirate41: :pirate41: :pirate41: :pirate41: :pirate41:
  3. Panel doors constructed not simulated! - miniature brass door knobs! - Glen impressive and magnificent craftsmanship - Your stairs look great also - look like the real thing. An inspiration to all of us.
  4. Ran across this article in the Rochester NY Democrat and Chronicle newspaper today.
  5. Rob, My kit parts list is dated 10/20/2010 - so more recent than yours. I'm attaching a photo of my keelson template. It's been so long since I built the keel/keelson that I don't remember if there were problems. If you slide the keelson piece along the template until the curvature of the piece matches the drawing, what happens? Does it become too long? Too short ????? Try dry fitting the piece that make up the whole keelson on the template and see how they fit together, move them around until the align with the curve of the drawing and see what it looks like. Sorry I can't be more helpful but I tend to forget the problems especially over a long time lapse.
  6. Rob, I'm building the Willie also - started it several years back, put it back in box and up on shelf due to frustration over the drawings et al. Decided to pull it back of the shelf this year and begin again. But sorry, I don't recall how I got the keelson built altho I do know it was/is not quite "right" but don't remember any of the details. My build log link is in my signature below if you want to pop over and have a look at mine. I got as far as planking the bottom and installing the sides the first time before I "jumped ship" and went to another couple of models before returning to Willie. Mine had an addendum set of plane changes for the keel as I recall except my patterns are long gone now. Does yours have an insert sheet of changes ? Or was that for the build board? .
  7. Mobbsie, just catching up. WOW ! Beautiful workmanship. Love the contrasting wood colors on the hull and elsewhere.
  8. I should probably update my post a little - my very first wooden ship model, after years of plastic models, was a Midwest row boat, made a couple of them, before tackling the Dumas Coast Guard 47 ft Utility boat model, but for this one my local hobby store owner - an accomplished modeler in his own right - gave me almost one-on-one guidance (since I bought the kit from him), from that I moved on to the Artesania Latina kits always choosing one that was in the 18 - 24 inch range finished. All of this was way before there was even an Internet or an MSW. That's the advice I give to anyone who asks me how to start building wood boat kits. Of course, Midwest in no longer in the kit business but there are probably other manufacturers who built small boat kits for beginners similar to Midwest's selection of kits.
  9. Not sure I understand that response Chris. Are you a Corgi lover also ? Or ???
  10. I have to agree with Skip - I too have been building models for over 60 (with starts and stops) both plastic and wood - some Military Armor and some wooden ships. And I too am not as good as many of the modelers I see here but so what. I'm learning !
  11. Time for a small update: Finally got the small pusher boat completed. Ran into some problems keeping the side aligned even with the aid of the frame templates. The instructions were really vague and frustrating on what size lumber to use - had to do a lot of "translating" from the plans and to find the right pieces. Mostly I eye-balled it and used what "looked correct". Results are shown below in the photos.
  12. Welcome to the Skipjacket club, Rob. I too am struggling with this kit altho it is not my first kit. I started it some years back, got frustrated with the rather cluttered plans (blueprints), put it back in the box and onto the shelf for several years while I built a few more kits. Picked it back up this year. My build log is in my signature below. My memory is a little vague but I think I ran into the same issue you're having but can't remember how I solved unfortunately. There are several excellent build logs for the kit here on MSW which I have been using as reference. Use the MSW Search function and you will find the rest of them. Good luck with your build.
  13. I use the plastic covers that come on some canned goods (so the unused portions can be preserved in the fridge) - the PVA glue does not adhere to the plastic so after a while I just peel the built-up cured glue off and start over. CA doesn't peel off so easily - for that I use a piece of scrap card stock.
  14. Carl, I have a third-hand tool - but I didn't use it because I thought it would act as a heat sink - these parts are teeny tiny.
  15. Feathermerchant, welcome aboard ! The dredge A-frame is leaving me a bit intimidated at the moment, so I'm working on other parts while I figure that one out - also I think I flunked Soldering 101 - having trouble getting the little brass pieces to "sit still" while I attempt to solder them. Also the cluttered nature of the plans makes for slow going. I did finish the small push boats - photos to follow shortly
  16. Glenn, I haven't used pastels on wooden ships but I have used them extensively on wood Model RR structures and on plastic Armor models. You can get artist pastel chalk in any good art supply shop. The technique I used was to take the chalk stick and create chalk "dust" using a knife, micro-plane zester, anything. Then use a fine clean artist paint brush to dab it onto the wood. The other technique used to weather models was dry brushing with various paint shades. An artist fixative can be used to set the chalk "dust" in place. You can use a Q-tip to rub the chalk into the wood for an even deeper weathering effect. Stick to the earth tones, grays, and black chalks for the best weathering effects.
